- Tinted tails are in...
- Could anyone running GIAC FXK03 be so kind as to post some Vag-Com logs please?
- Anyone know where to get some (low cost) piano black trim? i hate this dimpled aluminum?
- If the car alarm activates do the flashers eventually turn off by themselves...?
- Coilpack Question...
- For those with OnStar - Our systems will stop working January 1, 2008 ...
- Fixing pesky window seal / door seal leaks
- A recent article putting Audi's CVT in the spotlight
- AWE Tuning is heading to Waterfest
- hey guys just asking a question for a buddy.
- New trunk spoiler inside...
- ***Revo Technik National Waterfest 13 Sale Begins Tomorrow***
- STaSIS Engineering Waterfest Sale is on...
- Best Jack point?
- Modification required for a 2004 A4 Avant 3.0 from US to Calgary, Canada ?
- Anyone ever used "Autobahn88" stuff from zenaracing on ebay?
- B6 noob question: Is there any major problems with the 02 1.8tq compared to the other years?
- 60,000 mile service = $425???
- raising the rears for my koni coilovers? any ideas? the top of the rear perch sits at...
- will the stock 1.8t flywheel fit 240mm clutch discs? or is flywheel machined to 228 exactly
- where can i order the 5 point security torx bits?
- will i have trouble with dealerships if if i get a forged dv? more..
- anyone have a link to the mod to make the S4 lower grill fit a normal A4 lower?
- Anyone have to replace bushings on control arms yet. Stealership wants $1200
- Cut Back
- New Achtuning LMC wheels available!
- anyone have a picture of what a clean IAT sensor should look like?
- Short Shift Kit recommendations for 3.0q 6 speed?
- The APR Waterfest Sale has begun!
- GIAC Presents: Xbox 360®/Forza Motorsport 2® Giveaway at Waterfest 13!!!
- Waterfest sale at Achtuning.com!
- Went to a GTG recently and the photographer took a rolling shot of my car :)
- Will adjusting the door striker fix this "door slamming" issue?
- Help ID this part
- Does the A4 USP ride lower than the S4?
- Waterfest
- feeler - 02 A4 1.8TQMS - Stage 2 mods - 52k miles - price? $16.5k?
- not much buzz surrounding waterfest this year
- About to pull the trigger on ECS Stage 2v2 BBK
- More questions
- need help/advice...mishap this morning!
- New pics of the car with new shoes
- Question for those with wheel spacers and aftermarket wheels.
- Emissions Control System fault
- is $68 is the cheapest price for Bentley manual? it's from parts bin
- need help figuring out how to separate the shifter knob from the boot
- APR Stage 1+ long term care tips.
- OE Wheels from eBay? should I stay away?
- dipped left headlamp, no warnings, only resets occasionally
- any help on changing front turn signal bulbs?? tried the search....tia
- is there a way to get rid of secondary air injection system on my car
- Headlamp Leveling W/L on after Ride Height adjust
- Repost: fuses
- Had a guy ask me if I was selling my A4. I said no but that I was flattered that he showed...
- 2004 silver avant wagon
- 100,000 Mile Transmission?
- Haynes Manual about to be published
- Dyno Dynamics Results from Chicago Performance & Tuning
- 3 of 4 motor mounts leaking?
- Help: Diagram of pass wheel well. Hard evap line goes somehwere? need one.
- so i've read B7 rears don't fit? but also read they do fit. any reason they won't fit?
- castrol syntec 5w-40
- Car Covers?
- Update on my/Symo Sport FMIC...
- Mattias Ekstrom takes Audi's first 2007 pole....
- Just a few commentaries on the Toyo Proxes T1Rs and suspension upgrades...
- Does anyone know what year aero blades were OEM?
- Okay, I think I pulled the PART NUMBER I need. Someone verify.
- aftermarket stereo install kit
- PART NUMBER REQUEST: Cup Holder, Popout, 2002 A4 Black, In-Dash. STFA Already, Bad #.
- Anyone have a PART NUMBER for: Trim Above ESP button, Cup Holder, etc (top of console)
- Where can I buy Audi Parts online with Part Numbers?
- Why I'm not getting a PES Super Charger ...
- doing fuel filter today, any trick or cautions i should keep in mind?
- can you recode the # of blinks on the a4 like toureg?
- so. what to do first.
