- can i see some pics of painted brake calipers? Thanks.
- POLL: About to get my steering wheel rewrapped...
- Looking for impression of the B7 Rs4 from a well tuned K04ed B5 S4 owner
- Boost gauge plans
- Let my father drive the S4 this afternoon...(his impressions inside, long)
- OK, it appears both my cams are off by approx 2.3 degrees.. is that a lot?
- need new rotors that are stock size. What are some suggegstions? pads as well
- Can you get a RS4/Euro Cluster with WHITE needles that reads in MPH? <more>
- with all the action on here.. can I step in to ask which way the mechanical fan is threaded?
- Why was this locked?
- Broken AWE Twin2 exhaust clamp
- Easy to replace lower radiator hose?
- B5 S4 Lighting ?
- New set HREs on the Imola
- New S3 Content....
- Does anyone here have an account with Carfax? i need to run a VIN
- smoke at start? what is this?
- How much boost should I run with the vast fueling kit?
- wow.. i found out why my tranny was notchy.. no tranny fluid...hmm..
- someone PLEASE help me out with APR chip and Throttle Body Alignment/Fault Code Erase... I've read
- Spark Plug Poll: NGK BKR6E or PFR7Q? Stage 2+, 93 octane
- Great video, despite the 80's pRon music...
- if i made over 400k in a year i could afford coilovers. i would also have more than a
- 5 reasons why i like my s4 more than my girlfriend
- Re: BigBlues post (it will get deleted so )
- Tweaking APR v5 on K04s yields 0.4s FATS improvement - link inside
- I'm changing my ways.... sorry everyone, seriously read more --
- What is a reasonable labor charge to have 4:1 center diff installed? (Warning: OT comment inside)
- Velocity Motoring 19" B7 RS4 wheels on my B5 S4
- been playing around with the car, adding timing. Whats a safe level for correction factor?
- is stock rotor size 321 mm?
- what would make the shifting notcher when the car is moving ?
- and just like that.................it's gone.
- when you bring your car to a shop and hand them the keys are they not responsible?...
- stock ic hose id? when i weld the ic's next week i will keep stock sixe i think
- The only real problem I have about Autospeed products...
- without a lift Brakes have to be the dirtiest job.. And question about beading
- Autospeed represents a huge threat to me!? Come on, you cannot be serious, can you?
- Anyone have close up pictures of RS4 bumper and fenders?
- Are all OEM B5 S4 seats the same?
- just wanted to give a pre-emptive thanks to simpply. i'll have a write up later.
- Noticed the fan on the passenger side near the radiator isn't on...
- would someone PLEASE tell me the cam bolt torque sequence?
- My aux fan in front of the radiator is always on high. Is it easy to change?
- can I see some pics of some brilliant black s4's? THANKS!
- Check out the pics of the RS4 front bumper after the wash, let me know what you guys and ladies
- Performed Darintake mod last night... then killed my first E46 M3...
- Need new windshield (in LA area). Any recommendations on type and plate to get one??
- Post raccoon destruction MADWAGN...
- how much weight would i save w/ a CF hood. Is it worth it?
- MBC and boost gauge installed, if I don't use the N75 valve do I still leave it attached to the
- IPP Intercoolers versus Stock Intercoolers ! Part II ~ The Install
- APR Chip compatibility question
- Scale of 1-10, 10 being the hardest... Level of difficulty of installing a new clutch?
- 01=04 Jetta wheel specs, offest bolt pattern etc?
- NRH oil cooler option
- GTX
- loud knocking sound when shifting.
- Ko4s or ko3s?
- IPP Intercoolers versus Stock Intercoolers ! Part I ~ The Bench Test (edited)
- would it be possible to drop 1 second off of my 1/4 mile time with..
- paging OldskewS4........
- Looking to do a "scientific" study to compare two chips back to back.
- What are the best electric shavers available? I recently bought a new Norelco that is a POS which
- Can someone link me to Bee's pic poster?
- Car Show/Track Event Calendar
- Casa Pics......Please post pictures of your Casa without OEM wheels
- stoopid tranny's
- just a feeler. ne1 consider trading up to b7 a4 2.0t w/ s-line, ti package.?
- VW Corrado with a 2.7T under the hood....
- Homebrew stage 3 tuning questions
- More logs to update ongoing tune
- Anyone have a picture of their MBC installed? I'm installing mine today and am looking for a clean
- Boosting 1-2psi *more* since Watkins Glen II
- AWer in need of HELP!
- Update on headlight problem. It wasn't the lamp or the wiring harness.
- stasis coilovers how do i install them
- Latest mods
- Sudden knocking coming from right front. Loudest at > 5mph on decel.
- Car of the Future
- IK22 or IK20?
- zoldman o2 sensor question.
- Audi RS4 in action in mother Russia.
- After taking some advice from mike2ks4 and lemioux i have eliminated all the Y's and T's in my N249
- Spotted a Black Avant, lowered, exhaust, RS4 rep rims here in SB
- Nothing is worse than trying to participate on a forum and having posts deleted before you can even
- How do I make my picture larger?
