View Full Version : VAG-COM Discussion
- Have some codes that I need help
- Anyone mess with these HVAC settings before on an A4 B7?
- Soft coding
- VAG in Los Angeles
- got it to work just pulled these codes, any ideas or help - tia chase
- question, will my key-usb work on my buddies 1.8t 2003 b6 a4. tia- chase
- 1997 A4 ABS code
- VAG-COM Newbie: Now what?
- Error Codes
- F125 problem
- so i bought my vag at waterfest and its messing up..
- So I Scanned My car today since my airbag and check engine lights were on and this is what i got.
- Code: 00785 temp sensor in instrument panel
- Whose bought a VAG-COM from waterfest?...How much did you get it for?
- RS4 Outside Temperature Adjustment
- Can't remember now: did 704 include another firmware update to the dongle? HEX-USB-CAN.
- Dash illumination problem on 05.5 A4, Uwe anything new on this?
- Uwe & Company: tried to troubleshoot a B7 S4 but was unable to access most addresses. Some will
- NEW TO VAG COM =) HELP PLEASE?
- Symphony II+ Adaptation channel 002, request ??
- codes that are bugging me
- Can vag com be used to datalog engine channels on Porsche or BMW cars?
- How do I test the O2 sensors?
- Any way to disable the headlight level adjustment warning and/or buzzer?
- What should I do now?
- Anybody located in Columbus or Cincinnati that can help me out?
- VAG-COM sample rate really low.
- Can not log/connect to ecu with lemmi/vagcom when car is running only when the engine is not
- Daytime Running Lights
- Recoding suspension module
- Sat radio 0F, can't display any measuring blocks or adaptation channels?
- New Vag results
- Climate control display
- How do a test the MAF sensor with VAG software?
- 00 A6 2.7 Auto Secondary Air System HELP!!!
- On a C5 A6, can the independent driver and pass. CC temp set point controls be reprogrammed...
- Having problems recoding the Central Electr. to modify the DRL settings.
- Can I lengthen the door lock arming signal (horn beep)?
- any idea why the tail sniffer shows car running rich but channel 031 looks reasonable?
- Update VAG-COM 20070629
- 00561 013:mixture adatation limit(mul) not reach.lean or rich?
- AC Diagnostic on an A6
- Code 65535 on allroad air suspension
- vag com codes audi c5 a6 4.2 Secondary Air Injection System
- X-post with C5 forum....CEL help
- Question for the gurus (not much help in the TT forum)...
- ABS Repair & VAG-COM
- recoding question...
- Having trouble re-coding transmission
- RS4 Daytime Running Lights
- need help....engine heats up and the fan doesn't turn on
- Need Help with these codes
- i still have the old twin-com cable.. will it work with a 07 a3?
- I may be moving back to the shop floor.
- I disconnected my battery 04 d3, upon reconnection i get this any ideas?
- Begining the code check
- new to vag-com
- Think I know the answer - just want to be sure. I have a new cluster for a 2000 A8 on order...
- Another Lowering Question
- Do I know what I'm doing? - Diagnosing a miss
- Help with codes
- Can only open controller 17 and 8
- Fuel Gauge Shows Empty After Filling Up
- MIL?
- is there a way to see the vacuum reading through VAG? I'm not sure my boost gauge is working
- Help With a a VAG COM code 18032
- DIS Language on B6 S4
- Uwe, Andy or whomever. I'm in need of some assistance please
- Can i get my TCU number without having to take out the TCU via VAG?
- 18262-P1854 code. Not found in wiki update (recent post). Can anyone help?
- help interpreting fault codes
- Instrument Panel or VSS?
- B6 A4 Lowest Temp Setting on Climate Control
- Status: Questionable / K1: Short to ground
- MAF diagnostic measurements 2000 4.2 40v A8
- found fault code no its (P7030 incorrect gear ratio)any input would help
- Will a Ross-tech USB-HEX cable work on a 2006 Jeep Grand Cherokee
- Question regarding one of the Tech Articles... AIRBAG
- Trouble opening control modules
- Intel Apple and VAG-COM
- call ZF or check on ebay for phonex trans $1,800 w/warranty
- Can auto transmission output diagnostics be run with the ignition key turned off?
- 17544 - Fuel Trim: Bank 1 (Add): System too Lean : Need help
- probally getting a remanufactured trans from ZF
- Trouble code reader question...
