View Full Version : VAG-COM Discussion
- any here from connecticut who can help me vag-com my 04 s4, i just got a RNS-e navigation. it will
- x-post from the B5S4 forum:
- I'm looking to buy/register Vag-Com software and have several questions on what I need. Help
- What does this error code mean?
- HELP WITH THESE CODES, PLEASE!!!
- Bad Oil Sensor G266?
- Dreaded message: "Port OK, interface not found!"
- Odd
- Which free version do i need?
- VW question
- Help with these codes!
- Help interpret the codes... 2000 A4 2.8 QM engine code ATQ, stock.
- spam...
- VAG Options on the new S6 (5.2L 2007)?
- Can I do these 2 things with Free version
- Q7 trunk open and close can this be vagged to close by using button on door panel? Thanks
- Full scan on my A6Q '98 Avant
- How to get Ross-Tech VAG-COM setup for a '95 Audi 90
- Need some help diagnosing a misfire condition on an 03 A4 3.0qms with 100k miles. Please help
- Any tricks to disabling/enabling the TPMS? (seems dead after disabling/enabling via channel 61)
- Instrument FIS display communication 3-wire or CAN?
- And happy Thanksgiving, ye purveyors of most excellent VW/Audi diagnostic software
- Having problems with parallels, has anyone had any luck with it?
- A6 4F radio clock (funkuhr) coding
- Can I use autozone vag tool to reset my service interval light??
- CD Parts Catalogue
- Ok, got a good one to ponder on an 02 A4 3.0
- Little Help?
- X-Post: Fault codes from VAG scan...16805, 16815, 00716, 00962. Anyone seen/have these before?
- How to check the efficiency of the coil pack with vagcom?
- 02365...
- VAG Newbie Question...
- What affect will this have
- VAG full reset
- Vag-Com wont access Engine when engine is on, but will when engine is off?
- Window Opening & Closing
- Group 115? Dead turbo?
- Bright or high beam headlights
- Can Vag-Com access the 93C66 memory IC in the instrument cluster?
- One-touch rear window up code?
- Service interval help
- Anyone wanna trade a USB VAG-COM for my serial HEX-COM?
- Audi RS4 B7 2007 Coding for RNS-E and MFSW
- Headlight Setting Errors
- Block 15 on my 99.5 A4 1.8T: "Misfire <blah blah blah>...emissions"
- Key adaptation procedure / euro immobilizer
- I am afraid you guys were right.... Frozen Turbo
- Going to have to ask for help with this one. Assistance please?
- Software???
- New Windows Vista and Vag Com
- dropping the top with the remote
- Control module coding
- Help: Navigation Plus and cluster question.....
- Scanned my car with help from a friend on the VAG locator db
- Hey Steve from Shadetree! Are you around? I'm being asked for a 12 digit>
- Quick question for the Ross Tech guys
- Unstable idle, Audi A4 1.8 non turbo, 1996
- Posting Logs
- Any success running VAG-COM on XP via Parallels on an Intel-based Apple portable?
- Accessing Nav-Plus with Vag-Com
- My friend has a 98' A4. Can we recalibrate the speedometer with vag for a smaller or bigger wheels?
- what does it means? altitude regulation?
- Instrument Cluster replacement problem
- Code to turn off open door/seat belt alarms?
- VAG COM Question?
- Anybody in lower CT or NYC area have Vag-com?
- Ongoing problem with the battery dying!
- X-post: glass breakage sensor/location of Innenraumueberw module on avant
- How to get to acceleration screen? also codes fir 2002 jetta?
- My OBD stopped working...
- Help with codes please, 2001 S4....
- Help with codes please, B6 A4 1.8T
- Help with codes - 2000 S4....
- Is there a way to check just for what is throwing a CEL? Or.....
- Used cluster installation... Need Help!!!
- Limp mode and codes on 2000 S4...
- Unable to communicate with A4
- 2002 A4 1.8T B6 I have this VAG code could someone please tell me what it is...
- window roll up in a B5
- Gas Gauge showing Midtank as Full
- my question is ..how to perform bassic settings on ecu digifant 1.72?
- whats this immobilizer thing i hear about and how can i turn it on with vag? or is it on?
- B6 one touch windows up-down
- Just picked up a Vag-Com
- Xenon autolevelling- can i use shareware or do i need registered version of Ross Tech?
- Auto-scan results...any help...