- Anyone know anything about a tire called NEXEN N3000?
- anyone in the LA area have an extra power cord for a Valentine 1 i could borrow?
- Rs4 intermittent issue.
- Anyone heard of XTC HID lamps.
- Friend got a B7 Euro RS4 steering wheel and it fits but no horn.
- CHECK ENGINE LIGHT
- Another call for s4wiki help!
- Stage 3 install ... how many hours does it generally take?
- DxC to the courtesy phone please
- Boss just told me to go home..should I leave..she is in TX..I am in Calif?
- 1. where is everyone buying thier water/meth systems? 2. does anybody have a pair of blown ko4's t
- exhaust cam lobe wear limits?
- GREAT start to my Labor Day weekend!! :)
- half day repost for day crowd. Getting a squeak from my lower control arm area, OK to drive...
- What's the status of ASP's front mount IC? (rumor, gossip, & hearsay OK)
- anyone in SoCal have a Kumho MX tire (new or used)....need it by tomorrow (225/40/18)?
- Raise your hand if you "generally" drive too fast...everywhere you go?
- Need to get some tires mounted in the OC (SoCal), can someone
- Friday humor - just got this e-mailed from an OB/GYN friend of mine...(WW)
- Water in my car, how it got there i have no clue....
- What a tard.
- Follow up on explaining Borg Warner boxes to my wife ...
- It's so hard to delay instant gratification a.k.a. another week until i pick up my Stage 3 Tip...
- This is my IAT graph with RS4 ic..
- And the guest dj for today on the s4 forum 80's set: Beerock
- Axels
- So, you want to know how bad SoCal 91 Oct gas is?
- curbside crackdealer I have the top cover plate to your jack.
- Any Advertisers have any deals on K04's and install bits?
- Question about all the vac check-valves ......
- B7 RS4 vs C6 vette
- 3" cat back install, gutted post cats, boost guage flutters.......
- Mechanic charging $700 to repace engine mounts: should I attempt this myself and replace with RS4?
- Anyone in California who's done fueling mods or upgrade...
- So i am thinking about going home brew...
- Any interest in a GTG at Victory (Downingtown, PA) on September 23? Let's say noon.
- Poll: Seats... My current Status Rings in Leather and Kevlar or Stock and buy one cheaper seat?
- x-post re fading cluster repair
- Anyone know if Stasis is open today? All my calls last night and this AM go right into a general VM.
- Will this actually work to allow xenon D2S bulbs to work in our H7 foglight sockets?
- What just happened? Clunking noises.
- Big Topic on injectors. If I pull 18% on RS4 injectors that flow 481cc at 4 Bar, then what are my
- Repost...replacing cluster
- is there a way to make the gas pedal stiffer?
- X-Post: 2000 HP!!
- anyone have a driver side intercooler, and shroud they could part was with ?
- what do you think. since i have to replace it from accident.
- Trouble finding boost leak - coming from rear of engine, and I *think* drivers side
- Does the ECS tuning coilover sleeves kit only work on aftermarkets like bilstein or will
- Pole: Who is stage III with the most miles, and who has the highest miles on their S4?
- For those of you who have done piggie pipes...How long can I expect it to take for
- Paging Farbs
- how my beater 90Q almost caught on fire ...
- need a good body shop in Bay area.
- Tried out an APR chipped ECU last night
- it's been a while since NIKO's car got stolen ...SOMEONE must have seen something float around NYC
- Some surprising info on UHPAS, UHPS and MPS Tires
- How much better, if any, should my 91 octane APR ver 5.0 chip run with about 97 octane
- had a chance to play around with a Z4 M Coupe this mornin'
- My birthday present is in!!!
- What Recaro's are these?? Came across this site... <BWW>
- RS4 PARTS ARE HERE BITCHES~!
- How much cheaper is the labor for installing K03s vs K04s (if it all) since you don't change inlets?
- Got the headlight out indicator tonight. Need to get new HID lamps. Where's a good place to get it
- Finished Greedspeed Snub Mount Install with Bumper ON
- Cheapest place to buy RS4 carbon fiber engine covers?
- The track ate up my two front track tires...
- 60k major service - whats involved?
- 105K service...
- Will this key work for 01.5 6 speed ??
- Homebrew Junkies: I am pulling my motor this weekend, some questions. (F Hose Delete, Spider Delete)
- Squeak/creak from left front lower joint. Should I be worried?
- X- Post from Mid Atlantic Forum. Lookin for a guy I saw last night at Redskins game
- This may be a dumb question but does DP's and aftermarket exhaust ease the stress on turbos
- Replacing cluster with a used cluster
- does this car look familiar?
- ..ahhh!!!!!.. well i just got my car back and thought everything was pretty fine..
- This thing is faaast. Won't be picking on any of these anytime soon.
- Engine is about to go back in after turbo (and other) upgrades. Should I replace EGTs too?
- Who all is bringing their B5S4 to the AWE dyno day in early Oct?
- Another name for Secondary Water Pump? Where can I buy?..
