- Finished the timing belt job...ECS treated me well.
- anyone know what is the side of the Stasis engine mount top nut ?
- Reiger Window Spoiler *Puts on Flame Suit**edit**Pic added**
- Taking apart headlight assembly tonight. Do I need to disconnect the batt/worry about any stored
- Considering swaybar for Avant: is Adco enough or do I need more heavy duty? (Hsport or Neuspeed?)
- Does anyone run the short shifter that sells on Ebay for around $26? Are these things garbage?
- attn: CCW Wheel Owners...
- F/S Falken AZENIS RT-615 245/40R18 aprox 500 miles and about 10 laps
- It takes a college degree to fly a plane but only a high school diploma to fix one:
- opinion needed on Falken FK452. Is it a stiff sidewall tire? How is
- all that have had body work done by a body shop, I'm trying to collect some ammo for a visit
- on a stock avus wheel... what is the backspacing?
- simmply@WMS
- Anyone who has installed K04's, advice needed..
- K04 Inlet kit needed asap - anyone... anyone???
- Ok...we gotta give him some crap...met with Corey S last night for gokarting..
- Tire suggestions?
- B5 S4 AWE Tuning Brake Packages
- Feb.17 GTG planned at AWE Tuning - Willow Grove, PA. GIAC 10% off. DYNO Day!
- NE1 have a B5S4 Torsen diff laying around I can work on for a few weeks?
- how long does it take for the classifieds to update if you posted something new for sale?
- Hmmm ... Stage 3 S4 or R33 Skyline GTR?
- What do you think of these DP's?
- DIY Timing belt - Y or N?
- Does anybody knows the real performance gain with pulleys kits dor an S4 year 2000?
- AUX fan stays on all the time, I did my TB job last weekend
- Anyone in the Baltimore area available to look at a car this weekend
- Anyone try Car2PC? I bought one and can't seem to get it working...
- Well I found my rubbing noise.. Its was the dp flange that connects to the tranny but i need help
- ASP fueling > RS4 fueling ?? or ~ equal ??
- Question: B7 RS4 vs B5 S4, why?
- Oil gurus: my 1st Blackstone analysis...thoughts? comments?
- Attempted Theft
- ASP K04/RS6 Logs CFs MAF and overall timing at 38F FATS run
- is 220 miles to a tank bad gas mileage for stage 3 homebrew?
- s4 vs. motorcycle on the highway!! video
- CLUNK as I get off the gas hard in 1st or 2nd
- Where is the crank pin seal located?
- HELP: replacement TIRES 4 stock S4 rim, for <130$, and no jello feel
- Finally got my whip back-stasis track sports installed, great mod!!
- Outside temp gauge Q's... How low does it go, and does it factor in speed (i.e. windchill)?
- Is there any big hype over a REAL Bosch motorsports 5 bar FPR?
- Finally pulled the trigger on some new shoes.
- Hmm.. not bad for an SUV
- Poll: Black Avant...OZ SL III or. BBS CH
- I was quoted $1200 labor to install coilovers, all control arms, outer cv boots and TRE's. Thoughts?
- OK, who will be the first one. 6 piston monoblock Brembos.
- Click the link to see pics of my broken car, that jiffy lube broke
- Just passed SMOG with flying colors... GIAC Stage 1 (all else stock)
- Will brembo BBK fit behind b6 s4 wheels?
- bbs will not make custom wheels anymore?
- Switching oils?
- i got my 50k service today...
- If the manual adjuster screws on the headlights are stripped, can you do anything
- Whats up in the B5 s4 world? Mine is in pieces still.
- Question about fans
- Failed Clusters News
- poll. whos running 19's for summer? whats your overall expirence?
- quick question about changing the batteries in the key fob....
- Paging Little Red Wagon....
- what are the odds of all six coil packs going at once???
- Trying something diff with an extra set of int trim i have...
