- Horn doesn't work…?
- :: ECS Tuning :: B6 A4 1.8T ECS Carbon Fiber Engine Cover
- :: ECS Tuning :: B6 A4 DTM Interior Accessories
- Suspension on special at AWE Tuning
- Clearance needed to remove transmission
- Buying used audi A4 1.9tdi
- A4 B6 Raditator Fan, Fan Control Module, or Relay?
- small grinding noise coming from front of engine
- HID LIGHTING NEVER ENDING PROBLEMS! HELP YALL!
- Knocking engine sound, puffing exhaust 1.8T
- :: ECS Tuning :: B6 A4 Avant Rear Aero Wiper Conversion Kit
- Went and Dip my Car.....easy mod
- Water/coolant leaking problem - A4 3.0 Quattro
- need some diy help for p0171 p0507
- Clutch replacement on FWD '03 A4 B6
- Wipers wont stop wiping!
- :: ECS Tuning :: B6 A4 Alzor Style 010 Wheels
- Code out sai mil?
- Please help me.. 02 Audi a4 1.8t quattro
- Brake,Triangle,ECP lights.
- Manual transmission fluid change
- Boost Issues after 4500 RPM
- Please help my audi a4 died and won't turn over
- Cheap fix for intake cover? 2002 3.0
- B6 1.8T very loud ticking?!
- AMB egine - 2002 vs 2003 model year difference?
- 2002 A4 1.8 Coolant tank
- :: ECS Tuning :: B6 A4 Quattro ECS Rear Differential Mount
- Gear Ratio - Engine rev to wheel rpm formula
- tiptronic transmission ATF capacity help!
- AMB Engine differences?
- Audi security kicking in?
- Corner with Confidence. Special pricing on Bilstein and H&R at AWE Tuning
- Surviving B6ers!... Whats Your Odo??......
- 2002 Power Seat Swap
- Help passing inspection!
- Help!! Fluid in secondary air pump
- Buying an Audi A4- Busted Transmission
- :: ECS Tuning :: B6 A4 1.8T Forge Diverter Valves
- A4 B6 Rescue
- Audi A4 1.8T
- Transmission fluid replacement
- Vacuum leak?
- :: ECS Tuning :: B6 A4 1.8T Cooling System Refresh Kits
- Moving Sale - Help us move out - Detailer's Domain
- Rough idle
- :: ECS Tuning :: B6 A4 1.8T Front Control Arm Kits!
- Help Identifying Engine Hose
- A/C compressor has no power
- Immobiliser / Security / lockout problem
- windows and sunroof are not working
- Flashing gas light
- New guy here!
- Control. For less. Special Pricing on H&R Springs and Sway Bars from AWE Tuning
- :: ECS Tuning :: B6 A4 1.8T Auto Transmission Service Kit
- Help! 3.0 cylinders misfire, immobilizer, bad news.
- Fuel pump upgrade B6 1.8T
- Help with information on Audi A4 3.0
- 2003 Audi A4 Number Plate Lights
- 2003 AMB N75 OEM part number
- Audi a4 b6
- An introduction, a message from AWE Tuning
- Argg! Headliner fell out!
- Vacuum system problem
- preparing for a long trip
- what's the torque spec for CVT rear cover
- :: ECS Tuning :: NEW!! B6 A4 1.8T ECS 2.0T Ignition Conversion Kits
- A4 clicking noise/engine
- Axle broken?
- airbag light constantly on
- Fuel gauge misreading and rear window on driver's side is not working
- Coilover for Under is back, at AWE Tuning. Dial in your power stance, right here.
- 48 Hr - Summer Sale - Save 20% off at Detailer's Domain.com
- Slow gas fill
- Vacuum Hose
- :: ECS Tuning :: B6 A4 Fastener Assortment Kit
- Info center brake bulb warning
- I am new to Audi & AudiWorld
- Radiator Cooling Fan Assembly Replacement
- Wipers won't stop cycling!!!!!!!
- Get that power to the ground. South Bend Clutches, 10% off, at AWE Tuning.
- **Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - September 1st - 5th, 2014**
- P0299 and Positive Pressure in Valve Cover
- Not sure if I am getting correct info on my turbo/wg in A4 - B6 - 1.8TQM
- Estimate of new wipers including motor repair?
- Clean MAF
- Multitronic gearbox CVT question
- Strange noise when turning only to right...
- Valvoline CVT Fluid, anyone used it?
- :: ECS Tuning :: B6 A4 Smoked Halogen Headlight Set
- Replaced old 02 Sensor...But Started getting p0130 code???
