- Rotor removal
- What's your fav mod. Wheels are Turbo upgrade?
- I'm contemplating buying eyelids for my car...
- When buying a pre-owned car get the service report... here's all the service codes!
- stranded connector under the dash.. where does this thing go? Pic included
- Hmm, didn't realize the blades are approx $350 + shipping. Not sure I like them THAT much :)
- My '02 1.8TQMS for sale in the classifieds
- Carson at Riverside: Pricing on S4 blades? :) :)
- Two exhaust questions, one Milltek specific...
- New B6/B7 Sway Bar Kit From Hotchkis Sport Susp.
- PDXA4: Shoot me an email w/ pricing for your S4 blades.
- Hitch or roof rack for the Avant?
- Is anybody looking to sell a set of 18" RS4/ Ultrasport wheels? I'm looking for a used set
- Problem with vacuum lines?
- Classifieds doesn't have a "want to buy" section. Is it okay to post what I'm looking for?
- damn - found a rust spot on DS door at the front edge just above the door blade...
- Will a bad cam position sensor always throw a code?
- yay...fixed my front pass. window regulator last week and now my driver's side is dead...
- i replaced my front window regulator. works fine but it clicks once slightly only on the way down
- bah now the car won't start everytime, acts like the immobilizer shuts it down but no lights
- Brake Pad Wear Alarm Question - How does it work?
- Engine Oil Poll for 3.0 owners: Dino or Synthetic? What brand? Weight? What is you current milage?
- Review of Koni FSD/Eibach springs suspension
- PureMS still the best place to get S4 blades from?
- Spring Rate Help for Vogtland Coilovers...
- big ups to MC Hammered for his B6/B7 A4/S4 1st place!
- Alloy wheel repair
- Engine Noise
- Ran output tests in vagcom for auto hvac, fans didn't come on with j293 test?
- Part number needed for left rear window regulator green carrier thingy :)
- Anyone have 1 or 2 OEM sport rims they'd sell me for cheap? Few of mine have curb marks/scrapes
- Has anyone bought from jjbumpers.com?
- 03 A4 1.8T or 03 A6 3.0
- Finally...many months of waiting for these to arrive, look what brown dropped off =D
- Damn, driving a (lightly) modified car has made me a lot more paranoid then I thought...
- Does anyone here use erWin?
- Question for Dahlback people
- Insurance just called and said....
- Delighted to report my 6 year old bus passed her MOT with 99457 on the clock :-))
- Good Price on a B6 Avant 3.0?
- Poll: Easy on your car, normal, or hard on your car?
- Blown Turbo...Now Serious Coolant leak.......car is becoming really costly to fix every month.......
- Is there a fix for brake rattle?
- LOL, doesn't look like Audi got it right with the C6 A6 buttons...
- Pricing for timing belt/water pump/tensioner
- 3 days to clean the wheels + 4 hours to detail the inside of the car + 2 hours outside = ???
- 2004 A4 Brakes & Rotors
- S4 rear....Do these prices seem right?
- Flashing Check Engine light!
- Second Gear
- will 300mm S4 rears fit under 16s?
- Mother f*cker, finally found the problem, broken water pump!!!! BUT.....
- Instrument cluster removal and clean up..........DIY
- Front brake caliper seal replacement/rebuild....DIY
- my friends 1.8t B6 is overheating under load, but not at idle. any ideas??
- Got new tires, quiet, but terrible performance, all UHP all season suggestions in 235/45/17?
- What's the best way to drain the master cylinder reservoir?
- So are there any rumors about #'s regarding ASP's Stage 3 for our cars?
- oil light
- Anyone using Hawk HPS front pads with wear sensors experience this issue?
- Anyone ever replace or cover/line the center console to deal with peeling? If replacement range of $
- Why are my control arms hitting my springs??
- More problems!! Check engine & EPC light came on with loss of power - plugs??
- how much do average RS4 reps 18"x9" weigh ?....thanks
- Eclipse 5510
- DYNO EVENT @ VAGKRAFT NOW $40 - BROUGHT TO YOU BY PFAFF TUNING!
- need to replace the vacuum hose going into my intake manifold
- cant figure out how to use the memory
- After 4 years of driving with stock xenons, people are starting to highbeam me.
- How do I remove the wheel well cover??
- Should I get an 03 A4???
- UPDATE # 6. Symo-Sport's installation of the oil coolers for motor and power steering part 2...
- Are teweeter covers in the rear doors/dash board available alone or part of door panels?
- What do you guys think of the TT FWD for the girlfriend?
- 2003 A4 Avant 1.8t. Used purchase ????????
- Can a Timing Belt job do a 17939 error?
- Customer of mine has a high mileage 2000 A8 2.8
- Intercooler BT: will the dual intercoolers from a 225TT fit our A4s?
- I just installed the car mount for my iPhone. Here are some pics...
- Rear shock update, OEM sport springs w/ new shocks.......more...
