- Can having the clutch fan removed from the car cause idling misfires??
- Misfiring @ Idle will be the end of me... Is it possible to turn misfire recongnition off @ idle?
- too good to be true??
- Undecided - RNS-E or Aftermarket Nav?
- Does anyone here have a set of used K04's in good condition or a set of blown K04's? I am
- Booted Audi..must read LMAO.
- No more saggy sideskirts!!! Cheap Home Depot fix!!!
- just checked codes, p0507, p0431, p0421 any ideas?
- Just so everyone knows, getting an S4 resprayed is unbelievably expensive....
- Anyone putting in new upcoming RS6 turbos on our engine? Are they too expensive? etc.
- Anyone have Bosch 5 Bar fpr's in stock? if so...how much?
- [piggie pipes] - whats the name of the part that comes with the pipes?
- 3rd gear trolling
- trading my b6 for a b5 s4.. (private party)
- Airbag ECU fix - need to reset Seatbelt Pre-Tensioners?
- Ok, getting ready to pop for the Stoptech's up front ... what the best compliment to the rears ...
- Dentist Drill
- timing belt, H&R SS and SS brake lines..
- AWE B5 Package deals
- SoCal - Anyone know a good fabricator? for headlight modification ?
- RS4 Seats. Not mine. A little yellowed but could be fixed maybe?
- for those running 235/45/17 on stock avus, what brand tires do you run and did you need spacers?
- What are used KO3's worth? If anything.
- Anyone have EGT sensors for sale (private/dealer/shop)?
- tire question....will 225/55/17 tires fit without rubbing?
- Front swaybar bushings?
- best s4 replacement?
- putting the timing belt on but just missing getting it on by milimeters any suggestions.
- Cyl 4 misfire, Boost control below threshold, limp mode while logging... Just replaced coil pack...
- Afterrun Coolant Pump DIY (stfa/tech section) quick ?- I want part # 021 919 369 - blue right?
- I STFA, can anyone help me out with the procedure of oiling Bailey's DVs (and any other routine...
- R650 Price & ECU programming??
- My center temp/mpg/station center cluster has blank lines - who rebuilds?
- Which software would work best with RS6 turbo's?? ASP?? EPL??JHM?? dyno #'s if possible thanks
- Which Stage 3 - for someone who prioritizes drivability, reliability, gas milage over peak HP?
- Why does my speedo stop working when it is raining or after i wash my car?
- Any participants in the ER group purchase received their IC's yet?
- Anyone have a central locks air pump for sale? Bought a S from an auction and the car wont start..
- [podi boost gauge] - pics.
- pearl paint matching in the los angele area? suggestions cross post from socal forum
- APR Stage 3 Owner's Corral at Waterfest 14!
- A.W.E. Tuning Shows Some Love for B5 S4 Owners
- X POST from AZ.... How many miles have you gotten on your K04s/Stage3
- Anybody have a wideband 02 sensor in good working condition that they want to sell?
- AutoSpeed Summer Sale (web pricing updated)
- Anyone have a passenger side foglight they want to sell?
- Anyone parting out an interior?
- Welcome to the Classifieds.
- Selling a GIAC Abox ecu for B5S4 in the classifieds!!
- anyone have washer caps?
- Anyone have an extra passenger EGT sensor laying around? need on ASAP.
- RS4 K04's available, prices to increase soon...
- how much for my engine??
- Does anyone have their Engine & Transmission apart?...
- desperately need to buy lower grill section
- I motorboated from the Avant in this thread
- here's the pic of the headlight wiring... thoughts?
- Any one here ever have to use anything move than a caliper toll to spin there rear
- just installed my stoptech 332 bbk but ran into some problems need help advice thanks
- Clutch problem question
- Surging issue still present. I can't find a boost leak. At least not one that is significant....
- Does anyone have any experience with this Water/Meth Injection kit?