- New Radio for the A4
- Secondary Air Injection- Pump Functional but Not Turning on When Car is Started
- 03 A4 1.8t Cyl. 4 Misfire
- 2005 Carbiolet 3.0 rough starting and acceleration
- VCDS Country Code
- Need advice on engine change 1.8T Quattro
- :: ECS Tuning :: B6 A4 Bilstein Sport Shocks & Struts Kit
- 2003 1.8 Cabriolet checking in!! But problems already
- Blaque Diamond Wheels | New BD-1 pictures released
- Go for low with H&R. 10% off all H&R Springs, at AWE Tuning.
- Fuel Pump
- B7 Shocks on B6 Question?
- Radio Upgrade
- Waterfest 20 Promo - Stock up on your detailing gear @ Detailer's Domain
- :: ECS Tuning :: Bremmen B6 A4 Ultrasport Front Valance
- ABS Controller
- Is pressure regulator valve broken??
- Engine not decreasing revs when changing gear on 1.8T
- help! wiper problems
- A4 B6 water issue
- 02 a4 front brake question
- :: ECS Tuning :: B6 A4 1.8T Coolant Flange Kit
- :: ECS Tuning :: B6 A4 1.8T APR Summer Sale!
- **Don Nguyen | Light Smoke/Tint on Tail Lights - White Audi Q5 SUV**
- Help!
- Blue is Back. 10% off Bilstein at AWE Tuning.
- **Don Nguyen | 3M Di-noc Matte Carbon Fiber - White CRZ Hood**
- Curious temporary a/c failure
- Cam Chain tensioner. Helps and Ideas Please
- Not your normal clutch problem help please
- HELP! Windows etc. won't work :(
- :: ECS Tuning :: B6 A4 RS Mesh Style Grille
- July 4th Special - Save 15% off and Free Shipping Over $75.00 @ DetailersDomain.com
- :: ECS Tuning :: Cupra R Lip Spoilers - $59.95!!
- Need help?!?!?!?
- My car starts shaking at high speeds
- HELP!!!! No Coolant. Car wont start.. Normal?
- Serpentine belt appears to have destroyed my engine - how to go about repairing?
- Slow coolant leak only under pressure
- CEL comes on after heavy rain
- Need help with oxygen sensor wiring!!!
- intake manifold and then some..
- battery light comes when i start the car then goes off after 5-10 mins of driving
- 1.8T AC setup the same on A4 as on VW?
- Am i missing a gear????
- Car won't crank - manual transmission
- Wastegate fail
- DIY on bonnet/hood sensor
- :: ECS Tuning :: B6 A4 Quattro Air Lift Suspension Kits
- rear bumper & exhaust upgrade on 1.6 limousine
- :: ECS Tuning :: B6 A4 Heavy Duty Tie Rod Ends by Meyle
- H&R, handled. Special pricing on the entire H&R Catalog, at AWE Tuning.
- Can someone tell me if the '04 3.0 came with this part?
- Front bumper
- Help with my a/c fan
- Power Widow Auto stop
- :: ECS Tuning :: B6 A4 Belly Pan Kits
- Where to get an alignment done on a 2003 A4 1.8t Quattro Avant
- :: ECS Tuning :: B6 A4 Valeo Aero Wiper Sets
- BLAQUE DIAMOND WHEELS || 2012 A7 on BD-4s
- :: ECS Tuning :: B6 A4 1.8T Bilstein Sport Shocks & Struts
- satellite radio
- Father's Day Special at Detailer's Domain - Save 20% off and Free Shipping over $120
- 99 A4 quattro, rod bearing questions
- :: ECS Tuning :: B6 A4 1.8T Oil Sludge Repair Kit
- Serious Misfiring at Cold Starts... Car runs great after engine warms up ...why??
- Serious Misfiring at Cold Start... Car runs great after 15 mins...why??
- BLAQUE DIAMOND WHEELS || 2013 BMW 535i on BD-4's
- WTB B6 Avant 1.8T Manual
- :: ECS Tuning :: B6 A4 Vaico Rear Trunk Struts
- Major Electrical Issues
- Acceleration Problem
- Left Turn signal light staying on, where is the relay switch?
- Sirius XM radio question
- BLAQUE DIAMOND WHEELS || 2008 Lamborghini Gallardo on BD-4's
- Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - June 16th - 20th 2014
- Memorial Day Special @ Detailer's Domain - Stock up on your detailing gear!
