- Oil leak - Cylinder Head Gasket?? (see pic)
- Steering column actuator fault or keep vcds in car
- Trunk lid wont close and lock
- Alignment special tools?
- Ecm swap
- leaky diff???
- NO: Genuine Battery theory
- More air strut questions
- Door handle LED´s
- Noise
- Mechanic around douglasville Atlanta area
- Rain sensor
- Water ingress?
- Had an Italian Tune Up today...
- Expansion tank overflowing?
- A few questions on various issues
- HELP MMI and Speedometer Intermittent issues
- Europlating Yer D3 A8/S8
- 04 audi fan
- 2007 A8 D3 Parking Brake Issues
- I need help finding an S8 or W12 right rear caliper...
- Major coolant in oil
- Need definite fuse diagrams for my 04 a8l 4.2l BMF petrol
- SAI hose to combi values need help reattaching
- Climate Control in Protection Mode
- 04 A8L Won't Start
- Front floor mats with brown lining
- Oil change- Now more leaks
- New 04 A8 4.2 Quattro questions
- Another A/C blower issue, but is this different
- Air recirculation Flap Positioning Motor (V113
- Transmission making noise
- LED light in door handles
- Parking Brake Motor - Just spinning (parking lot wrenching at lunch)
- CAR MODE DEAD ON MMI
- Bad bulb or wiring/connector problem?
- Audi A8 D3 2004 Rear indicator (outer)
- stock vs. drill & slotted disks ?
- Rear Badges
- Used S8 or W12
- Sunroof drain leak - not clogged
- S5 Wheels on A8L?
- 2009 A8L W12 P0172/P0175 Codes w/VCDS Log
- Painting Replacement Parking Sensor
- Fix Audi A8 D3 Sunroof drainage problem
- What is this part?
- Smoke testing a Secondary Air Injection System code
- HELP! Changed out drivers side coils and plugs...MISFIRES EVERYWHERE!
- Audi A8 2004 4.2 D3 V8 Turbo ?
- 07 Audi A8l is stuck in trailer tow mode.
- 05161 : Brake Vacuum Pump code "Open Circuit"
- Interesting Air Suspension Video... Measuring Blocks
- 2008 S8 HID/LED fog lamp replacement
- Sunroof rattle misery! - any advice?
- a/c only cold through rear right vent?
- Nice aftermarket car mats
- LED headlight bulbs installed
- 2007 S8 Owner's manual set: $300?!?!?!
- Soft Break pedal.
- Vehicle Extremely Un-Level and Has became a Low-Rider on the right
- 2004 a8l 4.2 bfm wont crank!
- Taillight upgrade
- Seat heat
- New to me 2004 A8L
- Hvac issue ac not working also blowers not right
- Rear Left Light and Engine Hum
- 04 A8L won’t start after a long drive
- Front Suspension Control Arms
- Adaptive Cruise Control recalibration
- Searching for exhaust for V10
- Ross tech
- 2008 s8,13500$
- Rear view mirror
- Rattle at decel- Exhaust valves?
- knocking noise at 40mph
- A8 L 4.2 FSI misfire problems
- Sway bar stabilizer link problem
- Lubricating Rear Shade
- 2007 S8 whining noise coming from steering column
- starter life
- Need to replace the Fuel/Boot switch in door
- Ventilated seats and gas range
- Rough Idle & Misfire / Help with VAG-COM Scan
- Do I have a light sensor?
- Hi beam issue
- Are both front air struts bad?
- O2 Sensor Part #s
- O2 Sensors - worth replacing?
- 2005 A8L Cruise Control Inop
- audi s8 engine noise when hitting gas
- DRL bulb part number
- Rear Brake pads replacement
- Limp mode
- Was ready to give up...
- MMI Keyboard Part Numbers
- Audi A8L D3 2008 Paddles / Manual Mode
- Low oil warning
- Aircon Troubles
- Does the 04 a8l even have an AMI?
- Rear brake error codes, need help getting this car fixed!!!
- I think my wife’s car is loosing it!!!
- Brake Pedal Pressure Problem but fluid level seems fine?
- Mmi 2G update problem
- Retrofitting AMI unit
- 17” wheels?
- Cd changer
- D3 S8 vs D2 S8: seek advice from someone with hands-on experience with both
- My A8 is shinier than your A8 (MMI, Pbrake etc update)
- Hello and Goodbye (for now)
- 2006 Audi A8 Wiring Diagram Needed
- Navigation and parking sensors
- Tiny hose connection location?
- My Audi A8 L Tail lights
- Audi S8 D3 MMI Display Pinout for aftermarket display
- BVJ HPFP or injectors leaking, How to test?
- Rear caliper
- Audi S8 front left rattling sound!!
- Audi A8 D3 bank 1 & bank 2 running lean.
- Maintenance, Non-mechanical
- Bluetooth adapter for sale $50
- Anyone do Tail light repair?