- Matt's (OWKenobi's) Mom posted a thank you to all of us AWers in the PacNW forum. (x-post)
- How much do you think it will cost to repair this damage?
- I've all but given up on locating TopSpin Racing Harnesses...
- The new Lexus IS looks like it gets a boost in performance.....and an 8 spd tranny. Too bad it also
- Boys and girls It looks 80% certain I will be rejoining the B5 ranks...
- do up rs4 up pipes make a bihg difference??? im stage 3 aready
- Another "name that noise" - been about 500 miles now since i got a TB/WP service and some seals
- <update> been up a little more then 28 hours straight...Left Rochester at 1:10AM...im stuck
- PSA Scammer alert.
- Another custom tune stage 3 S4, and thank you to Tony @ EPL along with the crew
- A little throw back.... I saw X-1 Racers car today at my friends shop (AVS).... I wish he was still
- Question for those with stoptechs....
- Those with RS4 airbox tops - do you keep the internal "bell housing" which...
- hey Gatoral Al...wow!
- I hope i am not boring you guys, got some more pictures after they are installed
- Stage 3 injector change question
- My Brother (Piggiesmalls) told me to post here for some help
- Key Programming woes...
- Go gators the buckeyes dont stand a chance
- A look back on 06 with the s4. (A recap of events that happened to my s4)
- Anyone here interested in a euro s4 rear bumper? I am talking to Zev at Avalon, and if enough people
- B5 S4 forum still the most active? what's the concensus?
- Ugliest OEM spoiler I have ever seen. WOW> do not miss pic!
- best place to get RS4 MM and Tranny mounts from?
- Doing a Diff/Tranny fluid change this weekend...
- hey Ah10::On Ramen Diet
- Will a bad O2 sensor cause misfires on cyl # 1,2,3 or will the misfire's cause an O2 to go?
- Just a tiiiiiny bit of Clutch pR0n for everyone! :)
- new evo X many photos..i know
- so my tranny decides to take a dump (tip)
- Test drove a used 2007 RS4 yesterday...I'm pretty sure everyone has heard this before...
- Anyone know where I can buy the hose from the y-pipe to the divirter valve?...
- Poll: How is your wet weather braking on stock brakes? Which brake pads?
- Not pimping at all, just a little feedback for you guys!
- iForged Aero's or Hartmann forged DTM 7 spoke?
- Vag-Com help please-
- Fixing Lumbar Support
- don't hate just tell me the true about this bumper and will it block the intercool
- Stasis Motor mount user, please check see it your engine mount have a gap between the black sillicon
- I can't immagine trying to change headlight bulbs with out taking the headlights out...
- there has been alot of talk of the boost levels from the OTS ASP kit. for the record...
- cross post from the C5 forum.....vacuum valve?
- Nogaro B5 S4 on 75 service road and haskell.. (dallas tx) I was in white 90Q
- Any of you guys know this car?
- H7 HID Conversion Kit
- I need a tire recomendation, 19 by 8.0 front, 19 by 8.5 rear, Iforged flux
- Are the procedures *essentially* the same to change our trans + differential fluid as the A4 write
- B8 rendering. Is it just me or has the B aesthetic gone downhill since B5?
- I drove to Rochester NY, got here this AM
- Those using Forge diverter valves
- B7 RS4 guys crack me up...
- Where to purchase good quality carpeted front floor mats? TIA
- Anyone have instructions on Installing both ambient temp sensors??
- S4 Transmission: Is 2000 audi a6 6spd tranny the same as the s4?
- <giddy> I'll be getting my car back in the next day or two...
- Vid: AWE Twin1 with Stock DP's and ASP DP's
- Recv'd my OWK wrist bands...
- once the "silver" interior seats have yellowed...
- ToyGuy zip tie shifter mod...Definately Worth the time!
- Nice photo of the USA flag, at the Eagles/Giants game. c/o "NoSup4U" S4
- So how many people are running the improved APR stage 3? Looking for opinions? How..
