- 5000S automatic transmission needed
- What are the merits of 5-speed tranny code "5N"?
- Scott I've always found this inspiring and I'm feeling like sharing.
- Isn't it relatively easy to replace a steering rack?
- Will a ...
- My Quantum Syncro Turbo...
- What's the best place to get switched power for a new radio?
- Anybody know why so many ABS relay fuses blow?
- ShortyQ nice wagon....
- when I get the QLCC chip today should I get the spring also??
- going up to seattle to pick up a QLCC w/spring today...
- 5000 CS turbo sighting.. Middletown, NJ.. anyone on here?
- Fuel and coolant temp gauges
- Hey Toxcheap!!
- Turbo Question!
- Toxcheap.... If I may Ask...
- Anyone need a project car? Running and cheap!
- Since I'm on vacation...this would be a great time to get a chip for my baby...
- has anyone here brought or tried the new Escort Solo S2 radar/laser detector?
- k26/k24
- Nice cars for sale in the local (Alberta) paper
- CEL in my 1990 Avant
- Tach zusammen !!!
- Something is obviously wrong with the exhaust
- Question: will an "NF" head fit on an "MC2" ('91-200) engine???
- wagons..
- Steering wheel fore / aft play?
- Not many modded avants?
- Where can I buy the wastegate membrane (diaphragme) ???
- Links to Audi mowies ??
- I love LT1's
- Does anyone know how much a 5000s engine goes for?
- TEAM LT1Q CHALLENGES
- pic request!
- So, I have been thinking of "building" a Megasquirt system.
- Just replaced spark wires and distributor cap
- looking for a part...
- Lt1 Audi
- Is this the cause of a bad ISV????
- Dyed seats! youve gotta check this out (befor pic)
- HELP PLEASEdoes anyone have a type 44 rear sway bar Picture? S4's will do as well!
- who is up right now??? I'm just doing some Audi Certifcations right now on my vacation.
- Getting rid of ABS on 91 200TQ
- while working on my expansion tank, I noticed under the windshield fluid expasion a loose wire...
- NE1 here know how to mix in a pic of a sexy model on a pic with my Audi?
- 91 200tq20v, alignment problems, bent frame?
- p/s probs
- Boost Options
- If anyone is curious Stephen Ankney is fine, ran into him at Audifest.
- Mod'd 200TQ Avant's?
- Tedub...how do you like your QLCC chip?
- 1991 Audi 200 Turbo Quattro Pre-Purchase Questions
- my freakin coolant tank cracked yesterday, the saga continues...
- ABS modulation problem
- HELP! V8Q no start....
- Mr. DeMille, I'm ready for my close-up....
- audiqv8, removed RPM/crank sensors . . .
- Taillight swap....
- want to buy 3b IM and flywheel
- SMALL PART HELP!!!!
- A Rant
- Idle Problem - ISV??
- A couple pics of the Toxchp 5K
- A/C not working!!!
- Does anybody know if Monroe makes shocks for 5ktqw and 200q avants?
- v8phil and spdfrk135+ A/T - Intermittent Electrical Problems
- LOOK HERE!!!
- Found one of the CIS book links...
- 86 Audi 5000 Heater Fan Runs constantly
- Bar Reading?
- Was there a 20v 200 in 1990?
- Ferrocene's Interior Trim Restoration Project (long and big!)
- Spdfrk135+...any luck finding that sevice slip?
- V8 Heater Matrix (long)
- Ate up a souped up lime green neon last night...
- RS2 vs K24
- My work office has become an Audi parts warehouse....
- Anyone know why these odometers quit working?
- what are people seeing.......
- Cam's
- car died right on the off-ramp, tricky low gas light
- Blinked Out V8 ECU & Transmission Fault Codes . . .
- A discussion thread on cheap sound deadeners
- No Heat From Center Vents
- wheel bearing, anyone ever do it yourself?
- Megasquirt
- Mercedes Vs Audi
- Vendors / Sponsers of the 2003 Northeast Audi Event....(This weekend!)
- Different starting problem
- Carbon Fiber Hood for the Type 44
- YO...kidquattro :(
- Sunroof Track
- Won't idle...help
- Distributor rotor questions
- timing belt broke
- RPM Sensor Question
- Will headlights from 200 bolt on to a 100 frame?
- Shimming the FPR, revisited
- ABS question
- Has any one worked on an AC programmer??
- Should the ISV hoses have clamps on them?
- Engine Surging
- Attn: Those Interested In My Rear('eh heh)
- Re: Waterfest
- Re: watefest
- Some pic of the wagon at waterfest
- Just in case...
- KidQuattro
- rdoor parts/service
- HELP FOR A NEWB: Why won't the @$*$ing thing start?? (5000S)
- Javad's 80tq
- Does anyone know where I can find a good picture of the timing marks on the I-5?
- Anyone running a Mahle OC-264 oil fliters on their 5Kqt?
- Wow. Look whats for sale!
- 86 VW quantums. Whats their story? Weight?
- On the manifold question
- Steve I was just messing w/you
- Checkout this project 5000...
- 5ktq smoking C5's
- HUmming Sound
- ebay valves?
- Time to meet at the Charlton rest area for the Audifest convoy...
- whats goin on?!
- still dont understand the "shimming IC" thing..can someone break it down??
- 87 Audi 5ktq wagon at waterfest 13.1@103.6
- A few problems guys
- 5000 wastegate question, please help me out.....
