- burberry headliner hit or skip?
- Ahhhh Does it ever end?!? Finally after changing my O2's,coil packs and fixed the oil leaks
- I think my "S" appreciates the weather!
- Brake light flashing at 100mph?
- Help. Headlight issues. Bad Ignitor?
- Can anyone pls recommend best and cheapest place to get some Redline for my tranny?
- Got a work order from the stealership...
- Could use some assistance figuring out a rear diff problem. i have already STFA
- Lowering Kit? What kit should I get that will not kill my ride quality.
- hit 200,000 miles today!
- Who's running wide (fat) 17" wheels?
- Laser red advice - in need of new bumper - those that went RS4 any regrets? pics?
- headlight malfunction
- should i keep my piggies for stg 3 or use SSAC dps?
- when I dont use my car for like over 6 hours it makes a loud noise for like 1 1/2 min straight
- whatever became of this rs4 conversion?
- Where do you Road Race guys find info on suspension
- B6 S4 Compass rear view mirror
- Cargo Net coming off all the time... what do u guys do? get a new one? or is it just flawed design?
- LOUD ticking noise after motor swap. HELP!
- Stern Adjustable control arms all back in stock!
- WTB S4 with blown or bad engine. Im out of CA. Let me know what you have!
- any problems going with a resurfaced flywheel? or should i just by new?
- Here she is in all her glory, low ps fluid is the only noise, no CEL!
- My Build
- 2000S4 issues - Part 2
- where is the clutch switch, i pulled out 2 block boxes and not sure which
- post your mileage for wheel bearing replacements & price
- Got a bunch of new mounts recently that are waiting to be installed and curious about feed back on
- for those who have done aux coolant pump delete - what do you do with the sensor?
- Timing Belt kit
- Car doesnt drive straight
- Can anyone describe where the path of the wire that leads to the ambient temp sensor in the bumper
- Valley pan area wet. Is it valley pan gasket or PS hose leaking?
- Question: Climate control with heated seat controls interchangeable with a regular climate control
- Anyone have these springs on their S4? 1.4" drop in front is conservative right?
- Found an electrical short in my brake light assembly... fixed
- Ready to pull the trigger on a 2000 w/ 40k miles - couple questions.
- 18" B5 RS4 reps look dumb on stock ride height? yay or nay?
- Turbo line leaking
- seen this new s4 ad?
- W/M injection installed and retuned :-) dyno plot and logs inside
- To those who have the Koni adjustable w/ vogtland club spec springs from Purems, what do you think
- Can i use a 98' a4 coolant expansion tank in place of mine.?
- Anyone have a picture of the location of the front subframe bolt(s)?
- fwiw - low miles 07 A4 FS . . .
- Where to find decent O2 sensor wrench?
- Old school.
- Anyone have a cruise control stalk or whole set-up for sale. i need one asap.
- Where to find a oem ballast?
- i need new Catalytic Converters what are my choices?
- Track junkies - are Nitto NT01 OK in the rain?...
- OT: Can someone post up a pic the stereotypical "M3 Guy".
- Shifitng
- what the hell are teh brake pad sensor wires made of. i can solder them together.
- RS4 clutch question?
- Anyone experienced there brake pad light coming on after hitting a good-sized bump/pot-hole?
- driver side charge pipe, pass side mirror, either egt, i can check, miles? thanks still looking
- need a little help with an EFK install... Can someone tell exactly what wires they tapped into to
- coolant leak - i've noticed i leak coolant after i boost a lot.
- Argh - ABS / ESP and flashing hand brake light...any clue?
- Ford takes on the bi-turbo for its new Taurus SHO.... FO SHO!
- What's the best rear muffler for my application...
- clutch pack E bit it. No more tip fun.
- E-Codes are in rough shape. Anyone ever encounter a melted turn signal housing?
- Best/cheapest clutch for stage 3. NO launching, DD, normal driving. What do you think?
- Repost: ASP Custom Tuning in Chicago the week of March 2nd...
- Official DIY 2000 Audi S4 LCD Instrument Cluster Pixel Repair "No Hot Air Rework Station Needed"
- Does anyone know about Bremmer Kraft BR01 rims?
- FedEx From Pure Motor Sport Came Today........
- This Guy has the best Picture poster pictures i have seen on AW yet
- Cold Start, Lack of Power for first 5 min of driving. NO CEL, need HELP please!!!
- who is running an RS4 instrument cluster? Which country is the best to source from? Germany?
- friends looking for a stock charge pipe by the fan, also a mirror if anyone has some kicking around?
- Found '00 and '01 Audi sales brochures from Chicago Auto Show...
- **Official TIP to 6spd conversion Thread** - i've heard different things regarding this...
- In regards to EGT sensor failures and tuning
- Is a auto to manual worth doing in this situation.....
- Anyone familiar with Phenix wheel repair?
- where to pick up a thule roof rack?
- what kind of gasket maker is everyone using to seal upper and lower oil pans? what is recommended
- When I was driving home last night my dash started making noises like there was a mouse caught
- Someone help me find the mod where you can independently turn on your interior lights
- I have noticed a slight clunk when I hit the gas around 2300-2600 RPMs. Rear differential mount?
