- Just committed to a 2001 S4 with 85,000 and orig. turbos.....
- iPod wiring setup Q
- Still having problems with boost on my car, I just installed a TCD
- Anyone have a CF Hood or Trunk they want to get rid off?
- R8 Spotted in the Transformer 2.
- Think im ready, missing anything for stg3? might be having second thoughts
- Found Sunoco 104 semi-locally by the gallon. Is there a better method than plastic gas cans for
- witch one of four sensors is it???
- With all this trans talk I have a question about mine. I have a Stasis 6speed not
- anyone with a higher mileage
- Trying to figure out what is wrong with transmission, it was working so well up till a few days ago
- I want to have my tranny gears cryoed. Where in MA can i have that done? J @JHM said i should be
- ****Hartford CT GTG - New Date - Wednesday, September 17th
- Okay, back to my clicking sound from under hood. Ideas please.
- What is the best way to wire EFK?
- I cant find the front temp sensor???
- Photo Challenge
- Poll: who has faulty Febi oil-temp sensor?
- Does anyone have one or two Enkei RPM2 wheels in Hyperblack color that they're willing to part with?
- What kind of plugs shoud I run with an EPL Stage II tune? Would the OEM NGK PFR6Q be the right
- are any ppl running stage 3 and up on stock exhaust manifolds?
- paging z-tuned
- P/S leak
- Audi S4 newbie, but this can't be right... right?
- 2000 S4 Cylinder Compression
- need help locating the front trans filler & drain plug (01.5 tip)
- M1 5-40w?? is there such a thing and who carries it?/
- Do coilpacks ever just straight up Die? Go completely bad?
- When i am driving, my stearing wheel is shakeing and vibrating...
- Anyone here selling a set of used coilovers???????
- I don't like convertables but here is one I wouldn't mind taking for a spin. (R8 Spyder)
- I need some ic's anybody upgrade to ER's that had rs4 or awe? i have a rs4 oil cooler for trade.
- Anyone want to trade their "Piggie" pipes for some XS power ones?
- What the hell is the popping noise coming from top center of dash moments after I turn the car on
- NEED ICM's...who's got them in stock and can ship today? Carson,
- Anybody know if this type of Valeo Ballast will fit in our headlights?
- My car will be EPL Stg II custom tuned the morning of Friday the 19th. I can't wait.
- do the vogtland GT's come with install instructions? if not, how hard is it?
- Belated thanks to whoever posted cupholder instructions...
- ***Postponed, 9/9 Hartford CT GTG, due to weather.....new date to follow
- To those who have pulled the dash out before.....
- Aside from Ohlins, who makes an adjustable suspension setup?
- Hey all, tell me what you think of this rotor, it is bran new just taken out
- Got a fresh ECT sensor installed (green one) now coolant temp gauge takes forever to warm up...
- New weighted shift knobs from jhm. Let me know how you like them?
- anyone have a extra laser red washer cover lying around? for the left side?
- Another one - part number request for headlight washer T-joint, please.
- Is it true that S4 Avants have RS4 engine mounts stock? Read that in one post when STFAing.
- Drove through some standing water this weekend, and now I have issues...
- Any suggestions on wheel/tire packages for around $1200?
- Any1 have a A-pillar pod housing for a 52mm boost they gauge they want to sell???
- anyone running the ebay M3 spoilers? are they any good? how do they fit? good Quality?
- Can someone from Avalon Motor Sport answer my questions on RS4 bumper
- any college kids with a s4 in warrensburg, MO?
- Going from 25lbs wheels to 18lbs wheels - big difference in weight?
- Um wat...Nogaro S4 in NY
- Did any B5 RS4's make it to the states?
- Need a TBB......?
- Quick (possibly stupid) question- Will C5 A6 2.7t springs work for our B5 S4's?
- Motor and Trans Mount Swap Completed!
- Sometimes I lose some boost...
- Lot of s4's in manayunk sat night...
- Do DHM exhaust cutouts leak?
- Larger Y pipe?
- Sweet casa S4 on highway 85 south in Colorado...are you on here?
- Alright last night i posted up a shifting problem....HELP!!!!
- Whats the difference between the RS4 EGTs and the S4 EGTs? should be any difference right?
- Car died while driving...
- MAF sensor or Air mass meter?
- Finally got my new clutch installed
- Motor Mounts not lining up after DP install...more
- Coasting down the street and car suddenly veers right like the front passenger wheel locked up...
- saw a commerrica for worx gt grass trimmer haha gay i know but they have a B5 S4 in there lol weird
- can someone post a log of timing (block 003) during warm idle? - preferably stage3
- Are these ok Boost Vac Levels for stock?
- anyone know how much black s4 interiors are going for?
- HELP!!!!! was going to put my short shifter into tonight started but started to rain outside so...
- X-Post from tires & wheels Q I have.... Would appreciate some opinions...
- just acquired 01 silver and have some questions
- F$#k this throttle body boot crap
- I will be attempting to change motor mounts tomorow. I will report back and let you all know
- VIS carbon fiber hoods any good?
