- AWE Tuning's online ordering is backup. We apologize for the inconvenience.
- Anybody know how many hours a Timing Belt install takes?
- Ok guys....**drum roll*....This is my first FATS post...6.06..Is that good/bad?? Opinions please..
- need a set of rear stock calipers....if anyone has a set and would like to sell
- tail lights.
- I am about to buy a stage III avant or buy a stage II and upgrade...
- DIY oil change...
- Boost question - - Running home brew stage III - MBC alone (no N75) with TCD. Had it set at (edit).
- POLL: Without reloading, how may cars do you see in my sig pic? 1 or 3?
- due to recent posts...I just want to clarify....Tips are faster then 6spd. Dont hate!!
- Adding Mobil Delvac to 0-40 M1?
- i know its been discussed before, but did anyone ever get a lead on where to get the seats..
- It's 4am... time to head out to catch my flight :-)
- Just Fool'n Around
- Can anyone with an ETKA get me the part# for the front under-engine "pan" for a 2002S4?
- Paint
- Anyone ever change the Stasis Streetsports damper settings from the pre-adjusted?
- just ran a modded STi about 6 times... pulled about 3 cars on him every time, wth?
- just killed a E39 M5!
- Just got back from 2 weeks in So Cal on vacation. It's so nice to drive my own car again.
- Do you have to remove the calipers in order to Replace rotors, or can you simply wiggle the rotor
- Update on tonights logging (ko4/16s on AWE KO4 code)
- OMG, new RS4 will get 10mpg city. That's ridiculous.
- Anyone ever have a water pump start to go out after only 14.5k miles?
- M1 0w40 oil analysis results after 8k miles, 10.5 months, on a 78.5k miles S4...
- I forgot my car's B-day!! I got the car 4 years ago yesterday from Audi of Bernardsville. I had a
- Stasis Tracksport 600/700 adjusting and settings questions and poll...
- What's the best place to get a phatbox these days?
- anyone have a pic right after installing a tie rod end...
- Can anyone interpret some logs for me? Having trouble posting them up.
- 2Bennett S4 GTR..Now That's An AGGRESSIVE TIP..500HP...Nice Article In Nov 05 European Car Issue....
- Hip Hip... no more Brake and ABS warning lights.... thanks Module Master :-)
- Is $3300 a fair price to install Stage 3 (AWE) kit? <more>
- Few clean car pics:
- Some pests just don't know how to take a hint! :-/
- I need information on a Silver 2001 S4 that was being sold on ebay recently, it's an RS 4 conv.
- should 2nd gear O2s on a WOT run look like your 3rd gear (logging and don't want to get arrested)
- FINALLY... got one tie rod end off
- Where 'o where to find Avant window trim??????
- Perfered NJ / NY S4 Parking...
- Stripped bleed screw on rear pass. side caliper, what do i do?
- Today was the last SEM-PCA driver's education event at Waterford Hills this year.....(long write-up)
- Where do i get RS4 parts from?
- Whats the cost to get brake bleed at the dealer?
- How do you think most theives ID S4's from A4's?
- Tip trans problem (BIG):
- I bought these engine mounts P/N: 199-8D0-199-379 K. Wanted to check authenticity..AE1..please?
- S4 car cover with logo
- Any S4's going to be at the Berlin Turnpike in CT this sat?
- Progress Update
- any vendors in here carry ITG maxogen stuff? or any other decent can style housings?
- AMS is having a sale on Work Wheels this month
- Most likely a repost but news to me. 25th Anniversary Video
- already searched... how do i remove tie rods (not TRE)
- Anyone know a good Nogaro Avant thats currently for sale...
- Longevity of S4
- rim repair shop in socal?
- blowtorch didnt help with tie rod ends...
- Blinking dash lights
- RS4 body questions.. do you need to change to the new bumper shocks when going with the full front
- S4 : BT Found some 1/0 and 2 gauge wire.. which one to use for Battery relocation.
- I just figured out why it's called an F-Hose...
- stage 3 install in sf bay area? shops? anyone done it themselves?
- Anyone see this before? Hmmm :-)
- anyone know anything about centerline wheels? fitment question
- *Reminder* EdyJun's S4 Directory -- Updated September - 6 - 2005
- coil overs have been on for about two weeks now and...........
- So I turn on my car this morning and it shows me some little animated water sprinkler...
- do these O2 voltages look normal for 3rd gear at WOT?
- STaSIS 01E Close Ratio trans #2 and #3 going together!
- Samco Throttle Body Boots are back in stock.
- dealer: three classes of oil leaks: weep, drip, leak
- MAF Sensor problems again....Suggestions?
- Vacuum hose clamps...
- where to source a pair of RS4 mirror housings for less than the cost of a kidney transplant?
- threw a CEL, did the VAG, got this fault. Should I worry?
- Achtuning sale on RS4/K04 Turbos!
- Anyone else with Borla V2 catback having issues with it hanging centered in the real valence?
- Coil Over Swap
- Do the V8 engine mounts fit our cars? I'm thinking about 4.2 A6, S6 or RS6, maybe A/S8?