- How many Stage 3 peeps are running stock IC's?
- OK sorry, this is the last of this type of post for a while..... but though you guys might like this
- Check the classifieds I just posted a bunch of parts for sale.
- A proper successor to the 2.7T is finally unveiled...
- requesting part# for pressure regulator valve for the pcv system (aka pancake valve)
- Okay - so I get the drive train stabilizer installed...
- Someone's about to grab their ankles on this one!...
- Go Gators!
- Staggered setup...OK if tire size is same? ....
- Real quick, i'm about to do a business trans with imola02...anyone vouch for him
- Tranny gurus...shifter gurus...any help is appreciated..
- Oil temp to high
- Well - starting the year off right (I hope). Just pulled the trigger on some Vogtlands, more
- Congrats to PW's of teh year!
- 2001 A4/S4 Dash Cupholder Replacement
- Mileage rollback anyone? Kind of scary...I thought you could not even do this.
- Is there a DIY writeup with pictures for replacing primary O2 sensors.
- tweaking k03's with lemmiwinks?
- Timing belt question: Is lock-tight necessary for the bolts?
- Suspension BT: Ive had H&R Streets (2 blown) and Vogtlands (too much rear in roll) Whats next?
- anyone have a picture of a proclip ipod holder on a b5
- Autospeed Stage 3: initial impressions
- Damnit I'm lost! Getting BOV sound when letting off after building boost - What i've replaced:
- Who posted this pic yesterday?
- DarIntake.. yes or no?
- Anybody pass emissions with piggies in NJ?
- Temporary Dension mount.... LoL
- help.. misfires in all cylinders besides cyl 2...and it comes and goes..
- We don't need no stinking cats!
- in need of a stock m-box for a dealer trip anyone have one laying around?
- ABS problem - wheel speed sensor data inside...
- ok. facing some decisions coming up... what would you do?
- New sig, now easy to read......
- Front speakers on doors are blown and i have bose system, can i buy nice aftermarket speakers and...
- Is it ok to fire the car up without the radiator for a moment?
- Does an intake leak need fixing?
- Looking for C-NAVI cd for California...where to get!? Anyone have one?
- B6 S4 Winter Wheels Pics
- Has anyone successfully replaced the white aiming knobs on the headlight?
- well..looks like my ABS module is dead at 38k miles...how sad.
- I am purchasing a new MAF
- stoneman have you got the package yet?
- I'm wondering why I can't find any good Detroit AS coverage when I realize it is only 9:00 AM.
- Just replaced timing belt. turned it over by hand a few times and all seemed well...
- Can turbos die with no DTCs, Smoke, Noise ... anything!?
- Anyone Have a picture of the bundle of wires next to the Power Steering resevoir?
- Is today the deadline for calender votes? Can't seem to access URL...
- Your TOP TEN for VAG-COM cable/software.
- Sedan is done: OTS ASP Stg3 logs with pnp'd/clearanced OE RSK04's:
- CEL/codes 1131, 1113
- Got another car in the family
- Right headlight working intermittently...
- intermittent ABS and ESP light and throttle cut...temp CEL killing me...no codes!!!
- could people with a steering wheel mounted boost gauge...
- Random - But where can I find a 3.5'' ID (90mm) PVC or plastic tube? 3.5'' ID x 4'' to be precise.
- I don remember this pic.....From silver arrow
- Stage 3 guys, how do you hold up your engine mount, engine brackets
- Anti theft options??? I will take my answers off air....
- gaddamit. Someone just got a heck of a deal... $610 shipped RS4 IC's.
- shipping advice n e 1?...lowered + corner balanced. Dreading having to ship, ...
- whistles inside at high speeds
- dam shame we (edit: US) didn't get them in 99
- Anyone celebrating Xmas tonight?
- trying to choose between 18" Volk TE37's or OZ sl3's. any recomendations?
- How many BT S4 guys are still running stock internals, in particular stock rods?
