View Full Version : VAG-COM Discussion
- New some VAG-COM codes?!?!?!
- Can't access ECM on 1998 A8 4.2Q
- Vag-Com Codes
- problems with diagnostic on 93 Audi 80, via 2x2 connector
- Log 120 claims 368.1Nm @ 3080rpm of net Torque how accurate is this
- Question/problem with Xenon leveling w/VAG-COM
- Way isn't there "VAG-COM VW/Audi Computer Diagnostics " in the search AUDIWORLD database ?
- Questions on my 115 log
- does anyone know when the new hex-usb cable is coming out???
- Can I use Vagcom to have trip comp off as default?
- 01217 Side Airbag Igniter (N199) Driver side 32-10 Resistance too high intermittent
- Many controllers not responding with Hex-Com
- Any new news on increasing VAG-COMs sampling rate? Inquiring minds want to know.
- gee! I't my turn to post some codes! reallly interested in 16684 and 16689
- what and where is this problem?
- Questions about VAG Codes in general...
- Is there a way to check the output of the altitude sensor with Vag-Com?
- XPost: Timing Questions
- New to Vag Com. Please read inside...
- DTC's 16396 and 16712 - any ideas?
- Ever seen this DTC. Maximum engine speed exceeded warranty Voided :)
- Top Troubles with 96 Cabby
- Does anyone know what the correct setting is for recalibration of the trip comp. for SIII?
- STICKY IGNITION SWITCH
- where can I find good manual for VAG COM for download?
- Cause for DTC 16486 and 17862
- airbag light...what is/are the codes that it would throw
- Want to check codes on new purchase
- deciphering vag-com fault codes - help
- Issues after Forge DV-R Install
- need help with ABS codes after suspension install...
- MAF test results, advice needed
- Considering buying ross tech vag com, questions
- VAG codes for lock settings ETC? (00' 1.8T passat)
- 2x2 connector on 93 100CS
- ABS Diagnost which bank is which wheel
- Is there anyway to connect the VAG comm directly to a components K-wire?
- I have a 2002 Audi TT coupe - what version do I need -->
- how to read the save DTC'S saved from the prodiag?
- 3 fault codes
- Stalling '98 A4 1.8t....Need Input
- Dead A6... Help please
- head light, turn light, viper and air cond blower motor not working
- unable to perform throttle body adaptation
- X-post. Duh! I forgot about this forum :)
- kilometers to miles
- Would search, but can't on this forum. Is block 120 accurate when chipped? (S4). I'm betting not.
- X-post, Please help if you have any info or a Bentley Manual!
- dealer vagd the ride. probs...
- Downloaded new beta...says it's registered, but acts like it's still shareware :-(
- obdtools interface set up?
- When is that high speed version of VAG-COM comming out? I'm jealous of those APR people...
- I had to say good-bye to my 24hr clock :-(
- How do you intepret Vag Com log block 030 OS1 and OS2
- code description on vag doesn't match bentley...
- Capturing performance data
- this cable...
- Xenon level
- Need translation of codes.....
- Diag questions...x-post from B6 A4.
- can you Vag gas low to come on when 20 miles is left in DID. car is 03 b6 cabrio
- Adding miles traveled to MFD
- VAG software question...
- engine overheating
- new to car scene... what does this VAG code mean?
- Brake Pad Service Light? Can vag tell if it's front or rear?
- code interpretation
- Is the 03 A6 coding change from the 01 or 02's..
- Is there a way to change the time on the instrument cluster to 24-Hour?
- Throttle adaptation with the Palm Pro-Diag???
- Which vag-com is right for me?
- Diagnostic code help!
- Is it possible to deactivate the passenger airbag using vag-com ??
- Radio Fault on 8E - B6 Audi A4
- FYI: Called Ross-Tech and ordered a USB HEX-COM today. They're making them, but on a limited basis
- VAG-COM Link for S4 Mods & Tech?????
- making symphony ii randomize cds...
- Vagcom help and interpretation needed:
- vag-com sampling rate vs. apr's ecu explorer
- VAG-Check question... how do you log data?
- How do I Recode Something???
- VAG COM Question
- VAG-COM shareware in conjunction with alldatadiy.com
- how to make requested v's actual plot of boost?
- system requirements for VAG-COM?
