- Do I need to mate my new TCM to the ECM?
- 2003 A6 Radio Reception Problems
- Toe adjustment
- Allroad: alignment with 402 mod and spacers
- Anyone with experience on how (rapidly) wheel bearings fail?
- 1997 A6 Exhaust Question
- A6 3.0 Won't stay running after start
- Auto open of windows and auto close of windows & sunroof, via keyfob
- 99 audi a6 electric fan
- Pair of New Philips D2s 85122 HID bulbs available
- Fluid leak, need advice :-( (long post)
- New A6 Hazard Switch and Bezel Available
- 2004 2.7t sline
- Can't remove stock stereo. Help/thoughts?
- New RS4 mounts on my 01 2.7MT fixed the pickup truck ride
- S6 supposed to come w/full size spare?
- 2.7T synthetic vs mineral oil.
- Random internal lights and central locking while driving
- new 2001 audi a6
- 98 A6 trunk doesn't lock
- Raven Motorsports
- Father's Day Special at Detailer's Domain
- Huge Bearing isue need help ASAP
- Can a full interior swap be done???
- Avant cargo liner
- Which pic does not belong with the others?
- Pushing readiness
- 2004 A6 3.0L shakes a little and the engine is a little louder
- Factory first aid kit in rear armrest...
- 04 a6 bose upgrade
- Cotter and slotted castle nut - help please
- Wanted: 4B0 927 156 FE TCM Help :(
- Abs light blinking,grinding, and spudder
- 2.7L T Wont Start
- 2004 A6 4.2 upgrades
- A6 Allroad radio code fault/problem
- Aftermarket alarm recomendation
- OIl light on 2003 A6 3.0 quattro
- power windows,sunroof and interior light not working
- Brake Pads & Rotor Problems
- 2.7t Knocking / thunking noise 1200 rpm.
- Power Steering fluid question
- Do I have a Cruise Control Module?
- Cruise Control Module?
- 2001 a6 2.7T pressure relief hose from coolant reservoir
- Pinch Bolt Hell
- Does anyone have part numbers for OEM springs?
- Where can I buy this part?
- Advice buying an A6
- weird LCD display issue
- CEL blinks a few seconds then disappears
- 2003 RS6 Repair Milestones - advice
- Radiator Fluid Leak
- Car cover
- VAG-COM DIY?
- Windows won't work & car won't lock
- Will A 2000 A4 Right Side Mirror Fit A '99 A6?
- I thought i was done with codes
- Upgrade tires and rims??
- Handling at speed--yes, I'm wearing my asbestos suit, c'mon in.
- Finally managed to clean up and store my snow tires
- Brake Grinding
- Valve Seal Install Tools
- Is this true!?!?!? :)
- Besides the Allroad, has the USA seen a manual C5 Avant?
- Parts falling off my A6. What?
- How can these codes be corrected?
- CV boot question
- Handbrake loosened quickly
- 2007 A6 Quattro Need MMI software version
- Free beers on Power Steering
- Need some advice on oil leak
- speedometer and tacho
- A lot of headache, need your help
- Steering issues
- 2001 A6 4.2
- 2001 A6 Key Fob Reset - One Key Only
- turn signal relay
- Idle's fine drives like crap, can some one help me out
- vag-com won't communicate....
- O2 Sensor codes
- transmission control module (tcm).....
- SOS URGENT HELP!!! Exhaust problem
- A6 2.7T where does this connector go to? cream colored on radiator support harness?
- ***'99 audi won't shift into 5th***
- 3.0 timing belt replacement questions
- 11 Faults
- Wont start at first in the morning
- A6 Thermostat Warning Light On
- Yay, I've got a coolant leak. =)
- Head light warning buzzzer and other issue
- hard brake pedal. booster vacuum line problem?
- Traction front/rear ratio
- Barbarian method front control arm change
- 6MT Guys: clutch vacuum vent valve switch
- Memorial Day Special at Detailer's Domain
- Can someone tell me why.
- Bose "Half" or "Full" Amplified?
- No Start, What Next - Cont'd
- Trunk will not lock shut
- Loud humming noise at 40 - 60 mph
- Please help!!!
- Audi A6 Turbo Tranny Stuck on 3 or 4 Gear :( help
- Billy Boat Exhaust Group Buy!
- get the Aftermarket Audi A6 (2002-2010) 2 Din 7" In Dash DVD GPS Navigation
- Please Help ID This Part
- brake light switch
- 2000 A6 Avant 2.8 Acceleration hesitation & bad gas mileage
- warmup catalyst.. help :(
- Window trim, roof racks, trunk trim piece?
- How I debadged my A6
- Suggestions on changing a manual
- RS6/S6
- Hard going into reverse
- CIL error codes, help please? do I need new cats?
- ABS issue: ABS kicks on everytime at 10mph
- A6 2002 allroad suspension not working
- New Ride
- TCU Problem
- Steering feel B5 S4 vs C5 A6
- Tire Pressure for 19"
- I just posted my STAGE 3- C5 for sale in classifieds if anyone is interested
- considering an '02 S6 Avant...
- replacement headlight question
- Broken motor mount
- WTB: s-line/sports suspension..
- P0411 code.
