- Acting up at start up
- Reset Service Required Message
- Hawk HPS squeaking
- How to reset service warning
- 2003 A4 Q AC not working right
- intake question
- P0300 Still!?
- revo 4 hour trial tune
- Drivers Door Hinge Wiring Break
- Oil not registering on dip stick after change
- Pioneer releases FREE iPhone App [demo video]
- Head gasket 02 a4 1.8tmq
- Odd suspension problem... Passenger side rear is lower than everything else...
- How do I remove B6 A4 door molding?
- UPDATE: Electrical system and wiring...
- UPDATE: Oil catch can installation...
- Lean and High Idle 2004 A4 1.8T
- Update: FMIC piping modification and ITG air filter installation...
- What could cause a change in the amount of steering wheel road feedback?
- Avant Luggage Cover
- 2003 3.0 V6 exhaust
- Audi A4 B6 Rear Differential Fluid Capacity
- VALVE KNOCKING
- Parting out 2002 Audi A4 1.8T Quattro
- Noise on start up??
- Approved Coolants?
- PureMS - Febi-Bilstein B6/B7 Control Arm Kits on sale!
- SAVE 20% Storewide at Stratmosphere October 2009!
- Tiptronic Whine Noise Off Throttle Help!
- 1.8t rebuild help!
- B6 Tiptronic Off Throttle loud Whine
- Digital Speedo not woking Analog working fine
- Whats a good price for 03 a4
- Power Steering Rack
- parking brake indicator flashes/beeps when moving forward
- 02 Audi A4 V6 3.0L automatic
- vibration felt on certain RPM on Neutral...thereafter OK
- temp guage to abs brake light
- Rattle/rumble from under the hood when in gear
- changed a4 windshield wiper transmission and now the windshield wipers stop 1/2
- Valve knockin on low RPM
- Tansmission fluid capacity
- P1136
- Text display with Dension GW16AC2 on Symphony II without SAT
- Drivability Issues!
- Temp Gauge
- p1136 long term fuel trimm add.Fuel , Bank system too lean
- quick synthetic oil question
- P0304 and P0688 - A4 1.8T Quattro 02
- blown engine warning to all oil light on ?
- Ipod Aux!
- cracked windshield washer reservoir..cover under CPO???
- Hot engine start problem 1,8T
- How much should an alignment cost?
- Windows opening spontaneously
- Misfires around 2-3krpm
- Whistle noise 2004 A4 1.8T
- 04 1.8T 75k service
- Suspension install
- Program key to car on a 2002 audi a4
- Steering rack
- UPDATE: Setrab power steering oil cooler installation...
- Potenrial A4 owner
- Boost leak Test Question....(Air inside Crankcase)....
- New Struts -- Recommendations?
- A4 Dies at stop, seems like vacuum problem.
- 2005 A4 Check Engine Light Help!!!
- UPDATE: One more weight reduction solution (long)...
- Bad Flywheel?
- oil on spark plug and coil pack
- Bilstein Suspension Questions
- Cylinder Numbers
- Ignition cylinder failure
- 2003 A4 Avant 3.0 - a few questions
- tire replacement
- Timing belt etc done by Indy
- Is this what your OEM 1.8t manual trans mount looked like?
- '03 A4 Autotranny problem after a rebuild
- :: ECS Tuning :: aFe B6 A4 1.8T Air Intake Systems - Now Available !!!
- Glove box door
- Unable to get autolocks to work
- New guy...maybe... Advice please!
- ac oil weight for a4
- A4 transmission problem
- Gauging Interest - Custom Painted OEM Audi Emblems
- Wife was stranded today
- How much is my A4 worth today?
- 02 a4...stupid question...wiper blade replacement
- My A4 Car is totalled, should I repair
- Having problems fueling up...
- Help with worn finish on carbon fiber interior trim
- OEM Audi Parts and Performance Parts
- R&R Rear Rotors w/out removing carrier
- Audi/VW Technician
- Please Help !!!! Symphony II to II+ Upgrade Problems
- No communication with ECU and not starting
- Help with air filter
- What Audi Did I Buy?
- Working on Antenna Module, engine goes wonky?
- Sway Bar Question...
- MIL Problems, Need Help
- problem starting
- Carfax??
- local tristate gtg - October 10th, 2009
- 2002-04 B6 System pressure, fuel pressure regulator and residual pressure, checking
- 2002-04 B6 Brake Rotor Repair
- 2002-04 B6 Brake pads, removing and installing
- "2002-04" Front brakes, servicing
- Fuel Filter Replacement B6 "02-04"
- Replacing Vacuum Lines
- Different stock Rotor from 2002
- another overheating thread :(
- Grinding Noise when steering please help
- Battery Replaced - Now Beeping & Hazards Flashing
- Could use some buying advice.
- CAR AUDIO PROBLEM...PLEASE HELP...
- Quattro S-LINE vs Quattro SPORT??
- Questions for those who've replaced the catalytic converter on their 3.0
- fuel lid - how to re-enable locking after pulling red cable
- Is this a problem or is it normal? Aircon Problem.
- fog light switch?
- What is this part called? [with pic]
- Lighting Problem
- help me
- Loud Exhaust Burps in between boost and upshifts........any hints whats causing it??
- **DC Metro Area Drive and Drift 9/27**
- UPDATE: Fuel system (long)...
