- Help, please
- Weird temperature gauge behaviour when turning
- A4 Quattro Hard Shift
- Interesting Clutch Issue
- Tow bar electric killing cars electrics
- 2002 audi a4 3.0 b6 catalytic converter
- Just got an 02 A4 1.8t
- Engine froze while driving
- Check engine light, help plz
- Cooling Problems 2002
- Intercooler piping
- Windshield wiper blade conversion to beam - worth it?
- Seeking B6 automatic transmission Rebuild kit suppliers
- P1293 - 2006 A4 Cabrio
- Need Help with electrical
- Front brake pad wear and hot brake smell
- No start,No CEL A4 3.0
- Headlight alarm when left on
- Took off cylinder heat, Oil In Coolant holes even though I took off the radiator and
- ECT sensor clip replacement - near back of engine
- Do 2006 Audi 2.0t have ICM?
- audi a4 b6 engine swap project cheap
- new buyer and ease of maintenance
- Box of Unknowns
- Audi A4 B6 Trip Computer 2, How to get it?
- Burning smell from brakes
- 2003 audi a4 quattro base 3.0 by upper oil pan replacement
- Mobility vehicle- Not for Retail sale
- rearview mirror disc stuck
- Lower grill
- Special Vacuum Connector - How To Release?
- Which B6 model to consider?
- audi a5 8t coupe lock unlock key fob problem
- CECM - Connector C T32b (pin 18)
- instrument cluster error
- 2008 A4 2.0t
- No start. Electrical issue. Please help.
- Thanks to Marty at Raxles
- advice on replacing the trunk lid gasket/weather stripping
- Pedal not working?
- A4 avant automatic - gearbox issue?
- 2003 A4 Quattro Transmission Issue/s..
- A4 2003 Quattro Transmission issue
- Audi a4 b6 2l ALT rough cold start
- Glove Box catch/linkage/rod arm?
- Audi A4 - What is this tube??
- Need some help?? 2004 AUDI A4 QUATTRO 3.0
- 2004 A4 no head lights, turn signals, wipers, brake lights
- 1.8T Error codes *Please Help*
- 1.8T Headgasket
- AC compressor replaced; cold air again
- AC Not draining
- Alignment Camber issue
- B6 1.8t 6-speed Manual issue
- Long cranking when hot or first start of a day
- Window Regulator issues Front Driver Door
- A4 B6 Comfort Control Module change because of New seats?
- 2004 Audi A4 Quattro 1.8t clutch line issue
- Hard Start (2002 A4 B6)
- 3.0 V6 Quattro intake Flap
- Gearbox change
- Noob auto transmission question
- Is an S4 M/T swap doable?
- Window issues
- 2005 Cabriolet: most of dash is dead, starts then stops, top will not retract
- Issues with central locking/alarm
- Manual Seat Swap To S line Seats
- swapped steering wheel issue
- Audi A4 1.8T B6 Map / boost sensor wiring help
- A4 Key fob 2018
- 2001 A4 Quattro
- Random Misfire Help
- Need a hitch: help help
- p0420, p1479, p0411 Thinking it is all related
- 2001 A4 Quattro 2.8l: electrical ?
- Coolant liquid levels
- Am I experiencing Gearbox or Turbo issues?
- Groaning bushings
- Car wouldn't stop, ABS, and Vag Com Tool
- 2002 Audi A4 V6, water damage, couple of questions
- Trouble taking off after reverse
- Much needed Advice - Pay to Fix or Sell?
- $50 off ECS Engine Street Shields + Free Shipping
- From BMW To Audi
- Servo pulley position
- Audi rims...
- secondary air pump problem
- Engine rough idle - EGR code and EVAP failure
- Econ mode stuck - G65 sensor are changed
- DASH TRIM REMOVAL - 2004 A4 B6 Cabriolet
- 2003 Won't start! HELP! HELP!
- Is a ‘02 A6 Avant worth $2500?
- 2003 Audi A4 3.0 V6 EPC Light....Need HELP! PLEASE!
- 2006 A4 2.8 Cabrio - AC troubleshooting
- Help! Need access to VAGCOM
- 2002 3.0 Threw timing belt. Rebuilding heads.
- Charging system fail!!! Please help
- Vacume line disconnected
- 03 a4 3.0 Quattro
- Can't Open Avant Hatch
- Body control module
- Siren installation
- Fuel tank innards fell apart?
- Audi A4 2.4l -02 shaking on idle
- Problem with AC
- Triptronic and reverse
- WANTED: 18" ULTRASPORT RIMS for A4 B6
- A4 B6 3.0 exhaust
- AC not working (04)
- Steering column/shaft slop
- Base Suspension To Sport Swap Possible?
- Need help figuring out this particular part sputtering oil
- no electricity on the locker-side door at the driver's side.
- RNS-E upgrade
- CV issues. Please help!
- Alarm not working
- Transmission “issues” in the making
- What is this sensor/light?
- 04. A4 quattro damaged transmission pan repair
- Wiring questions.
- Overheating
- No idea what type of windshield wiper I need
- Vagcom errors
- Problems with my A4 B6 electronics
- A bucket load of faults... Any ideas??
