View Full Version : VAG-COM Discussion
- VAG-COM Help KC, MO
- 2017 Q7 Disable Start/Stop Vag-Com Code
- VAG-COM interface which one to buy?
- A3 1.9 TDI 59 Reg
- major issues in A6 C7
- Drive Select through Green Menu, possible?
- VCDS Log with error codes. Thoughts?
- OBD port not working
- 2013 A4 B8.5 (Facelift) Halogen to Xenon Conversion
- Any way to fix water under headlight on an '08 Q7?
- S7 Vag Com Stability Control question
- '08 Q7 key fob isn't recognized for keyless start?
- Procedure for removing rear caliper A8?
- Splitting cost of Hex-Can in Chicagoland area
- Adapting remotes to 2007 Q7
- Help with 3.0 TDI (VW Marine) turbo actuator.
- Black Friday/ Cyber Monday deals from Car Parts Discount
- S5 with MIL, EPC, TPMS.... Multiple "Short to Ground"
- Anyone with vag-com in Sacramento area?
- Anyone had Win+X Problems with VCDS?
- Dallas VAG-COM
- VAG Com wanted in Nashville, TN
- Audi Q5 Security Access Code (Ross-Tech VCDS)
- A4 b8 2009 DRL-Turn signal thread.
- Audi A6 (C5) VCDS - Everything That I know
- Allroad code 01324
- Audi A5 with 1.8 TFSI misfiring
- Congress Is Trying to Ban Car Hacking In Every Possible Form
- A5 cruise control
- Where
- 2007 A4, help with obd connection
- Central Electrics coding (DRL issue)
- READ - VAG COM
- How to delete old codes
- VAG COM in Atlanta?
- Ross-Tech / VAG-COM or the Schwaben VAG
- c7 2013 S6 - ACC Power Timer?
- c7 2013 S6 - Disable DRL?
- Raleigh, NC VagCom Testing
- what setup would i need?
- Has anyone seen this crazy web-site?
- Audi a5 2015 power steering fault
- Is there a way to disable a sensor from reporting? Keep getting brake bulb alerts.
- '07 Q7 multiple codes and kessy fail upon picking up at paint shop..
- J393 code wont erase
- Navigation Issue - Scanned By VCDS
- Security Access code
- Do I need to erase Adaptive Light Failure code to make error disappear?
- Replacing Steering Wheel Airbag
- P3206 c6 v10
- VAG-COM/VCDIS or Schwaben Self-Contained Diagnostic Tool
- P117C and P3145 codes, D3 V10
- Can anyone help out lower Hudson Valley, NY
- Steering column control module
- Oil reset tool
- vag com ????
- MA/CT VAG-COM and VCDS service
- Vag com in Arlington, VA / Northern VA area?
- 2000 Audi A6 2.7 T Electrical issue HELP PLEASE
- 17696 P1288 help !! Can't resolve
- Windows 10 and VCDS
- VCDS Faults Help
- Atlanta area testing
- What does this VCDS-Lite code indicate?
- Active Lane Assist Retrofit - 5C Lane Maintain Coding
- A4 B5 label files
- audi a4 b8 daytime lights not working
- Particle Filter Soot Mass
- need help with figuring out possible cause for fault codes
- A4 interface box, part number 8D0862335B
- 2016 S7 vag mods security code
- telephone not available, ah crap
- OBD2 Code - P053F - PLEASE HELP!
- A6 C5 4F Rear Turning Blinkers faults
- VCDS connection dropped during cranking
- A7 Mod - Audi Active Lane Assist and Spolier Up Speed
- Need a Security Access code for D3 S8
- Is there a VCDS for Sport Mode on startup?
- Q7 in storage mode
- 2010 Q5 - Battery Regulation Module
- vag not reading says link error
- OBD not cumminicating with scanner
- ADS Default coding on B8.5
- Parking Brake Release Vag Com question...
- low oil level warning - when everything is ok
- 01087 - Basic Setting Not Performed code
- need VAGCOM help in Saratoga NY area?
- Anyone have VAGCOM near Danbury, CT that can help a friend check codes on 2.7T?
- Need help with VAG-COM in Atlanta area
- Northern Colorado Vag Com
- Gremlin???
- 6d power lid a4 all road 2010
- testing cooling fans' high speed
- Fault 01273, 01844 and TPI 2033596/3
- Trouble with 2013 S4 Windows Down/Up Mod
- failed mot due to emmissions
- having issues with starting 2013 allroad HELP!!!
- can anyone with a vag com run a test on 2013 allroad in orange county california?
- HELP AUDI Q5 AFS CODING XENON
- Difficulty with DTC's
- ABS fault?
- Emission Control System - Fault Codes?
- VCDS / VagCom & MMI-3G+ Help...
- fuel level reading wrong
- A7 rain sensor replaced ... Issue with rain sensor
- Audi A4 B8 Problems with Dynamic Steering / ESP & TPMS
- Bluetooth OBD2 scanner?
- 01399 code
- testing drivers seat using Vag-Com
- 2010 Q7 VAG-COM Mods - Window and Roof Control via Fob & Emergency Brake Flash
- Q7 Driver's Seat won't lean all the way forward
- VAG COM needed badly in Metro Detroit (I am in the middle of brake job)
- VAG COM added Hidden Menu
- Adjust steering weight of non-sport 2015 A3 via VCDS/Vag-com?
- Washington DC
- Default ABS Coding - A3 3.2VR6
- VAG-COM coding needed in Arizona on my R8!