- I forgot to ask, but a couple of weeks ago when we had 100deg+ here up N. east the
- who has the best deal on Timing belt Kit w Water pump? Im out of CA
- This is depressing.... I thought I would get more for my car that I had invested so much in....
- [boost gauge] - does boost only build when u hit the throttle hard?
- So I went to the drag strip today...
- Will the Alcon 6-piston 355mm fit under VOLK LE37T with 18 x 17.5 ET 32?
- I screwed up. e-brake wiring friend - e-brake light always on -
- woot..just replaced Auxiliary Fan (A/C fan) in ~1hr and 2 beers
- Possible K04 failure after 13,000 Mi and 18 months?
- Swapped O2s and still getting these codes. Are they life threatening?
- People buying wheels this summer, avoid OZ Racing
- (Update) finally had some time to look for my boost leak....
- any one used a CVU steering rack
- Y'all ready to shift into a new Season of TopGear?
- Follow up on my K04 install experience...
- Will this bushing cause the suspension to clunk...
- Please post pics of ET 35 wheels, trying to make a wheel decision and I need to see more pics
- A while back, someone pics of a very expensive (yet light) wheel that looks like a BBS CH...
- OEM RS4 Seats Install Updated with Rear Seats.
- Is it possible to run 43.5 Lbs of boost on stock turbines?
- Rear passenger side wheel noise
- Seeking advice: Suspension for Dummies
- STFA - Oil smoke at startup - then none after. Only after sitting overnight, etc. (more)..
- Damaged HP2 caliper pistons...
- o2 Sensor locations on piggies... where should i relocated the o2 to so i wont get a CEL?
- DTCs: 17521,16684, 16685, 16686, and 16687
- I just got (what I think to be) salvaged S4 lights from Shokan...
- what kinda milage you goons gettin in avants?
- I've never done it before, but does anyone know how to PROPERLY wet sand scratches?
- I hate to do this, but I have to. What can I replace her with?
- Boost leak, please help
- Deer whistles: I heard they don't do much, but I thought if I mounted them like they are on this
- HELP...Cannot get the rear brake piston to move
- What the heck causes this loose wheel - video enclosed. Bearing? I assume worse
- Oetiker clamp tool kit...x-post from C5A6 forum
- Looking for instrument cluster disassembly help. Mine's got a rattle inside that I want to
- s4 noise diagnosis
- 01 S4 w/ 133k for $10k???
- Well.... She's gone. Not quite sure I want her recovered
- Did Sportcompact just raise the price on Vredestein Tires 225/45/17 from 100 to 135?
- anyone here interested in a set of Recaro seats???
- im at 50k miles... when is the next service interval? what should i do maintenance wise?
- VSS possible problem- question
- A call for help!!!
- Link to writeup for fueling install? having trouble with injector pull. TIA!
- pressure test to 15 psi, im ok. 18 psi, this thing starts leaking...?
- [boost gauge] - how many psi should i expect with APR stage 1?
- I average 15 MPG, mostly 94 octane on APR 93 Octane program, drive 70% city, 30% HWY, too high?!
- how do i replace the plastic trim piece behind the steering wheel?
- Am i missing anything for stage 3?
- My Stage 3 Fueling Experience...EPL rocks
- Maybe a repost but a small road test of the audi TTS
- anyone here in the WI Area selling a B5???
- AutoSpeed Summer / Pre-Waterfest Sale
- New stereo install pics...
- I have a different idea for becoming Stage III
- Have you guys seen this EZ Car Lift?
- OTS Water injection files now available through EPL.
- Quick: what seals oil level sensor: audi sealant or a specific gasket/o-ring. i STFA to no avail :(
- to the guido looking guy in the white B5S4 on the NJ turnpike last night @ 8 PM......
- Just bought a used MTM'd ECU...searched for answers to no avail...
- did many pulls against a mid 2000's M5 last night. look inside.......................
- Some news regarding my health. Not too good, really.