- FVCK! Someone stole my custom ultrasport/S4 lower grille...
- Seeing that I'm in my PW mood today, check out this POS that I see parked semi-frequently not far...
- How do you adjust front camber? Buddy's alignment shop couldn't figure it out
- Looking for OEM sport suspension part numbers
- I'm bored + my cell takes acceptable pics + has 2GB of memory to waste. = useless posting...
- Poll: For how much longer are you planning to keep your B6?
- Brocken k04 Turbo seems to be coming back to life...Is that possible???..........
- Dust in instrument cluster....anybody ever open one of those?
- Seting up the alarm on the flip key.
- owners manual
- Lysol is great for cleaning ac vent stink
- HID Lights
- 2004 A4 Ultrasport Grills
- anyone know where the a/c low pressure switch is on a 97 Audi A4 2.8?
- Short review of Carbotech Bobcat brake pads (Stoptech 332mm BBK)...
- 2003 A4 Key immobilizer
- CEL after Forge Tip Install
- Issues..
- RPMs go up but no acceleration and no speed - is the my turbo dead?? HELP!!
- Working on a B6 coolant leak/oil leak.
- Driveshaft
- b6 s4 wheels
- Lower Parking Brake Trim - How do I get this bugger off?
- Best place to get a timing belt kit in Socal? Need it fast!
- Avalon Motorsports.... Event sponsor for Dubs Along the Rockies 2007--->
- Who here with an 03 had the Fuel Pump recall done
- anyone used ebay aftermarket window switch?
- need help just pulled these codes on buddies car. what do you all think????
- Who sells a DSMIC kit besides Greedspeed?
- Am I the only person in the world that likes ALL low profile tires @ 40psi cold f/r for street?
- 1.8T...Engine has lack of power/pickup...ideas?
- H&R camber bolt sizes needed. do I even need them?
- So what should I keep when I sell my Audi....
- quick question will my buddies KEY-USB Interface vag-com work on my car or do i need a differnet one
- Pics from the Avant's first bike trip
- How healthy are my plugs?
- best place to pick up power steering fluid? dealer?
- what have you found when changing an air filter?
- Trouble with Tiptronic Shifting (CVT)
- Stripped screw in grab handle - best way to get it out?
- Update to my "ABS and ESP light coming on simultaneously" problem.
- window frame: i found 4 t45 torx on the front and 5 on the rear, frame still barely budged
- Product Review: HV rust proofing gun
- Audi A4 TDI I only wish they would bring these to the US with
- Where is BOSE Center Speaker Connection
- Rotors Size
- Paging tlcole70....
- X-Post from AWNE: Summer GTG!!! Tuesday August 7th @ Ken's Steakhouse, Route 9 Framingham, MA
- Squeaking when going over bumps
- Getting the wheels ready for Waterwagens! (56k go away!)
- Waterfest 13 Gallery is live!
- Changed Cam Chain Tensioner... Almost All Oil Lost After 2-3 minutes of engine running...
- My cars from Florida. do I need undercoating in the NE?
- OBD and emission inspection, please help!
- Check out This Ride!
- Poll: Are the larger tailpipes a 2003 Quattro thing or an all model 2004 thing?
- Paging Tgr_Clw
- Looking for pics of RS4 reps on a ming blue A4
- Should I buy 2002 Audi a4 1.8TQ for $3000 with siezed engine?
- Anyone go to H2O in OC MD in September?
- Need some help with diagnosis
- Finally got around to cleaning my undercarriage...
- Waterfest was good to my car and bad to my wallet...
- After a recent roadtrip took a few pics at the Salt Flats
- Drain plug to be replaced with every oil change? Washer doesn't appear to be crush type...
- Miltek exhaust owners, other tips fitment
- Anyone notice huge drag and harder take offs w/ 1.8 turbo quattro 5spd w/ A/C on
- You guys seen this?
- Repair Shop just called me about my car....k04 Turbo is Dead...*sigh*.........
- 2Q's: How wide can the wheels be on a OEM car? Is there anyway to know if you have a OEM S4 rear
- traded in my B6 A4 ... got some freebies.
- anyone have ETKA diagram of the front bellypan area?
- what do you guys think is better B5 s4 front brakes or b6 a4 3.0
- those with oettinger fronts, could you post some photos>?
- Anyone have an ETKA diagram of the rear suspension assy?
- akebono brakes
- Life Expectancy of Turbo in 18.t?
- X1Rider.........I owe you some VAG tool data logs......
- APR Stage 1+ vs GIAC FXK03....opinions?
- does b7 heater controls fit b6
- front passenger side window 1-touch up is not working from driver side controls...anyone have simila
- Paging Audi Junkie....How does Penzoil Platinum compare to Mobil 1?
- pulled code out of my car today it was 17697 over run valve turbo N249
- 3.0 coolant temp sensor replacement help?
- Any respected/reliable independent audi service in
- How much is the window track?