- Touring Car Racing from Ontario, 11am, /Speed/
- Anyone relocated the ambient outside air temp from down by the outer radiator? to be more accurate
- removing harmonic damper pulley
- a little RS4 sway bar write-up
- Help with PES G3 3.0L logs requested
- Help me choose a color!
- My Damn Coin Tray won't stay closed.
- fuses
- good pointers for newbies on trackday :)
- x-post - looking for einszett Silver Wheel paint
- CP's
- which model years were USP made?
- OK, how bad is this, don't spare my feelings...
- Finally... almost done with the mods....
- Paint touch-up -- who's got a good writeup?
- Break pad wear sensor went off, how long
- Where can I get Pagid black pads for my 04 3.0? Do they make it?
- Sport bump stop anyone??
- I'm out of ideas...
- part number for Bose symphony II radio
- Replacing horn(s) 02 1.8t
- Looking for a few good cars: Waterfest13
- Extended Warranty Group Buy
- Funky clutch action.
- A/C Compressor DIY?
- Dipped Front Right Headlight
- Quick Question...
- Supersprint testpipe and exhaust
- Does anyone have a coolant reservoir laying around that I can borrow to check for fit?
- Here's a sample of some video clips I made.......
- anyone got an extra black glove cmpartment?
- HP question how much do you think im at now?
- Thursday night DIY project.... (a little OT)
- carfax please
- hmmm Hitachi coil pack failure? going about 60 and CEL starts flashing, losing power and vibrations
- My dads got an 03 A4 avant 1.8t. How many quarts for an oilchange and where do you guys get your
- The reason I drive an A4...
- when did you guys get your timing belt and water pump replaced??
- Did anyone ever see a Silver Carbon Fiber (or other material) Hood on a B6 Audi...
- Clean ya MAF's!
- I want the projektzwo lip to come back
- new engine cover?
- siruis +ipod install!!
- Avalon Motorsports is MOVING...
- I need recommendations for a mechanic shop in the bay area
- Can Someone help me out, need carfax report
- timing belt -- check
- Is anyone running the DRL mod or the City LED mod?
- I'm now convinced what the best mod you can buy is
- So I got a 6-Hour trial APR Chip Installed - Overall Impressions: Meh
- Read "Rich Dad, Poor Dad" too many times. Now thinking about a used B6
- Burned trough Brake Fluid hose - B6
- UPDATED with pictures. Video clips from this past weekend's autocross event...
- Disappearing doors, anyone? Proto-type doors that slide down under you.
- 4 Months Now - Update in my citylight LED regulators, created by MC Hammered
- Just changed my oil, and noticed that my skid plate was missing...
- Transmission control module estimate (long)
- Quesiton about ecodes...
- Paging Rye.... how are the Oetty's doing?
- Install Vibrant tips before or after new S4 Rear Bumper?
- Body Work - West LA
- creative gauge mounting options?
- aftermarket navi install
- Thinking of trading in for a SAAB? What do you think?
- Anyone have a pic of the steering column mounted boost guauge ? (ECS kit or other?)
- Right front blinker bulb...
- Just bought 3 years of Level 4 Audi Warranty. Anyone want to share their experiences?
- LED interior lights!
- Check this out future 3 series...
- battery
- wheel repair, difficult-to-match color...
- HELP!!!!! Dealer quoted me at $11,500 to trade in my A4!!!
- A/C Vents throwing different temps from drivers side to passengers vents
- Audi dealerships and AOA can kiss my ass
- Do the 1.8Ts have really weak engine mounts?
- Help with Magnaflow muffler fitment
- wow...just drove 530ish miles on one tank with a/c on...
- Do you bead-blast calipers when doing a brake/rotor change at 75K?
- CEL -P0456- EVAP leak is baaack...
- anyone ever tried these plugs...
- Audi A4 reliability research - results in August
- replaced battry and now the alarm & hazards R going off and i cant turn it off, what can i
- SOME fuel pump noise normal? (changed fuel filter, faint cabin/rear seat fuel pump noise remains)
- Good Indy shop in So. Cal. San Gabriel Valley/N. Orange County
- Possible battery issue???
- radio issues
- How bad is Nuespeed exhaust compared to borla, asp, awe....
- 3 days at Mid Ohio.....the Avant held up great!
- Why our intakes have prefilters.
