- Is there still an issue with the ross tech usb model when using lemmiwinks?
- RS4 MAF to S4 connector issue
- hb stg3 with rs4 maf, too lean at wot, what to do?
- Checking in at 83k, maintence update/questions - TIA and I STFA
- Epoxied spider hose
- Oil Cooler Kit question - does any kit allow fitment in the passenger side IC area?
- I need a headlight leveling motor...can anyone help? Thanks!
- rs4 intercooler guys...what do you use for hoses?
- Quick phone camera pic of my ride... First time posting..
- Noob at logging.....questions, interpretation?
- Has anyone tried fitting B7A4/S4 wiper arms?
- Got charged 175 for auxilary water pump today,that really gets to me.
- been a while since I had to buy one of these, wheres the cheapest place to get a RS4 grill?
- Leak on both sides of the transmission at new CV boots? 6 spd manual. Anyone ever have this??
- how do i read boost with Vag com? im new to vag and could use some help with
- Going to take a long shot here but does anyone have a SDR hood they are looking to rid themselves of
- My VAG cable gets stuck sometimes..and needs some minor force to pull out is there a solution 2 fix?
- Just set a Santa Barbara Audi service record according to the manager.
- I know this is nothing new, but Vast's customer service is phenomenal.
- Alright, who's got the Black B5 S4 Avant with RS4 wheels here in Santa Barbara? Just drove past him.
- More ER Intercooler kits coming in this Friday. I'll have 2-3 sets avail for shipping
- where can I get an inner axle boot?
- Getting some pretty nasty crackling poping from the exhuast during downshifts..used to be just...
- Damn rearview mirror is leaking...
- 2.3 come out 2.7 go in...
- Anyone installed their Zeitronix EGT sensors?
- Got my car dynoed and ended up with some low numbers along with a very low AFR
- This won't be good
- New AWE Stage 3 Code: Drag Results - interesting (to me anyway)
- Can a lug nut thread be tapped on a wheel hub?
- It's funny how a whole car can turn in to just a few pieces...
- Could someone please measure the diameter of the rob knob II insert - in mm thanks!
- Only control arms that are NOT universal between steel & alum. uprights are the forward LCAs..
- Looking for Extended Wheel bolts
- Anyone looking for a GIAC 91 octane x chip? T box 6 speed
- Alex@STaSIS is no longer around, however Alex@Europrice is here full time again...
- Did anyone go the Treffen show in IL this weekend?
- Anyone know how to get a "air leather" e-brake handle?
- Which is the easier / cheaper DIY? Outer CV joint alone or whole axle with 2 new joints?
- Got my car back after almost 6 weeks :) Went from blown K03's to a Stage 3- setup...(long)...
- Long shot but.... Anybody have a mud flap set they don't need....
- Paging "Number54" ...Can you shoot me an e-mail
- PSA: Sam's Club has cases of Mobil1 5w40 for $29.99
- Just bought an S4, I'm a noob
- Aux H2O pump hose size?
- Fixing headlights after theft attempt ......
- STFA, but no dice: ISO DIY instructions for ABS controller removal / replacement. TIA!
- Control arm and haunted cruise control problem
- Should I go with a 1 ton or 2 ton engine hoist?
- Not mine APR stage 3 Audi s4 fueling kit Ebay
- Not mine stage 3 Audi s4 EBAY
- Is StonGard® a pre-cut kit, or custom cut by expert installer to fit RS4 front?
- Low max boost
- Are the DTS (Awe or Autospeed) worth the $, my Stage III feels really clunky when coming off of
- Why doesn't audi rally anymore?
- Where can I get DBA rotors?
- holy crap!!
- REPOST: 25 years of quattro
- tons of stuff in the classifieds
- Clutch options? (REPLACING SLIPPING OEM CLUTCH)
- XP: Put OEM RS6 wheels on my S4 with RS4 front fenders. Looks good!
- Anyone have high res pictures of a Nogaro S4 - in need of a new desktop. TIA.
- need some help (oil leak inside)...
- When replacing control arms: Anyone ever had the steel sleeves pop out of the bottom of the steering
- Is it bad to...
- is there such a thing as stage 2 software?
- Anyone have a set of OE upper control arms they don't need?
- Looks like a slight amount of transmission oil on the floor near the inner CV joints after a clutch
- Check out this B5 Vid Thought it was cool
- switching from 93 oct to 94 w/GIAC X...would there be any problems or
- First time signature... thoughts (be gentle, please)
- High pitched whine / whistle sound after I turn off my car -
- Xpost: My "oh sh!#" brain teaser for the day
- Sold my badass Jeep, bought a badass 01.5 Stage 3- S4, but I want a full stage 3 what can I expect?
- Anyone have a photo of RS6 Wheels on a Silver S4? Already STFA and checked the wheel gallery.
- Do you think this e-bay intercooler will perform as well as name brand fmic:
- RE: Help car is not going into 1st, 2nd etc.
- These are my symptoms, can anyone help?
- so yesterday I changed the dv's to 710N's..what a difference it made, stupid owned before me never
- People werent kidding when they said you'd know it when you have the dentist drill sound. K04 time.