- Found this picture in my phone from a wonderful day in my s4. anyone else celebrate?
- Value of 2001.5 S4 Avant with 125 k / Imola 6 speed
- Dyno results from the 034 Dyno Day
- If you haven't heard from Mike@VAST/Piggie....sorry in advance.
- how do you pressure test the cooling system?
- air bag light: seat belt sensor issue
- What do you guys think of this car>
- Anyone ever been failed an inspection for a creaky control arm?
- Most mileage without EGT / O2 sensor failure? Me = 135,000
- Vibration under braking that comes and goes.....
- I have a list of avants that I'm looking at...anyone else selling that I should know about?
- anyone running the Hartmann Evolution R5 wheels?
- Its it very hard to adjust my springs without taking them out of the car?
- WTB S4 front fog lights...
- Leaking fluids.. what part is this??
- 2000S4 issues
- Getting different part #s for fuel filters for 2000 vs. 2001-02 S4s - please help
- With regards to Turbo longevity...
- opinions on stock wheel color
- pic request: m3 lip spoiler on a black sedan(yes i stfa hardcore) TIA
- Anyone have piggies for sale or trade in nyc area?
- Why is there oil in the large grey plastic air intake tube ? (& in the connecting hoses)
- Looking for a stock ECU, any 2000-2002 model.
- Who is selling stock tip DP's? or maybe aftermarket DP's for a tip as long as they're not too much $
- is $280 a decent price for downpipes swap?
- DAMMIT!! I'm pissed and I need your suggestions and advice....
- Has anyone ever had the problem of CEL & EPC light quickly flash alternately when you turn the
- For the achives - if you are going to DIY hardwire a V1 without the hardwire kit - splice the
- Made audi manager look like an a$$ in front of the whole audi service center!!
- Anyone interested? 2001 Audi S4 Avant Nogaro Alcantara 6spd 57k mi Original Owner all docs STOCK
- Central Lock Pump/ Alarm Control unit price?
- for the first time i have problems with VAG! I cant connect to car. I get error about interface not
- would these look good on a Silver S4?
- Is it ok to delete the fan in front of the AC condensor or is that a vital part?
- weird battery light flickering/starting issue (Not the one from a post below) kind of long
- Where can i get a shorter Serpantine belt for my A/C delete and fan clutch delete mod?
- Anyone know the part number for this?
- o2 sensor question, are all 4 sensor same? just diff harness?
- Help! I already searched. I am looking for the part number of the foglight relay module for 01.5 s4.
- This is my first post, although i have been "lurking" for about three years now...
- Anyone have the connectors that the ECU plugs into? or know where I can get one?
- battery light lit up on dash and volt gauge showing <12v while car is on...alternator?
- paging @ bertworks.
- how are the stasis motor mounts??? been looking for info cant find any.
- Help, got these codes the other day, when W/M injects these came up
- What size/type of turbo is the new RS6 using?
- paging mike@vast, ygms!
- I need to take a poop
- Are the foglight lenses glass or plastic?
- does anyone have a spare stock mbox ecu available?
- Has anyone ever deat with US Fidelis Auto warranty Co. insuring their S?
- Having an issue with my brake lights. I searched the forums and this is what I found...
- I remember there was a post about someone making a tint for the reverse light section of our tail
- FS: A box APR ECU , I really need to sell this I have been trying for like 8 months!
- Is it possible to replace the part/material that the leading edge of the belly
- Anyone have a B5 S4 shell, with or without motor.
- Anyone have pics of an OEM RS4 bumper with JHM or like fmic?
- WTB: S4 front bumper... if you have one e-mail me. thanks
- Piano black trim and shifter surround
- Stage 3 K04 turbo swap questions.....
- Can anyone help oil leak repaired...now engine smoking! 2001 S4 Advice would help
- WTB Sym I radio, let me know if you have one for sale Thanks
- My after-run pump/fan sounds like a damn leaf blower...
- What do you guys think of this>
- I have calculated that ALex's car is faster than an Enzo from 60-140 mph.
- caliper or brake cable?
- Not in my S4, but in-car video of my rabbit at the track today.
- serpentine belt noise
- New Sig U Likey?
- Could somebody post logs of their VAST set up, please?
- bank2 sensor 2 issss (passenger or driver)
- Anyway to remove or move the seats without power(motor blown)? Been STFA and nothing.
- Potential used S4 purchase (looking for advice)
- Does anyone recognize this stage 3 S4? AW member?
- Video Audi S4 MRC K04 60-120mph
- noobie to forums. Just wanted to say hi.
- Whats up guys? Im looking for the write up for the foglight mod. I remeber seeing one with pics
- Replacing Driver's Side Turbo Gasket...
- Does anyone has Labree catback mated to piggie pipes?
- Engine won't turn, need help trying to figure out the problem
- Headlight turning yellow after a short time...