- does dension icelink work with new iphone 3g??
- what is the stock spring rate?
- Just installed Vibrant catback...seems loud?
- lookin to buy new wheels for my b5 silver s4?
- Progress on my GT28 build...
- Silver S4 at Rutland regional in VT; anyone here?
- Anyone going to Road America for the ACNA event this Mon/Tue, look me up, I'll be in my black avant.
- 2000 Audi S4 6 speed, dark red
- Anyone have torque specs for bolts on ASP street tranny mounts?
- Can I get coolant for my S4 at NAPA? If so, what kind do I get?
- So I found out why my transmission wouldn't go into any gear
- Paging Mr. "needsabumper."
- Aligned the car to zero toe all around! As well as raising it to 25.5" from about 25", tracking
- can i run sunoco 110 leaded in my car if it has no cats??
- do any of you need a rear bumper? silver
- AWE LWFW resurface kit has less holes then my original awe LWFW?
- URGENT: headlights out, got depo ecodes in the mail, attempting to swap, need some assistance...
- What are the symptoms of a turbo failure due to oil starvation? I just want to have my bases
- best place to get a rear main seal and gasket? how long do they usually last?
- Can a melted ebrake wire cause ABS light to come on, Brake light yes, but ABS?
- hey lemieux@curbside what do you think of this control arm kit? its made by FEBI-Bilstein
- The CPT treatment...
- Is giac x better then my mtm 345 software?
- Group buy for bumper bolts!
- Something's wrong with me, I've been seeing 8mm bolts all day!
- Is this the SSAC exhaust kit?
- How on earth do you remove the 18mm subframe bolts?!
- What are body panels off my car worth?
- Rough idle and other fun stuff . . .
- Yes I'm idiot, where is cts? I stfa and looked at tech articles but still cannot find. does someone
- Did I miss something... Why is everyone going crazy for 6mm bolt for the bummper?
- Who in a dry climate here has a reason for preffering the S4 over a supra?
- someone please verify what type of screw holds the steering column together???
- All you Northeast S4 owners......
- paging Mike@VAST. pls! come up with a more lightweight 6mm bolt for front bumper
- Correlation between FATS and 1/4 times...
- If a fuel pump relay is bad, is it often in conjunction with the engine speed sensor?
- Mkay, about to flip the fvck out!!!! Someone please come up w/ a solution to my problem!!!
- I STFA and it seems there are no VAG-Com templates so...
- Is it neccesary to use copper lube on the clutch slave??
- What size Allen wrench fits the 6mm bolt that holds the bumper to the car? i want to make sure mine
- Just a little trinket upgrade here....Oil cap w/a pressure relief...
- Has anyone ever replaced the egt sensor, but reused the control box?
- My friend says that his 04 dodge srt-4 has 239 hp stock and that he could smoke any stock b5 s4 is
- Paging Simmply@WMS labor quote on install of 6mm allen bolt for front bumper?
- How much of a PITA is replacing a window regulator?
- Brian@avalon Part number request for 6mm bumper bolt please?
- Wanted: Couple of rolls of this:
- My bumper just fell off
- to all of those in the 6mm bumper bolt group buy: your bolts are shipping today!
- Help...can anybody identify this item?
- air pressure for 225 40 18 inch tires for optimum DD
- Just sold Ram my 6mm bolt that holds on my bumper. Anyone know were to get one?
- Does anyone want to sell me the 6mm bolt that holds the bumper on? Just sold mine to Jason...
- Does anyone want to sell me the 6mm bolt that hold the bumper on? Thanks!
- RENNtech C63 AMG (548hp, 510lb/ft, no forced induction) vs. Stage 3 S4?
- Strange boosting, peaks at ~6000. Anyone experience this? Log inside...
- Any of you guys know the most popular Mustang website? I had a run in with one last night on RT80...
- should be on a b5 s4
- Xenon HID bulb(s)
- Schumacher busted speeding in his Audi...
- Where can I order a good pressure plate (not RS4)??
- How much PSI on stock S4 (no mods) would show in boost gauge?
- Something wierd about this picture or is it just me??
- Who wants to sell me a front bumper filler plate? Hopefully in black. TIA!
- anyone have some stock pads laying around? TIA.
- Need Help.. Anyone know whos car this is/was??
- car in stock mode for time being(turbos sound awful) now a boost problem....
- Im going to try launching while spraying a 100 shot be back in ten...
- Car wont start when hot - 2000 S4
- what are they chances that our ecu would pull timming or decrease power in some way while your
- wheel and suspension
- Name that Part and connector's
- messed around today and took some pics....
- Should requested vs actual boost be exactly the same at idle?
- One Xenon headlamp aims down....help
- Empi (made in China) front axles....good stuff?
- Anyone looking for an H Box ECU? I have one in the classified's for $Treefiddy...
- car overheating in hotter climate when the car is sitting still for more then 5 minutes:
- I just bought a AWE stage 3 clutch and they sent me a southbend clutch
- Can someone explain what voters see?
- I will be changing motor and trans mounts and all front control arms and was wondering
- X;post: If they made a LED headlight for the S4 like the new OEM ones would you buy them?
