View Full Version : VAG-COM Discussion
- Interace: Not Found! I checked FAQ's
- serial cable v. usb
- unable to code new DME Control Unit
- retrofitting cruise control to a3 8p Any1 have cag can in south west?
- Allroad question- can the speed at which the suspension lowers be changed?
- If P1612 is cleared, how fast will it come back with a bad ECU code?
- Variable service interval reset
- please help, i need to know what these codes mean, i need the engine codes deciphered
- Help Please . First Time. Can't connect with controller.
- Is there a list of all the convenience codes for the b7?
- Central Door Locking Question
- Xenon headlights not adjusting --- cleared codes but still getting errors each time
- Already searched the archives... but no luck. No OBDII connectivity, but Test says "OK"
- Sometimes inconsistent results between Autoscan and single module scan.
- Could VAG-COM help with a 18020 / P1612 code?
- Is there anyone in Central Oregon with a vag-com?
- vagcom problems
- brake bleeding and vag com
- Still having problems coding module....
- Q: VAG usefulness when looking to buy used car? Newbie Question
- Which VAG COM
- KKL USB Vag-COM Help please?
- Navigation 2006 S4
- Andy my 06 S4 is finaly getting a new gauge cluster
- Does anyone have sheets of codes and causes for their setting please
- Anyone have a wiring diagram or pin diagram for the ABS module on a B7 S4... for the J104
- UPDATED - Electrical Gremlins....Please help....codes inside.
- Code List Descriptions for A3 available? TIA
- Does anyone here know of s/ware for Range rovers?
- Short term fuel trim
- B6 rear-ended, now the sunroof opens and closes
- Problems trying to re-code ABS module/steering angle sensor...
- Trying to diagnose ABS module, and it looses communication contact
- Is it possible to activate / test N75 with VAG-COM? Not clear from the archives.
- I have a customer here with a new IP
- recurrent fault code 00957 - 2001 Audi TT
- remote doesn't work and 01330 fault code
- Will this do everything for my 1997 Audi A4 v6 12V Quattro
- Upgrading interface- USB or serial port better?
- Help please=can an a4 be reprogrammed to sport mode in the tcu?
- 06' C6 Avant VAG-COM question?
- Printable Manual for Release 512.1 Now Available
- Determining A/F via Lambda>>>>
- VAG-COM, CEL, APR chip, Boost, and Timing...
- B7 2006 A4 2.0 Vag Mods. Is there a list of mods available?
- 00' s4 overheats until near death VAG says its oxygen sensor HELP PLEASE
- reading vacum values with VAG?
- Troubles connecting...
- Any suggestions on how to test if your secondary injection pump is functioning?
- A4 B6 Proceedure to Adapt Instruments
- communication problems
- communication problem still!!
- WannaB with basic Q's
- Finally ordered a Vag-Com today and my CEL came on hopefully it gets here soon-->
- Canadian Mod - interior lights.
- Is there a way to have my gauge lights ONLY come on with the headlights? Now they are "key" active.
- STFA and found out there is a program for my Vag on my new Mac but hte link doesnt seem to work
- MPH to KMH
- VAG Codes
- "Too many communication errors to continue" - What can I do ?
- Gonna get a Vag-com i guess...need some quick advice
- Can't reach controller 56-Radio with MAX-Com 409.1..other controllers seem ok ?
- Any way to disable the TPMS?
- ? regarding auto trans adaptations
- Problem with VAGCOM.
- VAG code help and solutions
- Help with codes for 01 A6 2.7
- not bashing vag-com, but is it ever going to get faster in regards to logging
- Interface not found
- Fault codes from my 2002 Audi A4 1.8TQ. Was wondering if it was serious. Thanks!
- I have an APR chip, can I use a vag-com to raise boost higher?
- "Control Module Not Coded"... won't let me recode?
- Please help with 2x2 cable (long)
- Memory power to ECM getting lost PLEASE HELP
- Is there a way to log/read oil pressure in 2001 Audi S4 with VAG-COM?
- Just VAG my 01 s4 and went to readiness. The program says my evaporative emissions failed does that
- 46 - Central Conv - Can't recode ?
- Is there any way to disable the seat belt chime on new Beetles?
- What's next after the BMW-Mini "vag-com" ?
- Audi A6 ABS Controller not responding when car warm!
- 1995 Audi 90.
- Climate Control Codes for 99.5 WTF???
- A VAG-COM newbie, what next?
- any alternative programs to vag-com??