- FS: Stage III+++ S4 - $16,000 - Santorin Blue- built motor, custom tuned!!!!! - SEE LINK
- Anyone here go to Anchor Audi in Lynbrook, NY or work there with a b5 s4?
- Sent s4 to audi to get security lockout fixed and they put the code in and it worked. wtf?!?!
- Wheels are leaking air, slowly. Wheels are 3 piece, valve stem? Wheel itself?
- Weird surging issue...
- New bumper insert and clean pix.
- Rims for a 2001 S4
- In-car video of my new personal best FATS and 60-130 with the GenX GT28R kit
- Anyone here an autobody worker? If so, read what I'm having done, hopefully comes out nice!
- misfire cyl#4. swapped coils, new plugs, comp test, still missing
- If im gonna PB Blast the junk out of all the control arm joints/bolts, is a month premature?
- Too funny not to share with you guys.......
- Recovered after accident in last year! So niece to be back, but still lot of work left!
- OUTSTANDING service from Stratmosphere
- Broken bolt update:
- How tough is it to repair a 3 piece wheel?
- Looking for a used aftermarket / performance exhaust, not too concerned with brands.
- What differences are there between EU and US spec cars? might be moving back to EU
- so i am going to take the car in for service, what am i forgetting?
- Your mpg...
- new white BMW M6 - .6, RS6 turbie TIP S4 - .4 (edit!)
- WTF is wrong with my apr security lockout program? it locked me out!
- Has anyone wired in an Audio Jack (for mp3 players)?
- What's correct torque for axle bolt?
- Looking for an avant to put my heart in.
- Question for widebody guys: How many hours labor for welding in the rear...
- My new baby
- melted coilpack!
- Anyone recognize these B5 A4/S4 Ambassadors please?
- Who is running 30 psi(+) boost gauges? What brands, (Besides AWE option)? Do they have vac side?
- Somebody buy this GT car, its $22k! VAG MS S4 For Sale
- Brand new in box Euro post face lift rear trunk whats it worth??
- anyone know where the video is posted a few moinths ago
- Is there anyway to tell the difference between a bad front wheel bearing and a noisy tire?
- For those that wanted pics of the center armrest respray "earlier post"
- ASP Custom Tuning in Chicago the week of March 2nd...
- Observation
- PSA flush your ER coolers before you install them, there was slag and metal crap in mine.
- Is it possible to clean MAF? If it is possible - best way and with what to do it? Thanks.
- Help with rear end vibration. I checked my center support bearing and the rubber is not torn
- Quote: New tie end rods, possibly front CAs
- Another whats it worth post....
- I just bought 6 new Beru coilpacks. I noticed the groove on the bottom for the thin gasket but they
- Has anybody ever got bad or wrong new upper control arms? ...
- Keep the Piggies or upgrade to Downpipes? If yes, what is the best bang for the buck DPS?
- Speakers for 01 S4
- opinions...?
- Since I'll be moving out west to work and tune an S4 soon...
- Just came home tonight to see UPS dropped off my Euro Tail lights. Will take pics when there on.
- Does anyone know a user with "Audi Sales Trainer" or something similar username?
- any quick tips on removing my rear o2's?? (doing it right now, so please help)
- KONI Sale!
- ACHTUN!NG | 13% OFF Hartmann Wheel orders on Friday the 13th!!
- Finally got my RS4 bumper on...
- oem rs6 wheel fitment..
- Need help with bosch 044 drop in from 034. How did you guys get this thing installed?
- After 6 years, I'm finally selling my baby....one...last...rant....
- Shipping seats got me wondering...how much would it cost to ship my car to Hawaii? Any ideas? :)
- Any of you guys ship your seats? Cost?
- biggest size tank to fit in cd changer slot??
- best place to get Phillips D2S 4300k bulbs? thx
- Are these plugs toast, F5DPOR's...been in there for a while, time to replace??
- Update on defective Vogtlant GT's from Startup Racing. I'm not happy.
- Cluster Display Repair Fix. Success!
- So got my oil changed and the shop tells me my rear diff. input seal is leaking...
- Anyone have a set of Green Giants they want to sell???
- For the archives...Front crank seal replacement...
- 29.2 mpg this weekend!!
- Pad wear warning light on...everything checks ok but the light is still on, need advice, TIA
- silly run with e36 M3
- Only bikes will play...
- Castrol Syntec 0W-30 is track worthy oil, my oil analysis results inside
- Recaro Car seats on woot
- Pic request: Rear upper control arm. Please post if you have a pic. thx
- The bad news is the car is dead, the good news is I'm alive....
- Just posted my APR Stage 1 ECU in the classifieds. Priced to sell fast, hopefully...
- Does somebody know where is this nut from?
- Hard time finding wheels
- Having some fun in the snow. **Video Content**
- R8-0 B5 S4-1 R8 looks and sound-1 B5 S4 looks and sound-0
- Bored... some pics
- anyone got OEM bipipe lay around
- Car is stored, look the VIDEO I found in my archives (GT turbo content)
- what could I expect to pay for black front heated and rear seats? I STFA, but no prices.
- For those doing the S4 euro rear... just a little FYI