- G31 Senor Clasp wont go back into the TBB!
- What is the consensus on the Nitto NT555?
- does anybody have logs of MAF signal voltage vs g/sec on hitachi? (STOCK!)
- asp tru-dual...too loud or just right?
- Questions for removing dash/door trim
- I have a nickel that wedged my ashtray shut and it won't open. I can take the cover off....
- S4 SmokedU /-/// How long did it take to straighten the emblem?:)
- Wideband O2 guys, have a question for ya...
- Nitto Invo. Wish I had seen this a few weeks ago. Good prices at Discount Tire, too...
- EvilEmpirE my car needs wax. :-)
- Tirerack OZ supperleggera crack update.....HELP PLZ....
- INTAKE QUESTION!!
- i left my sunroof open over night and it rained hard, how do i get the seat back to normal texture?
- Where can you buy a re-manufactured instrument cluster?
- Good online junk yard for S4's ?
- For anyone contemplating the Auxiliary Coolant Pump Repair Kit TSB.
- got my car back.... a few questions...
- Urgent need help, I can win a free dinner at Olive Garden...
- Alignment Q.
- I still have clunking in the front end, any suggestions?
- local APR shop claims TIP 1/4 mile stock high 15s low 16s WTF is it true??
- anyone in the chicago area know a place where i can get a torque converter around here.. without
- Going to Australia, what good stuff for the S4 can I get there? DBA rotors?
- STFA and cant find anything.. does anyone have pics of a nogaro,,,,
- hey guys.. couple of questions.. would a upgraded stall converter at about 2800 rpm take away the
- warranty 12/12 question
- Someone suggested a STaSIS 4:1 Torsen Center Diff GB a while back, did it ever come to fruition?
- Which oil will make the most horsepower for my bi-turbos?
- paging RAD69>>> email me asap
- Smokin S4: did you measure the new cats you got when you put them in?
- Continuing with the InterCOOlin' topic.....heres a few AWE-->RS4-->DUH-->IPP graphs
- This wheel was posted a couple days ago...can someone tell me where you can get them in this finish
- Consequences for running MAF-less and TCD?
- need help with part id
- Warsaw Street Racing Vid...Repost?
- So anyone running Labrees...can you say yay or nay on this idea?
- Got nabbed with radar last night... V1 did NOT go off!
- Paging Jason @ Stasis- i need to send my core back to you- any special instructions?
- just ordered rear trunk and window lip from Zev @ Avalon Motorsports. I'll post pics once I get!
- those with piggie phenolics (or other brand 10mm thick) AND APR bi-pipe
- S4 Turbos Question....
- $2045 / wheel ...damn !!!
- Another good price on front control arms...?
- Who had the pic/link of that Subaru Legacy STi wagon the other day?
- What can cause IAT to read high or actually be high? and Ign. timing low!
- PHATBOX! If you're looking for one, hurry up. This place has 37 of them..
- Where to buy engine and tranny?
- WTF...a white A4 Avant in the bay area has his front and rear bumper painted gloss black..
- Clutch drama (continued...)
- Which B5's have the aluminum mirrors?
- Other than the software sucking... What do you think about the Phatbox...(more)
- Advice re: the dreaded 17125 and torque converter replacement
- Discuss....
- Is there anyway to tap into the factory EGT sensors for Zeitronix?
- So I'm putting Mark P's logging stuff to good use. For all the data/FATS whores, click me....
- Phatbox software sucks teh ass, that is all.
- Need help deciding on RS4 front mesh look...
- Hello old friends whats new......Bluecrush moves to europe
- Does anybody want to sell me one of those LCD displays in the instrument cluster?
- Would anyone be willing to refresh me on how to install 50W boosters
- So is there an up-to-date FATS database?? What should a 3- run?? (edited)
- can a s4 engine be made to fit in a 99 a4 easily , what would be needed other than the tranny,motor?
- Lower control arm install really as easy as this?
- picture time!
- Yet another getting ready for the track post. Is there so much debris on the track
- Just wondering who is the owner of the casa s4 with rs4 bumper and half painted..
- Rear view mirror exploded... where can I get a replacement cheap?
- Since IMHO this forum is the most car centric of AW i would like some feedback on an idea...
- Front to rear weight balance, stock? after stripping interior? questions!
- MJM turbos say that they could make a K04/GT25 hybrid turbo.
- Anyone want to trade my fiber image CF hood for your stock hood, I'm in Michigan?
- does anyone know if a certified audi tech be able to order oem k04s
- Wish I had a bazooka...
- 3rd Gear Problems..more (sorta long)
- Doing more tesing on EGT sensors....Anyone have bad ones laying around they want to send over?
- Charity GTG at H20... Raffle for Race Gas and $100 Gift Certificates
- OEM Bumper dilema
- Innovate THIS:
- Anyone have a carfax accounting active right now?
- Anyone have a spare black drivers side grill? I got attacked my a giant snake.
- I have to take the front end off my car...while I am in there is a new SNUB MOUNT
- weird tach behavior -- showed idle as 1100rpm...but car seemed to be idling normally