- Cruise stopped working '03 A4 - Vag-com diagnostics
- How a VAC-Com Pays for itself in time saved...
- Vag-com usb serial adapter that works!
- Just bought my Vag-Com and bentley manual.
- VAG Procedures for Radio Testing?
- A4 B6 brake pad warning light
- i cant reach my immobilizer with vag com after i replace the ecu?
- Need Help....
- I thought somewhere I read that the VAG will work with other makes/models?
- European codes to roll up windows with key fob
- already STFA, and found nothing... is there a specific location in the bentley manual
- Which adaptor for Audi A6 2001 2.5tdi?
- what vag-com do i need
- VAG-COM in Denver???
- 2005 B6 A4 Module 77 - Cannot Access
- vag-com equivalent for mercedes???
- Confused on Butt Dyno instructions. Do I need to edit the green values?
- Cant access Module?
- help....can't clear codes on my 97 aeb auto quattro...
- Emergency brakes lights - A3 8P
- My VAG-COM Autoscan Results, should I be worried?
- Will VAGCOM read DTCs on a 2000 Pontiac Grand Am? I heard it works on some non-Audi/VWs...
- Massachusetts Annual Inspection Question
- Can DRL's be turned off with VAG-COM?
- Bought a laptop with VAG com on it and I had to buy a cable...
- Throttle actuator - adaptation not started. Code 17987
- VAG-COM read. Help with some codes please -
- External Power
- Using Registered VAG-COM 409.1-S on B6 TQ
- what is the diference between diferent vag com versions?
- Upgrading to HEX-COM, question about laptop compatibility
- Need Help!!
- VAG-COM Error for '06 A3
- why volkswagen jeta 90/1.8 mono has onli L-line ?
- Navi-Plus K-line connection to OBD2 connector not working?
- symphony II+ coding
- Is there a way to alter adaptation codes on Audi S8 1998 Euro-model?
- What is the code for activate my cruise control? (new ECU) model inside
- incomplete test emission question
- A TWIN-COM serial VAG-COM (licensed Ross-Tech) will work on a B5, correct?
- Code for flashing brake lights when doing an emergency stop.
- MAF Cluster Retrofit??
- USB Error running 504.1 version
- is it posible the problem with lost power if the bypass valve of the turbo engine 1.8t doesnt work
- Vag-Com Autoscan Printout ***FEEDBACK NEEDED***
- Today is Uwe's birthday....well at least my Uwe's B-day.
- Is there a write up with all the cool little features/coding changes...
- Paging Andy@Ross-Tech---PC OS questions
- login code audi a4 96/1.8t
- Any TPMS updates? Need to disable
- Xpost:"DIAG" flashed on the radio when logging for misfires on blocks 14, 15 and 16.
- EVAP system test?...(small/large leak codes)
- auto lock
- shareware version
- Log from stock 99.0 A4 1.8t, 93 octane, 50f
- ABS Module/Controller not being recognized by VAG
- Procedure for items to datalog to verify good car power/operation with vagcom?
- Where could i find the diagnosis contact
- SoCal Inland Empire - Anyone with a VAG willing to meet up?
- Losing connection to ABS controller
- Will VAG-COM Support Apple Mac Someday?
- Step By Step VAG Procedure To Reset Xenon AutoLevel Upon Lowering Suspension For A6 4.2...Thank You!
- B5 A4 won't connect to 15 (abs) or airbags whichever code that is?
- How do I get rid of the "Brake Wear Sensor Light" on the trip computer?
- 01222 - Crash Sensor Side Airbag: Passenger Side (G180)
- Evap Large Leak 1998 A6 2.8 quattro
- Need help for EVAP Code 17834 and 16825
- Help me to recode my Tip~! 2002 A6 2.7T
- Is the central locking module part of the immobilizer ?
- Buying a VAG-COM
- VAG Com in Montreal Canada??
- Which measuring blocks to monitor to check O2 sensor function?
- really noob question
- When i went into the controller for the central locks it came up with two codes "Crash sensor
- VAG-Scope / API question
- Help with dtc
- Whats going on with my engine?!?!
- Seatbelt Codes....
- Not getting much help from APR about these codes!
- Any way to kill the "door open" chime (B7 RS4 w/ HEX+CAN)
- What can cause this....?
