- A4 Tie rod help
- Blowing Washer Fuse
- Coilover adjust to lift or lower ratio
- Will it be any problems with the Ecu when changing engine replaceing engine 1.9tdi
- What are a4 b6 brake shield bolts?
- 2005 1.8t Starting problems, ignition locking, clutch light on
- Oem wheels
- ticking noise in engine quattro A-6
- Headlight
- A3 Difference between Window Motor 8P0959801L and 8PO959801E
- "whump" from exhaust
- Radiator cooling fan size
- in need of full workshop manual 2004 a4 b6 1.8T download
- Help! Help!
- Audi A4 Clutch issues
- Topping off with PentofrostSF
- operating temp
- No Compression Cylinder 2 Yikes
- AMB CYLINDERS. 1.8t
- 2006 a4 Electrical DISASTER
- A4 B6 quattro 1.8T knocking noise from below
- creaking when turing steering wheel
- getAudiparts.com | Genuine Audi Collection Key Rings!
- CEL: MAF and P0300 (missfiring) but car runs smooth
- Audi B6 S4 Airbag Resistor
- Which antenna adapter do I need?
- Coil pack harness power all the time
- CD Error
- Help should i be worried?
- Advice on B6 3.0 Performance Chip
- AMB 1.8t no power windows, wipers, turn signals or horn
- Audi A4 B6(1.8T) overheating when driving slow or stopped.
- 1.8t literally flipped out when OBDii reader plugged in
- Sale 10% on Powerstop brakes!
- Thermostat replacement now misfires
- Would you buy this?
- Audi a4 2.0t drive shaft issue maybe
- Traction Control Issue?
- 3rd brake light plug/wiring
- A4 B6 very high frequency squeal/squeak
- PRND lights
- Keyless Remote Issue
- Going for ECU map and 35mm drop.
- 03 3.0L v6 sounds like diesel motor
- Rising and falling coolant level?
- Audi alternator 150 amp, but Passat 90 amp
- Bad gas mileage and smell of burning coolant
- Clicking/tapping from under valve cover 2002 A4 b6 3.0
- Oil Service | Oil Change | SALE save 10% for a limited time!
- First Audi - First Lit Up Dash
- Head gasket question
- A4 Cabriolet Fuel Tank Removal
- Poll:. How did you fix your p0011 code?
- OVERSTOCK SALE! Select Milltek Sport Exhaust on Limited Quantity Sale!
- ARP Performance Fasteners 10% off! FLASH SALE
- 1998 a4 quattro tcm wiring harness diagram?
- 04 Audi A4 1.8t did Audi up-grade or change the water pump design
- transmission code
- 2004 Audi A4 1.8t timing belt kit
- mifiring
- FLASH SALE 10% Off ECS Billet Aluminum Shift Knobs
- FLASH SALE! Street Shield Skid Plates 15% off + FREE SHIPPING
- HID unit - didn't know till light stopped working now...
- SALE GSP Replacement Parts | up to 15% off | Wheel Bearings, Axles, Loaded Struts
- Yes, you read correctly! We now have footwell LEDs for every single Audi model/trim o
- Flash SALE! Cooling Refresh! | #dontoverheat
- Pioneer AVIC 6000NEX GPS DVD car stereo w/audi A4 adapters - $400
- A4 stall/lunge at or near stop
- air bag problem
- Aftermarket Intercooler Kits A4 B6 1.8T
- Ma' Beloved AUDI A4 - Engine Management Light not working :-(
- Oil Pan bolt trouble
- Car Dies While Driving
- SALE SALE SALE!! JOM and FK Colilovers $350 SHIPPED
- Using A 1.8T In A Hot Rod
- '03 A4 3.0L QUATTRO - ERROR CODES P0501 & P0741...ARE THESE RELATED?
- Part number for plug where you insert the crankshaft locking tool b6 3.0
- Car won’t start after battery charge
- Audi A4 2005 3.0FWD (How do you diagnosed the vacuum activator?