- Regular Power Steering Fluid in 84 5000! UGH! UGH!
- Milling head? How much is too much.
- does anyone know of adding vacum lines to the wastegate rubber hoses for added boost??
- pulling the trigger and ordered my wheel bearing and it was only $30
- Will naturally aspirated I5s run on 87 octane gasoline?
- Audi S4 1992 Pearl White - $5500 (Andover, MA)
- Aspirator fan buzzing
- Audi error code 4444
- Attention Twisted 5000!!
- Brake problem
- Pics of my new flame!
- Idling/Acceleration Problems!!
- quick question about cold start valve
- 87 5000
- Lucky me!
- To audiqv8 . . . (theoretical)
- V8 Automatic Tranny Fluid
- Audi 5000 Windows
- Audisport4000 or anyone with info on this!!!!!
- Will Ng you out there?
- Would a bad thermostat also...
- Scored the car I want at a smoking hot price!!!
- Are 5000 and 200 driveshafts interchangable?
- Hydraulic Pump Re-seal. Success so far.
- How hard is it to service wheel bearing by yourself?
- Anyone know what this wire is???
- tires
- Cross pollenating again: Audifans Knowledgebase
- CIS Links...
- Stephen Ankney about sensor
- V8 wouldn't start hot, started hour later!
- V8 quattro buyer's guide? tried search...
- Anyone planning to attend the Audifest in Springfield MA Aug 2nd?
- Where are the a/c schraeder valves on an '89 200qtw? 134a retro?
- HELP...careless mech. caused-
- Looking for Roof Rack/Rails for 5000s Wagon
- My audi!
- What would a good independent shop typically charge to rebuild an existing 5000 turbo motor.
- Need help quick with 90 v8
- AudiWorld Merchandise now updated
- My '86 5K A/C system sprung a leak...
- HELP quick please!
- Shimming the FPR.
- audi 5000
- smoked a 03' VW passat 4Motion today on I-5(Tacoma going north)
- '90 200 avant roof rack removal
- a few drips of oil after shutting the engine off
- 84 5000S Wagon Cruise Control Not Working
- 86 5000 TQ air filter
- Audi center caps?
- Interior lights
- My Waterfest Pics
- oil pressure sending unit
- 1987 5000 CS Quattro Rear Door Locks are sticking.
- Sudden warm air from under foot well
- Clock light on 200 not working correctly
- V8 Serpentine Belt
- Waterfest was...
- Heavy cars??
- Audi warning lights
- Brake related hiss
- Hey, it really works!
- Crankcase vent question
- Dead trip meter
- I need to know what this is
- this is one nice car...anyone have something like this for sale.?
- E-brake
- Couldn't make it to Waterfest, someone please post some pics!
- Fuel Pump tomorrow. Special tool really needed?
- Crankshaft boltheads stripped. Help!
- Stalling problem....help!
- Waterfest is Over...
- 1984 5000S Power Steering Leak Question - Can I disconnect..
- The Bomb-a question
- X-Post of AW rafting trip G2G info.
- Anyone ever take their car into an AUDI dealer for service?
- One thing after another..brake light out
- 87 5KTQ turned
- Leaking Power Steering Fluid! Help!!!!
- So after i get the euro headlights and the new paint job i'm selling the 200! details inside
- will 5 lug Porsche wheels ( off a 95' 993) fit my car?
- Needed: ABS relay for 89 100q ...
- the audi likes the new exhaust
- Thanks to all for TPS information!
- injector cleaning failed.............
- ECI Light
- What size Air filter on the 90 100? What brand?
- What A Differance a Tranny Flush Makes
- throttle switch?
- another strange discovery (a/c related)
- Leaving for Waterfest...
- Hello Type 44 owners... opinions please...
- new rotors with 1 year old pads?
- What sort of clamp fastens boot ends to steering rack?
- headers
- One of you guys ought to BUY THESE WHEELS - AUCTION ENDS 1 HOUR (BBS RG 16x7)
- Upcoming Drivers Ed in Charlotte NC
- Locksmith help!!
- SELLING MY V8
- '89 200 AC info needed...
- Waterfest only two days away!
- 84 5k turbo won't run when hot
- NEWB questions alert.
- wtb: 5k tq grill
- '91 200 Air Bag Indicator
- Looking for a SUPER-CLEAN 91 100 non-quattro
- Can somebody post a close up pic of the 5KT throttle body
- What brand waterpump do you guys recommend I get (or not get, as the case may be)?
- PLEASE. Somebody know what can I do with a KH 10vt? Need references...ing like 250-300hp...???
- 200 20vtq Boost issues (Help out this new owner!)
- here is my new toy and 0-60 times, not sure how accurate this is.
- pic of my new tips.
- Anyone here in Texas, Missouri, ArkansaW or Colorado? (Looking for perspective 200 20v buyers!) :)
- Never had so much fun tearing something up in my life!!!
- I don't know if this is of interest here...83' Coupe TQ
- Problem with switch selector (SEM)?
- How do you remove injectors
- Window goes down, won't go up
- Can someone post a picture of a 5000 turbo intercooler please?
- Anyone with red wagons...
- I know I'm gonna get blasted for asking this question but.......
- bought a new toy today... the new Beltronic G-tech
- Uh-oh. There's a one inch tear in my rack's boot.