- Boost Logs
- I haven't checked yet, but can you set Date/Time on the instrument cluster with the VAG?
- Rapid Data Transfer (RPT)
- Block 032
- transmission went out 4.2Q A8 at 119,886k
- Tranny is in limp mode
- programming remote window closing etc on '06 A8
- Shade Tree ProDiag
- VAG indicates: 00856 - Radio Antenna: 36-00 Open Circuit
- Need help on Central Electronics for RS4 B7
- Uwe, are there any plans for a greater sampling rate for logging? Since ECUx works w/ the Vag-Com
- MAF? O2 sensor? Both? (X-post from B5 Forum)
- Vag-Com Locator is going off air on June 30th 2007
- Code 16684,85,86 - Looked it up. Could it be due to needing (B6S4)
- 01 A6 4.2 with VAG reading B1 S1 intermittent O2 sensor
- dog chasing his tail here....just trying to get ecux to work and
- Any way to use comfort group and measuring blocks to narrow NDBW 98.5 cruise control problem?
- power locks
- Question about resetting the "check engine light"
- ASK VagCom Expert about C6 A6 install Cruise Control and DIS
- Software updates for different control modules.
- CEL came on today and VAG'd These:
- Recoding trouble on 2007 RS4...
- C6 A6 want to active cruise control, need help on coding
- bought can vw/audi u281 autoscanner for my 1998 a4 is this the best tool for it
- a/t linking error made several attempts no joy-what is a/t on scanner tool?
- Q7 oil service reset ?
- Code keys for remote window closing etc on '06 A8
- AWD CANbus Fault
- code wont go away
- SDS help !
- Where is the immobilizer chip in a '04 S4 key? Is it in the remote of the key or in
- I have a mac. What do I need to make vag work besides a windows laptop
- vag newbie question - No OBDII response
- Interface Status = 3 Error Msg , K-line stuck?
- In a 2007 S8, is it true that the riding height can be adjusted to the loading level height?
- Lable file needed , 4F0 910 732
- Problem with VagCom cable connecting to the Vag port.
- Idel speed adaption error
- Auto Trans: "no faults found or DTCs not supported by controller..."
- Best Car Maintenance Program (other than Vag-Com)
- A simple question....
- component protection active
- New to the vag-com
- how can i disable the airbag?
- Language change
- O2 sensor questions
- "402" type mod for the new Q7... can it be done with the software I currently have?
- Battery Level Missing on A6 C6
- Is the VAG cable/software I use on my 00 s4 and 01 allroad compatible
- Codes 1998 Audi A4 1.8T
- VAG-COM 704.1 not loading...
- Laptop or Tablet PC for USB VAG-COM?
- The ultimate Key and Remote QUESTION . . .
- Need channel # to run Leak Detection Pump in Basic Settings for 99 A-8
- S8 - Two persistent error codes - Any ideas?
- Obdtool vs. Ross Tech
- I'm trying to uninstall VAG-COM using the Uninstaller but I get an error....
- Vag-Com Logs...
- Where is the port on the new A3's?
- vag noobie question
- What kind of radar detector should I buy?
- Looking to purchase a VAGCOM but not sure which one to buy??
- Practical Experience Recoding D3 A8's?
- A4 2007
- 7.04 update won't Autoscan
- The Elusive 01119 - Gear Recognition Signal (Intermittent) ABS DTC.
- how do adjust xenons?
- Is it me or ross-tech site is down?
- comfort control module
- Fault code No. 3 CYL Open Circuit..........Help!!!
- fast blinking of turn signals
- Help disabling seatbelt chime on 04 allroad
- Instrument Cluster and Immobilizer issues in 2002 A6
- Get these two codes after cluster swap, any help appreciated
- Can you program keys with Vag-com?
- Turn off delay - Short to ground. A6q 98 avant
- code readers
- is it possible to lift or remove speed limit?
- Help needed on 2.7t forum
- Anyone know how I can change kmpg and euro time back to US specs....
- Remote Key Programming Question
- Adjusting adaptive bi-xenons to dip right instead of left?
- workshop coding of abs computer?
- I want vag-com but,
- B7 RS 4 Fogs w/Parking lights coding?
- coding key with Vag-com - MY2003
- Isn't misfire recognition supposed to be activated 100% of the time?
