View Full Version : VAG-COM Discussion
- Uwe, I have a challenge for you!
- Tire size calibration
- Anyone know the codes for 2004 A6 2.7T
- Pro-diag v. Vag-com
- help with readiness code errors...
- San Antonio, TX vag-com?
- How can I check atlernator voltage output with VAG COM?
- vag-com in Chicago area?
- Found some DTCs - both are error messages from the ECU...
- Question on Coding Control Module for unlock features
- Options > Test > Interface Status: Error! Unknown USB Device Found!
- Is it possible to test the vacuum regulator solenoid valve on a 1995 90 with VAG COM?
- If i purchase the HEX-COM usb.. what are the chances of it working with the 2005 A4?
- Trying to make a purchase decision. Does the Vag support
- Vag-com
- is it true that the bosch 5.3 abs system
- VAG newbie...keep experiencing multiple comm errors
- when swapping ecu's whats the code you put in to check it , ( 060 ? ) then hit switch to basic ??
- is it possibel to turn off the abs warning light w/ vag
- Is it possible to make the power folding mirrors, close when you turn off or lock the car?
- Will my ISO - COM (old school) work with any other OBD2 software?
- Fuel consumption adaptation: up or down?
- Car in Safe mode, need help w/error codes since I don't have a Bentley yet...
- RANT: IT REALLY SHOULDN'T BE THIS DIFFICULT!!!!!
- Vag Newbie...getting started, but don't have the S4 Chassis Type for Auto Scan
- 97 A8 VAG problem. init. address ** try 1 then try 2 then try 3
- just got my vag tool tonight, found a few fault codes, can someone help me?
- Airbag light on. Vag-com points to control module. Anyone replace it? (searched - fnd a little info)
- VAS 5052 Eigendiagnoseprotokoll
- Can't find the 20' serial cable for my OBD tool
- 1998 Passat Measured/Requested Boost
- Got my block 115 measured last night.Let me know what you think.What does a stock TT boosts at?
- Before scanning airbag the software gives warning ('00/'01) about controller # 6Q0-909-605-A ...
- NOOB to VAG Tool - A Few Questions...
- Thanks, Andy; looking forward to getting the goodies!
- If i have Vag_Com constantly connected will the car stay in diag mode?
- Has anyone managed to change lighting modes??
- FYI: VAG com does not work in Virtual PC on Apple OS X 10.3 (Panther)
- Can I use the old VAG cable as a Cisco console cable?
- OBD Tool issues?
- having trouble getting started with vagcom
- VAG-COM Question!
- Trying to help somebody with a TT.. Codes enclosed
- I've seen the generic OBDII FAQ on your web site, but my question is....
- Anyone got a Vag in yhe Toronto Area?
- VAG questions - A8 - I am interested in doing a few things.
- Vag Fuel Trim Question
- what exactly is the location that the two pressure measurements in block 115 are taken from?
- Do you guys ship the software and key-usb cable to APO addresses?
- Does anyone technically own the rights to VWTool anymore? I don't want to pirate software...
- Focus Zenons?
- What is a VAG 1598/22 Test Box?
- Allroad 2.7T fault codes.
- VAG help in Philly please
- Can the radio in an S4 be "de-bosed" with the shareware version of the software?
- New dashboard adaptation
- No luck trying to connect to engine
- can anyone tell me more about what this code means?
- Mass Air Flow & Boost #'s
- What is the meaning of "readiness" codes in the engine ECU?
- Block 005 - never see "fl", normal?
- code to change tip tranny ECU to 5 speed and back to 5sp if its not the same code.
- MAF reading limitations with vag.com?
- Getting VAG-Com to work
- Coding a US 2004 A4
- VAG-COM vs. Aut. Transmission module
- A2 service interval
- VAG-COM Beta 402.3 is Now Available!
- VAG 1552 COMMUNICATION PROBLEMS
- Problems connecting VAG-COM to a S4
- What am I doing wrong?
- Anyone in NJ have a Vag I can use for 5 minutes?
- A bunch of Noob questions.
- Radio: codes 00850, 00668 and 00852 - what's that?
- What block do I record for a bad MAF? What SHOULD the readings be?
- Light power and VAG software
- is there something like prodiag or vag-com for BMW's?
