- 85 audi 4000s help
- faux fog light covers
- 1986 Audi 4000 Quattro parts for sale
- Fuel delivery problem, please help!
- 87 4000s, free parts car !
- WTB: 4000 2 door sedan
- post warm-up issue
- New Member here- Are there any other 4000's in lower NY area
- FINDING A PRIOR OWNED 1981 4000 5 +5
- Running problems
- Metric Fittings (Fuel)
- did lots of work today
- Louvers/Rear window
- Driveshaft play
- 84 Coupe idle issues
- Two Air Filters on a 1.8 4000 (no more dismantleing the fuel system!)
- Diff locker problem diagnosing
- anybody in alberta?
- Search for parts
- SCCA Guy - need some Coupe Help
- TT 272 Cam power?
- CIS-E service training manual
- FOR SALE: 87.5 Special Build CGT
- Color
- 1986 Coupe GT - getting wires off fuel pump
- lowering emissions
- New Group for vintage Audi owners...please read...
- Slow stall on cold start
- FWD to AWD swap
- 4000cs
- Audi GT Coupe Supercar?
- Rear Window dimensions Coupe
- Window Stuck
- 86 audi 4000 cs quattro
- Audi 5+5 - anybody remember or know about this car?
- CO emissions
- NO Emissions
- Surging/bucking under hard acceleration...
- 4000 Quattro front strut question/advise
- VW 1315 A/1 Test Harness KE-Jetronic
- hello and new to audi
- 1986 Coupe GT Oil Pressure Buzzer
- Hello!
- 4000s dash lights cut out
- Care to brainstorm my stumbling problem?
- Power Issue
- 1986 Coupe GT hard to start and idles at 3000 rpms!
- CGT Driver's Door Dimensions?
- 4000q on ebay
- Intake Boot?
- You show me yours, and ill show you mine (b2!!)
- Forgot....
- 81-87 Coupe black out tail lights & center "COUPE" section
- Failed emissions - troubleshooting - need suggestions!
- 1986 Coupe GT will not start (fuel injection system?)
- Source for New Parts - Audi GT / Audi 4000
- Control Arm Help
- WTB: Digidash
- 4K Syncro
- WTB: interior parts and control arm 4kq
- Crank, No Start
- Vacuum Line
- Advance distributor timing?
- looking for a coolant resevior tank for 84 cgt
- need help-how do you get the backseat out of 84 cgt?
- F/S coupe gt parts (cc,ac,wheels,springs)
- Wanted: Bentley Manual
- Wanted: Sway Bar
- Quick and dirty AC evaporator removal?
- DigiDash switches
- 86 4000cs problems, need help
- Sites for Audi Parts?
- A/C Questions-compressor needed
- Irregular Idle
- New to Audis
- Newbie help
- My 1985 4000 turbo quattro project
- 4000cs fuel problem
- Cruise stalk switch repair?
- flowmaster exhaust on a 4000s?
- how to adjust idle
- I think my 4000s is fixed!
- 20v turbo swap
- 87 4K Quattro system...
- Coupe GT side trim piece
- Air Cleaner/Valve Cover Gasket- 87 Coupe
- Water Pump removal
- Lancaster, PA Coupe GTG pics
- Clear corner euro-style headlights
- Head Light Replacement
- High Coolant Temps
- Cold Start Problem
- Get Together August 21st - Lititz PA....
- original decal
- selling an 87.5 GT with MC2 swap $1500
- might part out the '87 4000S
- Engine Swap Help!
- Rattle can paint matches
- Fuel pump rating for 4000s
- 4kQ parts
- Low amps from coil
- Want to re-bore and stroke
- Cleaning out the garage... Misc 4KQ/CGT parts available
- Free OE Light Bulb (for digital dashboard)
- Matching Bosch to VW/Audi Part Numbers?
- Smog Woes
- 1986 CGT and 16'' BBS with new Falcon for SALE
- 86 CGT Rear Drum to Disc conversion
- Need Sunroof Crank Handle for a Coupe GT
- '85 cgt was losing power now won't start
- 86 CGT fuel filter location..
- 87 cgt turbo swap
- :: ECS Tuning :: 4000/4000S and 5000/5000s - Radios - $93.95 43% OFF
- WTB 4000 quattro
- German car show
- Nooo! window regulator!
- New Car!
- Engage/Disengage Slow on Diffs on 87 4000Q
- Silver soldering, repair the unrepairable!
- The 2 Reasons you VW/AUDI odometer quits working
- 87 4KQ center drive shaft rebuild info.