- 04 A4 3.0: oil pump/pickup pipe removal tutorial instructions
- No sound
- Trasnsmission range sensor
- Best performance exhaust system for my 3.0 B6 A4 Quattro???
- Instrument cluster
- Soon to be blown head gasket..
- Fuel Flow indication erratic
- 2004 B6 3.0L P0321 & P0322 Codes +..
- 05 A4 1.8T Q brake lights on tail light problem
- H & R lowering springs, are they any good, even drop?
- window regulator a4 2001 b6 - rear right window reset auto up down and final position
- Engine Replacement
- help 2003 by a4 1.8t wont start
- Headlights on all the time
- Need some help identifying these wheels
- Upgrade wheels
- NEED HELP 2003 Audi A4 1.8 t WONT START !
- BOV Help!!!
- WIPER RELAY LOCATION
- Exhaust Discovery & Options
- Bremmen B6 Android Radios 10% off plus Free Shipping!
- SALE ALERT! Racingline 10% OFF
- Q5 High RPM's Going Downhill
- Right tail light color and thicknes
- 03 A4 1.8t
- front fender compatibility with passat and other problem
- Minimum Pressure not reached - sporadic 16683/P0299
- 10% off 42 Draft Designs | Exhaust, Adapters, Intakes, Catch Cans, and More
- AU: ANOTHER!! (B6) a4 1.8t crank no spark!!
- Key key fob can resync but after car is driven is isnt synced anymore?
- Flash SALE! Solo-Werks Coilovers 10% off + Free Shipping
- CVT tranny swap code match
- A4 B6 1.8T misfire when cold till temp reaches 80degrees
- Hard Start, Long crank time
- 2003 A4 3.0 Quattro automatic transmission trouble.
- 6 bolt steering wheel hub??
- Hello my name is Edgar I bought a Audi a4 b6 2003 and don’t make turn signal for bot
- S line or not?
- Need help from AC expert
- SWitching from park without brakes
- RPM Fluctuating at IDLE when AC is Off
- Rear differential centre bolt problem
- window & interior light
- Issues with coolant
- Where to buy driver side rear seat lever for 2003 a4 avant?
- UK: Rare A4 B6? With a CVT Fault?
- Audi A4 Convertible & Trunk switches dont work
- Mileage range doesn’t work
- s4 b7 starter issue
- 04 A4 oil leak: Smoke Right Side Firewall
- Maxton Design select FLASH SALE 15% off until 6/29/2018
- High beam light dont work
- Audi A4 1.8t air sucking from oil filler
- Is the 2.0T Stage 2 coil pack conversion worth it?
- New Alzor Wheel Styles! Starting at $499.95 a set!
- Gear selector poss probs
- Audi A4 1.8t need help please!
- Audi A4 1.8t B6 2004
- Mysterious rotor warping
- genuine Audi parts ON SALE!!!
- garage door opener not linking in any way
- ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
- 2003 A4 media/navigation system issues..
- 2003 Audi A4 Quattro navigation system /radio FOR SALE
- Best brand for cam chain tensioner replacement
- Need of Audi A4 B6 2003 Manual
- FLASH SALE -- Lightweight Flywheel + Performance Clutch
- no A/C
- Transmission in Limp Mode, OBD2 Not working
- 2004 Audi A4 front lower valence not fitting up.
- 2004 1.8T Quattro, Speedometer not working, Odometer OK?
- Coolant fans run even when the cars off
- Audi A4 B6 2.0 ALT Body control module issues
- Central locking
- Low oil pressure after clutch install
- My b6 sputters when building boost and then misfires at 4K.
- Oil sensor turns on and off
- Where can I get a replacement for my instrument panel screen ?
- Foot well light on drivers door out
- I got a 02 a4 v6 3.0l
- X-post: 18" BBS RS-GT Diamond Black Wheels in Marketplace
- Car wont start
- transmission problems audi a4 2.5tdi auto
- 03 a4 1.8t low fuel pressure
- Battery drain, removed cigarette lighter fuse & all is good.
- Brake booster question
- Spark plug reccomendation for 2.0T Coil Pack Conversion Kit.