- Passport radar detector failed me. Time for a Valentine....
- SIMPPLY YGM
- Hi...just stoipping in. Haven't been in a few years....Glad to see everyone is doing well. :-P
- Anyone here from ASP? Custom tune question
- Revenge ... made me chuckle....
- throttle body adjustment
- 2000 S4
- Wheel Question?
- APR cat delete software?
- my secondary air pump is shot makes a low grumble for 30-60 secs on cold start
- Best way to ship OEM black leather front seats?
- bird's-eye maple is nice...but i've been thinking about a marble stone texture w/ silver leather int
- Howling brakes when it rains. Normal?
- 2000 Audi S4 Stage 3 VS 2009 Nissan Skyline GTR with video
- Blast from the past...revised version of an old picture care of PunkAvant
- Is there a place on the dome light up front to hardwire a radar detector so it turns on w. ignition?
- Which plate frame on a Silver S? Quattro/Polished Metal/Carbon Fibre?
- Anyone interested in buying a Neuspeed G2 catback??
- Is the mesh over the flex pipe just a cover or does it actually provide some function? Shop that
- Looking for a clean, stage 3, B5 S4 in California or nearby
- recaro spg pole position hiy or skip??
- How do you tell if S4 wheels are OE or replica? Need to know for sale.
- 2nd day back to school and had to come back to this.
- I STFA but... does anyone have the link for the write-up on installing the Rs4 bumper grill?
- Can I safely up the boost a small amount, on-top of my ECU reflash?
- Paging 2faS4u2pass or anyone else who has done this...
- Audi Sport frame options...Quattro/Brushed Metal/Carbon Fibre? Which one?
- just bought some k04s wondering if any has the Inlet Piping they would want to sell.
- Oil Capacity
- bought new hazard relay, installed, and the hazard button gets stuck..
- I STFA is VAST the fastest software avail compared to my AWE Tune?
- It's TRANNY time :( Rebuild options? Stasis reviews? etc...
- Anyone have a stock M-box that they want to sell me (or trade)?
- Have you guys seen the R3? It may be a cool car. Mid engine and turbo...
- I need some used front bumper shocks in good condition.....anyone???
- Anyone have a set of 3mm spacers they don't need?
- anyone with an RS4 cluster in your S4, and it is working, and you have a vag com, could you do me a
- Sick of bursting turkey basters! What should I use for pressure tests?
- Any S4 Avants w/ K04 upgrade already done, for sale in the SE?
- Track only... what will be the recommend tire pressures (HOT) on NT-01 235/40/18 for our cars?
- who here has expierence with Light wieght racing seats that are NON reclinable (fixed backs) in your
- EGT Sensor Fault Code?
- Can I use a boost controller to raise my boost a small amount over the 14-15psi set by GIAC reflash?
- How much of a PITA is it to swap motor/tranny mounts while the engine is in?
- tool for removing drive axle bolts? where can i get one that doesn't strip?
- Cool product if you needed to change a flat on the side of the road
- Anyone have side grilles willing to sell?
- Wow, RS4 Grilles @ ECS are 200 !!
- ACNA-NJ NJ Motorsports Park, October 21st and 22nd...some open spots...
- I rocked a Mustang GT tonight. It was fun. I know make fun what ever I enjoyed it.
- Friggin' muffler shop welded APR exhaust to downpipes...
- symphony bose radio 01 in safe mode, tried code from front of radio book but did not work, what next
- Stupid Codes!
- im bored, pls humor me for a quick poll. stg3 build time?
- Issue with Hitachi MAFS Conversion after GIAC Stage 3- ECU Install
- wtb - low mile stage 3 or greater. western us
- Timing tensioner seal leak
- 18" Oettinger RZs - fair price?
- Would a healthy stg 3 B5 s4, be as fast as a higher HP supra to 80 mph? With the supra being limite
- Any AWs rocking the stock AVUS wheel replicas that come in 18"? Anybody paint any AVUSs BLACK?
- piggies = done
- Just got the S4 back after 6 months. Drove it from CO to Illinois....
- Holy IAT's Batman! Just did a pull tonight in Houston. Started at 130F and ended at 150F!
- ebay link to RNS-E!
- where does this rubber sensor from radiator area plug in?
- NEED TO DROP SUB FRAME HELP!!!
- Need help with code
- Carbon clutch break in
- AIR BAG light on?
- Anyone want to trade a stg3 sedan for my stg3 avant?
- Where to order a clutchmasters clutch from?
- Help with codes please...
- I have RS4 instrument panel, but RPM gauge is not working!
- Can anyone vouch for STGeleventyS4?
- Audi Driving Exp. + R8 (Video from Super Cars Exposed)
- Mobile 1
- Is these errors bad? What I must change?
- How to remove driveshaft?
- Part # for Window Wash tank??
- //SFest '08
- Well, I went ahead and ordered the new crank pulley...will be here tomorrow
- what do you think of my "dream S4" shot?
- best method for pulling engine on a tip?
- wheel spacer Question ?
- Timing