- Has anyone here ever tried this?
- Can someone point out ALL timing marks when PISTON #1 is TDC?
- can i retard timing at all if im running 94 all the time? how much? mods inside:
- holy sh!t! TSB group buy already full! took 3 days!
- Any Chipped S4 in Dallas area?
- Flywheel suppose to have some "play" ?
- selling my 2002 S4
- Question for the group:
- Did anybody here solved the "misfire at idle" problem ?
- hey mike here is whats going on with the car...
- welp...we did it..gt28r hybrid s4...
- using a blow tourch on tie rod ends
- Just let go of the extended warranty.
- well sold the S4..bought an new evo 8..it
- *Paging Mike2KS4*
- N75 valve
- Jacob please call or e-mail me mang.. need to get
- question what size tires can i run on 18x9 oz superleggras?
- Looking for some more suggestions.....
- VOTE to make mini pig change his name back, or to somethng else that doesnt imply he has a job
- Bad Wheel Bearing CPO'd?
- Just installed Vastperformance Snub mount and..
- Have you guys seen this?
- How can I tell if a bad valve spring is causing misfires?
- How many miles do you all get on a tank of gas?
- interest reading.
- Any ideas where to find 1/0gauge wire for cheap?
- Eurospec Turbo Head Bolts.. Non Stretch.
- Reminder to register for Oct. 19th at Hallett (near Tulsa, OK)
- wood trim...
- Update : 1200 PSI blast of Hot water and Soap to clean the carpet..
- thought others might wanna see this
- Finally biting the bullet...
- Raced a stock EVO MR tonight ....
- RS4 motor mount P/N anyone - STFAing
- Engine miss during warm-up…
- Help me solve this Rubix Cube! (Spare Tire fitment)
- PSA: Top Gear Discovery Channel... NOW!!!
- tried everything...tie rod ends... how to get tie rod off
- HP estimate from Nyet says 455 at the crank on my 3.66 (he says 3.64) FATS run.
- where can i get interior parts any one know a good spot hopefully used cheap
- What would you do: fueling kit or alarm??
- Calling AWE I heard theres a stage 3- setup out there. Is it ko4 and software?
- anyone know how to replace standard leather and woodgrain w/ alcatara suede inserts fiber trim
- Mike2ks4 and other vag commers.... *Edit*
- Anyone from San Diego Here or anywhere close by????
- When you guys run FATS tests, how much variance is there in the runs? Like, when the car is
- Join us a for drive this Saturday, Sept 10th- from Malibu to Ojai w/ stop at Old Creek Ranch Winery
- FVCK!! a friend had a pen in his rear pocket when he sat in my car!! i have a 4inch U-shaped pen
- What company makes the Factory Service Manual (FSM) for the B5 S4? And where do I get one?
- trunk being stuck
- Someone set up a NY-Long Island GTG
- Yo So Cal - Kart day @ Jim Hall this FRIDAY <ot>
- Only need 12 more orders for TSB Groupbuy!
- true or false. elevation affects g/s
- 2000sforce email me about RS4 Grill at ...
- Nokian Tires
- Where can i get these pedals the set for auto
- What's the part number for the RS4 Engine Mounts?
- Look what I might be getting and the current high bidder!!!
- Preliminary Notes: 42# Delphi/Lucas injectors.
- Aluminum S4 Pedals
- Oil pressure light on! How can I track this pressure with a VAG?
- Best Carpet Cleaner?
- HELP! Can't find reverse w piggied shifter. All other gears engage ok. Already STFA.
- My brother may get a E34 540 5 speed. The car seems fast, But how would it hold up to the S4? Any
- ne1 want to buy my car? :)
- my shiftknob is broken. which new one fit best?
- How would b6 avus wheels look on a b5? any pics?
- help needed for troubleshooting throttle cut
- How about those Carbon Fiber Intercooler Shrouds! Bravo! Two more months, two years? Car extinct?
- What's it called when you excessively admire your car?...
- anyone have the number for PureMS? Their site is down....TIA
- Who carries the best boost gauge. OCT is out of the question $$$$$
- Aftermarket radiator fans
- Pa people. Nestors/Kings meet tonight anyone planning on going?
- Catch cans
- Was just looking at some old pictures - I do miss it sometimes
- A/C Blower Problems... Can Someone Please look up where these Wires go/Proper voltage?
- Gadget Geeks: Who's getting an iPod nano? How will these adapt to the factory sound system?
- Need suggestion on Audi sites to list my car
- Rubber trunk mat
- RE: Stupid 350Z
- 710n'd !!!
- Full stage III versus a CLK 55AMG from a roll? I own the CLK and I pound on Stage IIs all day.
- Do the RS4 DTM's only come with the small center cap? or can you get the larger cap?
- Champion RF 33, anybody have these...
- Ugghh... Pulling up the carpet.. Found...
- My mum asked for my help yesterday out @ Rusnak in Pasadena..looking for a Porsche...
- I know the majority of the homebrew guys use giac, but have most of you switched to flashloader....
