- A few questions on Stasis Motorsports Coilovers
- Sad plea for help on O2 sensor
- heat shield rattle
- Humming Sound - Fuel Pump?
- Non OP?
- tuning up my 1.8T after two years of non-use
- high pitched noise
- DIY: Brake Caliper Rebuild
- DIY: Ultra Suede Trim
- How to remove coin drawer 2005 A4
- 03 Audi A4 3.0 V6...The worst car for mods....?
- Alarm problem
- Audi n00b.. Picking up tonight
- ***clutch pedal stuck to floor, pulled it up, sort of working but doesnt sound good*
- Driver side fog light won't stay on??
- Febi TRE Blowout
- Join A.W.E. Tuning at NJMP and drive our 375hp GT Turbo A4 on the racetrack
- 2002 A4 1.8T Need help...
- :: ECS Tuning :: B6 / B7 A4 H&R Coilover Kit - On Sale !!!
- Stock Sway Bar Replacement for RS4 Sway Bar - Issues Removing Stock???
- front spindle knuckle upright inquiry
- Name and possibly part # Required
- Painting - Dumb question to ease my paranoia
- New slotted/drilled rotors, pads not fully contacting...
- AutoSpeed B6 A4 - Summer Sale!
- UPDATE: Rear suspension modification (part 1)...
- Front Wheel Bushings
- '02 A4 1.8T CVT missfire, bucking on acceleration only
- 02 A4 1.8T Question
- EBC brake pads any good?
- Audi /VW TEchnician
- key not working
- gas mileage
- P0322 code and still running
- Who is actually running Mobile 1 ATF vs OEM mineral oil?
- 3.0 coil pack clip removal question
- Help, how do I remove door sills (not the blades)?
- 3.0 plug gap?
- Disconnected the battery and now...
- Cam belt change
- Uneven front pad wear
- :: ECS Tuning :: B6 A4 B&M Short Shift Kit - Limited Numbers !!!
- 02 b6 A4 aftermarket suspensions?
- when is fast enough fast enough?
- Low RPM flutter
- Gas Gauge Problema
- UPDATE: Front suspension upper strut hard mount design and manufacturing (long)...
- JP Viz Lower Front Lip Spoiler
- Battery Help 02 AudiA4 fwd
- ECON Air button won't turn off
- pass window motor dont work? help!!!
- Daytime Running Lights for Audi A4 B6
- Strange startup sound/noise
- Engine computer numbers
- 3.0 v 1.8 oil change
- Enkei EKM3....
- A4 misfiring, shaking... fuel filter??HELP!
- Throwing Code P0171 System Too Lean (bank 1) - any suggestions?
- P0741 - 17125 - Torque Converter Clutch Circuit Performance or Stuck Off.
- Passenger Seat Stuck
- How in the World do you remove the hoses from the coolant flange?! OMFG!
- Received back from STaSIS today my MS suspension and we are starting the…
- Is there a drain plug in the coolant holding tank?
- Best A4 Wagon to modify
- Windshield washer hose broke - oh noes!
- Europrice - Website Updates + New products...
- SPECIAL $999 Shipped, Flashpoint Wheels for your Audi. Ends soon!
- New rotors
- finally got my car back
- epc... soft limp mode....
- High-flow cat on CL
- Which timing belt kit....
- Sway Bar?
- 02 A4 3.0 Timing Belt Failed!
- Sick B5+ pictures!
- F1 Racing Stage 1 clutch kit by Gripforce
- Manual Transmisssion Rear Seal Leak
- :: ECS Tuning :: OEM Audi Parts Database Search - Now Live !!!
- Attn: APR .....Exhaust Delays
- B pillar rattle
- Doing TRE's on a 2003 1.8t this weekend...
- Broken Glove Box Door
- broken dip stick
- Help Still engine problems
- FSD in Nashville
- Please Help: Connector Locations 03 A4
- what is the difference in exhaust...
- Frustrating locking configuration
- Battery Replacement
- Has anyone here had a problem with ...
- whining noise coming from rear part of the car, in between the rear wheels
- Power steering pump replacement 3.0....
- abs sensor
- :: ECS Tuning :: New Website Now LIVE !!!
- B6 shock replacement &Control arm pinch bolt removal
- Low Boost/Losing power in the rain
- Eibach Pro Springs/OEM Sport Struts?
- Outside Air Temp Sensor (G17) pictures?
- Any idea where this goes?
- CEL Codes - your thoughts . . .
- Car revving to 2K RPM while idle, why????
- Motor oil in 3 of 4 coil pack chambers. Please adivse
- Car is still Not Boosting ....running like a Civic...need advise.
- Here are the final specs for my CP piston order...
- Trouble Codes
- Eyebrow and Eyelid kits
- Buh bye.
- anyone have an ultrasport steering wheel?
- 04 Ultrasport Avant pics...
- Cool things down and make more power!
- Boosty went away..running on limp mode...No CEL warning on dash..what happened?
- Pending Coil Pack Failure?
- Vlave cover gasket sealant
- Finding Coolant Temperature Sensor (A4)
- How to post in classified
- Daytime running lights - newbie, please help!
- Dipped Headlight
- Bearing noise?
- CVT Service, Check Engine Light ON
- New Here!
- 2002 A4 1.8 Need OEM Exhaust -Where to buy from?
