View Full Version : VAG-COM Discussion
- what can my vag do? what is the potential?
- A4 bluetooth telephone: disable automatic import of contacts or choose profile
- clearing obd codes
- chipping an Audi A4 1.8T
- How to "reset" battery meter on MMI High?
- problem with airbag light
- "System too lean" help
- Unable to contact Immobilizer module 25
- Can someone from ross-tech please contact me?
- cant open central locking module
- ecm swap
- Can Gateway Coding Help!
- MAF reading high?
- Swapped out my B7 A4 seats
- service reminder reset problem?
- Clearing Limp Mode with VAGCOM?
- P0306 & P0308 cylinder misfires
- Full codes for a my dealer
- Controlling windows with remote
- help with my codes
- Vag-com USB
- Need some expert help- 2007 Audi A8: Address 17: Instruments - Can't log in.....
- VagCom - S5 - Interface not found!
- VAG-COM Help
- Instrument adaptation. need help
- 16814: catalyst sys. efficiency below threshold, bank 2... O2 senor or Cats?
- Disable Lampcheck? A6 -05
- 2004 A6 4.2 ESP ABS Lights, Many Codes
- Implausible brake light switch signal
- Turning off DRL on new Passat
- DTC 17987 after changing ECM
- Need help with daylight
- really want a vag-com but...
- I want a VAG COM!
- 1999 A6 Trottle Body DTC's Need Help
- VCDS compatible with a 2004 Gallardo?
- 1993 audi 90S and CS, V6 and VAG-COM compatibilty
- help!!
- Q7 Turn Signal Error with Trailer Attached
- Q7 DRL and Headlights at the same time
- Swapped radio and xm won't work
- Vag-Com in SE Detroit?
- C6 - Adjusting Rain Sensor Correction Value
- codes causing check engine
- Ok let's try this again...
- Allroad level adjustment 1-2-3-4 402mod vagcom vag-com vag com
- Please help with code......
- VAG Code 01305 on MFSW - Help
- Checking MAF Group 002 question
- Audi A8 D3 - 2004 - Rain Sensor & Voice Recognition Problem!
- Catalyst System Fault
- I found a fault.....
- Reading ECU software version?
- Changing tire size....
- Please help with this code...
- VAGCOM 101
- EPC light on after hard accelerating, car is in limp mode, please advise
- What does this fault code means?
- B6 - Climate control fault codes
- Drl+fog lights coding possible?A6 4F
- vag-com
- VAG Codes for 2009 A6 Avant
- Dear MED 9 Expert, technical question...
- no response from controller
- VAG-COM Registry
- 1997 a4 computer reset..
- need help with codes??
- How to test Secondary Air Injection pump with VAG?
- Is this lighting set-up possible? (2006 A6)
- Wiring diagram for Audi A6 C4 - please
- Need help with VAG codes... 2000 Audi A6 2.7t
- 1999 A4 airbag module
- VAG in Chicago?
- 2004 A8L yellow suspension light
- Help!!! Need Vag-Com assistance in Austin Texas
- Throwing Code P0171 System Too Lean (bank 1) - any suggestions?
- Leak Detected - MIL on
- vag comm
- vag troubleshoot help.
- Bently Publishers web site problems?
- Can I diagnose AC problems in my 2001 225TTR?
- simos ignition timing
- Can any one tell me why on 05 A6 , the oil Leve display won't activate?
- volume/mute button
- Address 05: Acc/Start Auth.
- Standard code for instruments - 2004 S4?
- need some vag help with a ghost
- Replaced cluster - advancing ODO?
- Softcoding Audi TT for 6 speed gearbox
- Can someone tell me if I can do the following.....
- 2001 A6 4.2 Auto Window & Roof Code
- Unregitered hile licensed cabel
- Need help, trying to reset a fault - Address 52
- Fuel economy display?
- What does "Upper Limit Exceeded" mean in this case...
- Which Cylinder is Misfiring?
- Gauges Went to German & Airbag Light ?!?!
- Measuring blocks not available on EDC17 ecu equipped cars
- Auto Windows?
- I was wondering if i could change the engine code on my 2000 S4 to another...
