View Full Version : VAG-COM Discussion
- If I have a UNI-COM and format my computer, do I have to pay for the software again?
- Kudos to Uwe/Ross Tech
- Please take a look to answer my question.
- Few questions about my new VAG COM
- Looking for a Hex-Com BC Canada
- Looking for Vag com in VT - Burlington Area..
- OK, I'll ask again...Is the temperature readout on a B5 S4 adjustable using the Vag-Com ????
- Auto Check System (LCD Warning) - Engine Coolant
- measuring block 000 display field 9 always 000
- DTC 17584/17585-O2 sensor behind catalyst-correction limit reached...what does this mean?
- changing ecu
- Computer panel screen
- adding in the audi remote entry controller...
- Why can`t I access the ABS control module?
- HP5455 Blue tooth and Wifi, Just bought one, Anyone doing cool stuff with theirs??
- What is this fault code a result of...other than the obvious.
- I need help with 98 Audi A4 2.8 Fault Codes
- How long does it take to match throttle body in Vag-Com when swapping ecu's .....
- ABS/ESP lights on since I did a cruise control retro-fit
- I'm sure that I read once the procedure to adjust the outside temperature reading using the Vag-Com.
- How to check boost with VAG COM ?
- Need help with a new ECU
- will VAG com work with a MAC w/ Virtual PC?
- Andy can you help, here's a link to my question.
- Do dealers need to program the key?
- Just scanned for fault codes, and found 6 (!). Any ideas on what they are? TIA
- Now that VAG-Com can display multiple gauges can anyone recommend an on-board car computer?
- If you buy a used Hex-USB, and download the software do you have full functionality?
- VAG-COM Release 311.2 Announcement
- improved preformance v6 tdi
- Need to choose best version of VAG-COM interface(PalmVX/Powerbook/Thinkpad/Ipaq)? Help Thanks
- I keep getting the imobilizer code dtc.
- Need VAG help in Philly...
- are the measuring blocks on Shadetree's ProDiag the same as the dealers VAG tool?
- what's the diffrent between TWIN-USB and HEX-USB?
- 2003 B6 A4 1.8T ECU Swap
- Fault code - 16492
- Anyone know how to recode the new auto headlights?
- what does this vag readout mean?
- Looking for somebody with 3.0 Quattro Manual and Vag Com to
- Xenon Headlamp adjustment
- Bose "SVC" function: XPOST
- S4 DTC 17547
- Anyone have some good info on the usage of the Output test feature?
- How do I reset the service reminder on a 2000 A4? I have searched and come up with nothing...
- DTC 16396
- No luck w/remote matching via VAG-COM
- code 01039???
- Key configuring problem
- Soft coding problem with CH ECU--car dies during deceleration
- reseting airbag light
- VAG Tool near Old Greenwich/Stamford CT??
- Door open chime/continuous tone when the key is still in the ignition can it be turned off? Also,
- anyway to see maximum speed or rpm in history of vehicle?
- what is this and why is it off??OFF 12 4096 normal/????-alarm system
- Anybody done a "Dyno" run with their 3.0Quattro
- Can someone please look at this block and help me
- Friend just got a Touareg; does it work with Unicom, or does it have dual
- Seat OBD Connection Problems
- Anybody do the 200hp A6 VAG soft re-code for 5-speed 2.8 A4? Euro codes needed...
- Problem communicating with ABS ECU
- I now get an error 'car isn't OBII compatable' on my ISO com where in the past it
- VAG-COM for B4's???
- Pleased Help Me
- Throttle question block 005...
- Software coding and what module for fogs on when doors open?
- Got a new code that can't find a good answer to. Need Help
- can someone look at my log for block 020?? i need help understanding it
- replaced battery how do I get my one up/down windows back?
- How do I check boost with my Shady Tree VAG-?
- ross-tech guys!
- can VAG unlock Maximum speed electronically limited?
- TB full throttle adaptation
- Is there anyway to turn off the ABS/Brake warning light and beeping alarm temporarily?
- Measurement Blocks
- Anyone know what controller 7C does? I got DTC 32776 there, but Bentley does not list it.