- So I'm trying to get everything together to be able to use my HEX-COM...
- 00523 fault code, inlet air temp sensor
- Is vag-com going to offered a rapid transfer protocol like Apr's software?
- Anyone in Philly area with VAG that will work with '03 A6
- HELP codes:
- "Comm errors" on HEX-USB
- Problems with Vag.Com on 2002 A6
- Can read all codes but Engine..
- K-Line voltage high.
- Where can I download older versions of VAG-COM?
- Anyone want to help me interpret these....
- can some one give me a hand on exporting files to exel with the pro-diag
- ZF 5HP 19
- Can I tell if my car supports Cruise?
- Is the TBA on the vag com the 060 group for 99.5 A4?
- Engine Start Blocked by Immobiliser!!!!
- Question abut the upcoming new HEX+CAN interface...
- ProDiag won't completely connect
- Help Uwe Vag can't connect
- Anyone know if you can code the DIS to not come on when you start the car?
- VAG-COM Thoughts on the codes I just pulled
- Vag Help! Concert installed on a 97 A4 yes I did STFA
- To Mr. Uwe@Ross-Tech.com. I have been to your Site. . . .
- im starting to hate this car
- stupid question - how to reset the cel?
- anybody live in maryland with a vag?
- Anyone know how to recode my remote? It stoped working again. Last time dealer did it....
- Intermittent Fault Codes
- did the prices just go up? Just when I was getting my card out . . .
- Is it possible to swap between a chipped ecu and a stock ecu and is recoding involved.
- Help, I've already STFA but I am having my car VAG'ed today...
- DTC 17987 ???
- Radio US to Europe Spacing
- Anti-Lock Fault Code
- VAG socket pin out.
- Anyone have the problem of "too many communication errors " ?
- vag Tire size
- Can VAG change ECU values...??
- anyone have a vag in michigan?
- Is this the VAG-COM "dumb" interface?
- VAG-COM Interface Question..............
- Which port do I have on my car?
- 16500 - engine coolent temp sensor(G62) is it possible
- VAG-COM Beta 401.2 is Now Available!
- (repost) Computer not ready on A4 96 12v
- codes...
- Cross-forum post: Need help with VAG results...
- How can I check the duty cycle of the injectors?
- where do we get the recode values from?
- Help with Codes
- New Beta401 with popup bubble windows: The label files?
- where can i get serial-to-obd2 cables?
- Okay Ross-Tech I got one for you...
- abs help
- oxygen sensor correction limit reached error code.....
- Ride height on Toureg with air suspension?
- Fogs only on '04 A4?
- What is the most accurate way to calculate the a/f with the vag?
- Does ROSS-TECH has a wireless interface?
- Ecu Blocked by Immobilizer
- Uwe - product selection question for '04 A8L and '03 RS6
- anyone running vag on 75mh laptop? must have 100mh or faster cpu on your laptop?
- 2001 A6 2.7t -- fault code 17521- which oxy sensor?
- HELP - I can't find the info on how to run the fuel pump via the vag!?!
- x-post questions about about fault codes i received 01.5 A4
- Can you turn off the "burnt bulb" ie brake light ,warning on a 2001 allroad?
- Can someone give me quick info on how to recode A4 ECU from Tip to manual?
- Does anyone use Prodiag Software on their Palm?
- "Not Ready" during emissions test. (96 12v A4)
- This is my favorite forum to log onto. Always the same thing: Ross-Tech advertising! LOL ;)
- VAG help needed...
- fujitsu adapter - good stuff
- radio safe code
- Fuel Gauge high by 1/8
- VAG-com M-blocks...? Different information in different blocks on differnt 1.8T's?
- cruise control codes
- Faulty DTC's??
- VAG codes explained?
- can you shut off seatbelt warning in a 2004 a4
- Help with Codes
- VAG-COM not talking to car...
- New with vag tb codes not clearing
- Auto Scan stops after one module...
- 98.5 1.8T with Tip trans question
- Anyone know how to reset the readiness codes with the VAG-COM?
- Which blocks should I be logging to determine the fuel mixture?
- Can the VAG tool for a '96 A4 2.8 be used for a '04 A6 4.2 or S4?
