- anyone know who would install these in southern nh?
- Went Over Speed Bump, Now Car Is Grinding!?!?!?
- driver side plastic timing belt cover P# is 078109107H is the same for audi and VW
- Doesn't this price seem a little low?
- Newer been happier to get a speeding ticket
- paint job cost for rs4 front bumper
- which navigation...
- Am I the only one who is not very impress with the performance gain after installing an APR chip?
- Question about flash loading GIAC???
- NEED PARTS
- I lost my damn S4 key. How much will replacement cost?
- K04 Question
- can someone point me to a site to download a serial emulator for USB to use lemme - thx
- Used Bilstien dampers and H&R race springs....
- changing heads?
- I have narrowed it down to either ASP or miltek dps. forget about
- What do you make of this boost log? Actual is always above requested.
- Synchros dead
- Two PSA's
- Modified my helmet yesterday to accept the HANS Device. Thought I'd post pics.
- is Primary O2 volts in ECUx = Lambda = Actual a/f / Stoic a/f (14.7)...
- is there a way to search for all posts by a user?
- What do you track whores think about this post? I say BS
- Followup to my HVAC issues. Temp. Regulator Flap Motor Pot. (I still need help)
- Finally something technical happened, looks like a boost leak to me but no VAG :(
- Rear pictures of your Twin2?
- Whats the top speed of a stage 1?
- wow this is great. windows and sunroof dont work after gauge install. please help
- paging Hal_$4Shizzle - couple NAV / CAN connection questions for you
- Autozone no longer carries it! Where can I get M1 0W-40?
- Need part # for RS4 motor mounts please. Yes, I STFA, 161 posts-no luck.
- What is the best way to clean up the RS4 ICs? I have an interested buyer and want to clean them.
- Touch Up Paint: i need a spray can of silver for my car where can i get one?
- PSA: Chevron Techron Fuel Injector Cleaner FREE after MIR from Autozone (Limit 2 per household)
- Anybody know where I can get a used 6 sp tranny ?
- So is the plug on the center diff the 2nd trans fluid drain hole?
- Teaser pics of the car... well sorta
- Who has a Samco Hose set in black in stock? :) Best $'ing?
- DIYer timing belt job follow up post. [more inside]
- thank the lord! all the BS with my pod is finally over! (BWW)
- whos going to the Stand/Encino meet 2nite?
- Stasis Motorsport suspension on sale
- STaSIS Sale!!! While supplies last
- Sad day today for me...
- I haf AMS chip for a week now (m)
- K03's making the dentist drill sound. What's the best K04 (or Hybrid) solution?
- this RNS-E is pissing me off.
- Heads are off, Anything to do?
- can i use a fpr with a 3bar minimum with stage 2, or is that too high?
- RS4 Cams install-able with motor in car?
- Front door speaker fitment help?
- Anyone up for a few passes down Dinwiddie dragstrip (near Richmond, VA) this friday?
- Good shop near Boston/Nashua? in town from UT...
- How do these 02 voltages compare to others with AWE K04 kits?
- Looking for RAD wheel locks for HRE 545, does anyone know the length for B5 S4?
- Few pics from the ACNA event at Mid-Ohio in June....
- Advice needed removing musty smell from the car's carpet
- Hello all - new member here with some questions.
- this explains the dentist drill sound coming from the engine bay
- Where are the water drain areas on the S4 that we should be cleaning out to make drainage possible?
- Damn plastic bags!! I've got another one melted to my cats!
- So i'm still getting Throttle cut with a MBC in parallel with the N75...
- This Sunday, 7/10, CT/NY Audi Group presents Meguiar's Detailing Clinic - E.Hartford, CT
- Some better pics of the new car (2001 VW Golf 1.8T 4door)
- Brake pad sensor
- Oil Change, it is the first time that im going to need to change the oil since i got my S4
- K04 Kit or wait for the Garret GT28RS kit? Car is down, stock turbo popped!!!
- NU SHOOZ...aww yeah!
- People with 19x8.5 wheels with 235/35/19 tires, did u roll ur fender?
- God Bless America - BWW
- Repost: Anyone have a picture of a silver before & after suspension at 25.5" on Avus? TIA.
- Anyone know the screw size to mount the 6 disc CD changer in the trunk?
- Question for all of you who did your own Timing Belt/Water Pump job.
- (Video) Paul Lambert with his hands full. A 400hp Turbo Elise that does burn outs if 4th gear
- Which VAG COM do I need for my 2000 S4?
- Dynojetting my car after work. It's my 1st time w/ the S. Anything I should know?
- Cars going in for service thursday...Hearing a weird noise though....
- Zoops Sealer - Week 12 Update (X-Post from the Detailing Forum)
- who has the best price on milltek dp's, rs4 clutch & motor mounts? Can any1
- 18by 8.5 and 18by 9.5 in the rear what size tire all around to run?
- what fuel pump should i run in my car. my rs4 took a crap. i need opinions. thanks gus
- Having troubles with the CD player in the dash....
- Anyone with ETKA or wiring schematic? Looking for AC compressor signal wire...
- So Yesterday at limerock i got a peice of the R8's carbon fiber nose as a gift from chanpion Audi.