- anyone know Rodolfo Lamaestra, ebay user 1siks4??
- Your cars get keyed often? Some little faceless punk slashed my trunk . The thing is this car cost
- WMS does it again!!! Maybe like the 100000th time for people.
- I am stranded in San Fran need some help
- Today was a good Audi day for me..
- Did a little more logging and tweaking tonight...
- AWE stage 3 new file. Replaced MBC/TCD with N75
- Peeps with the new AWE stage 3 file.... are your mpg until empty and mpg calibrated?
- silver B5S4 with BBS wheels on Greenspring Valley in Owings Mills this afternoon, you here?
- Broken turbo studs! How to extract?
- This valve sodium or non sodium filled?
- n00b question: how do you clean your throttle body plate?
- Yo ECD >>> give me a hollar
- 400hp S4 B5 vs 500hp RS4 B5 SW vs 500hp Cayenne Turbo Track Action
- Anyone induce the diff clunk after install of the purems front diff stiffner plate?...
- got my car back after 7 weeks!! almost forgot how much i love this thing!!
- jagr bombs!
- double whammy
- What weight oil is everyone running?
- how do i post multiple pics?? this is driving me nuts! if i put more
- need some help with AC
- home from iraq.
- stereo removal... what a PITA
- What is the size of the third bolt used to fasten the headlight housing?
- jsut drove a new s4 and a srt8 jeep, am i crazy or is my stage 1
- 02 S6 wheel question
- Nice Avant for sale...
- Just got a no front plate ticket down the street from WMS. What happens if i......
- Prosport electric boost gauge with warning and peak mode
- 8d0807285 licence plate bracket, anyone have an idea what car this goes to?
- I hate this ^)(*#@)$(^ power steering pulley....
- anybody got an Exedy multiplate in a B5? STF got me nada.
- Brand new g-Force KDW-2 sidewall damage!
- AWE New File Stage 3 Drag Results Inside... What do you think?
- I'll be away from VAST the next 10 days
- Throttle sensativity
- PSA: S4 Wheel Gallery will be down today. I am moving it to a new server.
- logistical question for enduktion
- keys and immobilizers
- Help! WTB GIAC Tiptronic J box ECU
- Got to run a modded C5 Z06 the other nite.
- Looking to get an S4
- Oil and coolant leak fixed, I hope.
- Bolt on Evo 9 vs Bolt on K04 S4 (Video)
- Can anyone here convert my RS4 MAF housing to hitachi? I am not interested in even trying it myself.
- In-car video of a 2.27 FATS pull...
- Whew! Just replaced the center muffler section on the Milltek (warranty replacement) by myself with
- Any word from NED? Curious to see how ErikS4 did w/the new GIAC file & S2the4 w/his MRC tune
- can anyone get to Audizine page or it is down
- Finally a free day to work on my car, dusted off my coilovers that have been sitting in my closet
- I just realized this... RS4 has Brembos on the front only. Rear is just a nice rotor.
- Interesting find, thoughts? (Click saver C4S)
- * EDIT * I just grabbed the last 8 quarts from one of my local AZ's...muahahahahaa.
- Paging Brady M - Eibach Pro Streets...
- Does anyone have a couple extra AWE vent gauge pods they would part with??
- Anyone have the driver for APR USB cable they can send me? TIA
- Paging Beerock: Did you ever post pics of your epoxy spider hose coupling?
- Pagin Ah-10...how did you remove the Magnaflow logo from the tips you have?
- OMG. Now this is a great salesman.
- How many members have port and polished manifolds and throttle bodies?
- Car&Driver Audi R8 vs 997TT vs AM V8 Vantage Test Video
- HighBeam REMOVAL NEED HELP! I tried searchin forum but no answers...
- Need control arms for 00 with aluminum spindle (upright)
- 2000 S4 and 2000 A6 2.7 same driverside window controls?
- Question for Mark@ASP or others
- S4 (AWE, ASP, EPL) fun last night with some E55 AMG sprinkled in.............
- Chillin'
- wish i had an extra $3500 plus $600 for shipping
- I know its been posted but its still unclear to me, How many qts of oil for oil change? some say 7
- Somebody seemed to enjoy the snow pictures...
- After searching, asking, researching my car is in limp mode.......
- With all due respect.
- Pic request: B5 S4 with stock Porsche "twist" wheels
- Raise Headlamp Washer without squirting
- Looking at a 2000 S4 tiptronic today
- gone, but not forgotten
- Any stage 3 sedans for sale on the East coast, if so email me...
- Today is the LAST DAY to get the Eibach Pro Street S Coliovers for $940!!!
- Should I be worried about fluid leaking from just
- OZ Cronos anyone?
- Spotted: Silver S4 (old logo) widebody in Hayward, CA at 7:45pm Thursay
- Drilled Rotors... i know this has been beaten to death, just curious about a few things...
- Question about APR ECMS...
- What oil temps do you all get with Mobil 1 0W40?
- To anyone who has not replaced their xeon bulbs for 3-4 years or so - do it!
