- Tell Mark i got a race for him
- For all of you "P" car fans....
- Got my VAG-COM. First attempt at a FATS run. What am I doing wrong? :P
- Got a video of my screaming turbo and part throttle boost surge...
- Doing brakes this w/e...anything special to know?
- This windshield washer resovoir leaking is pissing me off
- is there a seperate clutch bleed valve?
- To those that replaced their seats...what to do to turn off the air bag light
- i really don't know what to say about this other that WTF was this guy thinking?!?????
- Looking for good cargo net for sedan - any suggestions?
- My S4 won't start
- Anyone with VAG-COM in Huntington Beach area? Beer or vodka red-bull on me
- Repost: any good place to install ko4 in Phily area?
- I dont frequent the S forums, but has anyone been using the ATP elim series in their
- Site input requested
- Will these fit on my S4?
- STFA'd...Fog light mod....my car has independent front and rear's right now....
- RADIATOR DRAIN HELP
- URGENT: More advice needed for seating upper control arm links....
- Picking up a 2000 S4 tomorrow....
- had all control arms replaced...
- LI,NYC,CT local GTG tonight 8PM
- Price for new instrument cluster (or computer display), and BOSE F-L speaker?
- Ultraleggera's
- Pics of my new Cayman for the track...............
- Brake work - including front rotors at the dealer - How much should this run me?
- i'm parting my car out, check the classifieds.
- Anyone come accross this situation: both a rich and a lean fault stored at the same time. MIL on,
- does anyone in the PHILLY (or other) area has a coolant system pressure tester i could borrow ?
- Curious: There was a guy posting in the classifieds for 18" O.Z. SL's with Bridgestone S03's. Did ..
- cross-posting for a good cause
- Considering moving up to an S4 from an A4...
- Low speed click - yes I STFA...
- Theoretic question: What would be the symptom if the hose between the two DVs was...
- Will a 355 brake kit fit behind a 19inch LM?
- S4 - 0, '04 Vette - 2... I KNOW with X sauce and exhaust I can get him...
- Engine Pull
- Naive question...does our slave cylinder have its own fluid or share with another hydraulic system?
- GIAC ecu coding problems - does this sound possible?
- Mid suspension install help request: How to align links to upright?
- Warranty expires on Monday....New cluster installed today...YEAH!!!!!!!!!!
- Should I notice that much of a power loss due to heat soak in the warm weather? I
- tip to manual conversion followup...
- My car seems to make less power with test pipes on pump gas than with cats
- After a few WOT runs to 18psi tapering to 15, car won't boost over 6psi after(limp?), restart....
- picked up my new car last night.
- Does anybody know the bulb type for the 02 S4 side marker?...194 or W5W?
- Help with engine miss-fire?
- Time to point and laugh..
- Track junkies.... I'm doing my first ACNA driving event in May & have a few questions
- TCD Install Question...
- Does anyone know where i can get a print out of the engine codes other than the dealership?
- Anyone know who sells refurbished RS-4 MAFs?
- Going under the knife for a STaSIS 4:1 center diff today. I will be at a bunch of DEs this spring
- i need a portable jack to keep in the trunk. any suggetions?
- whats the torque spec on our headbolts? those things take the force of a thousand hurricanes to
- Car feels noticably stronger after switching from my normal Shell gas to Mobil.
- OK, assuming clutch is toast, which new clutch for Stage2 and how much will it cost incl install?
- Dyno plots....some time back there was a Chicago dyno day. I posted #'s and people asked for the...
- Exhaust
- Damn, can't get to work...6spd won't go into gear. Any of you early birds got any ideas?
- AMS TBB install problems...
- last night I was watching all of my old B5 videos that I collected over the years...
- Doing TB tomorrow, need specs on timing belt tensioner bolts (stfa'd)
- WOOT...F1 Season is under way...That is all!!!
- do you think subaru master technician can swap our turbo?
