View Full Version : VAG-COM Discussion
- RNS-E navigation system - error code 2024
- Anybody have links to VAG-COM newb FAQ, thanks.
- Alternatives to Ross-Tech?
- Could someone post easy to understand directions on how to use a V/C to
- Newb help needed. Just got vag'd.
- Got a Vag-Com Question (Tryin to clear a code)
- Does anyone live around Wilkes Barre
- I think my VAG-COM cable is broken (I've only owned it for two months)...
- OBDII on pocket pc
- strange service light !!!
- Can an second ECU be coded to an 03 Allroad without a dealer's assistance?
- 2000 2.7T. CEL Code 16805 P0421
- '04 1.8T......please diagnose
- greetings from an extreme newbie at this
- any way to change the group settings to include parts of another group?
- Logged block 112 to check on exhaust temps, however...
- iso cable and laptop
- idle adjustment
- can anyone suggest a good reason for rough idle with no CEL?
- In-depth problem with an A8 leak detection pump.
- fuel trim info a6 2.7 - channel 32 - all 4 say 0.0%
- COOLING FANS ON ALL THE TIME PLEASE HELP
- recoding a 2000 s4 cluster into a 2000 a4..
- Need help diagnosing problem with A6..kinda long
- can someone tell me what these codes mean?
- I wanna log my cai. is the 002 block the correct one to look at?
- How far down the processor family tree will work with Ross-Tech's software?
- How to change the frequency step in FM radio
- Just got a vag-tool. I can connect to all my ECUs except my radio...any suggestions?
- Instrument cluster and VAG
- Hesitation problems... anything look weird???
- Noob to Vag-Com just got my Ross-Tech cable.
- Can I check codes on a A6 2.7T without a WSC?
- VAG-COM n00b question
- Beta 500.8 and generic OBD-II... follow up
- Alarm Chirp - A8
- Unintended metric switch
- while I search, does anyone know the codes for vag leveling B6 platform (2002) xenons?
- Got a new laptop and a new usb cable now what ?
- OK, Andy (or Uwe!), let's try for 2 for 2! Any idea what either of these mean?
- VAG-COM and the A8 W12
- blitz cable and vag com...do they work together?
- Andy or Uwe, need some help on a cruise control value.
- ABS/ESP Fault Code??
- Error code 17117 (P0733) 96 A6 Quattro
- 2 x 2 Cable
- Question about Audi Logic?
- b5 s4 fault codes
- Andy is this the correct procedure for adjusting Xenon Lights on a 03 RS6 ?
- Anyone who know's were i can get prg to change the Kilometer/miles on the dash
- So I go out to my car this morning and am surprised to find it unlocked, but I'm even more surprised
- Butt dyno in D3 A8...
- secondary air inj. system
- Can Vag-Com adjust instrument cluster lighting?
- Question about correcting engine idle with vag com (2000 S4)
- great...error code p0171 '01 A4 1.8t. I've searched the archives..
- Login/Adaptation for Transmission, can it be done?
- B5 S4 - Is there a measuring block for oil pressure?
- well, i decided to go out yesterday and do a little data aquisition with the Vag-Com...
- How serious should these errors be taken ?
- Problem with VAG-COM on my A6-C6
- New beta 500.7 and generic OBD-II
- Fault Code Question
- another recode question
- recoding my Concert II - 03 TT
- Apple Powerbook G4
- calibrating gauges w/VAG-COM
- How do i change the service interval using Vag-Com?
- Radio scan sensitivity.
- Programming Fogs W/O Low Beams on 01 A6 4.2
- K04 Vag Help
- 17912 - Intake Air System: Leak Detected
- ECU soft code request - '01 A4 1.8TQM M box
- Can production and beta VAG-COM coexist?
- Discussion: A6 scan reset yields rough idle DTC's
- Hey guys can someone give me a hand i did the vag just tonight and got....
- Andy , I upgraded like you sugessted to newest version ....updated
- I recoded 1997 A4 2.8L so that the warning lamps are active...but...
- Where is the best place to get VAG-COM?......
- VAG-COM locks up while logging ABS speed sensors on '01 B5 S4
- TBA doesn't exist?
- vag code 01203?
- A little B5 1.8T help please...