- Quick engine install update...
- A4 2002 Beige Driver Side Seat Bottom
- Transmission issue!!
- Do you recognize this part?
- Will A Split Crankcase Breather hose cause Rough Idling?
- HID in Helix for B6
- Rolled down my front passenger's side window, and heard crunching/scraping noises...
- Just got a a4...
- UPDATE: It as been a while since my last one...
- Avant rear hatch hydraulics/support bolt came unscrewed!!!
- Hsports for $345+ shipping
- Scary Traction control issue
- How to know if Quattro is working?
- Bending hood latch for FK grill installation
- ABS EPS lites on Speedo doesn't work
- Oil Light comes on
- Bose Speaker issue
- I'm looking for the ECU strap (metal) part number - I can't find it anywhere..
- Help VAGCOM Electric Failure!
- A4 3.0 exhaust question
- brake questions
- Omori ECS boost gauge issues
- Losing Headlamp/Windshield washer fluid...
- HELP! Need B6 Transmission Code "G" for my BT CVT Set up!
- Options for replacement factory radio
- 2001-2005 A4 - Engine Check Light - Brake boost - System too lean - System too rich
- Repair manual
- cigarette lighter power
- :: ECS Tuning :: ECS B6 A4 Ultimate Timing Belt Kits - Free Shipping !!!
- Misfiring, please help
- Great news; Finally it's back! I just got a call from the shop and the motor was...
- water leak top of engine
- Where is the coolant temp sensor on the 3.0L
- 3.0 Vacuum Leak
- LOWER CENTER BUMPER GRILL HELP
- Wiper control stalk
- Car shaking while driving (with codes)
- My new A4
- Huper Optik in Colorado
- Air Induction Sytem - Help!
- Mille Miglia EV-R 19x8.5
- Check engine light when under 3/4 tank
- Delayed Start
- N00B, several questions
- I'm in
- looking for used aftermarket exhaust for my 2003 a4 3.0L.. CT
- RS4 Rims on an A4 2005
- is this from the dreaded coolant flange leak?
- any tips for removing the top nut on the pass. side motor mount? 1.8t
- F900bt in a4 issue with rear speaker
- Ipod Adapter?
- Brake System Question
- fuel pressure
- fs 2004 a4
- help problems starting
- Car keeps draining battery
- MAF Plug wire sensor....broken or not??...more
- Faulty Alarm
- OK....Weird stuffs
- Key problems
- Glovebox crack
- Select APR Stage III Kit's are on sale till September 5th.
- Looking to buy an A4, have a few questions :)
- Selling 2003 1.8T A4 Avant. Any insight?
- Another Clunk Thread...
- Catalytic Converter! Help!
- Friend threw key into Lake!!!!! help
- 265's in the rear...Should i swap for other tires or can I get away with it?
- Brake Light issue and other question
- Engine misfire 2004 Audi A4 1.8
- Sport Suspension Upgrade
- Exhaust Upgrades... HP increase? and other questions...
- My exhaust pipe fell off today on the interstate.
- Body kit with unpainted lowers
- Audi 2003 coil pack.
- Is this an easy fix?
- New Member - Fuel Pump Noise
- Stop the presses... Comparo between the VP MS109 and the Elf Perfo 105...
- WTB: Performance Exhaust for 1.8T 5spd Quattro
- Looking to buy 2005 S4 Avant-questions
- Car died at 70mph and will not restart... single 'thud' from starter, no cranking
- rear lights out
- car shakes when at stoplight
- glove box will not open
- Car Starting to Hiccup during Acceleration....Need Advise and tips....
- No A/C, No Cooling Fan. Dont work.
- Rotors and pads need replacing all around. Thinking of upgrading. Is this a bad idea?
- HELP problems starting
- B5 BBK fit B6 A4?
- Value of 2005 USP Avant??
- 2002 a4 1.8t stock side skirt needed
- Anyone have experience with a 3.0L 30V timing belt failure?
- Stabilizer Bar Sizes - Autocross Setup
- Rear Brake Job - 08 1.8T - Info please. (which tools, which pads?)
- UPDATE: Elf Perfo 105 race gas dyno run (with graph)...
- Rear Diff Oil Replacement - How?!? (B6 A4 Avant Quattro 1.8T)
- New to Audi - timing belt question
- Audi 1.8 T 2004..... breather hose collapses behind the valve cover .excessive vacuum
- Airbags - replace after 7 years???
- Looking to buy an 2002 Audi A4 1.t or 3.0
- Problems starting car
- Engine not starting
- 3.0 with rough idle and P0015 code
- A/C Advice? Please!
- Should I buy 2004 A4 Avant 1.8T?
- What Kind Of Chip?
- Which Control Arm/Balljoint is bad?
- flashing check engine light
- Wipers stop working after 40 min searched and did the diy wiper bracket repair
- Limp mode? PRNDS backlight on........what coudl be the problem
- Misfire - Replaced all coilpacks and plugs??
- What's the best way to intergrate my iPhone with my RNS-E?
- misfiring under load
- Replacement sun visor clip?
- B6TQ tip to man trans conversion
- Has anyone used the engine mounts from ebay?
- Revo Technik's newest tuning center opens in Charlotte!
- Weird Vibrations unable to diagnose. Any ideas??
- quick question