- Anyone know of any shops in SoCal that can do RNS-D install?
- 3.83 FATS on 91 @43F. APR Stg3 v2.0 iz da shiz
- So I made it back from the Willow Springs today in one piece and the car is running still
- With this navigation unit what else would I need to be fully functinal???
- Can NE1 offer some idea? O2 swaped, still doesn't work....
- A8 rear brake upgrade..what should I do about splash shield?...
- 18K+ ......some free edvertisiing
- does anyone konow why im getting a tail lamp warning on my dash
- Poll: Value of a Stage 3 S4 (no I'm not even considering selling mine)
- 8900 mile Castrol 5w40 oil analysis results on my allroad...
- So friends old boss wants to race me in his 996 turbo 6sp..decent driver, I hear...how many cars do
- Keep getting a false Brake Light Lamp Warning on dash
- Free tech session at speedware...no need to be a member.
- To cam or not to cam... are the "revolver" cams worth it?
- update on the intake..
- Anyone in the Syracuse area w/2001 willing to let me try their MAF?
- The Skull n' Crossbones Mod
- Squeaking Brakes
- anyone know of any good welders of aluminum in north jersey?
- Udate: My Stage 2+ L10 Tip (Caution Tip Info Inside)
- Is it possible to have 800 h.p. or anything even close that in a 01' S4 w/6spd?
- What is the part number of the proclip ipod mount that goes next to the head unit?
- Followup on boost problems between 3800-4200 rpms...
- Help with Greddy III
- pleese help need wire diag. fuse box 2001 s4
- Help with clicking noise please!
- Opinions/experiences with the Audi Platinum Pure Protection plan?
- does upgrading the intercoolers from stock to RS4 or AWE help a lot on a Stage2+ S4?
- Greddy III
- 01 S4 Recap Timing belt issue --the verdict
- Finished the non-fouler O2 mod last weekend with the driver's side (B2-S2) sensor........
- Any "official" 1/4 mile or FATS times for a gt car out yet?? i STFA
- Searched everywhere, can't find info on the 02 sensor "Defouler mod". Anyone have a link?
- Thinking of just having my shop install my MTM F-Hose. How many hours would be fair for labor?
- Why are the Stoptech 355 x 32 mm Rotor/ 6 Piston Caliper kits...
- So how many things can I "T" into my FPR hose anyway??
- Help..........Swaped O2 sensors doesn't clear CEL
- My key and I are both broke
- I have never seen so many sets of k03 turbos on AW classifieds. K04 GB aftermath I guess.
- How many labor hours to install RS4 IC's + engine mounts + collant tank?
- (Ticket Closed) Rear reading lights do not go off? Hit all buttons, on/off, lock/unlock doors
- Planning on modifying my climatronic to fit where the ashtray is...
- Any temporary solution to the leak from Winshield Washer Resorvoir?
- Is Koni best for smooth riding?
- Audi World web site problems. Is it just me, or the new site is taking
- Which boost gauge (other than the AWE one) matches our interior the best?
- dp question
- Repost* Ladies and Gentlemen I had a delightful experience today with my extended warranty.
- *Paging Black Sunshine* What part# is the TT airbag you put in your S? Where did you source it? Do
- i need to get a pair of those wastegate actuator locking clips... the ones that lock the adjustment
- just checked the edyjun directory for the first time in a long time. WOW, thats great work.
- Has anyone heard from Alex(lil' is300)?
- dose the DTS really makes difference
- I think I have to run Stock DP for 2month after full Stage3.... is it bad??
- VDO Gauge install same as AWE? I have wiring and hose kit. Same connection points?
- Anyone else's car maintainance costs come in waves?
- stage 3 with stock exhaust = sucks! bad news...
- i havent seen this before
- any audio gurus on board?? i tried hooking my sub back up but the amp isn't
- so i pull inside drivers handle and.....
