- Is the RS4 center diff 4:1 like Stasis's unit? Direct swap with the S4 unit??
- can you help me identify this exhaust?
- Do B5 A4 & S4 share the same rear diff design and parts?
- First time at the drag strip EVER! didnt do to bad but time to get rid of MTM...
- Crazy night when having A stage3plus,myself,Zo6,355,and a Noble
- Replaced aux fan and it still doesn't work when I run the A/C.
- ECS Tuning has ECSellent customer service.
- Black plastic trim along the door holding down the carpet.....where can i get it? How much
- Had a little AW B5S4 GTG up at NED tonight, unannounced.
- I "fixed" the sunroof wind buffeting problem with an aerodynamic solution! (find out how inside)
- not mine but milltek downpipes w/cats on ebay $775
- tune update ...
- Anyone ever have an axle bolt partially back out??? (long)
- lug bolt size needed for 20 mil spacer......
- AWE pedal covers review (short)
- i promised ill post a few pics of my ol'school AMG...my S4 is down
- Saw a cactus today for the first time in a few years. I don't particularly like the color...
- Bad fuel pressure regulator?
- I need the part #s for 2 ambient temp sensors used for trip comp readings and climate control. TIA!
- BT: carbon fiber hood...
- i've searched "clean alcantara", "alcantara maintenance", and even the tech section but can't
- Oil in my Intercooler tubing!
- oh man whats going on here???
- Can anyone diagnose this tire wear - I've never seen this before (BWW)
- Does anyone have a dyno graph to show that piggie pipes produce more power and would you get........
- wow bedding new stoptech rotors was fun :)
- Spair Tire Question
- need a hand
- need help: misfire while idling goes away if i press the gas.
- witnessed a crazy high speed chase this am in leucadia ca......
- question about piggies.
- Wheel offset for S4 -- 45mm?
- Whats the difference in size between rs4 inlets and s4 inlets? I am going to mod my stockers to fit
- Doing a coolant flush this weekend. Any tips?
- yo, I just got 22s put on, what do you guys think?... <check the sig>
- big threads too wide? use greasemonkey to fix it (FF users only)
- Anybody use Lemmiwinks from the APR USB cable?
- Doh. Richard Hammond hurt in Top Gear crash
- What is the proper way to dispose of radiator fluid? Can I just flush it down the toilet?
- What's the butterfly sound I hear sometimes when the car is cold traveing less than 20 mph?
- Summer may be ending, but the STaSIS 14.5" Brake Sale begins...
- Rewiring bose rear deck speakers - wire with white stripe is positive?
- Poll: Can Zippy drive her S4 better than a golf cart?
- Poll: Shortest time between needing to replace control arms?
- Philly people - still planning on doing a GTG at Victory??
- who is going to be the first to do orbital valved heads on a 2.7t
- Paging OC Avant::A55clown Did you get my email by chance yesterday?
- Achtuning H2O specials going until Friday!
- Thoughts..what would I have to pay for four Samco intercooler hoses- ->
- do they sell aftermarket n75 valves, mine is bad and was wondering what my options are if any...
- Does anyone have a lead on a stock M box ecu? I need one really bad.
- My S4 is at the dealer for transmission trouble... maybe covered... maybe not... opinions?
- ** Pat-SoCal: check your email please **
- Who in LA has a pearl white sedan with a single magnaflow exhaust??
- i just was checkin out the vast website and i noticed there is a fueling kit...can i get a little
- Happy Birthday (5yrs old) to my S4 Avant!!!
- scale 1-10, 1 is most easy, 10 is hard........ how hard is it to swap out rear differential ?
- So, here's one for iridium vs. platinum plugs. Details inside; discussion welcome.
- Has anybody logged the BPV frequency to see if there is a...
- Do control arm parts 8E0 407 506C/8E0 407 505C have the part # on them or just "L" and "R"??
- Trip report. LA-> Seattle in newly Stage 3'ed Tip (long)...
- looking into custom ordering wheels from bbs....
- Changing tranny and diff fluids... what to use?
- Paging Verr?ckt .do you see ...