- burnig oil smell, and a little bit of smoke comming from where you add the oil. normal?
- can i or another tuner make adjustment to a vendor's tune?
- NS performance power intake manifold gaskets.. 30 (F) degrees cooler intake air? worth $70/pair?
- My car weighs 3520 lbs with a 1/2 tank of gas and no spare.
- k.. doing aux water pump replace.. here's the parts list so far, let me know if i left anything out
- Lower hose from coolant tank??
- leaking so much coolant it's scary
- New Stratmosphere short shifter for sale
- STaSIS will be closed tomorrow, Friday the 20th.
- Major pic compilation begins here, WB in the process pics
- Dxc YGM!
- having trouble shifting into gears. B&M SS...
- Lowered Car Alignment Specs
- If you're going with the ASP exhaust, do yourself a favor and just get their DP's.
- AQUAMIST 2D VS. AQUAMIST HFS-1
- PSA: Don't deal with Adrian Livescu from Eurosource Auto in Lavonia GA....
- Quick question???
- I'd like to apologize to the AW community.
- Tony & Dave @ EPL ...YGM
- Anyone have experience running PBR brake hoses with stock brakes?
- A/C Pressure switch- Need to Purge to replace?
- How does AW feel about a camo painted S4??
- CPO runs out next week ... ready for exhaust! Anyone have Miltek goodness for sale?
- Going from twin2 to twin1 i notice much better mpgs...25mpg at 80mph vs 21mpg with twin2
- Are there any issues with the retrosoultions 55watt hid upgrade?
- 2 month review: MTM vs EPL Stage II
- it had to happen I guess :( (crappy phone pic warning)
- Searched...can't find a thread. Looking for a fairly recent photo shoot thread of a red B5 S4
- Anyone know where to get the spring for the front drivers inside door handle?
- anyone selling AWE or ER ICs?
- Theives got my baby.....I dont know how i feel?
- 2450$ for Power Steering Rack?
- WTH... I don't wanna buy a exhaust kit and since I have the means an material why not build one...
- Rear Differential Mounts/bushings
- Recaro mounting bracket source-
- Broken Headlight tab - Part# 8D 094 1454 - quoted $30 at stealership... it's just a small piece!
- Whats a standard price for the lower temp thermo switch?
- Radio removal tab is non functional. How would one remove it if keys don't work?
- ANyone install Bosch 044 and have problems starting right away?
- Opinoins on new brake pads.....the ones that come w/ stoptech BBK are driving me nuts!!!
- My Brakes are really squeaky
- RSTT will be 365hp. 2.5L 5cyl. Turbo- FLD Link
- stage 3- is k04s w/o fuel rail? Am I wrong? What the hp difference?
- Ok need some input on going stage 3???
- Wheel recommendations for the S4? Prefer them to be 18x8 (already have tires). Seems like choices
- im runnin k04s right now and trying to figure out what is overkill
- anyone think i could pull off installing new motor/trans/diff mounts at waterfest?
- When pressure testing, how obvious are leaks? Trying to diagnose a boost deviation issue.
- Project Imola Beast Update - IT IS ALIVE !!!!
- Stage 3 Dyno Results
- BEWARE OF THE SNAKES!!!!!!!!!
- question about ignition coil wire.. is this the same as the 75x terminal?
- local parts department just told me a brand new cluster lists for $820! what're they really worth?
- rebuilding heads
- ECS control arm kits?
- Radio Help! Disconnected battery, accidently entered incorrect code twice.. now its locked! :(
- Will Apr cats fit on Awe downpipes?
- Best place to get some Alcons?
- So I'm pretty sure either one or both of my front passenger side control arm(s) are shot
- Need help with some misc codes after the K04s went in.
- WTF is w/ the deleted posts? Useful info lost...
- upper control arms the same as a4?
- So has anyone here actually tried the V-Maxx coilovers? Impressions?
- Has anyone first gone Stage 3- and then Stage 3, but then thought that 3- was...