- Brake Light Warning annoying me to death
- Note to every one...driving stg. 3+ with labree's dp's and nothing else to work is nuts
- PSA: Leaving your dongle plugged into the OBDII port will drain your battery:-/
- can somebody here help me check out an S4 for me (MA area) ?
- 2000 s4 - symphony stereo programming
- Can someone recommend a good aftermarket WARRANTY? hopefully including wear&tear. TIA!!
- Is there a correlation between Suspension Upgrades and premature Control Arm failures?
- I really can't get over how fast my car is!!!! I had to put it in chip'd/stg3 mode at lunch today
- Kinda funny Imola/taxi story
- I feel dumb for asking this.... Electrical relay BT? EDL defeat discussion inside.
- POLL: If you had $50K to spend on a 2nd car (fun/track car to accompany the S4), what would it be?
- Any special procedures after replacing the O2 sensors? TBA?
- this has been rehashed a million times... will 235/40 18 fit w\out rubbing?
- i think there is a b6 SS retrofit group buy in order. who would be in.
- STock for Stock who would win in a race S4 or SRT-4?
- PSA: do not use duct tape to fix/piece together your s4
- Is build date August 2001 a 2001 model or a 2001.5 model year, i dont have pics
- I got a S4 with a broken oil pan from the auction do you think that the engine is locked ????
- So is it safe to say I can rest assured I wont have any problems once I go w/ GIAC chip?
- Looking for a P/N of the little cable that connects the airbag to the steering wheel
- Got code for my car...any hints?
- Engine Porn, new coolant tank and engine clean.
- Car won't start: Help! It acts like it wants to start but won't turn over
- Anyone interested? brand new as you can see still wrapped up was supposed to go on my A4 but g
- Paging...................NogaroHiro
- Is Englishtown the only track with annoucers this dumb/annoying? Turn your volumes up...
- Can some explain the B6 Shifter Retrofit?
- how much do used stock shifters go for?
- interesting. some type of bird that sharts purple, found my trunk.....
- Dyno Day tomorrow (Friday) at Streetwerke...
- people with LWFW, is it a pita for you guys to start off in first? not sure if it's the
- Stasis motorsport users: Any low-speed knocking from rear coilovers? If so, cause/fix?
- Just curious, when people's coolant expansion tanks crank.....where has the crack been?
- POLL,which boost gauge ? autometer z series or vdo
- Replacing coolant expansion tank. Suggestions? Tips? Thanks in advance.
- PSA: Possible impact of Cone Filter connection on A/F .........
- scary sight...i saw a brand new lambo getting work done at the local audi
- need help with this log, Throttle cut, boost leak or something else?
- Update: My car will still not start. (from last week)
- Windshield Washer Tank Leaking I Think...What To Do??? any DIY???
- anyone buy anything from here???
- falken wheels...
- Anyone have pics of stoptech rear 2 piston caliper kit?
- IIRC, a few of you guys were running Dunlop SP Sport Race tires
- Has anyone experienced any HP gains or real benefits to upgrading the stock air filter to the K&
- Followup on low boost in cold weather...
- cool guy got the latest post!!!! STFA N00b STFA Noob... haha
- Was it possible to get the S4 dash in any color but onyx?
- Darintake, not so pretty for me (sorry its so long)
- Couple rear brake questions...
- Sneak peak at the B7 Stasis Touring car!
- So I talked to my local APR/GIAC dealer today...
- a sad day
- mike2ks4: What do you think?
- Enough Said Its An A4 : P
- Can I get a final answer? "1 wheel is in the air"
- My local GIAC dealer doesn't know about the 3- code. What exactly do I tell him to make it clear?
- 1/4 Time
- Would a 4bar or 5bar FPR cause 12-14mpg driving city/highway? How bought fuel injectors?
- Pressure test veterans...couple of questions.
- Xpost: AWer needs help in NJ
- rs4 intake...
- Anyone w/ GIAC X Chip on Tip car, but no Tip Chip?