- 8D0 907 551L ECU Needed
- SRSLY...I found it very difficult to keep the grin off of my face when Mike fired up my S4
- Opinions needed on the clutch masters stage 4 clutch and lightweight flywheel??
- ok... so I need to sell or store my car - advice please
- Saw a laser sedan pre-01.5 with a woman driver today!...
- I just got a new uncut key fob now how the hell do I get it to work to unlock the doors......
- Tip shifting question
- X Post: Who needs radio removal keys when you got these...
- H&R blown Street Sport - can they be rebuilt?
- Will a shifter assembly work from a 99.5 A4 on a 2001 S4?
- Looks like I will have coilovers going in very shortly. Two questions:
- H&R springs are too low... Eibach anyone?
- Stasis 4:1 torsen diff DIY install write-up
- Smog check... CEL light on
- Changing plugs...need a little help...
- Looking to buy set of OEM b5 s4 rims
- question about stage 3- setup
- Need to find a new shifter assembly..how much am i looking at?
- S is sold, let the vultures in!
- Caractere CA.5 Avant Rear Spoiler
- ABS problem
- WTB asap: K04 inlets, K04 install kit, RS4 clutch, RS4 engine mounts
- paging Eric @ SupremePowerParts - ygm
- saw a black S4 in the parking lot of Chipotle in Hudson, WI on Friday
- Audi S4 Avant Dustop Car Cover and Black S4 Logo Mats on eBay
- AWE cold start --- 2nd morning w/ out the issue
- Anything wrong with the Bosch Premium oil filter for our cars? I was lazy and picked one up at
- Xenon Headlight Module
- With these miles which route for reliable daily driver, stage 3+ or stock?(more)
- installed xenon conversion kit in my fog lights tonite...
- "Internal control module failed self-test" on my Abt/AMS chip, 01.5 S4 6sp M-box
- Why doesn't anybody make Avus S4 OEM style wheels in 18x8.5 at a realistic light weight?
- TURBO LADY JUST WALKED IN MY HOUSE!
- periodicly my one of my lowbeams will shut off, when flicked off and back on
- Who carries Lemforder control arms and are they considered the best?
- 2nd gear grind + plus loose shifter..
- Ok, tell me one more time, bad OCD - Crappy gas milage, sluggish performance, weird boost behavior..
- Swapping Clusters and Changing Mileage
- next question...WTF does this code mean...ran another scan
- already stfa..what is the part # for...
- For Stage III with KO4's, will it be worth going with coated or port and polish exhaust manifolds?
- Ok, I'm trying to figure out these price points. Someone please explain this to me.
- OK Fats Experts- A couple of questions.
- Best place to get fuba antenna for avant?
- Anyone have a line on an airbag control module?
- Anyone know where I can find a replacement driver side exhaust camshaft??
- Any one in the mass area selling Iforged wheels? Or any other type of dished wheel?
- Vag Com questions: cannot connect to controller
- So, my mechanic said the car has too much postive crankcase pressure ...please help!
- Odd Trunk Release Question
- Hey, look-only $45K, US......ghey wheels, though. (I know it's absurdly expens. to federalize......)
- Tony@EPL.... can you answer my Email or give me a call if you around ?
- Poll: Who's replaced their HID Headlight Bulbs? (Based on the post below)
- Hope this ain't a repost >>>
- Girlfriend got me this poster for christmas (knowing my obsession) Does anybody here speak German? I
- Replacement Remote and Key
- Was offered $14k on a 2002 S4 trade. told him yes if i got the s2000 for galvins too.
- Well thanks to Ben I finally got some 19" Rs4 reps.......
- For those who have shipped wheels and tires...
- Ok - I've STFA. Any issues using Bosch Universal O2 Sensor ? Here's the linky
- Do the stock HID bulbs get much dimmer as they get older? I'm wondering if I need to get new bulbs
- WHOA!