- Lower B-Pillar Trim. - Can't "unclip" it... is this stuff on with crazy glue?
- newbie consider purchaisng 2002 a4, experts please help
- Who has replaced oxygen sensor/s?
- Are there any performance cams? Has anyone used?
- dealership synthetic oil
- id this turbo?
- UPDATE # 5. Symo-Spor'ts FMIC/Setrab motor oil cooler re-location...
- UPDATE # 4. Symo -Sport FMIC, piping assembly and install...
- trade-in value of my 02?
- STFA but couldnt find anything. Getting some weird vibration from the undercarriage @ 3500 RPMs
- got a bit of a polishing problem
- Possibly trading my b6 this week for a TT, any advice?
- Can engine oil get contaminated by running really rich for a little while?
- Followup to my rear clunking noise issue
- Hoen NOT SO GREAT
- Going rate for a timing belt job these days? 03, 1.8T
- 10% discount on shipping Monday!!!!!!!!!!!
- ATE PremiumOne Orbital Slot rotors noisy?
- Brembo....
- New Photo shoot of Hartmann Gallardo reps on MkII TT
- need some help locating a screw.
- STaSIS Engineering invites you to our booth at Waterfest and to come enjoy some savings!
- What would you recommend for rear shocks with '02 OEM sport springs?
- ESP and ABS light came on simultaneously and stayed on while driving. What does this mean?
- What rears go best w/B5 S4 front brakes?
- coolant flush - service guy says two hours to perform. Does that sound correct?
- Bought a replacement Symphony on eBay (may have gotten robbed) - Question:
- Back speaker rattle fix?
- anti-roll bars
- Dumb question of the day......forged BPV:which side connects to Boost,which side goes to Intake??...
- used '03 A4 Avant black on black
- The Final Day Of The Waterfest Countown is here. Make sure you stop by A.W.E. Tuning's Tent.....
- Battery life???
- For those who were looking for 5 point torx security bits...
- New mod I decided on while doing the FMIC...
- Anyone cured minor wind noise by adjusting door striker on body?
- Loud @ss tires?
- PES G2 Supercharger Used or good price for one?
- left tail light out, but the bulb is ok, happened once before and i just took it out and cleaned it
- Where can I buy one of those paint depth measuring devices??
- XENON Head Lamp Nightmare - please help
- Clay barred, Waxed, Tinted tails.
- What value are you guys seeing for trade-in at a dealership...
- Chalfont suspended - if you know Chalfont (me) please read & support
- whose silver A4 avant did I see dwtn Winston Salem today at Bus 40 @ 5:!0? Fvckin hawt
- Flash problem - searched for hours to no avail
- Coil Packs Question!!
- Stoptech Stainless Steel Brake Lines
- I suspect my CPO vehicle was in an accident before I bought it. Do I have any recourse?
- Neuspeed vs. Greedspeed DSMIC: same? Any other full kits?
- glove box compartment stuck
- ESP and ABS light coming on simultaneously?
- So, who was 2 days ago in Page/AZ, Lake Powell with a red
- Card tray stuck, any advice
- Rubbery covering on the door handles wearing/chipping away...
- Opinions - change T-belt when I fix water pump or not? Selling the car soon!
- Audi hesitating to start on first try
- Purems.com Coupon codes!
- Waterfest Deals At The A.W.E. Tuning Booth
- AudiWorld as been acquired...
- Bought the 02 avant last night!
- Got my Recaro Young Sport ($179) do we have top tether point?
- Bad Engine Mount at 62K?
- UPDATE #3 on my/Symo-Sport FMIC... Cutting the rebar, making brackets, test fitting the FMIC...
- what are some differences between B5 and B6 FMIC piping?
- Brake question
- OT: Got hooked up for B-day...but dont want it. Want Mod money. The BUG is BACK...lol.
- These forums are great!!!
- B5 S4 wheel vent liners BT: for those who have done this mod (shadyraven, Bolo, etc.) (m)
- Thank god coolant flange getting fixed next week. The leak is BAD now.
- DEADLINE TO REGISTER FOR VAGKRAFT.COM EVENTS IS AUG. 4. ACT NOW!!!
- Is this Normal????
- 60K Miles!!! Couple questions...
- Because I'm a noob...how can I tell which connector I need for front brake pads with wear indicator?
- If I have a VIN number can I get any Audi dealer to run the service history?
- Injection cleanining
- Got my 3.0 flashed with Giac this past weekend...
- Where do you guys recommend I buy a new K03 turbo? My turbo is dying and I'll need one soon.
- Buying a car and seeking advice.
- Shipping car from NYC to California. Best prices & service??
- DTC / Help with my 2002 A4 3.0L
- DD's Pre Waterfest Special starts now! 10% 15% and 20% off!!!!!
- Tinted tails are in...
- Could anyone running GIAC FXK03 be so kind as to post some Vag-Com logs please?