- Anybody know the trick to disconnect the driver's aribag wire
- Who posted about Forge 007 springs recently? This might interest you.
- Come on, when are some good threads about how stout or motors are/brands of pistons/rods/crank stren
- ok, my first misfire DTC...
- Imola S4 coming over Cabrillo hill in SB a little before 6:00pm
- would an aftermarket air intake effect a solenoid valve, or make it throw a code
- Feels soo good, but gets hot as hell.
- Is anyone familiar with this set up....
- So who wants to drive my car around and tell me what's wrong with it?
- Any one have a stock new style shifter and center vent for sale?
- show us your knob! ... ... ... ... ... please
- All of a sudden my front passenger door will not open from the outside handle
- At work so no time to really stfa. What's the current limit of the 75x terminal??
- Is ~940rpm idle for a AWE STG III normal?
- How do I replace the drivers side o-ring from the hard pipe to the block in the valley
- Sexxy S4 spotted, been seeing it around town lately its a Nogaro bluewit silver wheels and all black
- Anyone have trunk closing problems, before i used to...
- Will 221 pound weight reduction make a difference on a track??
- Man, the new RS4 is really growing on me...
- Hybrid turbos...
- Will BBS RS-GT 19x8.5 clear BBK? STFA pops up uncertain answers.
- who has the best timing belt kit or should i just use the dealers parts??
- Is there any reason why a Roll Cage for a B5 A4 would not fit a B5 S4?
- Odd idle dying...
- Any ideas: Misfires only in the left bank cylinders 4-5-6. 4 is getting the lion share (not long)
- Incase anyone needs a free O2 sesor crowfoot the bartsbin seems to be giving them away....
- Review: My saga...or going to level 2+ w/ a L10 tip pretty long...
- Drivers side Intercooler part number
- no luck with my defouler mod...can someone help?
- who sniped my RS4 alum mirror housings off of ebay.ca???? I really want a set
- AMS stage 2, block 115 chart. How does this look?
- lease buyout stuff-am i nuts?
- Oh the Irony & Completely Unrelated, Headlights
- LI,NYC,CT Audi GTG march 10th 8pm
- POLL: If you have had an O2 sensor fail please reply here with which one (e.g. B2S1). TIA.
- does SPP still sell the pillar gauge pods? i didnt see it on the new site.
- ignore me. oops.
- How would you make a carbon fiber heatshield like the x1 racer one??
- painting calipers..should i get something other than a kit...opinions?
- How much does this Audi touch-up paint with clear coat usually cost? (pic)
- just curious....how you would you "break in" an engine?
- Dealership BT: I popped the hood after they did some work and a wrench fell out...
- K03's only. How many do NOT get cold oil temp, low boost siren/turbo whine ?
- There will be one happy B5er tonight look what i just got in for him!!!
- Rear Alcon brake pr0n. (BWW)
- anyone know why the heat/AC blow out the air when I ran over bump sometime ?
- is this normal for tracksports for the rear suspension?
- from the Wheel/Tire forum: limited production forged OZ "SL"s
- looking for manual tranny to swap to (from tip) ... can't find one ... any idears?
- Repost for the Day Crowd.....Neuspeed Customer Service Experience.....
- S4 Poor, what is your email addy? I have some questions for you.
- not FS post -mods, pls don't delete : nedd help : how much do you guys think my car worth?
- is this worth pursuing or not?
- Was it dumb to just order primary O2 sensors? I've never gotten a code for the secondaries....
- Anyone w/ a factory 6-Disc Cd Changer for sale? Someone i know is looking for one
- Timing Belt Kits and Warranty
- Some OZ Ultraleggera eye candy on the beast.
- Stage 1/2/2+ poll: Stage/chip type/MBC?/TCD?/MBC set at x psi
- Which photo looks like it contains more?
- anyone want to trade their avant for a 95.5 S6 black on black 100k
- anyone know how to email APR? Their form comes back with an error...
