- Update from yesterday's bouncing idle post...
- Cold start issue.
- a few questions...
- complete set of V8 tails?
- Memory lane.. found a bunch of old pix of the car over the past year.. bww
- 1990 audi 200 turbo for sale ...
- starter replacement
- Where? Oil temp sender.
- i need a mac-14
- Anyone near Boston got an MAF I could borrow for 10 minutes?
- Car bucking under wot??
- oh sh!t! i just remembered there was a n/t audi down at the junkyard..
- just browsin... found this.
- Is anyone "producing" a tube EM for the 10vt yet?
- progress update on my car....
- Any ideas why my idle will bounce from 1100 - 1300 continuously in a '90 200TQ?
- cold start valve
- Well I'm in trouble now... Ive been thinking about power again... Help?
- Please Help as I need some advice on purchasing a 200t
- 5000cstq TO THE RESCUE...
- well we installed the first test header this weekend
- Why wont my shifter shift?
- Voltage issues, Verification please
- Rear seat heaters aren't working. Im I missing something here or should I start testing>
- Took some shots of Superior today
- anyone around milwaukee have a spare NF/NG distributor?
- 1986 5k exhaust question...
- Anyone familiar with these CD's???
- Is something wrong with the Forum or with me?
- tie rods and front axle
- Still no start!! Please Help (again)
- 1989 Audi 200 Q EFI - For Sale
- Anyone on here know flyboysteve on here...Tried to contact several times...
- what is a good set of euro headlights worth?
- Checking auto trans, marks on ATF dipstick ??
- Powersteering pump 1990 100
- those of you with euros...good deal on osrams
- zener and resistor mod question
- Will have my black 1990 Audi 200 TQ for sale
- found expensive seller of chip for MC ;)
- intercooler out
- charcoal canister...
- Source for teensy VDO odometer gears?
- 5 speed transmission.
- Is this the way to the supermarket?
- Spark from coil wire, car not starting ??
- Happy birthday quattro!!!....
- Steering Flange & Column
- Checking Automatic Transmission Fluid
- Hi guys. I'm lurking here from the C5 A6 board. Does this look like a good deal - '89 200TQ?
- Got the beast running:) Black smoke from tail pipe ??
- 86 5000cd turbo 5 speed 250klms
- Who's going to Carlisle? Who's aready registered who is not on 85-4kq-girl's list?
- Looking....
- what is your opinion?
- clear side marker options?
- Temp Sensor Or Just Overheating? Other questions also..
- Oh boy, talk about a PITA
- What brands of batteries are you guys using ??
- Audi stereo
- 2 x 2 vag com cable
- Cheap engine, Ebay/Illinois
- Made a video of the Beast today
- Exhaust nuts / What are they?
- 89 100 s quattro n/t.... NF or NG?
- Now I know why I could not pull codes, the "check engine light" is not...
- check this out
- no heat on audi 5000cs
- what to do when leaving car sitting for extended periods?
- Deadline to register for our Buttonwillow Driving School is next WED March 2nd
- Those who asked for parts.. give me an Offer on what you needed.
- How to go over 2.0bar without blowing the ECU?
- Well, That was fun
- Steering flange problem, 1987 cd 100
- bouncing speedo
- As if there wasn't enough saliva dripping from my mouth looking at the first RS4... jeezus
- water pump replacement 200 T 1990
- A must visit: Audi's new "25 years of quattro" site...
- I set up a new gallery for my Audi pics.
- Maybe in the market for a 91 200 20vt, how reliable are they?
- 1991 200 20vt timing belt change interval
- CT/NY Audi Group "Spring" Gathering - Momentum Tuning, Wallingford, CT - 3/12/05
- Paging Fletch.......heard you called Randy and he saved you alot of money for parts on your Audi.
- 5ktq wheel bearings
- [SoCal] Don't forget to RSVP for the Angeles Crest Drive this Saturday, FEB 26th
- Anyone have a pic of a 20v turbo engine in the 200
- hey blackwolf you out there?
- Would fuel injectors or Fuel distributor cause temporary hesitation issues when accelerating while
- Pulling fault codes on MC2/MAC14 cars
- did you ever get your 5000 tq running? - Calling AudiQV8
- Need: '91 200 20v TQ rear drivers side caliper
- Paging 5kcstq, quick question regarding your Coupe swap...
- new noise
- A cool mods list
- well I did it... I got rid of my Audi and got a.......
- 17inch wheels
- Son of Quattrofest, PIR in Portland
- Goodbye baby!
- sunroof problem
- website adress....
- Ice Racing with the 5000CDQTurbo :-)
- no power to fuel pump 84 5000s
- V8 exhaust questions
- Anyone in the Portland OR/Vancouver WA Area? I need
- Body Kits??
- Any BTDT with shipping large or heavy parts?
- Bentley Book
- Gearbox oil capacity
- cheap new headlight on ebay
- Need suggestions for axle supplier, 1991 100
- Adive
- question about pressure testing for boost leaks
- 200 10v auto tranny
- Audi K26 vs 944t K26 searched the archives but I'll ask again
- exhaust leak NOT joint between halves, NOT broken or loose studs
- How to restore clearcoat? Can you have just the clearcoat resprayed.
- hello all...update on brakes.
- New to the world of Audi.. go easy :)
- Narrowing down tranny limp home mode
- ISV hose
- euro lights question - '91 200
- Fuse #12
- Audio Question
- 0-60 and 1/4 mile times for Audi vehicles (stock)
- Going to salvage yard today-- 87 5kcstq need something?