- is it possible to check what bar chip the ecu has with a vag??
- Troubles with the remote
- CEL Reset strategy
- REPOST: Vag Com connection problems
- Accelorator Position Sensor
- Vag not communicating help please
- throttle position 3/4 = full throttle- WOT=75%??
- Logging Blocks 115 and 120 on a 97 A4
- VAG COM in Seattle/tacoma area?
- Boost problems...again
- Instruments adaption, B6 A4
- what boost are u guys seeing when using vag-com- i'm only at 13psi=(
- Instrument Lights 2002 allroad
- anyone take a look at my raw data- make sure i converted right+graphed correctly?
- Please Help P0431 code. Need GURU!
- VAG COM connection problems
- code P1139
- graphing/scope question/limit?
- Vag-Com connection
- ATTN: UWE or ANDY...can you guys take a look at my scan test and tell me some info how to clear them
- help...beginning programmer
- Are there any blocks that read distance?
- Fuel Adaptation block 32 B and D on 3.0Q Man
- 7800 kms to Service (Service Interval Q)
- 17964 DTC and newbie hose/engine questions
- upgrade question for VAG-Com
- Block 20, timing
- Question on HEX-USB
- Can the instrument panel light mode be changed for an allroad?
- VAG Codes? Please help, I have a trip to go on tomorrow
- those that have upgraded rims/tires and looking to get rid of OEM ....
- Need adivce on how to clear this codes....enclosed..
- what's the deal with aftermarket radios?
- Calling Andy@Ross-Tech.com, Could you take a look at a thread for me? - Thank You
- 2004 A4 3.0Q - auto door lock function - how do I do this
- Anybody tried to "adapt" or "calibrate" the lambda sensors?
- recode transmission type?
- VAG-COM for PDA (Pocket PC 2002)
- Software for BMW
- Uwe, you out there?
- heated steering wheel, any chance VAG can correct?
- Is this forum specifically for the VAG-Com from Rosstech or is it also Pro-Diag diagnostics?
- 99 A6 Avant Trans Intermitent Problem
- Misfire
- Complete List of VAG-COM Mods for an '02 3.0 A4?
- Vag-com scheme
- tried scanning for codes 5 times. I keep getting ""error 3" at random times
- DTC 65535 for 2000 1.8tq Tip...
- Dealer replaced instr. cluster, fuel sending units: errors inside
- Which block logs misfires in cyl.3?
- Disabling passenger airbag - help neded
- auto light coding
- VAG-Com with 1988 80 4C (5sp)?
- Instrument lights mode: Help please!
- I need help (link to my post in S4 forum inside)
- SeatBelt Warning linght in A4/B6
- Does anyone have a write up on how to graph MAF values vs..
- ECU and VIN xpost
- Fuel Pressure; where do you get this?
- What is your instrument code for 07, mine is 07242.....
- Which vag tool is right for me? Can't STFA (arrgh!)
- anybody have their VAG-Com for sale?
- anybody got VAG com in Toronto area?
- Seat Position Memory
- 95 A6 TCM coding
- Com1 Not accessible -- pls help?
- anyone got a VAG in central Jersey...Bridgewater/Hillsborough/Princeon Area?? got a airbag light on
- How activated cruise control in a 2000 A6
- Is this dangerous?
- Can anybody in the Pittsburgh area help me out!???????
- A3 cannot find engine managment
- Problem with car - Check my MAF data please!
- How can a VAG-COM cable go bad? I have the old school ISO-COM cable and it recently stopped working.
- Anybody got a VAG tool in East Texas? I need to see how much boost my TT is running....
- VAG COM Code # 16486/ PO102
- Parking Tone
- Auto headlights??
- anyone feel like interperting my 115 log...
- Protocol error when attempting to access module Engine
- reset inspection light for service on a8
- anyone using Shadetrees ProDiag vag tool for a palm pilot?
- need driver!!!... for usb->serial adapter...
- Connecting to a 1994 90 when sparks fly...
- unable to communicate with scan tool
- New VAG -COM User 99 A6 Avant 2.8
- Oxygen sensor
- login to 09
- Fault code: 01177... thoughts?
- Fault codes on an A3, what do I do??????