- How can I uninstall VAG COM from my laptop. I get an error and it stops uninstalling...
- hi i need help with this one BTW new vag owner
- MODE BUTTON ON STEERING WHEEL CODING
- Is there any difference between HEX-USB (without CAN) and the current KEY-USB cable?
- Assistance needed recoding ABS module and bleeding brake system
- Anyone in New Jersey with Ross-Tech software that can recode my tranny?
- Vag com
- B7 Driving School Function - Change km/h to mph?
- I have a 2006 a4 2.0t and would like to know how to reset the fuel adaptations
- Problems with A4
- Q7 Fault - Any Ideas?
- wierd connection problem...i can connect fine to some modules but not others.
- Help with engine fault code
- Help with scan results B5 A4 please...
- Ross-tech Key-USB cable: "Not connected to car" error message.
- update ECU
- Should i get a Cable do i need it?
- Need some help. I'm at a total loss for these misfire codes I've been getting for 6 months!
- Anybody know how I can change kmpg mpg and the euro time etc back to US specs?
- Help on diagnosing Engine and Auto Trans fault codes
- Help on diagnostic Tip VB Solenoids or up shifting Problems.
- Is it possible to pull a log of recent VAG-COM activity?
- Can I recode the TCU in a C5 A6 3.0
- Output Tests: Error: Function Not Available
- Can't achieve near-100% wastegate duty cycle
- KEY-USB and '06 A3
- is it possible to re-code the memory seats on 1999 A6 (details within)
- car running rough. going to VAG this weekend (long).....
- Is it normal that I cannot access Module 01-Engine on my B7 3.2?
- Just came from the Ross-Tech site... Which VAG-COM to get?
- Fuel injector open circuit
- xpost to b5: softcoding for 2000 a4 tip
- J1850 protocol and VAS 5051
- VAG-COM lost connection while checking ATF level
- Exploring vag com a little more and have some questions...
- Got email about VAGCAN tool. Something about " can change the mileages"
- Need some help troubleshooting brake problems.
- Was attempting to change to "Old-style Tiptronic" but....
- airbag errors help pls
- Airbag DTC Assistance
- Instuments - 17 > adaptation - 10 > Channel 46. What does this value represent?
- will KEY-USB work properly in my 04 s4, also do i need to register it, im buying a used one.
- Allroad VAG test
- Updated link: Problems with MAF, Intake
- First SCAN! Audi A6 4.2v8 2001 Tip
- VAG and Vista (USB)
- Update on prior post regarding A/C mode idle speed kick-up..'03 1.8T A4
- Looking to pick-up a VAG-COM cable from Ross-Tech, need some tips on what to get.
- P1122? What is going on here, O2 sensor?
- USB vs Serial Vag Com Cable?
- Is there a way to upgrade...
- What exactly does the "Rest of the World" setting change on the central electronics on a b6 S4?
- What kind of PDAs can you run VAG-COM on?
- Need help interpreting this for an 99 A6 Avant
- Can i recode my 2000 a4 1.8tq tip, to this so called sports mode or does it already have?
- Cart before the horse maybe, but
- 2002 TT window will not go up after door is shut. Can I reset with Vag-Com?
- Car stalling, surging when hot, no power intermiten EXPERIENCED GURUS HELP PLEASE( kinda long)
- VAG-COM Release 704 Now Available!
- need software
- Intake Camshaft Contr.Circ.,Bank2 Short to B+ 17943, save me $1800 i will paypal $20
- New Vag Com Owner need help on using all the options web site maybe?
- Uwe: I didnt expect to find a picture of you on YoMomma
- What do you think of these readings.
- what blocks should I log to find a bouncing boost issue? also, the car goes into a soft limp mode
- Is there any way to have the ESP default to off when car is started?
- Can I use a Ross-Tech USB cable for EVOscan software?
- Can someone tell me if these block 115 graphs are normal?
- Rooling back driven km
- 2001 S4-Windows Vista-have cable..what all do i need?
- One Click Unlocking B7 A4
- Vag-Com rookie here. Can someone help a brother out?
- Just picked up the ross-tech usb cable and software...
- VAG-COM / HEX-CAN USB and Vista under Bootcamp | help!
- A4 - how to interpret coding for steering wheel module 16
- Need some DTC help, already searched the archives.
- 16706 Engine Speed Sensor G28 No Signal - bad?
