- Can anyone answer a few secondary coolant pump questions for me?
- My EFI conversion is almost DONE!!!
- who's car is this?!
- flickering digital readout (kinda long)
- buying a 5000?
- Brakes Hissing
- My car is getting close to 90k miles. Am i a bad person?!
- interior lighting question
- INTERCOOLER INLET DIAMETER
- What size 17 inch tires for my car?
- Does anybody have an experience with cardone remanufactured brake master cylinders?
- interesting set of 5x112 wheels on ebay! i would go for em if they fit right offset etc
- goin through some old pics, found a bunch of the ladies from last year and before...BWW-12 pix
- Anyone here upgraded their 5KTQ's rear brakes?
- ISV need cleaning? Harbor Freight to the rescue (again).
- '89 200 before/during/after pics!
- Different intercooler setup
- Drag Day - May 21st - Lebanon Valley Dragway (New England/NY), Sign Up Now...
- 200Q 10v stereo questions
- Speedo no working
- AP 13inch Brake Kit System - passing on a local deal i found
- Bypass Valve
- Where the hell does the ISV get the temperature signal?
- how many of your cars cruise control works?
- No pressure in A/C system...where to start?
- can anyone let me know were i can get an intake boot for an audi 5000 qt 1986
- Downshift at 90mph...
- Looking for a spare injector cooling duct
- Difficulty accessing 1st / 2nd gears - Up-date
- Magical 1.6
- can't decide how to spend my money...need your advice
- adam- darklightning's pictures are down! does john know, or did u know?
- Socket Driver, Metric, Double Hex size ?
- What's it worth?
- I need a test pilot...
- CC Programmer fix, does one exist??
- MN quattro club racing school - BIR
- does this sound like a bad bomb?!
- exhaust questions
- p/s pump question: Please Help.
- Does anyone know the a/r ratio of the k26 off a 5k turbo
- Throttle Switch Resoldering
- Anybody have a blow-off or compressor bypass valve on their T44??
- V8 A/C question
- She hummms but doesn't suck.
- Euro shipping source?
- Survey finds BMW drivers have more sex
- Dash issues.... continued....
- Anyone run a 5000 Turbo with no middle muffler?
- do 1993 s4 seats fit in an 87 5000cs yes/no?
- A/C compressor not coming on
- could I have the pArt # of the 70amp 200 radiator fan relay?
- Floor Mats! stupid question, but anyway!
- Where can I get parts for my European Headlights?
- got some parts to get rid of
- cool old school 5000.. but go through the stats on the site.. correct?!
- cool little toy...
- beginning to part 85 5k + rest of 88 5ktq ... anybody in need of anything?
- go here, then bottom of page!!
- '90 V8Q rear brakes help
- Anyone have any CV joints/axles hanging around?
- Anyone know what the latest is re: Megasquirt implementations on Type44Q's?
- how bad is it when an auto tranny "lurches" into reverse....
- Has anyone used the Flex-A-Lite 310 cooling fan?
- Its amazing what a freshly clean K&N filter will do to increase mileage.
- New to the board... had car search questions.
- And so it begins...
- General consensus on BPV port locations...
- 200 20 Valve Engine Swap
- Overheating... I guess???
- BMW vs Audi comparison.....
- Convert to R134 ??
- Ideas for a 200 Avant?
- 86 5K TQ turbo hose
- Normal Mileage on a 84 5000S?
- Heeellllp..... 5000RPM and Climbing
- Read a ton of old posts, but a couple of AC questions >>
- where is the afterrun thermoswitch located on 5000 turbos?
- transmission blocked
- oil pressure question
- got a pair of A-6 headlights,now to...
- Why does Audi use Loctite on axle splines?
- How do I tell if my WOT switch is no bueno?
- Has anybody "shaded / smoked" their headlights??
- Finally got around to taking some pix of my rig...
- 175 PSI compression test...too high? 89' 200QT
- 89 200 dash/ ignition question
- Weird changes with dash swap...
- Do new 3.6l or 4.2l engines still exist?
- Some boost gauge pictures and other misc. pictures
- Whooo! Found another one! White knuckling it..
- hmmm very interesting.. another treser creation
- Here you go boys and girls! A little need for speed...
- Can a valve cover gasket leak slightly all the way around? (85 5000, not the s4)
- Flat Towing (4 wheels down): 200/ 20V/5 Speed?
- How hard do you guys suppose it would be to swap the euros + relay harness on my 200 20v with the US
- i cant post...
- audi_v8_parts_specialist is a crook and thief
- I have a set of Yokohama AVS intermediates 215/60/15... you want them? I'll trade for 2 cases...
- 195/65 front - 205/60 rear
- 2004 Northeast Audi Summer Event Info/Registration/Forums/Site is up!
- electrical problems - large current draw?
- Canadian ppl here or BC resident?
- will an 82 coupe 5 speed tranny fit an early 84 5k ?
- Well... here we go again... updated news on pearl 91 200TQ for sale... turbo is working... bad hose
- Ahh... the V8 tail lights... Thanks Tom, they look great.
- Question: The V8 has bigger fender flares OR is the bumper fatter?!
- slow day at Jaguar....pondering about better lights on my 5ktq
- what kind of hp can i get out of a 89 100 non turbo
- anyone heard from radim in a while? should be getting close to that beast running......
- 5ktq wanted
- has anyone here converted their 90 coupe quattro lights to B5 A4 lights...ive seen it
- V-belts for 2.3L NF
- Heater won't stop
- Getting a Tornado Red 20VT!
- lookey what i woke up to this morning.......