- HVAC help... Oscilating Fan Speeds. (details)
- Avalon in CO ROCKS!
- Right around 65mph I feel a vibration through the gas pedal with wheel rotation
- Repost for responses: Anyone know if 17" Flik Justices will clear Porsche/Brembo 322 brakes?
- Any solutions for ridding the ignition system of the stock Power Output Stages?
- sorry for another post, has anyone every bought these?
- How much are ABT/AMS M-Box's selling for these days?
- HELP! CEL light came on and I'm 4 hours from home. MORE...
- I can not get my y-pipe clean. Any suggestions? Anyone ever painted theirs?
- will this navi work in our cars? ebay listing ending soon
- RS4 Clutch blow out sale!!!!! $450 shipped
- Does anyone know the stock wheel offset?
- Good news, replaced front wheel bearing myself. Bad News, turns out my rear bearing is out too.
- Question about APR ECUx
- S4 Wheels
- Timing belt kit question - please help me with the jargon (more)
- Ebay OCK installed!
- Anyone know where I can get a Bosch Adjustable FPR ? ECS is back-ordered forever ...
- :::::::::::::::::::::: PacNW Forza (Xbox) Track Event ::::::::::::::::::::::::: (major BWW)
- It sure is easy to fix your lower IC hose with the belly pan off! :)
- Do I need to re-surface my Fly Wheel ?
- oil question...
- Nightly FATS post - Hit 4.63, but this time I logged block 003 so more data inside!
- Check out how clean my pollen filter was when i changed it today....
- OK, I call B.S. on knock sensor output
- well i have decided to not sell anything my father convinced me to not do it. so i say fv ck it.
- So . . . same page repost, why is this RS4 fuel rail not mating with the RS4 intake?
- ko4/16 aweko4 fats pull - give me email add if you want Mark P's excel output - comments appreciated
- Need Help...In Connecticut, need new engine and someone to install at a good cost. Any answers?
- $500 for rs4 clutch install, resurfaced FW and DP install.. sound good?
- YOINK!
- With all this FATS talk, what do other cars do in this same gear/RPM range?
- Life is good... That is all
- been looking for the "Audi - Unfair Advantage" picture.. cannot find.. anyone have? thanks
- SO what's the deal with RS4 intake and fuel rail, looks like I need spacers?? wtf . . .
- Here's the timing belt tensioner pulley, for viewing enjoyment:)
- HOW-TO use the subject line like everyone
- A little 4th of July investigative work......
- Anyone have before and after pic's of a silver on stock suspension with AVUS to a 25.5" ride height?
- Based on what I've heard, I am going to cancel my order with ECS for the TB kit and go all OEM. (m)
- Temp gauge over halfway...
- quick question......Will Axis Mod Sevens, fit over s4 brakes???
- [L.A. Reminder] Tomorrow nite, July 5th : GTG @ The Stand in Encino (SFV) - 7:00pm
- adjusted my shifter back to where it was, still cant get into reverse though...
- X-post::Saturday the 9th, pre-Waterfest GTG for Philly and NJ area guys::
- Red S4 Pron - Pocket Camera action... [BWW!]
- New Things
- So the cam sprockets don't have a key or anything?
- What would an independant shop pay for new K03s?
- Ugh time to name that dealership problem
- can someone with an account on navplus.us do me a huge favor?
- NE1 ever break a cam pulley? My drivers side pulley has
- 400 miles after ECS ultimate timing belt kit installation, car sounds like a diesel at idle.
- today i just got around turning the airbag light off with the new Sparco steering wheel
- Whos going to Waterfest?
- How to remove lower door moldings?
- Stock M-box FATS: 6.89
- Hey guys, I just wanted to introduce myself...(sorry cant sleep and a little bored)
- More help needed - Intake Air Temp. Sensor
- Yet another FATS time, this time I *almost* broke into the 4.5's...managed a 4.61.
- Boost spike AFTER I get off gas. Help needed.
- Spent 2 hours slaving over the slowgaro this evening. She's looking pretty good now.....
- White S4 parked off 3rd ave. in Avalon, NJ yesteday-- nice ride.
- is there any place cheaper than ECS for timing belt parts?...
- Help with diagnosing problem...
- What are your opinions on suspension choice? H&R/Bilstein type upgrade or coilover kit?
- and my day started off so good.....
- Is this the possible cause of water entering right-rear floorboard?
- Help with headlights!
- Can you help a brotha out? Part needed. But ETKA says "I don't think so!"
- FATS for Tips: Difference from 5.76 to 5.57 by measuring Block 005 (Speed)
- hey for homebrew fueling could one use a ford lightning 90mm maf?
- last night in Fairfax Va. s4=3,dodge colt turbo=0......
- Do your suspension mods FIRST.
- Nuvolari PS (early stages)
- AMS/ABT Stage 1 Fats time..
- Paging Silver Y2K S4 That Raced Me Over The Gandy Bridge (Tampa/St.Pete FL) Last Night..U Here?
- Ok, someone enlighten me. If going stage 3- with MBC in parallel and no TCD (ie running...