- Lemmiwinks - timing advance HELP
- Anyone near Sioux City Iowa with Vag.
- Are there any performance mods that vag offers for the TT?
- Strange read-out from VAG-Com when trying a TBA
- If I update from my ancient ISO-COM cable, to the KEY-COM cable...........
- controller no respnse
- The learning function of CVT
- Benchmarking Performance with VAG-Scope?
- How do you do a TBA with the VAG tool...I've searched and haven't found a solid answer. TIA!
- trouble with codes kinda wierd
- instrument coding
- Check control, Bulb check
- Switch for Anti-Theft Alarm????
- VAG codes
- pad wear check
- Question regarding block 031 first field
- Uwe, thank you for sending me my activation code last night, you saved me, also, ABS issue....
- Warning: do not use cheap-o adapters for laptop
- Cruise controll for 2000 S4. I am having intermittent issues while trying to acess my antitheft
- Finally got a vag cable and did the simple mods..
- How do I change the "Press Clutch to Start Engine" message to something else?
- can I vag off the seatbelt chime on an 04 A4?
- Sorry for my VAG nOObneSS, Quick ?...........
- really newb question
- Where do I find a CAN connection for my Navigation system ?
- Any reference (other than Bentley) to TT's engine measuring blocks?
- Block 002, 2nd gear WOT reading is 130g/s...
- Ok, I have my new VAGCOM, I've screwed around with my windows and locks... what now?
- I've got the HEX-COM - do I need to upgrade to HEX-COM+CAN?
- Xpost, went to smog and and didnt pass the fuel part, these codes were thrown.. need help!!
- Interior Motion Sensor Module Error
- A3 2.0 TDI faulty electronic module
- n00b needs more help
- HOW DO I CLOSE MY WINDOWS WITH REMOTE?
- Curious instrument coding in '05 MMI/Nav+ allroad
- Lambda (Oxygen Sensor) Regulation - Upper Limit Help
- 01367 - Central Locking Pump
- 01274: Air Flow Flap Motor
- Codes from going into "limp mode". Can anyone give me some insight?
- A4 Windows open when door opens!
- Basic question
- Total idiot needs help
- Less than a year ago I bought the VAG-COM HEX-COM cable...
- some newbie questions?
- Theresias do you have the transmission codes for the D3 A8?
- Vag Help...My Protocol wont change to KWP-1281??
- Anyone near Binghamton with a vag com who could help trouble shoot a check engine light I have?
- Turning off Brake Wear Sensor with VAG???
- Xenon error on C6
- Multiple misfires....HELP !! 2000 A6 2.7T
- Invalid msg length
- where can I find all the codes?
- "No response from controller"
- does anyone know what i have to buy in order to fix these codes....
- Anyone in Phoenix???????
- Need a little help after switching out the MAF...
- CAN'T SYNCH BAUD RATE ISSUE, HELP PLS...
- How do I cycle my secondary air pump? 2000 A4 ATW
- Product upgrade questions for Ross-tech
- ok trying to get this vag to work right first ..i get these errors what do they mean ?
- Searched and didn't find much info - calling all experts: DTC: 18256 - P1848
- A4 Odometer problem
- my computer still works?
- Which vehicle speed is correct? ...
- ok i tried STFA with no success, where can i buy ETKA 6?
- I'm using a MAX-COM with a USB-Serial adapter since my laptop doesn't have a serial port
- Speed signal
- Recode MAF? (or tranny?)
- noobie here too
- noob question...
- Airbag light is on in B5 Passat. Can I use VAG COM to find the problem?
- hey guys, if you car is over heating will it send a code to the ECU? if so what would it look like?
- I want to purchase the VAG-COM tool but have a few questions..
- v409.1 and 311.2 problems.
- DRL via VAG with US A4 (8E)....which lights will activate? Low Beams? Low Beams and tail? Or ???
- News story on CELs in general shows a VAG-COM in use on an A6.
- Possible to log IAT out of AAN (urS4/S6) motor?
- 2001 A4 2.8 with camshaft control malfunction, code 17927
- Camshaft Sensor Problem
- meas. Block 77 & 138
- 16506 Throttle Position Sensor Signal Too Low
- B6 A4, 2003 A4 1.8T code
- burnt out bulb indicator is on steady
- Just got a new car.....