- Suggestions on a good compound for buffing out surface scratches, and swirls? Using an
- homebrewers
- AWE Tuning at H2O International
- TCD (Zener Diode 4.7v) is directional. Anyone knows which way it should go? STFA and got NADA
- gotta check this video out. Funny Sorry for the cut and paste
- ok guys need your help
- AHH!!! Clutch Issues. Again. Symptoms are Hard to get into gear, reverse does not grind but it is
- Can anyone break down a rough estimate of labor hours to replace the following?
- It's getting to be turbo-happy weather out there! In car temp read 49* outside this a.m...
- quattro history, great vid
- Well my car was wicked fast tonight . 4.6x fats ~ Stage 3- K04s ARP k03 software (v5.0 I think...!)
- Filk Justice Rims...
- More homebrew stage 3 graphs + idle/LTFT data....
- Anyone degree the revolvers yet? Do they have more overlap at idle than the stockers?
- wheel opinions please!!!!!
- Anybody have a black plastic shift trim for sale? For a tip
- stage 2 fats 5.57 sound right? if not what should i log?
- So who all have put in a PC in their car, details, pics, would you build another etc?
- anyone doing either the Barber or VIR QCUSA events this fall?
- whose got the best pricing on bbs lm wheels?
- Anyone want to "loan" me their Hitachi MAF in the NNJ area for 10 minutes? Trying to confirm it's
- What is the most recent version of GIAC 3- code?
- How about some recommendations for a decent yet economical 1/2" air impact wrench
- thoughts about injecting windshield washer fluid via water inj system? please discuss
- If you are running seimens injectors with the stock fuel pump @ 24psi...
- X-Thread fromt he computer forum....
- went through a puddle and the car died
- Got car back today w/ RS4 clutch installed and I'm so sad at the turnout. NOW, suddenly,
- Strange Clutch issue with my Stage 4 CM and LWFW.......
- How many PSI would it take to get our wheel lugs off if torqued to spec?
- Ok lets try this again if anyone is good with Pshop can you hook me up with a new sig..
- Lost my last four Koi Fish tonight. Needless to say I'm very sad...
- Is there a Verruckt in the house?
- Stage 3 TIP guys, MBC in parallel or stand alone?
- Easiest way to tell what chip is in an ECU?
- B5tS4t, time to chill out now...
- Blast From the Past. Chip Shootout.
- Having not driven the S4 in so long, I had forgot how much the police love our cars! :-/
- *block*
- I Love My TIP. Who else agrees. Manual i s nice but for everyday TIP does it.
- Who is the wizard when it comes to explaining the diff between a, b, j, h, aa, etc BOXES...
- can i use any blank key, the isnt a fob key for our car ?
- Finally My ECU-x is working.. BIG thanks to APR and AH10
- Paging davenew - ECUx help in Richmond VA needed...
- Misfire Issue. Cylinder 1 misfires, help/input appreciated. Here is the story...
- Avant anyone?
- What's a good compressor (for an impact wrench) around $3-400 to get for home use?
- i think im gonna sea foam.
- Slightly OT. Friend is buying a F355 from Duluth, GA..
- OT: What do you like best about the AW classifieds? What would you change?
- mercedes 1 > audi 0 ;p
- Who's pearl white S4 parked at Northrop Grumman in Azusa??
- OT:Does anyone know anybody in FL with a exotic car that would want to put there car in a music...
- What do I need to get this in the dash of my car? Harnesses? etc?
- whats the text that I need to put in to make a hyperlink in my sig?
- Car power steering screeching a little...changed fluid...think it the pump?
- Magic!!
- Thoughts on these seats?
- Anyone see this? Wonder how much T-sauce is floating around in some of you junkies??
- How high off the ground is the centre of mass on the stock S4 ??
- Hearing a blow off valve sound when letting off throttle, replaced BPV's but still makes the sound!
- We won again and set another Hill record "VIDEO"
- ABS light on intermittently, and the flashing BRAKE. Besides modulemasters, ne1 else
- Boost level and spike video of my Stage 3 APR (27 p.s.i?) LOOK INSIDE
- Does anyone know for sure whether this is the correct ballast for our cars?