- VCDS - Lost Service interval information
- Perhaps a basic coding question...
- VAG-COM Cable question
- Auto HVAC excessive comm errors...
- Air suspension problem
- Instrument cluster just repaired, now gauges are screwy
- Central Locking Module - Replaced and wont learn remote????
- In need of a code
- How to reset dasboard service interval alert?
- Replaced O2 sensor and still getting 17524 code. Any suggestions?
- can't recode ECU...
- RS4 Cab, remote windows not working 100%
- How to do output tests for auto transmission 2000 S6
- audi a3 folding mirrors coding!
- Long code and soft code for TTS Xenon Range?
- Lowering car with air suspension. How much is possible?
- Readiness change?
- Question on codes 16502 and 16706
- Problems running VAG-COM and Bentley on Vista 64-bit
- Has anyone else gotten VAG-Com to work under Linux? (Ubuntu in particular)
- Readiness: Secondary Air Injection does not "pass"?
- Is it possible to configure the speed to open/close the rear spoiler of TT mk2 using vag-com?
- Is it possible to code Audi TT (8J) to make a self test on instrument when turning on the car?
- I'm curious as to why I can't get the programming for the window-up remote...
- Am I missing something trying to activate Battery Level in Car menu on U.S. B8 A4?
- B6 A4 - Cranking but won't start and won't connect to Hex-USB
- Since I finally got the downloaded Ross-Tech 409.1 to work with the USB....
- Measuring Value Blocks (MVB) to Check Timing Chain??
- Need some help to clarify
- headlight level system
- a little help with some symptoms and codes, pretty please.
- Having some issues trying to get VAG to work....
- B6 Driver's Seat Issues - are these related, and can I diagnose / reset?
- Possible typo on Ross-Tech site RE: B6 lighting tweaks
- Diesel pump computer adjustment; Audi 80 1Z
- Help, fault code 01044 after swap to euro rs4 wheel....(on US rs4)
- Metric display of Mileage Driving me Crazy
- Rear light active with DRLs?
- digital speedometer in A6 C6 2005
- audi s3 2002/02 abs fault
- Test upon initial connection seems fine - but cannot communicate with certain modules
- Immobilizer question. I bought a new key on ebay for my wife's C5 A6 and got it cut.
- Codes on my wife's 2006 B7 A4 Avant
- Does anyone know the LTFT % trip point for a 17545 - system too rich (add) DTC?
- Checking true mileage of can-bus cars?
- x-post: New FOB doesn't work. Tried many programming steps (VAG-COM, etc)
- Turn off Brakepad Wear Sensor?
- Is there a way to check the number of times the car has been flashed?
- "Active" Cruise Control Question.......can it be added to my 2007 Q7?
- Hello, Help decoding VAG-COM Codes
- Hellllllllllp. :( Anyone know what code 99 refers to? It's on a B7 2.0. Car runs great, just
- DRL's & Seatbelt
- Question for Ross-Techies
- A4 Drive Select - Is there an option to maintain my preferred ADS Selection?
- BLOWN MY CAT????AUDI A4 B7 2.0TFSI
- Tank Leak Test?
- 07 Q7-switched fogs to xenons, now they blink...
- Cruise control function stopped working
- A6 C6 vag code
- What's the difference between HEX-USB and KEY-USB? Is one better than the other for an '02 B6 A4?
- Changed region on US cluster to CND... date time problem?
- Use vag-com to raise warmup catalyst threshold?
- Help! Wipers/washers and horn not working. Fault Codes 00962 and 01753
- help me plz, diesel particular filter???
- Problem running ABS pump using VAG COM
- Help with trouble code 00792 A/C Pressure Switch
- Running Rich, need some help
- VCDS keeps freezing on my computer with a HEX-USB cable.
- Ross-Tech VAG-COM 311.2 Tojan?
- Car wont start after vag com
- Newbie needs help with.... Everything
- 18058 - Powertrain Data Bus: help
- iPhone OBD-II client released today...
- Just coughed up the upgrade fee to keep my Bentley program current, and
- TPMS disable?, see attached, more info? ideas?