- WTF-Still can't find out why I'm getting water build up in the right-rear floorboard!!!!!
- USGP Michelin tire problem pictures.
- what were the audi engineers thinking when they designed the stock S4 ride height? was my car just
- B&M Short shifter. How hard of an install?
- Would people call me names, if I stated I liked the transAm series?
- wash and wax. bling blingggg
- repost from yesterday about ride height but with a pic...
- Metal brake union and blown turbos
- threw CEL light
- finally got the symphony unit out and the RNS-E unit hooked up!
- Anybody know if 17" Flik Justices will clear Porsche/Brembo 4 piston front brakes?
- Pioneer In Ashtray?
- Anyone knows where Dr. Lease is?
- Does anyone have an ECUx logs that contain
- Pictures of my mediocre navigation installation (very long, cliffs notes at the bottom slighy BBW)
- why would timing get pulled if using 100 octane with 93 octane software?
- Anyone know where I can get Flik Arctic Rim besides EdgeRacing?
- dealership replacement tires rant...(long)
- from looking at that German wheel company's videos recently, are certain forged wheels that much
- American LeMans / Speed World Challenge @ Lime Rock Park...
- ok changed the primary (right after the turbo) O2 sensors, and everything is "better" now
- Best way to tell if my Aquamist system is spraying??
- Fun with photoshop ------------->
- I have formulated a new soap for car washes!
- Stage 1 Avant AMS/ABT Fats time
- Fvck...race pad dust is impossible to get off my rims...can anyone give some tips?
- are the turbos on the '01 S4 coolant cooled?
- So got the Mr Clean Pro setup for my Bday and used it yesterday
- Where to get replacement spacers and torx screws from short shifter install?
- Got my Neuspeed RS10s all mounted up, pics inside. Enjoy!
- MOTHER F$*&$(&ING SH%#$@TTT!!! I was just rear ended AGAIN!!
- Anybody ever hear of "Roar" air filters? This is the first time the company ...
- San Diego service questions
- Non-Bose Symphony Remote Amp Turn on- Where to tap in other than HU
- Check out this video!!
- ugh, just spent the past hour getting pwned by my symphony HU - it wont come out!!
- Interesting comparison..."1000 hp" Z06 video.
- You know what I haven't heard anyting about in a long time? DUH FMIC's. They still on uber backorder
- Converting bar to PSI (and other conversions)
- User quota exceeded: SMTP <sales@awe-tuning.com>
- First logging experience with ECUx went well! 65F, 94 oct, 4.18 FATS, 5.66 FATS+ (4k-7k) (BWW!)
- need part # for hard brake line on RF caliper
- Watch out for pirates!
- Paul Miller Audi - wouldn't recommend
- Screen Between Gauges Not Working... help!
- does anyone have a picture of the stock navigation system from 2001 and 2002?
- ah yes! the sweet sound of exhaust hmmm...........
- anyone here runnin the sportec rs4 air box mod? debating between that and darintake style
- How often does your after-run fan go on??
- Online escrow service. Suggestions??..
- Level 10 opinions please...
- Does the PhatBox from Clair include the wire we need to connect?
- very loud s4 today, it was fun driving around (sound clip inside)
- Body Shop Question - Cleveland OH Area...
- GIAC chip upgrade gone wrong..help......
- STaSIS Ohlins dampers -- ABS mounting bracket and wire rubbing on spring...
- Limited-Time S4 Offer Exclusively for ACNA Members!
- Okay washing Silver SL's after abusing Cactus for what maybe a month or so
- Rotor vibrations -- ECS Tuning 2-Piece, Floating, Replica Rotor Kit
- So, do our cars have a diversity antenna installed from the factory?
- xpost from audi ma forum
- Clicking sound from the front of the car... power steering pump I think.
- quick question about ride height w/ springs & shocks
- I just install New 710N valve and AMS chip
- I could have missed it, but what's the status on the RS4 raffle?
- Really into my car....;-)
- maroon s4 that is for sale... does this car look modded? is it anyone here?
- 99999....100000....100001
- question regarding blinkers.
- So much for ECUx being midget proof! Woooooooooo Hooooooooooooooo!
- If only it wasnt pouring...
- kind of a craptastic picture but I hate it when my friend drives my old car into work!
- mjtaylor, your email server is bouncing my emails.
- can someone from induktion answer this
- Allroad has no HID's?
- 2nd and 3rd Boost run Graphs...Everything look normal? I'm running APR 93...
- Did you know... The new Avic-D1 can not play dvd's! If you know how to chage this i know a shop that
- Lime Rock American LeMans Series
- Bad news!! :( The RS4 Raffle is a NO GO!
- Help: S-Flow install troubles
- VAG fault codes inside...EGT and Oxygen sensor...
- Nashua, NH GTG from Wednesday... x-post from NE forum.
- Silver S4 Sedan on RT 80 E In NJ near Rockaway. Anyone's here?
- Help!! Car died...bad maf, and now its still blowing black smoke...
- so who wants to toy with my buddys dodge truck???
- I haven't been here for a while, and I have a few questions...
- a prime example of TC....
- according to fedex, theres an RNS-E sitting at my house.