- anyone have a fender roller?
- Very premature Meyle HD tie rod end failure
- POLL: Do you actually changes your pollen filter every 20K miles like the maintenance manual says?
- rear diff mount part # 8A0-599-133B $221 ?! damn ...
- Lost a RS4 centercap- where can I get a replacement?
- Best place to buy OEM Valeo European Headlights for the B5. ECS and lltek sold out and they are....
- POLL: whats yer favorite current mod on your S-Foh?
- CV boot BT: PureMS or Raxles?
- I brokeded my kar. Owdeworld nevar likes me. Imagun if I did dees?
- Couldn't drive my S4 to work yesterday because...
- Front driverside speaker blown, anyone got one laying around?
- Tranny fluid flush - Should the car be cold or shall I do it after driving a bit? 6sp manual tranny
- S4 Vs. Supra.
- for those running ko4/rs6's.......a few questions...
- Got my new rear rotors, but one is damaged, is this safe to put on the car?
- Just called and said my car is done. Got TB, water pump, cam seals, and front engine mount done for
- September exhaust sale @ Tantrumwerks
- So if anyone is bored i would appreciate some pricing feedback...
- Is there a vag channel that shows oil temp? just replaced my oil temp sensor, and still no reading
- sweet vid
- As a bit of a wrap-up to my Stage 3- tuning, here's a hp/FATS plot
- Loss of power at HIGH RPM's in my car info inside
- ECUx cable install issue...XP finds "Cheetah" rather than "APR USB OBDII DIRECT PORT" Help!!!
- Would it be possible to transplant 2.7T in a B7 RS4 or even A4 and get everything working?
- I just wanted to say that I drive an, S Farrrrrrrrrrrrr.....
- HP AND TORQUE graphed for ASP GT25(93oct) vs ASP K04(100oct)
- I forgot about this: european street racing story on CNN this weekend, they had the RS4 v. M5 video.
- Got called out by a 96 supra w/t60 auto, do I have a chance with XR?
- I thought it was time for a new shift knob. Will this fit?
- once again ASP FTW :)
- Anyone have DUH FMIC install instructions?
- FMIC Question
- Poll: easier kill... modded evo or modded sti...
- I think Land Rover AWD system is rear biased... I got the tail out tonight on my run to FedEx
- Too Clear Things Up....Here is the HP Dynoplots for GT25(93oct) and k04(100oct)
- STG3S4-1 Ferrari F430-0
- Not having an ECU in my car has significantly decreased my S4 paranoia
- Anybody heard from dscottjr? He's mia...especially considering how much he posts. :)
- Does anyone have any k04/RS6 hybrids sitting around waiting to be installed?
- Cheapest source for front outer CV boot kit? tia
- S4 Brake Question
- Doing CV joints, TREs, some control arms. Should I presume my bearings are shot at 126k too?
- AWE Boost Follow Up - It Works! :)
- anyone have pics of 19's on their car?
- Anyone!! Where can I get some R8 wheels?? Will they clear my
- best way to ship a hood? NH to OH. suggestions appreciated
- x-post... new addition to my audi family... 1990 Coupe Quattro
- ASP K04/RS6 M-box MAF graph - 3.9X FATS run 4200-6500
- Repost: How to remove carpet in the front?
- A rather different movie of new RS4
- COMPUSTAR ALARM? Who can install?? second time asking...sorry
- where is the FPR located?
- Average/good labor price for timing belt and waterpump change?
- AWE Boost Valve Question
- Comparing AWHP to RWHP. Not directly comparable right?
- OMG. I just realized it's been 7 years! No 7-year itch here. She's a keeper.
- FYI: ASP full exhaust is not as loud as ASP DP/Twin1 combo.
- Second set of K03's just went, looking for the best price on K04's and inlet pipes.
- Vibrant sound clip. Sporty yet civilized in my opinion.
- Does the rear subframe slide left-right the same way that the front subframe does ?
- Anybody wanna hear my tip with Vibrant Catback?