- Seatbelt Buzzer Nose VAG-COM Help needed San Diego / SO CAL
- Help with codes
- Need VAGCOM in DC/Metro Area
- code 18062 and 16825 help please
- VAG-COm In Las Vegas
- Anyone have a VAG COM in Tucson, AZ or around Tucson?
- Odometer question.
- Andy/Uwe - Lease is up on '03 C5 4.2; about to get '07 4.2 - new window codes?
- B7 RS4: Can Auto relock (after 60 seconds) be disabled?
- Noob question for B7 RS4 - Is servotronic steering adjustable?
- A4-error 17978 P1570-35-10
- 97 A4 seatbelt pretensioner codes.....ugh....
- 12555
- looking for a VAG COM in central NJ that would be able to help out with adapting a new ECU
- Error Codes Help:Warm Up Catalyst (Both Banks) Efficiency Below Threshold
- Do the window and other codes in the FAQ work on the newest cars (specifically C6's)? TIA.
- I want to roll my windows down buy just unlocking the car
- Replaced my instrument cluster today now MPG is stuck at 200.0 -
- connecting up Vag com
- MAF low g/s - definite diagnosis? Code 00575
- Airbag light on.. what could this code mean?
- RNS-E Coding with Version 409????
- Can I edit the seatbelt chime on a B7 with the OBD-II interface?
- Does the D2 A8 record V-Max?
- '01 Jetta TDI O1M Fault 00652 3-4 gearshift
- Questions about fuel trims.. I have the original factory MAF in my car after 100K miles
- Got some fault codes today. Please Help!
- Prob with A6
- Can you clear an airbag light with VagCom?
- ABS fault code?
- new TT, tweak S-tronic
- How to test break vacuum pump with VAG-COM
- Xpost: Disabled the VAG COM driver and replugged the dongle. Is XP supposed to detect "new hardware?
- Engine tweaking for the track.
- Radio Diagnosis
- Charge Pressure limit exceeded...
- serial to usb adapter question.
- after changing central lock pump, i can't access central locking group in VAG-COM, any ideas?
- Possible to tweak timing with VAG v512-4? (m)
- Fault Codes? I suspect my maf
- stupid VAG related radio question for b6 a4
- Hey Andy, is your MAF test the same for NA engines?
- 2005.5 S4 requires +CAN? Old HEX-COM no can?
- CEL with code #17953 which I can't identify...ne1 help with this code #
- K-line wire for engine module help, no connection to ECM
- window roll up code 2001Jetta VR6
- 01437 Control Position not learned - allroad
- Fault Codes Found, Need Help
- How can you adjust mike sensitivity on a SE or Nokia BT kit?
- Evap 16825 P0441-35-10 Intermittent..Thought I had it fixed with new vacuum lines..
- Steering Assist -Chan 01 n/a?
- SKC -- 4 vs 7-digit, key tag, etc. Is this it?
- window roll up code 2002 a3 (8L)
- i have a 99.5 tip, and have auto tranny problems could getting vag-com figure help,any opionions pl
- Help! How to get rid of fog light warning?
- Check Engine Keeps coming on
- VAG won't talk to car...
- 00 s4 can i turn on defrost or heater w/vagcom?
- X-Post...k-line
- Can anyone explain C6 seatbelt chime codings to me?
- Wierd Brake Indicator?
- 2005 A6 Service Reminder Reset wont update? HELP ANDY
- how to disable the sensor after the CAT?
- 4B - heating unit not visible through OBD
- is there a way to read how much timing is being retarded per cyl on a 1.8T?
- HELP! VAG can't talk to car at all...
- How do you login and put in a login code using 409.1 VAG-Com?...
- Help with CEL codes
- Vag-Com and Mac (intel)...
- 1994-1997 C4 (A6/S6) Instrument Clusters
- Coding help please, Address 16: Steering wheel
- some problem with parking aid system
- New ECU, but dealership forgot to turn cruise control on...
- DTC P1122 and P1140 in 2.7T (APB)
- any way to switch/reverse the ESP function so that ESP is auto off instead of auto-on...
- Searched but no luck with these codes...
- 18158 - Supply Voltage: too Low
- Fuel trim need help! vagcom
- Sirius satellite recevier
- Can you adjust the # of blinks the blinker performes on soft tap on a A4 B7?
- Park Assist problem
- Did some logging after getting my Vag-Com
- I have a problem reading engine block through vag while I am able to read other blocks such as Conv.
