PDA
View Full Version : VAG-COM Discussion
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. Would replacing the air conditioner compressor cause this DTC?
  2. P1139 Long Term Fuel Trim 2002 allroad 2.7T
  3. My GF accidently threw out the second disk of my bently repair manual, is ther a place i can just
  4. Looking to buy a Key-USB Dongle cable from a member... Question about transfer of ownership
  5. I love Ross Tech. XXOOXOXOXXOOO That is all.
  6. A4 easter eggs: The interior lights turn on like in an airplane.
  7. Lowering D3 A8 - How much is possible?
  8. Does anyone know what 04-Basic Settings under 55-Xenon Range does?
  9. 2006, A8 4E Cluster Coding question, changing wheels from
  10. Need help with vag com Please
  11. ECU ? Question
  12. Ideas on a range of codes. '06 A42.0TQ6M
  13. No Back-Up lights 2K C5 A6 Avant
  14. Looking to buy a Vag-Com... Any for sale?
  15. can I log the knock sensors in my 94 Urs4 ?
  16. Help with 99 A6 aftermath of engine rebuild....
  17. X-post: Help with codes on a B6 A4? TIA!
  18. VAG Noob - 2008 RS4 intake manifold flap issue?
  19. Retracting rear brakes Audi A6 2005
  20. Service Rest Questions
  21. Looking to buy a Vag-Com system but I'm not sure which one is best.
  22. Will the Air/Fuel Ratio Calculation sheet on Ross-Tech work for all applications.......(more inside)
  23. Can VAG-COM change the default start up settings for ESP?
  24. Hex-USB work with 2/3 cars in my driveway
  25. Looking for A6 3.0 AVK 2004 codes
  26. Automatic Transmission controller has gone bad???
  27. error when running basic settings
  28. '00 A6 4.2 codes P1137 & P1139?????
  29. VAG of ABS Control module checks OK
  30. TTS headlights on TT
  31. Anyone have a VAG-COM in Calgary that might be able to help me for a sec?
  32. Idle speed adjustment.
  33. All of a sudden my VAGCOM is not getting an OBD-II connection...>
  34. Too much fuel consumption and VAG-Com diagnose A4 1.8 late 2000
  35. Display group 093 readings
  36. ECU to Instruments comm. and no-start condition
  37. Can't get my VAG-COM to work...
  38. Can VAG control HVAC functions on my 04 A8? Looked at Wiki but didn't find anything.
  39. After Repairing a Problem. I clear code and then go to DEQ for new Tags But Then They Say I have to
  40. i just bought a 02 s6 from the US. i live in canada, can i change the odometer to km's and mpg to...
  41. 1997 A4 2.8L AUTOMATIC PURGE EVAP CANISTER CODE
  42. suspension 402 failure
  43. what cable i need to my a6 1995 2.6L V6 12V
  44. help, downloaded 805.1 from Ross-Tech website and now I can't communicate at all
  45. 01539 on Audi TT
  46. Stupid Fookin' user can't seem to get the right driver for his XP Pro SP2/Dell D630 Latitude
  47. New TCM
  48. Ross-tech: when are you going to make an OSX release?
  49. Not an Audi but.... this is an error on my father's Bentley Flying Spur ... what can this be?
  50. A5 "Can't communicate with CAN bus" per dealer. Any ideas?
  51. Integrate LM-1 or LM-2 wideband sensor with VAG COM
  52. 16684/8 - Misfired on cold start. Engine sputtered and smell of sulfur
  53. P1423, P1411-What do these mean?
  54. VAG code 17748 / P1340
  55. What exactly happens when you clear codes? Strange airbag light fix... and question
  56. seat belt chime
  57. scanner code 4488
  58. Timing Log for RS4
  59. Check the true mileage of a car with Vag Com
  60. How to keep fog lights on with high beams?
  61. 2001 s4 keyless entry problems
  62. Measuring Block 90 - AHA engine ('98 A4 V6 30V)
  63. need code interpretation help
  64. MMI update problems
  65. Please help. '06 A4, 2.0t with CEL on. Fault codes below. Forums searched.Also posted on B7 forum.
  66. Something is weird going on...
  67. Are there any editors available for the V10 ecm?
  68. please advise what to buy....
  69. Is it possible to raise my headlights up with my VAG-COM on a Q7?
  70. Auto Trans Fault Code-P0703
  71. Coding to disable bulb out warning on C5 A6?
  72. If one has a Vag-Com cable, can the latest version of software be downloaded for free?
  73. help needed with immobilizer
  74. can q7 headlights on a canada spec car be reprogrammed
  75. need a lil help please
  76. Programming 97 A8Q to "Sport Mode"
  77. Does anybody know the specific thresholds to trigger a: 17545, 17547 code
  78. Poor running on A6 V8
  79. ABS module recoding
  80. 1 engine fault found...