- lowering my car 2" do i need to roll fenders at all? stock 17" tires
- how much estimated cost for upgrading to gt28's from stg2?
- Brake pads: Big difference between Hawk HPS and Carbotech Bobcats?
- HID leveling sensor
- Which one of you hammerheads w/ a station wagon has the brass?
- 2000 S4 Stock vs Zimmermann rotors
- I am 99.99% sure this a stock A box ECU but
- Looking for Sola shift knob insert for my B5 S4
- I have accesss to the battery now, where is it held in.
- blow off valves...car stumbles immediately after turning the car on and giving it some gave the idle
- Is this a decent oil catch can or garbage?
- Anyone have an extra ballast laying around they wanna sell me? Need one pretty quick...
- Any place online I can order the DV hoses from?
- Does anyone have a set (6) green giants injectors laying around or...
- paging Greg @ SSP " tuning " !
- Spotted
- Need rob knob insert with 6 speed pattern, anyone?
- What should the labor be for replacing one K-04? Give or take....
- I have had this ebay vag cable for nearly 3 years. I have STFA..
- Searching gave mixed answers, please help. Thank you
- Paging Beeman or XCCESS:
- Cylinder Head reinstall
- Ah the glory!
- Anyone try this or know of any other leather repair option that works well?
- X-post: anyone in southern NY area want to split some race gas?
- Ahhh, rant...why don't people secure their ****
- Is there a direct fit replacement battery for the 2001.5, besides OEM?
- Whoever mentioned they were parting their car out yesterday...I need the carpet to cover a open
- Can you actually use a forklift to put a car on a flatbed, without damaging it?
- Can someone post the part number for the rs4 carbon fiber shift plate? Tried stfa, tia
- Whats a good price for homemade piggies with 40k miles on them??
- Where can i get a OEM window washer tank??
- Where to get stock front floor mats? ....and don't let girls drive stick shift in heels...:)
- Need p/n: Vacuum hose from intake manifold to brake booster on '01.5+ TIP car.
- Clutchmasters Stage 3 or 4? Stock flywheel or Lightweight? Ploz?
- So, my first 2 times buying something from a fellow AW member, and Im totally
- So are the oem brake pads the best as far as longevity? or is there soemthing better out there?
- Update on my Laser Avant: Bad news, good news and really good news!!
- I am changing out my springs next week. I usually use air tools but...
- follow up post about free exhaust
- Is it common for these engine to make more engine noise with 140k on the clock?
- finally got the car back after 3 years and 10 months...
- Please list the different OEM used parts seller that you guys have had good experiences with...
- for those who know hybrid turbo's
- Wrong forum but still funny. I love when German car companies do this. I remember Porsche spelling
- 2AM. StopTechs installed. I'm beat. Pics in the morning.
- Darintake?
- PSA: German Castrol is returning to Autozone!!!
- Good replacement speakers for Avant - Just speakers
- Sold My Car Sad Day for me Good day for Jeff
- just installed piggies and there is a potent burning smell and noticeable smoke when warm...
- First drag strip results: meh... (sort of x-post)
- head light housing question
- I edited the wikipedia entry for the B5 S4. What do you think? They had deleted
- ASP FMIC is in stock and available.
- i find it alarming when a valet guy gets out of my car and tells me "man your car is fast!".....
- anybody have cheap used ko4's
- Epping Dragway Friday August 17, 2007 Please join us
- Audi Dealer Service Work and Parts Pricing
- hey guys -- stopping by from the TT forum -- looking into buying >>
- Avant or sedan
- Please help me with a very fundamental problem
- FYI-Raxles now makes rear axles $175. A few months ago you had to send in your old for a rebuild.
- Boost gauge??
- Front end noise...Need some opinions...**VIDEO**
- Can't get bolt on rear driver horizontal control arm - it just spins with the bolt
- does this ABD Racing Big Bore Intake really amkes a difference in power?
- s8 rear rotors that much difference?
- cool link of some of our VAST clutches getting put to the test...thanks jaybquick...
- Sold my S4 yesterday...
- I have a small pool of oil in the hose between the turbo compressor and intercooler...
- Bought as new 6 speed for you TIP haters........PICS!
- Anyone know "quattro_silver"? I need to get a rob knob insert his looks very good.
- so heres the dillema
- Quick question: What do the stoptech 332mm go for brandnew? As well as teh 355mm set too?
- Coolant Temp sensor - I swear I think I'm the crappiest DIY mechanic this side of the mississippi
- Anyone in CT/MA/RI area planning a TB-athon anytime soon?
- anyone ever bleached the standard wood beltline trim? To get a silvery look?
- Does Ecux work for MS Vista? I STFA'd
- silver b5 s4 at 'enyay' tapas in soho last night. you here?
- dumb question i thought i knew the answer to..Should a caliper be loose?
- I just want to go home and put on my StopTechs
- Sanity check - S8 rear brakes and maint parts
- Does anyone know the size of the line going into the PCV valve on the y-pipe? 5/8 or 3/8?
- RS6 Brakes on CraigsList