- Factory Repair Manual for UK 99 A3?
- Air Bag light on since cold weather hit Northeast. Used a Snap-on MicroSCAN tonight, didn't help.
- HELP needed Error:17938 - Camshshaft Timing Adjustment: Short to Ground
- Xpost from B6 S4 .....anyone know what this error might mean?
- hi all... i cleared my CEL, and several other lights.. but i still can't figure out how to clear ln2
- Haldex Diag with VAG-COM
- Any block that I can monitor/log to show Haldex engage and disengaged?
- BAD COMPUTER?
- Question for Andy...
- Still throwing 2 codes... think it's a bad 02 sensor....
- Will a HEX-COM work with a Serial to USB adapter?
- Ok, connected but NOT all modules. Suggestions?
- Engine Code in the VAG & Transmission ECU Version
- Vag-com doesn't recognise the car-any help?
- LTFT and STFT on 2.8
- No luck w/remote matching via VAG-COM (part II)
- Does ProDiag provide same functionality as VAG-COMM?
- Help adapting a new key/remote to a VW Beetle.
- Tranny recode....
- GIAC Chip & VAG-COM
- Anyone know this DTC -- 16825 - Evap Emission Control Sys: Incorrect Flow?
- VAG tool won't connect to the allroad.
- is their a way to vag when low fuel comes on in a 2003 a4.. i want it to warn me on 20 miles left
- Can seat belt warning be programmed on 2004
- VAG?
- Adr 01 error 08011
- semi X-Post: Check Engine Light and DTCs
- can someone tell me if they think 18021 could be caused by
- symphony 2 with stuck volume control
- Does anyone know where to get Audi Serice Codes?
- Rev history?
- Heck of a time to learn how to use our VAG
- CEL error codes
- Error Code
- New Vag System
- Another VAG-COM Question(?)
- No Idea where to start
- looking for suport on this darn work shop code....
- recode question for a 1998 a4 1.8tqm with a 97 auto-front track ecu
- anyone near annapolis, MD??
- 04 S4 Bose EQ adjusts??
- Still the same error : EPC Light & 18047 DTC Error
- What VAG-COM would you recommend for a..........
- where to get VAG tools
- Knock, Timing correction..
- 96 a4 quattro - modules not connecting????
- DTC 17536, Black Smoke, 1.8T engine
- engine dtc's inside..........please help
- Just got my Vag - Com today, and I need some help.
- VAG gave me the following codes...help/advice needed
- Keyspan USA-19HS does it work?
- looking for suff
- Help with a new code
- The VAG-COM Printable Manual version 311.2 is now available
- new laptop, no serial port, can you use a usb to serial port converter anyone know?
- Just downloaded and installed v311.2, and sent in for my activation code.
- fuel mixture on a 12V
- Instrument programming
- FWD to AWD
- Throtle adaptation
- My gf's mystique has an ODBII connector, can I vag-com it?
- Hey all, got an error code...18017
- HEX-COM from my TT work on my 1990 Audi 100? Possible?
- cel help
- Problem with trip computer screen. Help please!!
- Will driving w/ Hazard Relay disconnected trigger the Engine Light?
- Question on parktronic....
- is a vag tool neccessary when installing a new engine?
- AWE-tuning has a Vag sale...Which type do I need?
- Radio settings VW/Audi
- Question Regarding CAN bus and coding a A/C head unit
- where can i get the options for the codes for my B6 S4?
- Trying to adjust alarm sensitivity on a friend's 98 2.8 A4 with aftermarket head unit.
- i am having problem with headlight range
- the airbag light stayed on all day
- "Evaporative emissions - large leak" ?
- Has anyone got a Toshiba 700 series ppc to work with the VAG-Com software?
- Any way to "VAG" a 1998.5 and a 2003 A4 to switch the radio off upon opening door vs. shutting...
- Audi B6 S4, dealer has not put any maintenance schedule so it display:
- Perhaps I can get an explanation for this fault:
- Adjusting steering angle sensor with vagcom?
- measuring block 211 questions
- My car is throwing codes PLEASE HELP!
- help with B6 A4 xenon alignment. 55-headlight range category
- 18047 DTC Error : Please I need some help
- Recoded the engine softcode, then restored, and my engine light is on?
