- Corner De Mayo: All Suspension on Special Today!
- Retrofitting '09 Facelift Turn-Signal Mirrors on Pre-Facelift
- 2000 Audi A6 2.7T low oil pressure warning
- 2011 A6 - Repair to Brake Caplier
- where do i buy downpipes for a6 2.7t ?
- Where do you apply dielectric grease on Ignition Coil? Is it necessary?
- New member/ what's the best website to find performance parts for a 2004 c5 a6 2.7t
- Is D176404M2 (Audi Genuine Sealant) Worth It?
- 2002 Audi Rear fog light cluster question
- How do we remove the Breather Hose Connectors behind the Valve Covers?
- Had my instrument cluster lcd repaired, now showing incorrect consumption and speed
- Radiator
- scaudi site
- FS- 2004 A6 4.2
- '99 V6 quattro avant - *thuds* on engaging and rocking back/forth on throttle on/off
- Febi vs. Meyle Signal Stalk
- Anyone knows or is there a DIY for Replacing Cam Seals on a 2004 A6 C5 3.0L?
- Found few black specks floating in the Coolant Expansion Tank, anyway to remove them?
- How do you all clean the MAF Sensor?
- Need to Change Valve Cover Gasket
- How should I clean the residue inside the coil pack/spark plug wells?
- Broke Ignition Coil Harness Clip; Unable to Remove Ignition Coil from Connector
- Super Low Mileage '04 A6: Smart Buy or Timebomb?
- Hedlight projector/adjuster connection loose (?)
- How many Coolant Fan Relays are there? What type?
- Help! misfires! ICMs or coils? Both?!
- Front Fenders
- Troubleshooting Fault Codes P0421 & P0431
- alarm please help
- Koni FSD/ Eiback Pro Springs 05/2000 C5 2.7T
- How to remove the panel over the rocker panel ?
- Install Glass mounted DAB antenna
- Catalytic Converter Cleaner?
- Pre-Post Facelift differences
- 03 a6 2.7t auto tiptronic no torque at wot
- Totaled Car - Advice? Sell for Parts?
- 2002 Allroad headlights ona A6 sedan
- Coolant Reservoir...
- Does Anyone Have the Label File For ECU Part No. 8E0-909-559 R
- Does the Freeze Frame Data feature on OBD2 Scanners work with the Audi A6 C5?
- Certain Front Driver Side Interior Lights Do Not Work; all linked to the same wire?
- Anyone have the Cylinder # Markup Diagram for an Audi A6 C5 3.0L (2004)
- Exhaust flex pipe replacement?
- "Occasional" Idle Noise When Starting 2004 Audi A6 C5 Avant 3.0L
- Anyone Familiar with XTool VAG401? (Handheld VCDS Device)
- Revving Engine to 3,000RPM, Brief Sound of Sharpening Knives,
- Front & Rear Fog Lights Do Not Turn On; Replaced Headlight Switch; Same Result
- 2008 A6 4.2 S Line
- How Does My Idling Engine Sound? Video Link Enclosed | YouTube |
- Hazards blinking when parked '02 S6 Avant
- Power Mirror
- :: ECS Tuning :: C5 A6 SPC Adjustable Upper Control Arm Kit
- H&R Springs and Sways Special at AWE Tuning
- 2003 A6 Cranks - Does not Run
- removing doors and door parts
- help! dont know what vacuum line goes to this.
- 2008 s6 fuel gauge malfunction
- Power steering click/light clank.
- car overheats when i shut it down | 2.7 t 2001
- A6 C5 2.4 V6, strange whining from throttle body
- Paint Work Referral Baltimore area- scratches
- A6 parts to save.
- Moving Bose system (2001 A6)
- Interior light stay on and door locks stop working???
- Some door and body questions
- A/C issues after new compressor installed
- A6 3.0T Superhagred 2014
- Flush cooland system
- How to bleed cooling system
- Engine fan runs on
- Massive oil leak front of engine, but timing belt clean?