- V8 euros in 200 20v
- scratch removal
- OK just picked my 1991 20v avant this morning. Woohoo Few questions
- Where to get relays for euros?
- Guys,, what's the best way to pull the downtube off the turbo?
- Cutout problem. Anyone want to help? (long)
- Should I be able to blow through an ISV?
- Public Service Announcement: 91 200 chips and spring on ebay.. no affiliation.
- Tranny Q's: Elephantman727 and impalass96lt1 how'd yours go?
- my Ouchie is at it again
- Who's replaced their own clutch before?
- FrankenAudi turned the big 300,000 kms today... Happy birthday you monster ;-)
- stripped speedo gear
- any way to test MAF?
- Ac pulley not moving.....clutch or compressor?
- Will ECU latch a fault code from a bad or failing 02 sensor?
- Important question
- Finally...
- ultra repost to the max, video has been around a long time...
- Euro Lights... if anyone is interested..
- paging tonyj
- SoCal Reminder -- 2 events coming up this weekend
- High Boost on unchipped ECU cont...
- Anyone familar with BMW? (off-topic)
- Replacing Motor & Trans Mounts (very long)
- isv
- What kind of oil should go in the final drive and.....
- wish you could really get one of these-
- This is impressive :
- 2231 fault code. Anyone have any experience?
- Ok guys, Its Exhaust Question Time (those with aftermarket...)
- Who supplies a 10mm tee for oil pressure switch?
- where to tap power for boost guage.
- does anyone have this game for your Xbox?
- 100 Exhaust
- Boxerfan, i'm going with the extra injector too
- can i get money for my core?
- installed A/F meter, having an issue
- It has become apparent why the factory limits boost- anyone else plagued with leaky exhaust?
- 1990 V8Q 3.6 Piston Rings?
- stereo upgrade means good working bose speakers and delta cassete (non coded reman unit) up for grab
- Anyone looking to get rid of a working alternator for a 1990 200 quattro??
- seriously- is there a piezo in the seat belt circuit that could pick up sound if it's loud enough
- new sound coming from wheel
- i fixed my trunk wiring hinge but i still don't have any brake lights.
- cutout under acceleration
- 1.7 on the gauge... but not chipped?
- Lights
- 91 200 20V stutters/bogs down as you begin to hit gas. ONLY the Beginnng-worse when COLD
- I need a Auto trans again......
- Need help removing a rusty bolt on my other car
- Pics of the 5k
- <whimper> My brother is officially parting with his Olympic Edition...
- My dual banjo bolt is in...
- can someone w/ a bently manual for a 200 u/l a diagram of the 2 piece exhaust mani.
- Job Well Done
- got me curious (new oddity)
- I'm baack, check this out!
- tell me what you know about O2 sensors
- Service in Palm Springs Cal Area
- lazy spark
- Go figure...
- wanting to save money and wants to clean out the cat some how.
- why is that AW moderators delete a place that we recommend to save people $$$$.
- Mirror Swap?
- Ball Joint Press Out?
- head from 89 5000 s quattro n/t..? NF?
- wow high price for a 93V8
- The Audi Gods have decided it's my time again!! : (
- UPDATE: 2005 Viking Cup Classic Annual Ice Race & GTG - cancelled
- 86 5KCD TQ start issue.
- 1990 100 fwd
- New problem (fix one and another rears its ugly head!) Sluggish from 1K to 2K then...
- ABS troubleshoot while I have time with the car off the road...
- bad temp sensor?
- Stalling question - 85 5kS
- Hydraulic Fluid System.
- repair process beginning, Step 1: off to a bad start.
- My rad fan does not come on until this temp.
- How tight should I tighten the pinch connector on the control arm?
- Changed HVAC programmer, a couple of times this week..........
- 8.5 compression question
- dash lights begone after resoldering speedo leads and jumpering from digital clock lead to chassis
- no boost, at all.
- Ignition Upgrades (1990 V8)
- Avant antenna masts - do they unscrew
- Electrical Question (s)
- Problems begat problems. Hey is that biblical?
- Attack of the fogging windsheild
- Speedo from 91 200 turbo up for grabs.....
- Instrument cluster
- V8Q - Anyone make aftermarket exhausts for them? Any location for good used units?
- Need to Sell 1989 200TQ
- it was chillier day than yesterday and the heater (defrost) not working like yesterday.
- Got colder plugs! boost is back and back with attitude.
- How do i tell if my CV joint was the problem?
- need ecu help
- air vents
- An Update on my no spark problem:
- Everyone read the articles in the following link
- Koni GB Pricing
- found out my cat is making noises today..time to replace.
- 60 thru the esses
- Save your starter.....buy some Techron
- cleaning isv
- B5 guy here looking for V8 info. Curb weight?...
- ok the 2 hoses are connected to the heater core and no signs of being looped.
- Audi V8q, or will, or steve... or God, anyone who knows anything about spark?
- spark plugs
- now im f***ing pissed...
- My STILL NO SPARK issue
- Stupid NTB: "Uh, sir, your tie rod ends are rusted"
- Easy lower control arm removal
- Moving and need to off load some items fast...
- brake upgrade questions...
- This is an interesting car...
- YAY!!! Update:
- Bleeding ABS brakes
- Got axle out, do i need to do anything with the tranny? clean it out? anything?
- When did Castrol 10w/40 turn blue?
- tire question
- Paging Yawdi, did you get a chance to check on that trim yet?
- I sold my Audi...
- Axle turning??