- A8 4.2 Rev bounce when coasting
- Need Help Locating Vacuum Reservoir Hose Location
- Air conditioning trouble
- Dreaded Combi Valve
- Rebuilding rear calipers
- MEW MEMBER NEED HELP 04 A8 OBDELEVEN MMI CODING
- Fuel pressure sensor location ? help!
- D3 alternator heats up, Help
- HVAC not cold enough
- Intermittent battery discharging
- Where does this hose go?
- Vcds engine module tests step by step guide
- Valve Cover Gasket BFM
- HELP WITH MY D3
- Elect park brake error
- From an 03 S8 to an 06 W12?
- Couple issues
- Screen won't open, MMI dead. fuses OK!
- 04 audi a8 wont start
- 08’ A8 AMI - Tune2Air Doesn’t Work?
- Best way to hold V10 engine from the bottom?
- Audi A8 MMI
- A/C pulley
- Highest Mileage S8?
- AMI and MMI 2 High
- W12 help
- I need the coolant reservoir
- Air suspension ?
- 2008 A8 Lower Control Arm Bushings Part Numbers
- Oil Pan Bolt Size and Thread Pitch
- 10' 4.2 V8 Rattle
- Air Suspension lights on. VCDS Scan results included
- Oil Pressure
- A8 mobile phone
- Inspection service, San Antonio area ?
- constant tone from Park Assist ?
- Audi A8 d3 radio issue
- MMI 4G System & Apple CarPlay Retrofitted in Audi A8 2013
- Hello, Not on in awhile
- MMI software update/upgrade
- Transmission problem
- Getting this code. Not much is coming up for it P0481
- Starter located
- Kessy module
- Lost my baby today
- EPC Light On After Intake/Injector Cleaning
- Key fob
- MM...I can't take it anymore! Aftermarket stereo install help
- will early D4 grille adapt to D3 A8 ?
- A8 corrosion issues ?
- Production Numbers
- Went and saw a 2005, also 2006 for sale... thinking about resets
- Anyone have the PN for the airbox snorkel?
- Coolant Fan Not working
- Recalcitrant Power Trunk
- That stupid pinch bolt
- Slow Air Suspension
- TIres
- Air compressor shananagins
- Audi S8 V10 - Timing Retardation
- Anyone able to provide some DIY instructions for PCV replacement on V10?
- 08’ 4.2 V8 FSI Engine Rattle on Startup
- Driver info shows trunk open
- Half Shaft Seal - 2008 A8L
- anyone added sound deadening material to doors ?
- After years of loving my D3, I think its time to sell
- MMI Keypanel - versions ???
- 2008 A8 4.2
- Bad Passenger side motor mount
- Moving on. Thanks For All The Help.
- Won't stay in dynamic mode
- Over heating
- Mmi music problems A8 d3 3.0tdi
- W12 secondary air pump fuse
- Front ist lowered. Air Suspension Settings in MMI grey. Compressor not starting up.
- Dead, real dead
- Front Sidemarker Light
- Paging Luis
- 01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
- 2001 D2 S8 left side lights not working
- Seat won't move forward/back
- A/C Compressor O-rings?
- Keyless Entry Not Working; Seeking Advice
- Car does not have heat
- MMI does not open
- Is there anyway to get a second key for cheaper ?
- A/C not blowing cold air?
- VCDS Battery Advanced Measuring
- an economical source for injector 'O' rings ?
- Engine.... Heal thyself?
- Shifter track
- #2825 front parking light bulb
- How long for sleep mode to kick in?
- Siemens Control Module Fried
- Parasitic draw reading (pic)
- With two new struts the trunk still won't open
- Which MMI software do I have? (picture)
- Pressure Line Install
- AC blowing hot air
- Audi a8
- Ventilated seats retrofit
- Parking brake Help
- It’s time to say goodbye
- Heater core replacement 2005 A8
- Upper radiator hose help
- P0491 and P1411 codes
- A8 D3 4E 3.0 MUSIC STOPS when i driving
- 2005 A8L Won’t run with more than 4 gallons of gas
- Passenger mirror stuck down after car is in reverse
- Valve Cover Gaskets
- MMI DIAG
- Exhaust valve?
- Mmi batton panel
- 09 A8L start/stop without key or FOB
- Audi 2004 audi a8
- adaptive headlights
- engine start/stop without key
- 2009 A8L W12 P0172 & P0175
- FCP Euro life time warranty?
- Need help diagnosing engine shake. Please!
- Cloudy sky... Beautiful car
- brake rotor and pads recommendation?
- Continued air suspension misery....
- Fuel rail/system pressure too low
- Solar roof (sunroof) groan/mooing during last few closing inches
- Leaking water !
- Easiest way to remove air ride compressor for repair a8l 04?
- Keyless / proxmity unlock -- I don't get it
- Can you adjust muffler height?