- For those interested: Alternative to Bentley...
- Time for me to say good bye to Omori Gauge...Got Electronic bOOost Gauge by STRi
- 2 thumbs up for replacement headlight switches from DubStop on ebay
- 2500 for a new clutch???
- Ultra Sports Package
- front passenger window groaned on way down - dying regulator?
- Coincidence or not?
- hairline cracks coming from vent holes in zimmerman brake rotors
- Replacing the brake switch of my B6 A4
- Forgot to ask earlier...brake fluid observation when I changed the pads yesterday.
- lower A/C valve location??? TIA
- its been a while since i posted pics of my car..i did a quick wash and
- Weird squeak noise from rear of car...
- removed the perfilter screen in the intake today and the car felt better overall
- vibrations in steering , braking on freeway speed.
- Normal to have left over brake fluid after a pad change?
- New exhaust pic and clip
- I broke the small ear piece off on the right end of the aluminum transmission mount. Nothing else
- Yay! Got the hawk pads in just a few minutes ago...
- Fixed (long read)...!
- 100 degrees today and a/c is barely maintaining. is it possible 45k miles needs a booster charge
- New rotors and pads....your suggestion??
- Help: Identify this metal crunch noise on almost every cold start
- HowTo DIY Fix: Broken Front Seat Rear Panels for < $2
- Anyone have any tips on adjusting ride height with coilovers?
- rolling......
- Window problem - has anyone experienced this?
- Can anyone help me ? Check engine light is on
- HELP! What went wrong with my shifter/transmission??
- Still pondering on low or no boost on my car..Hoses looks ok.Can a broken DV or N75 caused it??.....
- K&N Filter
- SE MI owners- anyone use Adv. AutoSports in Farmington?
- hey beeches! long time since i've been in this forum...
- AMS Inventory Clearance Sale Coilovers, Springs, Short Shifters, Wheels more...
- N75K valve what does it do.....
- A4 2003 battery cover
- Ticking noise while turning at low speeds
- Suspected bad fuel issue...
- Any idea how to get this connector off (without breaking it)?
- I just love this forum and knowledge of members here
- Oil Level / Ambient Heat
- Audi A4 Global Drives Contest
- new Safari friendly link for genuineaudiparts.com
- Maxspeed Motorsports
- Huh? (Carsdirect.com)
- Get in the car this morning and what do I hear? A vacuum type of noise from the rear right, UGH!
- STFA works ;~)
- Audi Experts I needs HELP - Front Wheel well question and Xeno lights
- OK these guys at Symo-Sport are driving me mad with their designs. I might as well send them my...
- Lemmiwinks chanel 9 (timing) value with APR's stage 1+?
- Uh Ohh...sudden loss of power...no boost...high pitch hissing while accelerating...any suggestions??
- So here we go with another mod. I've been waiting a long time for this one...
- Added Bluetooth and Radar/Laser protection. (pics included)
- Pics of my (relatively) new ride.
- So it looks like my alternator is not working properly...
- Overheating engine - could it be a bad thermostat?
- New skins...
- What happened to www.genuineaudiparts.com?
- Is there supposed to be two sound deadener (belly pans) under the B6?
- rs4 and s4 sways
- too late to bed hps pads?
- talk to me about wheel spacers..
- Congrats to APR for the EVO article!!
- Worry Free Driving?
- My impressions of the B7 2.0T CVT after driving a loaner A4...
- Any California 3.0 owners have a PES Tuning G3 supercharger?
- F&*&!n Coilpack C*&t
- TB service and...?
- No new news here...
- Follow up on old thread...Need your help diagnosticator1
- Question on coding another ECU to my car
- Brake Upgrade Advice
- What's new I was in Europe for five weeks.
- Front Bumper Fix
- Trifecta!
- any touch up paints or the soft touch interiors?
- Haven't been here for a while..I live at AWOT
- Having trouble with reprogramming homelink at the new house
- How do you (carefully) remove door seals to get window frame/regulator out?
- Help needed identifying the head of a bolt...
- Loking for B6 3.0 sport suspension.Does anybody know the parts number?
- Cooling Fan won't shut off
- Might a stupdid question.. Anyone ever installed an oil catch can to minimize sludge?
- Noob question: how can I tell if I have round or square brake pad connectors? Also, since front
- Switching from halogen to xenon bulbs