- Upgrading HVAC from 1 to 3 Zones Audi a4 8k
- Fuel tank leak detection test "aborts" (???)
- 1997 A6 Sedan with Avant Auto Transmission
- Key-usb tests as OK, but times out when trying to connect to car. v805.2
- TPMS disable, A4Happy, any luck yet?
- 97 A4 Quatro 2.8V6 Automatic
- 16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold (( WHAT DOES THIS MEAN?? ONLY CODE ))
- 18058 (P1650) Data Bus Powertrain missing fr. instrument panel ECU 18050
- Gotta get rid of my computer that has VAG-com on it, but dont have a new computer yet
- What does the part at the top mean: Labels: Redir Fail!
- What would be causing this?
- Alarm Horn (H12) Location?
- VCDS won't let me open certain control modules....
- 3b Passat trans issue.
- Is this a coilpack failure?
- VCDS: Fault Interpretation Please....
- A4 2.0t 2005
- Little FYI about the LED light not being on with the Diagnostic Cable
- Central Electronics info for coding to xenons on A4/A5 B8 chassis?
- Can the HID headlight washers be disabled..?
- How do I check cam timing?
- Seatbelt Chime 04 ar
- tiptronic trans. adaption after upgrading ECU...
- central locking system -> Enabling remote?
- Autoscan.txt File questions
- bother with VAG-COM?
- Help With VAG-Com Codes
- Update on the codes '06 A4 2.0 cam / High pressure fuel pump issue
- Question regarding some communication errors...
- Will a VAG-COM work on my new VW CC?
- Any news on a VAG.COM/VCDS update with UDS/ODX support?
- Question about Bentley licensing...
- Replacing ECU in a 2005 B6 S4?
- Is there any way to Vag the NAV screen to allow for more detail in screens zoomed out farther
- The dreaded winking LED DRL on the 2009 A3, how to disable?
- Diagnostics Question on random misfires
- Reset ECU?
- Portable Vag Com in Montreal?
- Bump -> TPMS (tire pressure) disable on A4 B8
- can clear VSS sensor code but not headlamp range fault on cluster
- High Mileage 2001 A4 1.8T Quattro = best way to inspect?
- cant get ECSTuning cable to work with vag com 409.1.........
- Any way to adjust brightness of display on climate control?
- Can I program my car to start without depressing the clutch?
- Question OBD-II feature in VAG-COM.
- Help with VAG-COM Airbag controller...
- Recs on buying 2nd-hand VAG-COM?
- I have this error on my S8, what should i do?
- 18 T high EGT temp
- Associated with many DTCs is "35-10". What is this related to? Meaning?
- code16825 question
- Having trouble with a B5 S4 code.....
- Anyone have luck running on a MacBook with XP via Bootcamp?
- VCDS airflow in gram/sec and volumetric efficiency
- Vag com mod for A6 (C6)
- Fuel gauge, 7/8 full when tank is full
- 2001 S8 (USA) -- is it possible to code for European lighting and 24 hour clock? danke.
- Setting door unlock with key removal on a 2009 Tiguan?
- TPMS (tire pressure) disable on A4 B8
- ANyone know how to disable TPMS on B8 A5/S5? Attempted according to previous instructions
- Confused as to which VAG product I need for 2004 S4 Avant....
- How do you Reset Suspension limp home mode on A8(D3) with Vag???
- Is there a way to recode/reset the B&O amp
- anyone with vag-com in the milwaukee area who can clear code for me?
- Has anyone tried out Carman on an Audi with OBD2?
- license plate bulb out error - help?
- Question Regarding Code 17538/P1130
- Need some help with how to clear the Steering Angle Sensor code
- Is there any one in the Albany NY area that would be willing to read a code for me??
- Do USB-Serial adapters and/or Vista work with VAG-COM software?
- Port Status OK, Interface Not Found! w/authentic KEY-COM
- Need help diagnosing 18014 ABS code without ABS dash light on
- [01 Engine], [Measuring block 08] button grayed out?
- Is it possible to reprogram the Symphony radio from a B5 S4 from US to Europe.
- B6 intrument cluster Adaption ?