- Uwe: one more serial port problem/question...
- DTCs 17545 and 17547...
- speedometer calibration with VAG-COM?...
- 01366 code...What triggers it?.....
- question: 93 audi 90cs - VAG
- What block do I log for intake air temperature?
- I have an 04 A4, is there any vag info on the 2004s yet?
- How can I tell if my MAF is going bad with my VAG-com?
- Question on TBA with Vag for B5 A4
- VAG-Check for pocket PC...pretty damn cool!
- Can I reset the Service light on my 2k S4 with the Vag?
- anyone know of Shade Tree Software ?
- DTC 01274 & 01273 air vents only work intermittently...
- ESP light after alignment on a MKIV Jetta
- What block do I log for IAT?
- CEL light on. cant get a dealer apt for a month:( whats the cheapest way to know whats wrong?
- Need help with a couple of Codes...CEL on and these codes come up
- Color Code for Clutch Wire on '02 A4 1.8T
- Is there any way to advance timing or ignition angle with the VAG?
- Headlight Recode
- Newbie question re: knock sensor
- Having trouble resetting the Oil change indicator...
- Need help with 2003 A4 Cab 1.8t remote windows up/down
- Comfort/Security Codes on a UK vehicle
- Cruise control
- Will the HEX-COM work with a usb to serial adapter for my laptop? and....
- Twin-Com in OC
- Question about engine codes for Ross-Tech guys
- Two new O2 sensors and now new codes. is there something else I should be looking for?
- Question about faultcodes after changing steering wheel
- Uwe@Ross-Tech
- had my car on diagnostic computer and no error found-why!!!!
- VAG 1552 help please
- Need some help with interpretation of requested v's actual plot
- A6 windows and door lock control
- 2001 s4 avant radio volume control
- Can I change the language of the cluster to German
- what i have to do to put imp to zero again
- Battery died - jump started car - are these codes normal?
- How do I get the Engine and Tip ECU part #'s through VAG ?
- Does anybody know what this means? (00958)
- Resetting timing adaptation - possible with VAG-com?
- Will twin com work on an 02 passat wagon?
- Qtn using VWtool. Is there any way to log more then 1 block at the same time?
- comp. error
- Op condition (idl/prt/fl/dcl/erch)
- Does Vag-Com Work with 1990 coupe quattros?
- VAG Com and 98 A418TQ
- Anybody know the code to program cuise control on a 2001 A4 1.8t tip????
- I previously had a spead sheet type of diagram which gave all the codes to the comfort mods....
- Hex-com usb sometime in the future...
- TCU Number from a 2002 A6
- HELP! What code to program ECU?
- X Post Need Advice : Check engine light, and oil pressure light on!!!
- Will the recoding program for the auto tranny on the A8/S8 work for a 97A4 ?
- Location of VAG COM port in TT, for perm. install
- P1545 Throttle body malfunction
- Where does ross-tech get all the good car specific mod info from?
- 02 Sensor internal resistance too high - Any reason I shouldn't take this as face value??
- Any trick to getting an '02 4.2 to take Tip recode with a Hexcom? Thanks in advance.
- ok, dumb question...diagnosing boost leaks with vag-com.
- Transmission "readiness code"
- How to remove the ABS light using the VAG CODE? It keeps comming back. Any advice would be great....
- Ok I just want to make sure I got this right before I try...
- Windows up/down with remote
- Fuel injector timing?
- Can I recode my keys with my Vag-Com
- anyone else have trouble logging into the HVAC system? everything else seems to work fine
- How to read out the DTC
- Does a 2002 A6 2.7T use the same connecting port as my 99.5 1.8T ?
- How do I do a TBA with VAG-COM?
- anybody know what might make a car not send a signal to a vag??
- Settle a bet...Can the fogs be recoded to run independent of parking lights...ala fog mod?
- FMIC
- Resetting Idle back to 800?
- Can the fogs be re-coded to work independant of parking lights?
- after installing the Nav Plus HU i got these error codes:
- using vag-com to turn off brake pad wear sensor light
- Vag-Com ?
- Can you guys (Ross-Tech) update VAG-COM so it samples at 18/second?
- HELP dtc 17536 fuel trim, too lean. Replaced MAF but no help...