- Power loss, Shakes and low RPM (2005 1.8T)
- ross-tech
- 2005 A4 1.8T Manual Transmision
- Temperature Guage?
- Replaced Cat - P0420 returns. Now What?
- after changing my spark plugs
- oil pressure light still!!
- CVT Swap?
- Anyone parting out a B6 A4?
- Key Fob and Noise & Radio Pause Button?
- noise in gear at partial throttle?
- twitter.com/mybrokenaudi : My new experiment
- Performance Cats needed for 3.0
- Emissions Warranty?
- Carpet Wet again Help!!!!
- breakable a4 body parts-- you know the ones that always break.
- Thinking about buying a 2002 audi with 26kkm on it (2009)
- FMIC --trouble with Califonia smog?
- Convertible Emergency Key - Where to Buy
- 23% vs. 35% tint
- :: ECS Tuning :: B6 A4 1.8T Maintenance Products and Service Kits
- shuddering sound when closing the sunroof
- Overstock TRE Sale!
- Wheel fitment
- Wheel fitment
- Four beeps from back seat?
- Broken driver's side mirror post
- A4 vs passat
- 04 S4 Avant subwoofer
- Engine Surging
- 3.0 manifold change over
- Help: Engine shut off while idling, battery light on
- intercooler fan thermostat setting?
- Emission Light appeared on Dashboard
- CEL showed up but car runs fine, why?
- Audi wiper arm removal hell
- ABT replica pedal cover for Triptronic cars
- HELP!!! Just changed fuel filter and wont start...
- Koni FSD's, new control arm kit installed
- rear piston came out far along with brake fluid
- Can't remove my exterior door handle - HELP Please
- Code PO341: sensor or more? need advice
- b6 with 35% tint
- Quick update on the suspension upgrade I'm getting done by STaSIS...
- fuse for dome lights.
- How to fix ghosting sunroof (DYI)?
- *Announcing Revo Techniks Forum Member Discount*
- Car is having Koni FSD put on, other issues found
- B6 A4 Starting problem
- Billboards War: BMW vs. Audi (sorry if repost)
- Gonna buy an Audi, & have some questions.
- Oil Sensor Light
- Ridiculous price (CDN) for painting or not?
- Need Radio code 04 Audi A4
- PARTING OUT 2003 A4 1.8T Quattro B6
- Bad Cat Test Procedure Help...
- Factory or Thule/Yakima Roof Rack?
- Mountain Bike Racks
- Part numbers needed...
- Interesting misfires after rebuild
- WARRANTY HELP
- 80K miles
- Looking for a damaged Headlight for A4...
- Looking for some opinions on mixing tire tread patterns
- Windshield washer fluid leaking...
- News Flash: Wustefest 2009 Is Latest Bailout!
- Wheel and Tire Setup
- Leaking Steering Rack
- Change the colour?
- 04' A4 3.0 needs a new catalytic convertor... any good aftermarket options?
- basslink install
- Reoccuring Air Bag MIL Help.
- Technical Articles
- ECT replaced , , , now what?
- Advice on new rims
- Oil Sludge?
- my new remotes will not program! 04 cabriolet
- 1.8t Quattro and Forge Splitter Valve
- Haven't been here in ages so can someone tell me where to ge cheap coilpacks?
- will a cvt from a 3.0 fit a 1.8?????
- Lost oil filler cap - need short term fix
- Looking for B6 6 spoke wheel center caps...tire shop broke my clips
- Best place to sell 2005 A4
- what does your PSI read on your boost gauge?
- Size of stock sport front sway bar???
- Size of front sport sway bar???
- Holy sh!t! I never knew it was going to be that expensive of a project...
- where to buy HID's
- 16" Pirelli P6 Four Seasons - wore out in 12k
- battery cable
- When an unstoppable force meets an immovable object...
- B6 Gearbox mount replacement?
- Spring engine cleaning
- Seat drawers
- low engine oil, '03 A4 1.8T w/ 65k miles
- 60k service ('03)
- need a pointer/body work
- USP suspension, stock B6 sport suspension or stock B6 S4 suspension???
- Were are the good prices for suspension and brake parts?
- Burned out rear brake light...is this a DIY project?
- Dipped Bulb sensor??
- Fornt end Clunk
- 2002 Amber turn signal bulb: where to buy?
- humming noise... wheel bearing?
- DV part# question.
- Need used Antenna Amplifier for 2002 A4
- Coil Pack Replacement
- APR stage 1+ by itself, NO DMIC or exhaust
- real xenon fog light bulbs, anyone try these?
- vacuum leak
- Conflicting info on the TT225 injectors...
- Coolant Fans Killing Battery fun with car off
- Seeking spark plug recommendations...
- engine filthy
- why is my 0-60 time is so slow..
- Updated Europrice Sale - STaSIS Engineering Parts 10-15% off...
- taking a4 front seats out
- APR I+ (bosch TT 225 injectors or genesis 380)
- Has anyone ever replaced a accelerator position sensor?????
- Need to tow 2 jetskis with my 1.8TQ.... :) I need torque!!!
- Random EPC + Traction + CEL all together and limited boost....
- gas the pump constantly stops
- Some punk took the trim / cover off of my door handle
- Potential audi owner
- part number ECU
- Latest update on the car's engine components being used in the build...
- i have a ghost in my 3,0
- New Stern Pro-Mount Motor Mount Presale Ends Today!