- boost issue
- Heater on ECON
- Shouldn't be able to turn the connector on the VVT solenoid right?
- Question for Lower door blade mouldings
- stuck on a head job (any advice greatly appreciated
- Wondering what this piece/part is
- 6K for key replacement?!
- Locked out of my trunk... almost
- Tiptronic Transmission Issue
- Coolant issues
- ECON Button Staying On & Engine is producing loud sound
- Coolant Issue, any help appreciated!
- pcv hose behind intake - replacement??
- Bad Turbo?
- A4 obd2 scanned
- Audi A4 quattro 1.8t tiptronic won't shift out of first gear
- Is it really my ac blower motor?
- Turbo boost issue
- Quick bent valves questions
- S5 B8 seats in A4 B6
- Cooling
- 2003 3.0 fuse box/electrical question
- Would you change this timing belt?
- a4 cooling system issue
- Only warm air from the vents!
- whinning noise on gearbox
- Driving without cps?
- Timing out or not?
- HELP! Passenger AXEL Install Problems
- 2003 Audi A4 Quattro. All Cylinder Misfires, P0300 as well. P0171
- CEL P0102 MAF mass air flow sensor, now CEL is off
- #3 Misfire.........
- Engine swap
- Transmission doesnt engadge
- Key Fob Battery Replacement Not Working
- Help guys! newbie`s Audi a4 b6 1.9 TDI problem
- Headlight replacement bulb
- 2003 Audi A4 1.8T Stars and dies
- Rear fog lights
- lift kit b6-b7 ?
- 2005 S Line Steering Rack Issues
- BEX Engine Gearbox
- Ye Ubiquitous Coolant Flange
- Recommended obd scanner
- Sudden misfires while driving, now it wont start?
- Fans coming on. Suspect relay 219. Change my mind...
- Usa style parking lights
- Driver's window switch acting up
- Bad sound
- Cilmacontrol
- Bizarre fuel gauge behavior
- Codigo de la manguera? please
- 0122 fault
- MANGUERAS DE ENFRIAMIENTO CODIGO???? Ayuda
- 3.0 ASN Timing replacement without cam lock tool
- P0688 Audi A4 1.8t B6
- 2002 A4 Broke for no reason (immobilizer issue)
- Blow of valve
- Car died on highway and wont start
- Getting started on a project, engine/trans work.
- CD player/Radio not working
- Gaming my SAI to the ECU.
- 2002 A4 Avant help
- Automatic transmission Ok? 04 A4 1.8T Quattro
- Helicopter sound
- BG: стрелката на горивото
- Semi clogged heater core
- 2002 A4 speedo questions.
- All of a sudden...
- fuel pump isn't kicking on and it sounds like the control module is straining
- PRV Bad?
- Not blowing air
- Need help finding a part for CEL - p0411
- 2002 1.9 tdi 96kw oil leak help needed!!
- A4 P0340 CamShaftPositionSensor Replacement
- 2003 Audi A4 cv axle Help !!!
- AM and FM no sound, but sound on CD and satellite - any ideas?
- Mass air flow sensor testing
- Cold start engine noise
- Code p0688 not start
- Rodentia
- Replacing Headlight assemblies on wifes car - options?
- PROBLEM WITH FUEL LEVEL
- Too Lean CEL Codes
- B6 AVant 500hp club ❤️
- AC Stop Working and Car start overheating
- Replaced fan relay 219 but problem not fixed
- Cam adjuster removal on ALT 2.0 20V engine
- FEELS LIKE I HAVE A FLAT TIRE BUT DON'T
- This forum is almost on life support
- Possibly threw off timing
- AC not blowing hot or cold air
- Perfect coffee travel mug for Hubby's B6?
- INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
- Today Only! Solo-Werks Coilovers 10% off + $50 Rebate + Free Shipping
- Tuned AK eco in a 2002
- Something is missing?
- Problems after disconnecting battery. ( car wont drive)
- New hydraulic timing tensioner won’t fit?
- HEAD GASKET(?) (COST/WHAT TO BUY)
- CHECK ENGINE LIGHT & ESP !!!!
- Dual mass flywheel seporation, what clutch kit to get
- Threw timing belt. how do i check for damage to rods, crankshaft etc.
- Garden hose for vacuum hose
- Lower valance replacement ‘03 doesn’t match6
- COOLANT ?
- Audi automatic displaying "Press clutch to start"
- Alarm goes off when disconnecting the main battery (to clean water drain holes)
- Fuel Tank Removal
- Exhaust bi-pass valve or back box delete - droning !?
- 10% Off ECS Fiber Mirror Caps
- Heated Seat Issue
- 05 Audi A4 Quattro 1.8T(6 Speed Manual) shifter got wobbly and only takes 3rd and 4th
- Both rear doors won't open from the inside or outside
- billy boat downpipe options
- Wiper washer only modification
- 5 codes
- Help.Loss of power and rattling noise.
- Rattling noise front left insanity
- Hood stuck due to broken cable
- Can Anyone Identify This Part??
- How to tell if water pump is bad
- Manual Key or Fob not working!
- Cold engine starting problems 2.5 tdi 132kw