- Poll - Who thinks we should start calling Andrew R. either Ward or Beaver Cleaver?
- Anyone have an after-run relay for sale?
- here is pictures of my TO bearing from two years ago, never posted cuz i was too pissed
- corner lights
- Audi 5000 3 spd auto transmission
- Andrew! stop buying cars and fix up the other 4 that dont work! =P
- trouble in my V8 paradise
- Auto Trans
- I can't believe it!! I think my steering rack is shot after just one year.
- What a little bit of "elbow grease" will get you...BWW
- And for tonight's story..."When T/O Bearings go Bad"...
- cat heaving in my glove box
- Odometer
- 5000TQ inoperative speedometer cause?
- Is this clutch the same? MC-2
- Tranny time
- To you electronics / Modification gurus...
- 87 5000 S intermittant power surge at idle
- Fuel Injector - What are these little tips at the ends?
- junkyard tourism
- The easiest way to pull the engine/tranny?
- yet another battery/alternator ques
- Is anyone using an EGT guage on there '44?
- Nice V8 paint job on eBay . . .
- major power loss at highway speeds
- V8 personalized plates
- Coming up on 90k miles ..... timing belt change.
- Is there agreement on who makes the best/quietest water pump?
- water pump -- need help
- also anyone know how well the axles hold up under 260 hp on the 86 qt models and also the tranny
- question about going with a bigger oil cooler . is it better
- Hall sender
- Ofeelya...Re : steering rack
- My friend is getting rid of his Audi 5000 turbo. Anyone in Northern NJ wants dibs?
- Now that the interior is clean the exterior is next
- O2 Sensor - Only 2-wires connected?
- Noticable gains with a single pass fmic?
- Adam: Your BOV....
- Converting CIS to EFI on 5kt
- What kind of stuts/shocks is everyone using?
- Bomb - where to get?
- 88 5000 turbo battery power loss
- used fuel pump for 87 audi 5000 turbo
- Has anyone here upgraded to A8 312mm rotors?
- Rear Speaker Mounts for a 1987 5k CS
- V8Q....center muffler opinions....
- caliper bolts stripped
- this might be a dumb question, but
- CHF leak
- How fast does your car run with a chip?
- Gonna buff up the twins this summer
- It's not 5K but I wanted to share with my old buddies.
- Wheel hop on bumps/sharp turns
- 10vt exhaust studs...
- who wants a 5k...
- Brakes are shaking..........not the rotors
- Considering a 1992-94 100 quattro...............
- EFI and Emissions Testing
- I wonder what Adam's up to?
- Headliner removal question 5KTQ
- 200TQ 4,11 ratio since witch year ?
- Oil
- Where to get and how much of a b*tch izzit too......
- Charging System Question
- Parts WANTED!
- 88 5000 CS Wagon, pearl....
- 1990 200 Avant transmission issues?
- Hey guys, Carbuerated engine q
- Differences between '84 and '86 5000?
- Help! Car won't start!
- 5000 exhaust manifold options??
- Brake lights always on..........
- I need some suggestions..........
- V8 power steering rack question . . .
- automatic tranny shifting
- Starting probs
- Brake lights not working - HELP!
- New struts in, gas filled up w/ 93 ... cars feels great yet i'm still bothered by something
- Looking at a 1990 100.....opinions?
- Chineese Audi :)
- '90 V8Q tape deck needed
- Looking for places to buy a 5tkq avant or 200tq avant
- Thinking of Selling 1988 5000 csqt
- Any way to get a german bumper?
- Sunroof Problem - Audi 5000s 1984
- Rear Passenger Side Window Problem - Audi 5000s 1984
- Squeaky Squeaky...
- front bearing noise
- Purchased a new (to me) ride to take the place of old faithful...
- auto tranny Q
- WTB: New Chrome "200" and "turbo" emblem for a '89 200...
- 89 200TQ Trans problems (Manual)
- 5KST transmission swap questions
- Got a new muffler....
- Free to a good home
- coolant warning light problem
- Cross-Post...What I/we did today...
- 87 5ktq - ? on brakes, and fan
- Temp guage doesn't work on my 88 5kqt
- still having lock problems
- Top Ten Reasons Steve should keep the Audi [EDITED]
- 86 5ks front speakers......................
- Intermittent heavy steering....
- Whens the last time you heard this?
- Finally got my little weekend project finished.
- nt
- 88' 5000 CST Manual trans parts
- What a great day for pics
- Looking for an "aspirator" / "temp sensor" motor...
- Need help with clutch rebuild, '89 200tqa
- Whats the trick to getting the rear driverside door panel off?
- Heater Control Valve '87 5K
- Need '91 100Q intake manifold/throttle body
- Arg....
- for sale or trade
- Those that have swapped k26's out for a k24 ...
- Used/New K26
- 1989 100 difficult to engage 1st & 2nd gears - clutch?
- 1990. Audi.100.AC/Heater Blower..
- swapping struts
- nice V8 on Ebay
- Decel cut-off valve...
- For you turbo guys...
- Spark plugs
- I got da Hook-up
- Did they make 5000 "quattro" in 1984? or all of them were FWDs? Model guide doesnt list any q's
- Door locks
- Audi 100 instrument cluster
- Will a faulty O2 sensor cue a "check engine" light in a V8?
- Anybody change their single lense...
- anyone have a write-up or suggestions on drivers side door handle replacement? 85 5000
- OT sort of...Anyone heading out (rather coming down) for YarrowSports opening this weekend?
- Replacing deck in 90 V8Q w/Bose system
- Sagging headliner cloth solution.