- just got interface and i cant get it to work
- Tip Recode
- Vag Com Faults on new A3
- Is there any Mac OSX compatible VAG solution? Virtual PC work w/ my USB interface?
- Code 00293 Implausible signal A8 2.8 Sport
- Idle Control Problems
- LOTS of fault codes...I need some help
- I'm getting a VAG-COM for Christmas and I have a few questions about what to get.
- oil and fuel quality display. what are normal values?
- How to upgrade VAG-COM
- Replacing Airbag ECU w/one from A4...need to recode?
- Vag O2 sensor and MAF
- ECU swap no response from controller, A8 1997
- Central Locks Question
- Can't connect to ABS controller, 18014 electrical malfunction
- What is the measuring block for oil temperature in 2001 Audi S4?
- Links between fuel gauge - engine temp gauge and cluster dimmer
- I am still having the same problem with the new Beta 510.0 software. Please advise.
- What kind of "tricks" can the VAG do? Probaly a stupid question, but..
- VAG COM question
- Reversed Polarity - No Diagnostic Computer Signal
- I have my VAG-COM installed on a work laptop. I leave my job this Friday...
- label file for 1992 100
- S4 cluster into an A4
- Hi, could some one tell me what 00526 fault code is? Thanks.
- Allroad suspension
- any way to force the cigarette lighters to be ignition-switched?
- What other cars I can diag. with Vag-com -- Toyota RAV4? connector look the same
- Today I got my Vag-com and there is a results
- Anyone ever find diag software for the Sony Clie's?
- Using a Mac laptop?
- Air Bag Code 00558 - Airbag Igniter
- secondary air injection pump runs every 5-10 minutes.
- Cant seem to recode the Seatbelt chime
- just to clarify AirBags only get damaged on VW's there is no mention about it to Audis
- Just bought a VAG COM - Times out every time I check the AWD system but works otherwise,suggestions?
- Installed Timing Belt - Can VAG confirm belt was installed at DTC?
- which USB Vag-Com Cable should I buy? for(99.5 A4 q 2.8 v6)
- A6 C4 ( 1995 ) - Auto Door Lock and Other Features
- Any ideas how to deactive the clock data from the CAN signal in a B5 S4?
- How do i log these values? MAF values, O2 voltages, throttle angle, requested boost, actual boost.
- Can VagCom do this?
- VAG COM can't connect to most modules in my car after updating to Beta 510.0.
- ABS
- Golf 5 GTI no wiper communication with Cent Elec 09
- without searching what's the simplest free method to building something to hookup to my audi?
- so my genuine isocom keeps getting connection errors on channel 56 for the radio
- Bentley manual and vag com
- some questions about fault codes and clearing them
- OK I have one I'm puzzled with. Need direction on what to look at next
- 8E0 927 317 what is this thing?
- ISO-COM to USB-type upgrade, for 2001 A4, really necessary?
- noob to the vag-com. Which cable?
- Has anyone used the serial VAG-COM with IBM's port replicator?
- measuring blocks question regarding timing retard
- Help - I too have many fault codes
- ****!!Plaese Help me Lots of faults!! *****
- I have a Serial connection VAG tool. Is there any converter to switch to USB?
- code 01213 (airbag light is on)
- Airbag Module Reprogram
- Is there a way to check for a faulty brake switch using VAG-COM? Thx.
- north american 2006 s4 service reset
- VAG-com problems
- Is it possible to use VAG-COM on Porsche Cayenne Turbo?
- link to my window problem...any insight here for my b6?
- Help with fault codes...TIA
- Having problem connecting VAG COM to car
- Reprogramming the steering wheel audio controls? (2001 Allroad)
- what in the world would cause this and what is it
- DTC #18000 (Altitude sensor/boost pressure sensor implausible correlation P1592-35---intermittent)
- is it possible to change a ecu's settings with vag-com to be compatable from a k03 to a k04 tuurbo,
- eliminating top speed limiter on '06 GTi
- Getting these codes 16518 17509 16516 >> more
- A little Ross-Tech thank you for the holidays......
- can some one lead me to the right area for a list of what each DTC means?
- Secondary Air Injection System
- Bad EGT on 2000 S4, puzzling...
- Sluggish performance 2005 A8, no faults
- Code 16785 EGR System Insufficient Flow
- Threw some codes today, Anyone?
- Xpost: CEL after timing belt swap
- Ambient Temp sensor HELP!!
- Crap! Cracked exhaust manifold and 17544 fault - related?