- need a pair of 01 Xenon headlights ?
- A6 4.2 problem, timing chain alignment?
- ATF - 2003 A6 Quattro - Fluid Fill
- 2003 A6Quattro - ATF fill
- Torque Converter
- Egt g235 sensor
- Foreign Object Under Right Valve Cover!
- No Start, What next??
- New catalytic converters for my A6
- A6 2.7T subframe lowering
- strange shifting
- Loctite & crank bolt questions
- wheel tiressize question..pics requested
- just changed my cv axles, still cracks when i turnthe wheel when its under 40 f
- reving while idling
- Replacing Camshaft Position Sensor '01 A6 2.7t... OEM or Aftermarket
- Wanted: Tow Hitch for A6 Wagon C5
- wheel issue please help
- front end rotating grinding noise
- Need Tips to Remove Clip on 2004 2.7T Front Brakes (ATE)
- Please help... Turbo shot (there's a surprise)
- need help about the vacuum hose...stealer told me it a 100euro a piece
- TB service parts list...anything missing?
- Is the A6 4.2 slow or what?
- A/C doesn't work after timing belt job
- Turbos 'sing' sometimes at startup?
- Camshaft Position Sensor codes - help
- Rear wheel will not come off
- Two BALLs connect to the end of vacuum hose
- Strange problem, please help! -- my car attracts dinosaurs.
- Does this make sense? 3.0 cvt to 2.7T 6sp or V8 S4?
- A6 vs S4
- VAG code 16815 - Do I need new CAT?
- Off topic but worthy, thank our service men and women!
- Too Much Oil??
- Need clear corner headlamps?
- So,,, anyone have an oil filter housing/bracket they don't need?
- 2002 s6 vs 2002 A6
- Flex pipe leak
- 2002 A6 Brakes
- Looking to buy an A6
- big problem
- Build an A6 vs hunt down an RS6?
- question about pig tails
- Cluster question !
- bearing help
- Wiring Harness to Trunk
- steel brake line
- Chrome Mirror Covers
- Planning on going stage 3, advice?
- 2003 A6 Quattro (3.0) 5 valve cylinder heads
- immobilizer RFID programming
- TBB
- So who has an MTM chip?
- Coolant and A/C fans not coming on
- Quick opinion on missing clamps
- Interior trunk lights
- Need a Part Number.
- ALIGNMENT ISSUE??
- ABS stutters after axle and control arm swap
- Homemade handy fluid recovery tool
- Brake Beeding - Pedal Prop
- TCM problems, some advice please?
- Installed a Aftermarket DVD Player
- Airbag reset
- transmission leak after curb hit and flood
- I just bought this Audi A-6 bi-turbo..
- 2000 A4 - Low beam fuse blows when I turn the headlights on
- Main seal starting to leak. 2002 s6 wagon
- Blower Motor won't blow... any ideas? 2006 A6
- Floor Mats Wanted
- windows and interior lights dont work
- A6 Flex Pipe Repair
- Unlocking Bentley CD on Windows 7?
- Help with 99' Audi A6 2.8l!!
- Alternative to Bentley manual?
- Changing primary coolant temp sensor on 04 2.7T, pics & need a little advice
- anyone have Auto HVAC experience?
- Gutted dps diy project?
- Timing Belt Etc..
- Can't get radiator hose back on - help!
- For Sale - ITG air filter, Bentely Repair CD and O2 sensors
- Oil Temperature Sensor/Switch connector?
- 2.7t detonation/hesitation when towing?
- hawk pads for sale
- Car wouldn't start then fine!?
- Need Help decoding VCDS-Lite (VAG-COM) codes!!
- Engine stutters
- PSI for 2.7t Engine "Compression Check"?
- 2.8L Hesitation during acceleration
- 2001 audi 4.2 shift lock override
- Complete C5 front halogen lamp housings available
- Thumping noise after changing front brakes
- Farewell to my Audi, and I won't miss it
- Trying to remove cylinder head - how to unbolt turbo?
- Where to buy paperback Bentley Repair Manual?
- Maybe I'm crazy but...
- X-Post : Magnaflow Catback kit group pricing is set.....details and pricing here
- How to test 2.8 Cam Position / Crank Sensors?
- HELP!!! Need advice on the vacuum line (can’t find where it starts).
- just scanned with vag, fault codes found, any ideas??/
- Seeking advice/experience on replacing power steering pressure hose
- Fuel Pump DIED.....got a question
- Length of Intake Manifold Linkage Arms?
- front bumper cover
- Buying 2.7T with 150k miles
- Tie rod ends.....
- Missing part?
- Need help identifying a part....
- Working on group buy pricing on the Magnaflow 16493 catback exhaust kits...
- Airbox clips.
- awd to 2wd conversion?
- Crankshaft Position Sensor?
- Is this a giant vacuum line?
- 2000 A6 Avant 2.8 AC Compressor Not Turning On
- Engine wiring harness diagram?
- Replacing interior, what aftermarket interior parts?
- What sensor does this plug go to? #1
- What sensor does this plug go to? #2
- Paging 4Driver4 -Camshaft Timing Update
- 2.8 Just replaced motor, need some help
- To the RS4 and S5 I just raced