  81. Windows via remote for '09 TT. I've unchecked all of the 'inactive' in Byte 5 and checked all of the
  82. On a 08 RS4 can the TPMS be deactivated via VAG?
  83. Resetting all engine adaptations to default
  84. level sensor help.
  85. RE: Testers Wanted!! Guided Readiness Scripts
  86. VAG COM Test Impact on Battery, Normal "Cold" Amperage Draw?
  87. Help with B5 S4 Fault Code
  88. ACK 2.8 ltr V6 - misfire or what?
  89. Probably going to order vagcom soon. Couple questions for the gurus...
  90. anyone ever seen a P0735 code?
  91. Retrofitting OEM park assist A4 B7 - help needed
  92. Proper method to reset computer and set new learn data?
  93. Looking for the correct code to enable remote comfort access on 2008 A6.
  94. I bought a generic OBD-II cable, can I download software to make it work with my A4?
  95. Has anyone had any success running a serial port adaptor?
  96. Is there a way of disabling an '05 a6 with the vag tool? or do i need to bring all my keys with me
  97. HELP Need manual engine readiness. had steps on how to reset and lost
  98. Strange issue with the MMI Hidden Menu...
  99. 61-Battery Regul. -- Status: Malfunction 0010
  100. B7 A4 Finland Lighting Type
  101. Which one of these will shut off the parking lights on a B7RS4 ?
  102. Looking for performance software developer.
  103. Will VAG version 8 run in linux wine ?
  104. Problems after updating to version 8.05 of Vag-Com.
  105. Does this mean that the switch is bad, or that something is triggering it? Vag scan inside
  106. Cross platform immobilizer issues
  107. How does one enable the mode button on the stearing wheel to work on a b7 a4.
  108. Vag-com code for B6 S4 disable windshield washer warning light
  109. Measuring block 33 - O2 sensor voltages
  110. coding a g202 accleration / yaw sensor
  111. xenon range faulty
  112. Adaptation Channels for MMI Control Head?
  113. seat belt chime
  114. Are there any PDA phones that Vag com will work on?
  115. Does HEX-USB+CAN Interface work with EOBD cars?
  116. Help: Raleigh NC - VAG Available for Code Reset/Read
  117. ABS/EDL diagnostic procedures
  118. Any way to disable the Bluetooth connect/disconnect tone (09 TT)?
  119. Info/pointers on writing diag app?
  120. Coding list for TT Mk2 Central Electronics
  121. Seat Belt Chime and Forgot Lights on Chime quit working. 02 A4 1.8L
  122. Anyone familiar with vag on the URS cars know if there is anything in there for the IR keys?...
  123. Emissions coding
  124. Trailer Coding
  125. Please help - coding comfort via remote option.
  126. X-post battery meter revisited
  127. Suddenly car is shaking and blinking check engine light
  128. No response from controller...HELP!!!
  129. Compatibility with 1998 Audi A4?
  130. A6 C6 coding
  131. Vag-com to determine a/c problem?
  132. Vag-com list
  133. airbag light & shareware version capability
  134. URGENT HELP NEEDED...03 ABS Module
  135. Anyone here - how do I measure boost on my 2.7T? I have Vag-Com, but don't
  136. seat belt chime and key window control
  137. 05 allroad dash
  138. NO DTC But...
  139. Andy or Anyone...any chance my shipment can be released w/o sig? we both work <more>
  140. 01039 code- Coolant leak?