- '01 A6 2.8 Overheating
- Solid to flip key
- 2001 A6 2.7 secondary water pump leak
- new guy with some questions
- Quick Question, buying late C5 2.7T
- C5 center console latch
- '00 A6 Avant Prop Shaft Replacement / Center Bearing Align
- Charred 2015 A6 New Delhi
- Coilover for Under Special is back at AWE Tuning
- A6 Window Problems
- 2002 S6 comfort module PN question
- Whats your style?
- Help - 2003 A6 Avant - Won't Run
- Speaker wire colors for 02 audi a6 quattro
- Adjustable Upper Control Arms
- Stereo Wiring
- 2.7 t revs hard / clutch slip
- Wheel fitment
- A6 2.7 with KO4's clutch problem
- :: ECS Tuning :: C5 A6 2.7T Valeo Clutch Kit
- '04 A6 Avant? 3.0
- CTS always reading 30.0'C at the cluster
- 2002 Headlight question
- Drive Ratios 2000/2.8 vs. 2002/3.0
- C5 passenger side lighting/electric??!!
- Where can I find?
- Driver's Side Axle
- A6 Colors 2000 and 2002
- steering rack
- 4 Sale, Tool for AVK (+BBK) 3.0 5 valves
- No headlights, taillights
- :: ECS Tuning :: C5 A6 2.7T & 2.8L Timing Belt Kits
- New CTS, temp readings way off
- Rough idle with flashing CEL
- Please Help :'( Audi a6
- H&R Coilover Suspension Savings at AWE Tuning
- :: ECS Tuning :: C5 A6/Allroad Stage 4 Front Big Brake Kits
- 04 A6 2.7t Tip having Tip issue!
- 3.0 change-over valve disassembly
- audi a6 exhaust interchangeable ?
- Bought a S6 today
- Rice over speed
- Transmission ID and proper fluid type...I"m confused
- :: ECS Tuning :: C5 A6 2.7T ECS GEOMET® Rotors
- 3.0 guys look... Billet aluminum dip stick
- :: ECS Tuning :: C5 2.7T 2.0T Coil Pack Conversion Kit
- abs fault a6 2.7t - after search, i am helpless...
- Changed O2 sensors and still got codes...
- Rear pax side axle/cv
- 2004 Audi A6 Quattro 3 : Gear Shifter Not Moving to D easily
- Wix oil filters
- Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - March, Monday 25th - Sunday 29th
- 2WD auto trans for 4.2 mid engine setup
- Telephone not installed Issue after MMI update
- A6 4.2 transmission issues
- 2.8 service question
- Help with determining the correct platform
- Missing Problem, No trouble code
- 02 S6 - Tranny in Limp Mode - Stranded, need help!
- Transmission Swap
- Boost Pressure at Idle?
- False code for torque converter???
- Bilstein Suspension Savings at AWE Tuning
- 03' A6 Cupholders
- 2008 3.2S A6 Intake Manifold
- P1179 and P0175 keep coming back
- New Audi Owner 12 Error Codes - Where does an Audi newbie begin???
- :: ECS Tuning :: C5 A6 Bremmen Parts Armrest Lid
- Steering Rack: Servotronic or Not
- Audi C5 fizz sound appear from stereos after shut down engine
- Anyone have use for a gray headliner and pillar trim?
- 5 monitors not ready. CA emissions coming up.
- Need write up to take dash apart
- :: ECS Tuning :: C5 A6 Front Wheel Bearing Kits
- Pieces of metal in the oil collector
- 2001 A6 4.2L Valve cover gaskets
- 2004 A6 2.6T - cranking but no start
- chasing air intake leak
- Winter wiper blades for C5 S6
- new owner question...
- Ice and Curb Rash
- Radiator replacemement
- Has anyone seen an exterior black vinly roof kit?
- S6 vs S8
- Parts Cars, Buy, Sell, Experiance
- Instrument Cluster for 2000 Audi A6 2.7T
- 2002 A6 C5 2.7t in black. Suspension bushings...