- Uh oh...turbo woes
- Dealer is replacing my gauge cluster. Says 1 week lead time on cluster. Is he for real?
- sometimes baby seals just need to be smacked around a little.
- Just saw a 2000 6MT silver with 105k miles listed at $15.5 on Craigslist. Yikes!
- hmph
- Here is a 2000 Nogaro Blue 6MT on ebay (Not mine or anyone I know)
- With gas going so high a friend of mine
- thinking about selling my STG3 Avant and getting E46 M3...
- I do not think I will be buying the new RS4! Audi only offers...
- I have to give credit where it is due - so VWoA comes through for me to the tune of $50! Shocking,
- Can anything be daignosed by looking at these EGT sensors?
- a couple lil questions about a vibration(kinda long)
- MSN Autos chart to find the lowest priced gas in your area. It was totally accurate for my area.
- Has anyone heard when the 2nd generation ASP downpipes are supposed to be available?
- Filled up with gas this morning: cost me nearly $50. :(
- RS4 Grill: anyone have one for sale? (with the badge preferably...)
- Will front O2 sensors come lose easier with cold or warm/hot exhaust?
- where can a brother find a drivesoft system?
- Just wanted to share: SERIOUS V8 Oz sedans
- STUPID NISSAN 350Z!!!!!!!!!!!!!!!!!!!!!
- For those interested in the nicest (by far) S4 I've ever driven, check out the front page...
- Anyone wedge one of these into the ashtray yet?
- Ignition/spark plug question for the experts
- Funny video of my S4 vs a Supercharged Stang at the track a few years ago...
- Just wanted to say thank you to EdyJun
- Was AWE closed today?
- hey guys do you think having a boost leak would actually........
- ECUx - purchase and download, or only available on disk through mail?
- 710n...too many posts
- Pulled out the ole VAG COM and it's a UNI COM (more)
- Quick answer needed involving boost
- What do you all think of this car.....
- If the W8 belly pan fits the S4, will it fit my A6 2.7T?
- Where did my thread go?..
- Anyone want my chrome S4 license plate frame? Cops hassled me about it this weekend. Shoot me an...
- Truth in spam??? Another scam but wait ....
- Paging ---> DISTINCT <--- Can you elaborate on your bent Flik Artics?
- Black S4 - Berwyn PA (You Here?)
- With all of these nOObrish posts....
- Looking for a new set of tires 235/40/18 to replace ny noisy Yoko ES100. . .
- stupid little clamps on BPV's...
- So I unpacked my Stassis Tracksports tonight and.... (paging Josh@Actuning; and other TS owners)
- I've been reading the archives regarding rattles - does the typical heat shield rattle sound as if
- wheres the best place to buy an odyssey battery online, i'm about to get the PC925, but
- tie rod help
- Holy crap!!! Ugliest SUV evar!!!
- any moonlight mechanics in the tri-state area SoMD-NoVA-DE?
- So my left front axles dropped away from the tranny at 75mph on the I-85
- I have had stoptechs for about 6 months with the AXXIS Ultimate brake pads and recently
- Here is the vid I tried to post yesterday. A few fly bys and a little power oversteer
- on exhaust manifolds and going aftermarket pros/cons/brand/experiences TIA
- Any recs on places to get new xenon bulbs?
- EdyJun's S4 Directory ---- Updated September - 6 - 2005
- I got my S4 at 25k miles and now its at 31k is that too much?
- paging...mike@purems YGM
- Gas Mileage
- Audi S2 and S4-RS4 spec doing 0-60 runs, videos inside
- diverter/blow off valves
- Ok, let me rephrase... is $850 too much to ask for a GIAC M Box?
- STaSIS Street Sport suspension available now (back orders filled)
- Anyone in SoCal with a stage 3 car....
- Pinging again... Need help!
- painting RS4 grill surround, how do you get the trim off without breaking tabs?
- Anyone want to trade a rsr grille(mine) for an rs4?
- About to buy BBS RS-GT 19X8.5 +38. Clearance issues while stock? Can I run a BBK?
- AVC-R works great.. until throttle cut at part throttle
- want to buy exhaust! 2 options! please help!
- $10k project
- I got strange Throttle Cut while logging. It was not deviation based and boost was fine until TC.
- chip affect speedo? Got 93 octane,pulls like spaceship. Feels faster than speedo reading 4 sure!
- Anyone know where I can buy a triple square to remove the front half shafts?
- Overheating problem I am having is a bad thermostat - do these costs quoted by dealer seem right
- Handle of glovebox came off in my hand .. looks kind of snapped .. any diy fix for that?
- Need help: wheel bearing for CV joint failure?
- Anyone wanna swap A Box APR V5.0 (4 programs + TBA/Fault Code Erase) for AMS?
- Good deal ?
- Window Tint - send pics. please
- It's been 8 months and 10k since my last Mobil One 0W-40 change - It's about time now, no?
- Need recommandadtion on helmet selection! (new to this)
- bypassing the need for RS4 fueling kit?