- I want to upgrade my old ISO-COM to HEX-USB...
- Any single place to find ALL vag codes for 2001 A6 4.2?
- can esp be set to off as default choice?
- Need Help quick. Need to recode an CH ECU with ESP to Non ESP.
- The A/C display on the TT
- DTC 17769
- Question on fault code indicating lean fuel mixture (add).
- code for installing cd changer
- i just got the ProDiag fr Shadetree, what fun stuff could i do with it?
- looking for some measuring blocks to check 2nd o2 sensor on an A4
- just got my first 2 codes! :( 2001 S4 6spd only 12K no mods
- Does the fog light VAG mod work on a '02 TT?
- Are there any ODB-II functions in VAG-COM?
- scanning for codes
- MPG 4bar FPR vs 5 bar FPR
- Which measuring block for wastegate duty cycle on 99.5 1.8t ndbw?
- 00858 - Connection: Radio ZF Output to Antenna Amplifier
- how do I get to the measuring blocks
- Does anyone know what code is 270 on the transmission?
- Brake wear warning on 2000 A4
- Is there a section for Newbies or an FAQ section in the Vag area??
- erratic speed and fuel readings...
- Changing the US menu to European on A6?
- need servis in Chicago area for my audi 200TQ please
- Something New
- Just got a VAG, how to log Engine RPM???
- Different Block 026(Knock voltage) readings in each cylinder...
- DTC help
- high-speed VAG (ala ecu explorer) any closer to release?
- question about throttle adaptation.
- Wastegate activity and N249 valve?
- Module 032
- Compatability question
- Fault code: 01039... thoughts?
- Q: Hard Wire Radar '03 A6 4.2
- Is there a block in Vag-Com that can measure distance?
- On Board Controllers
- measuring blocks for mbar and torque?
- COMPRO los manuales y libros de mantenimiento del AUDI A6 2.5, TDI V6, modelo del año 99 de 150 cv,
- COMPRO, para AUDI A6 2.5, TDI V6, modelo del año 99 de 150 cv., el Sistema de Aparcamiento Acústico
- Dash Pod illumination Control
- Air bag problem . . .
- 2000 A6 Dash lights
- I'm looking to buy a VAG-COM, any group buys going on?
- how do i find out how much boost im getting??
- Ross-Tech: Have you guys thought about online registrations? It probably wouldn't be too difficult
- Measuring Block codes
- Is my boost normal? Check this out
- Problem with Airbag Light on after switching seats and lack of power to passenger seat... help.. :o(
- Miles Per Gallon
- Anyone in the NYC area with a VAGCOM that can help me with ...
- Which blocks to log for timing?
- HELP!!! So what do you think is going on here......
- A question for VAG-COM adapter,thanks!
- Do missfires mean that the coil or coil is going
- 93 Audi 90cs V6 - 00522 coolant temp code
- Andy/Uwe: Status of the datalogging sample rate upgrade? Please. =)
- installed HKS intake...codes
- DTC -17519 o2 sensor.
- Ghost Codes?
- How to read data from wheel-speed sensors
- Where can I find a Vag-Com kit cheap?
- strange yyyyyyyyy in extra field of immobilizer
- Adjusting MPG in MFD
- Just ordered a VAG-COM I have some questions
- adaptation problems
- my laptop is broken and my new one doesnt have a serial port...
- check engine....
- Code 17522 -- oxygen sensor (post-cat) ...
- just installed my s4 headlights...got the auto-leveler orange wanring light on...how can i clear it?
- Anyone in Colorado have a VAG com that i can use for my S8?
- need help --18057-power train data bus missing message ...
- Recoding didn't "stick" in "46 - Central Convenience"
- vag tool problem.....
- is there a vagtool program for the p-cars??
- attempted to change the codes for that TIP trans and
- How do you enable bose on a Concert II
- odb vag location
- Anyone know if an A6 can use the "inspection" reminder function that some VWs can use? Also -->
- Repair manual for '99 A6
- any suggestions??
- Which Nav disks do I need? Help!
- New some VAG-COM codes?!?!?!
- Can't access ECM on 1998 A8 4.2Q