- Inner tie rod ends.
- Wiper arm
- Rough idle, missing, stalling, no acceleration, smelly exhaust
- camshaft 2.5 tdi help
- engine compressions
- :: ECS Tuning :: C5 A6 2.8L Complete Valve Cover Gasket Kit
- ECU chips
- S4 Avant or S6 Avant?
- How can I make it faster
- brand new coolant tank from dealer still leaking
- Need new radiator support cant find right one
- Power Steering Pump Failure
- audi a6 c5 2.5 tdi (2000)
- Rear Brake upgrade
- 2002 S6 Avant OEM Headlights
- audi a6 c5 2.5 tdi. coolant
- 2.8 general maintenance
- Free Shipping on suspension at AWE Tuning
- Your new Performance Specialist, a message from AWE Tuning
- Help Me!!!
- Help me make my 2.7T fast again!!
- 2005-2008 Audi A6 LED Strip R8 Style Projector Headlights for sale
- Please Help with Coolant Reservoir
- 2003 Audi A6 3.0 Torque Converter
- 2001 Avant turn signals
- new to me 2.8 with 3 cel codes.
- Coolant Recommendation
- 2001 A6 2.8l oil pressure light issue
- 2.7t grinding noise
- Seat panel removal
- Which oil filter (?)
- Is this coolant hose loose?
- Jumping sensation when accelarating between 40 and 60 MPH
- trans slipping in D and R
- mirror upgrade
- :: ECS Tuning :: !!10% Off Exclusively Through ECS On ST Coilovers 2/5 - 2/15!!
- Crazy Steering Wheel Whip
- 2000 Audi A6 2.7T Oil Change
- Front End Parts
- Lumbar Switch
- Anyone every looked into these stereos?
- PS pump replacement
- need advice buying a 2.8 avant (searched)
- steering rack compatibility
- After Run Coolant Pump Wiring Polarity?
- Sound curiosity- left and ride side
- 2003 Audi A6 Quattro P0300 P0301 P0305
- How to remove lower crankcase breather hose?
- 2000 Audi A6 error codes
- Can 2.7T Auto handle upgrades? How much?
- 2.8 Variable Volume Intake Manifold Test
- :: ECS Tuning :: C5 A6 2.7T Oil Pan Replacement Kits
- Shark Fin Antenna Encasement Missing
- :: ECS Tuning :: C5 A6 Vaico Front Upper Control Arm Kit
- Windown Control Module
- Don't buy from Am-Autoparts!
- Does OBDII Port Stay Powered?
- 2.7T allroad APB Throttle Body Reset?
- common air leaks?
- 2.7 a/c bypass
- 02 S6 brake seizure
- An Electrical Problem
- Driveshaft Problem
- Intermittent Multi Cyl Misfire
- Another wiper thread, sorry!
- weird noise from suspension while driving
- A6 Avant 2000 Regular gas vs Premium gas?
- Issue with 2002 A6 2.7t - Stalling at start today, almost didn't get home
- Cat Delete?
- :: ECS Tuning :: C5 A6 2.7T 710N Diverter Valves
- Smoke and oil coming from exhaust tail pipes
- Triptronic not working and doesnt have drive
- Outer tie rod end question
- New to the forum but could really use some help.
- Hazard lights come on
- Any A6 2.8 no start gurus want to scratch thier heads?
- Windshield wipers come automatically in AM when cold
- climate temperature control question
- HELP needed 2001 A6 serpentine tensioner
- :: ECS Tuning :: C5 A6 Quattro ECS Exact-Fit Brake Lines
- JHM Fmic
- A6 2.8 part lengths.
- 2000 Audi a6 4.2 exhaust ?
- A6 cluster into A4 for testing
- p1522 & Flashing Cel
- 2.7T To 2.0T Coil Pack Conversion Kit
- Can a pcv breather hose be cleaned out?
- 2002 A6 3.0L Low Oil Level Light - Bizarre Issue
- Can someone explain me the "puck" on 4.2?