- Getting interface status = 0, VAG-COM via USB v409.1 on 2000 S4.
- Newb vag/APR chip problem, throwing cels...
- DIY VAG wont communicate / Interface not ready
- searched but can't find block to log mph. Would like to see 0-60 and 0-100 times.
- VAG-COM Login Function 11 question
- steady ESP light and DTC 00526
- searched with no luck....one touch windows up for passenger window or all?
- Is there a way to VAG the auto lights on feature....
- How do I change 1998 A8 dash temp change from C To F also temp reading in heater controls
- saratoga NY area VAG COM?
- X-post: Help! My ecu isn't adpating my fuel trims
- Upgrading Twin USB cable and 3XX.XX software...
- Novice in trouble!
- Tiptronic recodeing on Audi S4(B6) problem
- lemmiwinks
- Source for basic OBD-ii cable ???
- OK, one more question... Is there a way of VAGing OFF the auto dim mirrors feature? Car is a B6 S4.
- Is this a cause for concern? Car is an RS6 if that matters any. Was told no biggie, but I'm having
- help newbie
- ABS Cross post from B5 S4 forum
- check engine light for catalytic converter
- 2001 A6 2.7t will not interface with vag-com....
- How to get rid of the seat belt chime?...2000 A4
- Should I replace the ECU??
- Hood sensor switch electrical cable was severed and alarm not arming
- newbe question
- Problem Connecting ProDiag to 2004 AllRoad...(on a Treo600)
- Engine module login code (europe)
- Anyone have a VAG-COM in San Diego/Orange County area?
- Group 30 O2s Ctrl
- Trying to recode Tip
- 0991 (lights) and 01367 (locking system leak)
- Will vag-com diagnose onstar problems? not many audis have it but mine is having problems
- A few codes to be explained
- DRL via VAG?
- Help with my Car and what i have seen while doing VAG logging.
- Ok, so this is a tiny bit off-topic (since it's not "VAG" related)... but can I use my HEX-USB
- Suggestions for disabling annoying seat belt chime in '04 B6 S4???
- VAG 00032 won't stick
- Of No Horn Sound, Loosing Codes and Other Inconveniences
- Vag'd my 2000 S4, got a central locking code....cleared it
- Got a CEL: Code 17544 & 18010
- Is there a way to keep the radio on
- Identify socket type GIAC uses?
- Vag the following codes b/c airbag light is on
- DTC 00797 Sunlight photo sensor (G107)
- X-post from S4 forum: ABS controller help!
- Help with fault code 16684, "Random Multiple Cylinder Misfire"
- Whether there are here users VAG-CHECK??
- Need help with ECU & Immo
- Need help with codes. Yes, I'm a noob.
- x-post stereo problems
- need help with some engine codes A4 (B5)
- Code 17965 HELP!
- Clearing airbag codes
- 18021 MIL Control Circuit Open or Short to Plus
- ODBtool cable vs Ross-Tech cable
- Can't find LBL file
- Hello!
- Question on ignition angle!!!!
- difference (in software) between vag-com ver. 311.2 & 409.1
- Pulled these codes, what are they and what do i do?
- Help - 2004 S4 VAG codes?
- Air Bad light came on... Need help
- 17536 - Fuel Trim: Bank 1 (Mult): System too Lean
- Why does my central locking module lose coding?
- Looking for someone with a VAG in sacramento area for help with my ar...
- O2 codes
- What kind of cool things can I re-program in my 97 A4?
- NewB Ques: Buying cable on e-bay vs Ross-Tech
- Looking to get VAG com but want to be able to do logging, etc....
- Check Turbo
- OBDII engineers wanted.
- VAG-COM help
- Noob question, adaptation chan. 62
- 7 digit security code :: Anybody been able to retreive this for the immobilizer?
- Measurement blocks for Audi S4 92?
- Will VAG toold measure the brake fluid level and...
- Serial to USB
- Tuning and Logging VAG Values...
- Serial Vag-Com Cable + ODB Software for Toyota?
- Vag codes
- VAG-noob question here...very easy I hope...just received my Key-com in the mail...