- vag-com compatible with
- Engine Mount Sensor Solenoid - what does it mean???
- Bad EGT...
- Reversed Polarity
- A3 rear fog light
- the code that came up is 560 027 EGR incorect signal. Any Ideas????
- 99 a6 2.8 quattro fault code 18010 terminal 30 voltage to low intermittent?? Any idear where or what
- Throttle lag on '04, A4 1.8 T
- Codes 17547, 16805, 16815, 00787, 01206 on my 02 S4
- 1.8T Poor idling
- Which "Basic Settings" channel to perform test on evaporative emissions system?
- 2002 A6 - Need a Little bit of Guidence
- 12V v6 and auto+ vag-Com help needed...
- OK I STFA but no luck: beginner how to log using VAG?
- Check engine light - no codes on VAG_COM?
- I keep getting this Block 1 Lean code, the cel comes back after i clear it and flashes if im driving
- Can U help me with this STUPID codes?01367 and 65535
- What does it take to generate a DTC?
- Recurring 17544 Code
- OK. I got around my "Interface not found" problem, but...
- Using the VAG-COM on Volvo's.
- EVAP purge valve short to ground
- Problems coding my new instrument cluster...
- What does the °KW in block 020 stand for, and deos 1°KW= 1 degree of timing
- M-blocks
- Multiple codes - Need help deciphering! (17544/18062/16684-7)
- have had 2 codes for 2 days now car in limp mode:(
- Little help diagnosing my problem?
- Suggest a small VAG-COM intended laptop please
- will symphony radio in safe mode ground the k-line?
- Can anyone explain the following codes to me?
- Anyone know how to do a Throttle Adaptation on Pro-Diag Software?
- Does VAG-COM work with macs yet?
- CEL 17545 17536 Please help
- Problems with the CAN protocal vag tool. Help from Ross-Tech or others requested....
- Audi TV Tuner install problem Vag-com
- minimum needed
- I remember seeing a way to recode a B5 A4/S4 to have all the dash lights on all the time...
- Can anyone let me know what could be the cause of these CELs...
- Does anyone know what may be causing the following codes
- USB vs. Serial?
- Is KWP-2000 same as CAN ? I have a 2001 A4 and I can only connect using KWP-1281 is it normal ?
- 1998 Audi A8 failed emissions
- New to this system, but I wanted to know which one to buy?
- Is there a way to reprogram the ECU to manual from automatic?
- Is there a way to disable full-throttle kickdown? 01 1.8t avant w/ tip
- How do I disable the chirp with keyless locking on '06 A3
- Key-com, question about cable length
- can I transfer ownership of Vag-com Sw if I sell it?
- Need help on fault code please
- P2181 Colant Permorance Problem
- 00 s4 hard time starting, throwing 17704 code?
- Has anyone just purchased the software from ross-tech and a cheaper interface from somewhere else?
- Oil temp meas. block & service reminder reset issues.
- PIII 1ghz w\ 512mb ram adaqute for running vag-com?
- VW PASSAT FAULT CODE 17965 TURBO PROBLEM
- Is it possible to recode the instrument cluster and the ECU from automatic to manual with VAG-COM?
- '91 200 Airbag Code Reset Possible...
- Key USB interface OK for 2004 S4 (B6)?
- 2004 S4 Modifications
- Just got car back from stealership....Airbag code
- Just scanned my S4 with a new key-usb and can't clear DTC's....
- b6 a4 coding assist request
- Uwe or Andy, question re: post-cat O2 sensor controlling air/fuel mix
- Help defining:17573 P1165 Bank1, Long Term Fuel Trim, Range 1 Rich Limit Exceeded
- just picked up a thinkpad over the weekend that i'm planning on using w/ VAG COM
- Help with VAG
- hlp pls: recently got a CEL so decided to get a hex+can cable
- Recoding using HEX-xxx+CAN on non-CAN cars?
- 2.5TDI AFB engine code
- ??code 4191??exhaust gas recirculation system Through-flow too small...
- Can't enable cruise control
- my ODB II Vag-Com cable broke today...(edit)
- Head Light light on
- for sale Laptop and vag-com
- Im lost is there a vag com manual for dummies!!
- ? about error mesage: Interface not ready
- VAG-COM advice?
- I've tried doing a search but not finding much. Could anybody please help on how to make an adapter?
- Audi A6 2.7t 2001 UK
- code 01486 "system function test activated"...How the hell do I get rid of it ????
- Where can I find a driver for my USB KKL USB Cable?
- Basic question, is right side passenger side?