- Vag-com on Long Island - need help and will compen$ate
- Anyone have a Vag Com to borrow
- Panel malfunction
- Total car Diagnostics Scan tool question
- VAG-COM Help in Lehigh Valley, Pa.
- anyone near knoxville tn with vag com?
- Adaptation reset?
- help with vagcom
- **RESOLVED** Vag-com Newb' questions.
- Auto EPB
- Passenger detection system bypass
- alarm malfunctions
- '07 Q7 4.2 - Cluster Backlight Coding Issue
- VAG Session in the Greater Seattle area?
- Parking Assist not working-fault codes--PLEASE HELP
- Enable trip computer stalk functions Audi TT 8n
- Chinese ECU stuff.. anyone try it?
- Did any one have tried ELM327 WiFi?VCDS-Mobil?
- Battery Coding - Measuring Blocks
- 2004 A8 4.0TDi Label file for engine
- heater system
- My center cluster has warning messages in French and regular stuff in English!
- Help!! Window motor bad?
- oil level warning light
- Vagcom needed
- VAGCOM / VCDS NEAR Stoke-on-Trent
- VAG-COM near League City, TX
- 5671 - Boost Pressure Regulation P0299
- CODING ACC ON A A4 ALL ROAD?
- Major problem w/ A/C compressor & Adaptations
- Label file for [08] Auto HVAC on B8 RS5
- A/C Issue in Texas, Please Help
- New to this Q7 07 3.6
- 00604 code, seen this a lot but no definite results please help
- 2004 A8L Level Control Adaptation issues
- Trying to find someone to help unlock 14 q7 video in motion
- Power Loss / High Pitch Whistling Noise
- VAG-COM what do I need
- Enabling DRL w/ VagCom unit
- 2000 Audi a6 won't run with MAF sensor plugged in
- Q7 2006 problem with MMI panel E380
- coils
- Where there's a buy
- Adding Remote 2000 A6
- Audi a3 3.2 v6
- Odd misfire issue
- What is cylinder voltage?
- Pad Thickness Adaption - or not ...
- Cold Start Idle Air Control System Malfunction?
- Instrument Cluster consumption signal correction: ERROR
- ABS-Cluster Fault
- a4 8k 44 steering assist security access
- Program
- ignition lock defected
- Just bought a HEX-NET
- what settings to look for to duplicate other car
- VIM Through VAG-COM File Type Question
- HELP Q5 HYBRID BATTERY MODULE REST
- Is this a coding problem?
- Steering Angle Sensor / Steering Column Module (J527)
- VagCom in north Alabama area? Need help!!!
- Ac fan not running
- Anyone with vag com in western suffolk long island?
- Anyone with VAGCOM in San Diego willing to help out a new user ?
- 2007 a8 instrument cluster
- Q7 POS please help
- What tablet are you using?
- Modification Codes
- A5 Cab top up - down with VAG Com Only!
- Vag-Com...to buy or not to buy
- checking original miles/kms on a Q7
- Help...Anybody?
- 2008 Audi A6 4.2 Telephone module keeps resetting back to zero's
- key adaptation question, 2004 S4
- Seeking advice on what to log/graph; checking MAF
- Missing image on Rear Parking Camera
- Hazard lights difficulty
- Default Coding for 2014 A4 (B8) Cent Elect and Insturments
- Interior lights stay on
- VCDS/VAG for 2013 Q7 Help
- Rain Sensor, auto close windows
- coding genuine audi b8 rear led tail lights
- 2003 A4 Cabriolet Electrical Issue
- Possible settings via VCDS
- SetUp Button on Climate Control does Nothing!
- Remote Key Windows/Sunroof VagCom
- Brooklyn
- Atlanta, GA need VAG help please
- calculated soot mass reset
- Does this mean my ECU is bad?
- VAG-COM questions
- How to pair a donor ECM when Original ECM is DEAD - Immo 3
- About to buy 01 Allroad pulled 31 DTCs Suggestions?
- VAG-COM in So. Cal?
- VCDS question.
- Anyone used adkautodiagnostic.com ?
- A7 vcds trouble code help
- Advice on S3 airbag code (via VCDS)
- EGT measurement with Innovate TC-4 and LM-2
- Vag-com in SNH - Hampstead/Manch?
- 5.2L V10 MAF logging
- Long coding Audi A7 - trailer hitch mounted
- module test says voice module not available?
- Blower Motor Faults
- vag com settings for tire and wheel size?
- akkow blue tooth use with audio system?
- Coding Help - Equipment Number Invalid
- Deciphering what's already installed
- Wiper module - fault and mod problems, please help
- anyone in ct that can activate my voice button?
- Newbie in San Jose
- VAG-COM Meet up in St. Louis
- 07 A4 - help with Convenience codes
- Fuel issues
- VCDS PROBLEM PLEASE HELP
- Raleigh Durham Triangle area NC, vagcom wanted
- Recoding Bosch ESP 8.0 modules
- Coding Help with BiXenon Conversion
- AC cuts out in hot weather
- please translate these codes
- Vag Com to fix headlight dysfunction.
- B8 3 faults
- I want to DISABLE side assist feature
- Automatic headlights sensitivity(?)
- datastream group 115
- Voice Command not active
- Vag Com needed - 2014 S4 Northern NJ
- lap timer/oil temp Q3 with VCDS?
- 2001 A6 'No Communication' with Radio help!
- audi q7 diagnostic
- VAG-COM in NJ