- Just brought a spare ECU for 2001 A4 1.8t .. what exactly do I do to recode my original to the spare
- Can the ABS light be cleared with VAG on a B5 VW Passat?
- Need a cheap laptop to run VAG-COM on... suggestions?
- How do I reset the computer?
- What's this code mean?
- intermitant stalling and VAG codes
- Vag error question...Here's what happened
- change speed limit to 155?
- Freeware: www.arbal.it
- 03 A4 Bose system codes?
- where to get Vag-Com cable?
- A6 2,8 quattro COMPUTER PROBLEM, pls HELP!
- Retrieving Fault Codes
- ? to Uwe. Any plans for a Pocket PC VAG-COM. software?
- help with DTC 17538 intemittent
- Can the VIN, Cluster ID, and Date of Serial be done with the VAG?
- Help Diagnosing problem..
- how long does it take
- I need to completely uninstall VAG-COM from my work computer
- anyone know the code for making the fan running longer after ignition has been turn off? thks.
- Uwe, have you had a chance to hook up to a new 2004 A8L yet?
- Anyone know how to force 96A6Q auto trans into "fail safe" mode using VAG-COM?
- VAG ever state wrong DTC description?
- 2000 TTC Haldex problem
- Anyone ever use their VAG to bleed the brakes using the ABS pump on a B6?
- Help ! I need my headlights always on !
- hex-com quit working..."com1 not accessible" Help?
- I just bought Bentley, I have no idea how to use it.....
- Help... not able to correctly change the "Market Version" under Instruments...
- pinch protection disabling?
- I just got a VAG-COM. If anyone near State College, PA...
- xenon calibrating?
- jet ecu chip
- I'm new to VAG. How to activate the dash board light on when the car started
- Mod's to 20th AE GTI like my A4?
- just got the vag com from ross tech.....already vag'ed my car and it helped a lot..what else can i
- Will the VAG-COM work with a PCMCIA Serial card? If so, which ones?
- Testing secondary air injection system
- running rich on my 03 1.8T......(m)
- Need help with Cruise activation. Would anybody ...
- Block 032 - "duty cycle" -- Is this talking about injector duty cycle?
- FYI - I will be getting my HEX COM on Wednesday. Baltimore Area
- VAG-COM Canada??????
- Anyone looking for a Quatech Serial Adaptor?
- Trouble with Doors...
- HELP ME!!!!
- Pro-Diag (Palm based) log questions
- Will there be/is there any VAG-COM software for Mac?
- Adaptation?
- vag com on ebay
- HELP ME!!!!!! SoftCode:00000
- Getting ABT chip and live in Sacramento....AMS told me i need someone to "VAG"
- The reverse of my A4 doesn't work
- 91' V8q, I've been having stalling problems when shifting into reverse and drive...
- Accept the newcomer!
- This the dreaded "Dead MAF" fault codes ?
- Recoding Instruments (Market Version): Is it ECU-specific or not? ...
- Serial port question
- in block 032 my readings remain constant
- Anyone try running VAG-COM on a Tablet PC yet?
- Is twin-com the same as twin-USB?
- air con wont switch on !!!
- Adaptation channels for new navigation BNS 4.2
- Cannot connect VAG-COM to modules...
- Where can I download the shareware version on vag-com, I lost my disk that came w/cable.
- Question concerning the windows VAG-COM mod on B-6...
- Navigation plus
- have version 208.1, downloaded version 303.1 and installed and i get this on startup(hex com cable)
- 1997 A4 2.6 (UK) Without remote
- Can I recode the sensitivity of the auto-dimming mirrors?
- just got my Vag-com set-up. Any good refernence materials available here?
- How do you pronounce Uwe?
- can I remove (or change) the speed limiter using vag-com?
- Auto Scanning on 1997 B5 A4
- Block 032 Question: Do negative O2S learning values indicate...
- Uwe can I check intake air temps with vag-com?
- Going to the dealership tomorrow and I need....
- Is there some way of finding out what all the numbers in the measuring blocks represent ......
- DTC 16795
- VAG COM connection problems
- Didn't there used to be a listing of people who owned VAG tools on this site?
- Does any version of ETKA have RS4 parts?
- Boost block and other helpful blocks
- Possible to detect low fuel pressure/bad fuel pump with VAG-COM ?