- distance of rear O2 sensor from the catalyst
- does the awe exhaust use stock size 55mm exhaust sleeves?
- Front End Bounce
- Do these codes mean I need to replace my EGT and both O2's??
- Paging Carson @ Riverside. RS4/European parts availability.
- Poll: What have you dropped down the engine bay while working under there w/ hood open and its gone
- In preparing for move to Denver (within 6 months)..tell me what you think of this...
- Anyone have a passenger side headlight (non ecode) lying around?
- AutoSpeed Connecting Rod Group Buy
- Which size sleeve fits on a stock S4 exhaust?
- URGENT front suspesion how do you get it off?
- tell me what you think
- Is there a headlight lower tab repair kit? Traded for some e-codes and lower tab is busted.
- does anyone still do the 3/4 throttle trick??
- APR stealth for AWE Twin 1 deal fell through. Anyone...
- SE.WI or N.IL- Anyone down to go to Great Lakes Dragway tonight? I'll be there with a few friends.
- Where is everyone buying shocks these days? I think my driverside bit the dust!
- Carson @ Riverside you have an e-mail! Please help me if you can !!
- Wow, good targeted advertising or just a coincidence?
- ok, original thoughts were the head gasket. not so sure now. was about 1/2 a quart low on oil,
- do 2001.5 avants come with full size spares?
- Couldn't fill the car up all the way. The gas station lets u only fill $75 if u are using card....
- Overboosting problem...However a manual boost controller fixes the problem..so that means to me that
- one of my headlights looks dimmer? bulb dying? what bulbs to get or aftermarket 55w?
- Anyone know if a Samco lower passenger side IC hose is longer or shorter than stock?
- If you guys saw these codes...what would you think?
- VMR Wheels | Brand new V710: 19x8.5 +35 Available in July! Pre-Order your set now!!
- Boost leak? N75? Just installed ASP Stage 3, not hitting req'd boost, slow! Logs (114/115)...
- Paging sj6sp
- anyone know where I can get replacement threaded perches for my H&R coilovers?
- Thanks guys for the help last couple weeks! Quick engine internal cleanup suggestion?
- O-Rings For Leaking Upper And Lower Radiator Hoses
- Anyone need a front wheel bearing for a 2000 w/ aluminum up rights?
- A quick question before I bring my car into the shop tomorrow...
- Question about programming keys
- Need some input on a code I'm seeing in the ABS module:
- Any have an upper-rear driver side control arm in new or good condition?
- Production finished on the new Apikol RS4 Y-pipe hoses....
- Thought you might enjoy. :)
- I need a stock M-Box ECU, if anyone's got one.
- Where is the DIY to install the After Run Coolant Sensor Switch?
- Why the F is the entrance to the fuel pump so small, WTF is the fuel filter such a pain in the ass t
- What cause's code P0601 - Internal control module memory error on an APR flash?
- congratulation to rob(DonQ) and rein for being Audiworld's newest married couple!
- springs w/ stock stock shocks????
- AWE OTS Stage 3 Logs
- Anyone have experience with the ECS Control Arm Kit?
- anyone has a part number for the brake line that goes across the back of the front caliper?
- any tricks when replacing the FPR hose?
- My AC wont cool, just blows normal air. Is there anything that is known I should check?
- Coolant secondary pump leaking, dealer only?
- Issue with ASP Fuel pump?
- KUDOS TO WMS!!!
- Road trip!
- what happend to milipitas 2.7? Is his car still running on the stock block?
- Extended warranty?
- A/C recharging question
- help. car stalled on a redlight. anyone ever heard of 044 failed? stfa didn't show anything. more
- anyone here have experience with Fuel Pumps and Bosch 044? I installed the 044- and
- The two photos I managed to sneak from the DSF Safety Day at Fort Campbell Airbase, KY . . .
- when tappin the boost for a gauge.. how critical is it that that nylon hose is all the way in?