- Oil Service Tool Sale! 25% off!
- Wheel Skip When Turning
- Coolant fan problems
- A4 B6 Avant 2002 1.6L Service Manual
- Battery help
- Street Shields Skid Plates on Sale! Free Shipping + 15% off!@!@#@!
- 1.8t GT2860R upgrade shopping list and help
- GFB diverter valve... ?
- Introducing ECS V4 Performance Brake Rotors | Free Shipping
- A4 B6 & A6 C5 Diff Compatibility
- After shifting to second, let of the clutch and hit the gas and it kicks it into neut
- Help with an electrical nightmare
- Lowering car near Stratford upon Avon
- FLASH SALE 25% off Schwaben Scan Tools + FREE SHIPPING
- Audi A4 rear mirror fell off
- fuel pump or just fuel filter
- A4 b6 driver door anomalies
- Bought Audi 2 days ago... broke down in limp mode
- 2006 A4 Cabrio 1.8T smoking
- 2005,1.8t,high idle,occassional whistling
- 2005,1.8t
- Driver Information System goes blank
- 2012 A4 avant loosing coolant
- 1.8 timing belt install question
- Sometimes it starts, sometimes it doesn't
- B6 Lower Front Bumper Lip Colour Match?
- Low Oil Pressure then Miss-fire problem Help?
- Center drink holder question
- Looking to buy performance exhaust system for my a4 b6 1.8t Quattro.
- Gas starvation with 2+ gallons remaining - a new thing
- Cylinder Order
- The ECS Memorial Day Sale starts NOW!!! up to 25% off your favorite brands!
- Facing problem of P0421 and P0431
- Exhaust interchangeable between manual A4 sedan and automatic A4 avant?
- FLASH SALE!! up to 15% off Cooling Refresh Kits
- Non return vale position
- High vibration at idle - is my MAF bad?
- B5 TDI 6-Speed Swap Into a B6
- Air Con
- Audi A4B6 Radio
- Headlight won't work. Bulb changed
- Coolant system performance code
- Audi q7 2007 4.2l fsi
- abs code 00526
- Looking at buying a used a4, could use some "Audi folks" input
- Running rough when warm and going up hill.
- Loud groaning when steering on full lock
- AIR CON does it just need topping up?
- is there a way to rig the hood latch sensor so it will appear as if it was closed?
- 3.0 Unknown Issue
- ABS 01200 fault code please help
- FLASH SALE! Maxton Design Exterior Upgrades 15% OFF!!! Today and Tomorrow ONLY
- Exterior trim name
- New! ECS Billet Aluminum Shift Knobs | Black Red Blue Natural Billet Finishes
- 2004 1.8 Coolant Fans Not Working...
- How to Really complicate your life!
- B6 3.0 Quattro misfire problems
- Big Brake Kits: How big is too big?
- Can I disable the warning chime?
- CVT - transmission range sensor F125 - code 17090 P0706 , location
- Changing the A/C Compressor
- My radio reception keeps cutting out on my Audi Q5 2014 model
- Traction Light, Abs light and Engine Oil Light intermittent flashes
- 3 days only ECS Silicone Turbo Inlet Hose 10% off
- swap from a 3.0 to a 3.2 in a A4 both 2005s?
- Audi A4 Quattro 2003
- FCM fail ? 2002 A4 B6
- Buy a B6 A4 aFe intake and get a Free Gift!
- Oil Leak Assistance!! Newbie!
- COOLANT Leak
- Fault codes, please help! P0345, P0346, P0365, P0011, P0014, P0021, P0300
- No keys, help!
- I have a coolant leak in my 05 a4. Part name??
- Brighter D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs
- a4 b6 3.0 crank timing not matching cams
- scanner does not recognize computer 04 audi a4 convertible 3.0
- Timing chain
- Audi Q5 2011 model transmission control unit
- On Sale Neuspeed Performance Upgrades
- Leaking from pipe above engine
- Stock exhaust diameter size before split
- FLASH SALE Up To 15% on Timing Chain and Belt Kits