  141. VAG-COM in Memphis
  142. VCDS on a 3C Passat
  143. Andy & Co....Ordered today w/FedEx 2 day..Can it ship Wed please?? GTG on Sat my place..Thnx..
  144. Any way to turn off license plate "light out" warning with vag-com?
  145. Help please....
  146. Is there a way to turn OFF the feature where the car turns ON the overhead lights when i turn off...
  147. Does the VCDS have any way of removing Component Protection?
  148. Anyone using an Asus PC? Just talked to Andy and did not want to bother him again<more>
  149. What could the repair shop's computer diagnostic have done?
  150. Need a little help: "005 - No or Incorrect Basic Setting / Adaptation"
  151. Symphony II+ Coding - Is there more to be unearthed?
  152. Ross-Tech Vag?
  153. ODBII and VAG-COM readings.
  154. Measuring Block 32 - AHA engine ('98 A4 V6 30V)
  155. How turn off brake wear sensor warning on instrument cluster?
  156. Help with fault found
  157. "free" VAG-COM
  158. Is there a way to get real TPMS on an A6 (instead of the idiot light)?
  159. NAV + Airbag: Internal Control Module Error?
  160. Code 17584 - bank 1 lambda correction downstream catalyst: limit attained
  161. Immo 3 issues
  162. "CAN: Not Ready" Message
  163. VAGCOM Service Reminder blackout with VCDS ver. 805
  164. VAG-com in Waukesha/Milwaukee area?
  165. Vag-Com in MOntreal
  166. P1409 (Tank Ventilation Valve Circ. Electrical Malfunction 17817
  167. What exactly does setting Adapt Ch 01 to 00 do on a 2001 ECU? What are the factory defaults?
  168. What does this mean..."18010 P1602 Power Supply (B+) Terminal 30 - Low Voltage D"....
  169. Problem coding the instrument module????
  170. Vag-com download issue
  171. Need help with codes misfire 2.7T please help!
  172. Need help please with analysis of logs, RE: P1127
  173. error code P1612 on my Audi TT AWP
  174. Error code 01336 From radio
  175. Vag com codes what do they mean
  176. A4 2003 1.8T QU Central Locking No Response from Controller
  177. Cannot perform ECU output tests!
  178. Low requested boost, what can cause it?
  179. MIL on no codes readiness passed
  180. Can a Ford PWM cable be used on an A8
  181. New to VAG-COM
  182. Vag Com-OBD-Acura
  183. Musical VAG-COM serial numbers
  184. VAG-COM Can''t clear all DTC with ebay cable??? Help!!!
  185. Redline tested my MAF, could anything else be the cause of bad readings?
  186. remote key fob adapt help plz!
  187. no response from controller - ABS/Brakes modules
  188. Secondary air injection system Leak test
  189. Anyone know if I can use my VAG COM cable to scan a 2000 Ford Contour?
  190. 2000 A6 2.7T Nav Not Working Nothing Displayed on Info Display AirBag Light Wont Eras
  191. Now I'm confused - possible MAF code, MAF replaced
  192. new to vag
  193. Grrr... Air conditioner stopped working yesterday...
  194. Audi A4 (8E-B6): 1) Instrument coding, 2) Trip Computer and Cruise Control fitting
  195. VAG-COM vs. VAD Mobile?
  196. Will the new 805 Label files work with 405 software??
  197. level control sensor help
  198. Difficulty disabling Seat belt Chime on 2006 A4 B7 3.2
  199. Is there a way to disable the Auto Lock of the car.. Not the speed based one..
  200. 1999 Audi A6 2.8 Quattro 93k miles CEL Help P0441 and P0445
  201. Auto HVAC - Not able to read
  202. did search need to disable TPMS in 2008 A3 TIA
  203. Need some help with Vag-Com
  204. HVAC Basic Settings
  205. recoding central locks [35] - is the AW tech article still valid for a C5 S6?
  206. groups 26 and 27 on VAG 409.XX?
  207. Running out of things to replace, still getting a code.. Getting a consistant 17549 - ......
  208. Thanks to Uwe and entire Ross-Tech team, it made our used car buying experience very sound...
  209. Need help interpreting log data
  210. Any way to have log files saved to diff directory then Installed_directory:\Ross-Tech\VCDS\Logs\ ?
  211. Is it possible to get information about which dealer serviced my car last
  212. Cross-post: My latest check engine light problem from STP cleaner?
  213. How to adaptations for instrument cluster (B5 A4) please!
  214. Kudos to the folks at Ross-Tech...
  215. Need help with central locking recode gone wrong
  216. Swapped instrument cluster, now no radio info in center display...
  217. Lexus automobiles and VAG-COM
  218. Steering angle sensor calibration issues with Vag com
  219. Throwing a code, need some help..P1128
  220. Gas gauge not reading full after fill up
  221. Can I use my Vag-Com to temporarily turn off ABS? My ABS controller is messed up, and
  222. BT issue
  223. Can't run ABS pump with VCDS 805.0 or VAG-COM 704.1
  224. VC on a OBD-II Car
  225. Why does VCDS 805.0 keep prompting me to install it each time I reboot?
  226. Please help with VAG-COM and activation of a new key...
  227. x-post from the TT forum: Need help with a CEL - 17584 (P1176)
  228. Where to look to buy second hand (other than e-bay)?
  229. Uwe? Andy? Theresias? Anyone?
  230. What's changed in the newest version?
  231. Need Help! - A6 2.7t with AWE RSK04 kit - Logging block 115 & 119
  232. Need Help! Keep getting no response from controller. I have a HEX-USB...
  233. Any way of changing the 10,000 mile Service reminder to 7,500?? X Post
  234. old vag.com owner with new vag car....(cable question within)
  235. Post overhaul codes help (VAG-COM Rocks!)
  236. Any way of changing the 10,000 mile Service reminder to 7,500??
  237. Surging/Throttle Issues in chip mode. Have Vag codes. Need HELP!
  238. New To me Ross Tech Vag... Q's within..
  239. New VAG User
  240. Fault Code on 2007 A8 4.2 TDI (D3)
  241. vag com on audi tt
  242. Couple codes and CEL is on.
  243. 12 Hour Clock
  244. Help with some codes...
  245. VCDS 805 Manual - Availability?
  246. A4 B5 Alarm coding
  247. HP/TQ numbers from Vag com?
  248. VAG COM problem
  249. Lable file update?
  250. is it possible to see the boost pressure through the VAG?