- ASP GT25(93oct) vs ASP K04(100oct) Dynoplots inside....
- boost leak questions? can the accordin hose with the plug thing cause a leak? smoke ?
- hating the GIAC turbo lag
- RS4 tranny mounts and transmision/engine to prop shaft alignment
- WTF Control Arm kit to buy (aluminum uprights, already STFA)?
- 2000 Porsche 911 Carrera 6peed vs. Stage 2 GIAC Tip S4. Drivers race?
- Poll: Homebrew Stage 3 Folks: MBC only, MBC in parallel, or EBC only?
- Repost for weekday crowd...dyno results
- Anybody have a roof mounted bike rack(2bikes) they want to part with?(sedan)
- Limited computer skills here. Can someone tell me how to upload a sound clip?
- interior b pillar part number?
- Bent/Cracked an SSR GT-1. Anyone have one to part with or know where to find?
- STFA Lubricating DV's
- Anyone have any suggestions for "clunking" due to coil bind for my Stasis SS progressive springs?
- Are Greentops 42# injectors (~440cc@3bar/~510cc@4bar) or 45# injectors (~475cc@3bar/~550cc@4bar)??
- I feel like a mush-mouth assclown
- Anyone have a sound clip of an S4 with a "fart can". Ive seen a few on here and want to hear it, Thx
- buddy of mine in the office has an 06 s cooper and was wanting to know
- Sweet save from rolling over. Yeah... all wheel drive.
- What would be the "throatiest" sounding intake? Want the vr6/r32 sound if possible...
- AWE Stage 3'ers Poll: Post your peak boost (please indicate if you have ICs, cams, or etc)
- Thinking of ditching the S for this...
- Whats the current going price for a ready to drop in RNS-e?????
- New track video posted - Pacific Raceways near Seattle, WA
- Any one want to guess what i'll put down on the dyno?
- Can of worms...
- Saturday, September 23 Victory Brewing (Downingtown, PA) at noon...
- mintex red box pad set for the street hit/skip?
- Wanted to thanks Brian at ICS performance in Stamford CT. Very helpful...
- there is no use to install the rear o2's when using test pipes...RIght
- Anyone have GIAC 3- logs (O2s, Timing, MAF, CFs, etc)? Not homebrew on X, but 3- software
- FATS time PRE and POST gutting precats on stock exaust?
- Poll: Does your significant other know the difference between stage 1/2/2+/3 ?
- Anyone have a spare fuse panel cover (onyx) they want to get rid of. Cracked mine.
- Some on track action shots
- reeferbob... look at post below for tshirt pics.
- Paging Rakta Bean - send me an email !!! I have the RS6 Wheel, Bag & Paddles
- Check Engine Light...can a local shop tell me what codes im throwing? or do i need to go to audi?
- funny video, you have to see this...
- serpentine belt / ribbed belt shredding (Help!)
- Does anyone with Pshop wanna be nice and hook me up with a new better sig i got some new mods...
- who else is running asp stg 2 software, for dps and catback? est. Whp?
- Alignment.
- What's my horsepower and torque at stage 2? APR 93 - Vibrant catback - K&N panel filter
- Buying Coilpack VW or Audi?
- a friend of mine looking to get a black sedan, if you're selling - email me with info, thanks!
- Eliminate Transmission rattle with fluid mixing ?....
- Headlight protectors (3M?) for Valeo Ecodes...where to buy a set?
- Anyone know where I can get the green window slider for front pass. without buying the whole
- Had my door lock shaved, now I cannot program my keys! help
- You guys think I'd regret selling my low mileage stage 3 s4 for this a4 avant?
- Where is the engine number on the 2.7T?
- winter wheel offset/spacer question
- Body question.. Windsheild Help
- First round of shirts has been sent/email me if you want one.
- paging mtaesch, markp, snowtrooper, etc, need some input on exhaust / dump system
- I know this is the B5 S4 Forum but would like some thoughts?
- WAG-com...
- who has shipped a stock hood? approx, dimension and weight?
- PBR/Axxiss Metalmaster pads and ECS drilled/slotted rotors are warped when heated up...