- Any interest in odometer repair process?
- Should I post 4000 quattro specific questions here?
- Any inexpensive source for sunroof seal 321-877-209A
- fuel pump confusion
- Custom 4000/CGT/UrQ white face gauges
- Top Secret custom 4000/Coupe GT grill
- 4 x 108 wheels
- 87 Coupe GT Stereo Wiring
- I'm in love with my new audi
- Audi GT info
- No power to all Window switches
- Transmission whine
- clunking in to 5th
- Gettin rid of the GT coupe
- any one around Burlington VT wanna help
- How to restore a GT
- back up light switch.
- Major issues
- Speedometer issues
- Looking for Fellow Audi People
- windshield replacement help
- Diff problems
- Front Grill /85 Coupe Gt
- 86 CGT turbo engine swap options?
- 86 gt coupe temp. gauge sensor
- radio ideas?
- 2.2L 5-cyl. idle/timing RPM issues
- what is this?
- 87 4k computer
- 1984 4000 S
- 4KQ engine-trans swap from the bottom?
- sun roof
- GT Coupe Clutch Disc
- 20v 2.3 in a 4k?
- Need windshield
- where is located the oxygen sensor in a 1986 Audi 4000CS Quattro?
- Another Coupe GT with a bad starter
- 1985 Coupe GT/Sunvisor clips/Louvers
- Trying to sort out some issues: 86 CGT
- Black smoke and slow running when pushing gas pedal.
- Just Bought an 83 CGT
- Engine hydrolocking after fuel dist. rebuild.
- Hood release cable horrors
- Strange Audi 4000s Starting problem?
- Center LCD glass for coupe gt digi dash
- Audi Coupe GT Clutch Reservoir.
- Audi Coupe GT buying advice please
- !HELP! Reverse and first !HELP!
- CGT parts on Ebay
- new car...new problems
- 4000 valve tick
- STARTER DOES NOT ENGAGE
- Looking for a 034-103-247B
- 85 Coupe GT front end loosness and rattles
- Thermo fan switch wiring color?
- awd conversion for audi coupe gt
- 85 4KSQ starting/running issue
- '86 CGT no start (cranks), no cluster lights
- Just Got 1985 COUPE
- EASY POWER UPGRADES?
- heated seat issue
- Euro Fog Lights & Clear Blinker
- Coupe GT front lip spoiler
- Restoring Hella Euro's
- The Audi quattro story video!
- Looking to buy wheels for my 4k 20v
- Blau cam $199.00!! + tons of other stuff!
- rota wheels
- 84 4000 start mystery
- audi1126- i need restoration help
- tire sizes for 15x7 rim on coupe gt
- Hissing from brakes
- Anyone know where to get Kamei x1 kit for early CGT?
- Advice on Engine Teardown Appreciated
- any one try these
- wanted: 4000cs quattro
- '87 Coupe Gt
- LCD's on digi dash
- 86 Audi 4000cs quattro in perfect condition
- My winter driver
- I NEED HELP
- Value of quattro 88' 4000 CS
- connector under seat
- heat issue
- Audi Coupe GT Engine
- Minor warm-up annoyance.
- Semi-new 4000S Owner Considering Engine Swap
- pass. tail lights won't work
- STARTING PROBLEM 4000s
- Center Caps
- Coupe GT Questions
- 87.5 cgt -- burning oil, maybe coolant?
- HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- HELP REQUIERED
- audi 4000 type 81
- 4000s 3spd Auto transmission cable needed Help!
- Carlisle registration open for 2010 may 21st through 23rd
- starting problem is back
- rear diff schematic?
- I have a radiator fan that will not turn ON
- I have a radior fan that wont turn off.
- Window Regulator Question
- power steering rack source needed
- CGT Turbo swap questions
- Noob Lookin at '85 4000 quattro in Wisconsin
- Air Filter
- Gearbox problems
- Turbo conversion
- Audi 4KCS Tail light lenses
- 84 cgt timing belt position?
- starting problem kinda(lots of details)
- 84 cgt fusebox issues
- I miss my 4KQ!
- center differentail problems
- Engine Size?
- i need help
- Clock not working....
- 84 ur quattro
- 4000CS quattro starting problem
- How many were made/Came to the USA?
- CGT Electrical Weirdness - Lighting & 12V Port
- tranny fluid
- speedo pinion gear 84 4000S
- Anybody in the search of a 5ktq donor car?
- Advice Appreciated on Idle/Emissions Issues
- 1982 Audi 4000 2 Door
- fuel pump
- Basketweave BBS rims