- What Broken door wiring harness is this? Lower front Bose speaker not working below
- Vibration at high speed
- 2002 A4 Avant electrical problem
- Fuse Diagram
- about to get a used SAT radio
- :: ECS Tuning :: B6 A4 1.8T Valeo Radiators
- New Member & New Owner
- TIRES: 205/55/16 on USP ??
- :: ECS Tuning :: NEW!! Schwaben Connector Removal Tool
- Coilover for Under. Special pricing on Bilstein, H&R, and KONI coilovers.
- Low Oil Level issue
- Dome light front and rear roof lights not working
- Sunroof Shade Problem
- '02 A4 1.8t Turbo lag or Transmission slip?
- good replacement Headlight housings?
- :: ECS Tuning :: B6 A4 V6 30v Timing Belt Kits
- 1.8T acceleration boost
- Sports Mode
- DC Maryland Virginia
- possible coolant leaks
- New Member, Mechanic, Automatic Transmission Question...
- :: ECS Tuning :: RA4 Clutch Conversion Kits For B6 A4 1.8T
- :: ECS Tuning :: B6 A4 Quattro ST Performance Coilovers - $100 Mail In Rebate!!
- :: ECS Tuning :: B6 A4 1.8T Oil Cooler Refresh Kit
- Difficulty replacing key fob shell
- BLAQUE DIAMOND WHEELS || 2013 A5 on BD-4's
- Transmission compatibility
- Corner with confidence. Special pricing on H&R Sway Bars from AWE Tuning.
- B6 non-bose Symphony2 moody volume when bass kicks
- :: ECS Tuning :: B6 A4 30V Big Brake Kit
- :: ECS Tuning :: B6 A4 1.8T Stage IV Big Brake Kit
- Should I buy?!
- :: ECS Tuning :: B6 A4 30V Quattro Valeo Clutch Kits
- Engine dimensions?!?!?!
- BLAQUE DIAMOND WHEELS || New 2014 Collection
- HELP! 2003 A4 Electrical Issues Need CCM Compatibility
- **Don Nguyen | Gloss Black Vinyl Roof Installed - White Audi RS7 Sedan**
- Is $900 the going price for Timing Belt service?
- **Don Nguyen | 3M Dinoc Matte Carbon Fiber - Wrapped Interior Trim**
- :: ECS Tuning :: B6 A4 V6 30v Oil Service Kits
- :: ECS Tuning :: B6 A4 Schwaben Floor Mats
- question on lowering suspension
- Please help Audi A4 2003 1.9 TDI Starts and dies immediately
- Lack of power and a 'grumble' when putting foot down
- :: ECS Tuning :: B6 A4 1.8T Vaico Windshield Wiper Transmission
- AMI connection and bluetooth
- 19's on the b6. Too much rim?
- FEP Transmission Replacement with FAR Transmission A4 1.8T
- help!!!!! 2003 audi quattro 1.8 t
- :: ECS Tuning :: B6 A4 H&R Sway Bars - FREE Shipping!
- Battery Dead immediately upon replacing Ignition Coils
- intermitten ac issue
- Changing Language For Error Messages From Germany to English
- 3.0 upper oil pan bolt access
- :: ECS Tuning :: B6 A4 Premium Headlight Lens Restoration Kit
- Cylinder Head Coolant Pipe Replacement Write Up
- ECON function wont shut off (No AC)
- Rear 02 wiring diagram for 02avant
- Selling a B6 Bentley service manual
- Let's get low with H&R. Spring Fling starts now, at AWE Tuning.
- :: ECS Tuning :: B6 A4 Quattro JOM Coilovers
- Can't Get Rid of Misfire
- :: ECS Tuning :: B6 A4 1.8T APR Spring Sale!!
- any solution for that headache
- 2004 A4 3.0 6sp - headlight fuses
- Driver side window crunching noise
- Can someone tell me what this silver canister is in the picture?
- 1.8T AMB - upgrade
- High beams don't work. help
- :: ECS Tuning :: B6 A4 P3 Cars Digital Vent Gauge
- URGENT!!!!! -After Timing Belt Diagnosis Help
- :: ECS Tuning :: B6/B7 FWD A4 ST Performance Coilovers
- 02 A4 not cranking
- :: ECS Tuning :: B6 A4 1.8T ECS Vent Pod Boost Gauge Kit
- Wont Start!
- Timing Rattle B6 A4 1.8T - Belt or Chain ??
- 98 1.8l turbo white smoke
- Exhaust question.....
- :: ECS Tuning :: B6 A4 1.8T Oil Service Kits
- :: ECS Tuning :: B6 A4 1.8T Pipercross Performance Filters
- A4 3.0 Quattro new owner have Eng Code ???
- For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95!
