- 2004 s line a6 steering rack replacement
- 2004 2.7T A6 "Whoosh" Sound After APR
- O ring below aux water pump - how to remove?
- I've got conflicting instructions (help)
- How many stage 3+ or better A6's out there?
- Stainless Grille Strips
- 1995 Audi A6 2.8L Wont start no forewarned problems
- JHM Drivetrain Stabilizer to Eliminate Snub Mount?
- APR Stage I Performance Chip Now onboard!
- Replace all front end suspension on A6
- Rear window wiper arm replacement
- Engine chatter at 1500 rpm - '00 A6 4.2L
- Trunk Lid Fog Light
- Best hid bulbs?
- Is it just me, or is 2nd gear...stiff? Crunchy? How to describe...
- Does anyone make a rebuildable coilover for these cars?
- what control arm/tre kits have people been using?
- Adding a new dimension or two to the driveability puzzle.
- Multiple Qs
- is their a Fuse for the SAI pump on 2.7t?
- Fuel pump removal
- Cam Timing Help!
- Timing Belt
- Flex pipe replacement
- complete suspension overhall questions......
- 1998 audi a6 2.8 quattro need ideas
- Symptoms of a failed fuel pressure regulator?
- Snub Mount aftermarket
- WANTED: S-line Sport Springs for 2.7T Quattro Auto
- Removing HP2 calipers 2002 S6 - seems simple; isn't
- 2.7t emissions system insuficient flow?
- ITB's
- cyclonic technology
- Is there a transmission Dr. in the house?
- Quick control arm question...
- '04 A6 2.7T Sline Quattro - New to us - Questions
- Clogged EGR Combi Port? P1423
- Ongoing problem
- Sounds like a TDI. 99' A6 2.8
- Codes thrown after major engine work
- Deploying and Storing Car for a Year: Tips or Suggestions?
- Help interpreting VCDS emissions codes, please...
- What a night! More parts replaced, and a weird failure. (HELP)
- Twin turbo your V8 C5, RS6 stuff FS
- newbie question again,,,
- no up shifting
- where to find relay #30 in Audi A6 -97?
- Satellite Radio.. To Be or Not To Be..!
- lots of codes
- Acceleration results 2.7T APR 93octane
- Won't start, starts, won't start.
- Wheel Fitment - offset issue?
- Newbie - Engine T-Belt goes slack after sitting
- Subwoofer/amp installation
- service position for radiator removal?
- Avant LED Tail Lamp Housing
- Upgraded wheel sizes for 2007 A6
- NEEED HELP
- head light lenses.. Swap..
- History on Maintance... How to..
- New To audi please help :)
- Help !
- inner tire wear
- Headlight Adjusting Screw
- 2000, a6, quatro, 2.7t
- sale parts
- help
- front dif seal
- Help draining fuel tank
- audi a6 99
- many many A6 troubles, help please?
- :: ECS Tuning :: 84% Off Ski Bags!!
- :: ECS Tuning :: 95 % Off Front Floor Mats!!!!
- new to audi, question with picture............................
- 2001 A6 4.2 typical coolant and oil temp?
- 350 amp alternator
- Hello / Need Advice
- differential oil
- Fog light grilles
- Need Help with Flex pipe Issue
- Stainless Steel Breather Hoses for Sale for 2.8 C5 Platform
- Rebuilding electric radiator fan motor
- Accessing fuel door lock actuator help needed
- 99 won't start...Help!!! Please
- Busy day at the Hansen society for preseving old Audis
- Emergency: Need fuel injectors!!
- Never thought I'd throw parts at a car. What causes weird idle/throttle conditions?
- Programming an ebay fob for 2000 A6 2.7T
- Newbie Needs 01 A6 Quattro Wagon parts
- Anyone have a set of Tiptronic downpipes for the 2.7t engine they are looking to sell
- Deleting LDP?
- FrankenTURBO beware(not really, but kinda ;) )
- 2000 A6 2.7t no boost and no smoke?
- VAG-COM
- 2000 A6 2.7T Curtain Airbag removal?
- DIY: ABS Module replacement in Audi A6
- 2002 A6 2.7T - Catalysts & O2 sensors
- Parts CD's ETKA on Ebay?
- Tranny fluid recomendations
- Anyone want an MTM Chip for a 2001 A6 2.7t 6Speed?
- Gurgling noise from rear
- 2004 Audi A6 2.7T Quattro S Line Part 2: Opions/Decisions
- HELP! Timing Troubles!
- Various warning lights, maintenance, pictures, now with slightly more street cred
- 2.7t using 2.8 bumper?
- timing belt 1998 A6
- Vacume testing suggestions/help
- 2001 1.9Tdi AC not working
- Need Help with 2.8L Combi Valve Replacement!
- VAG-COM not communicating. K1 short to ground
- Is Mobil 1 LS75W-90 OK to use in rear dif?
- constant brake wear indicator on dash--annoying!
- New owner
- Intake manifold corrosion in injector holes
- A6 A/C relay
- We’re looking for a few good cars.
- 2.7t fankenturbo kit
- What is this antenna for???
- A6 2.7 rim problem
- New to Audi, have some questions
- 2004 A6 Avant V1 Hardwire to Fuse
- Audi S6 2002 wiper funny
- Looks like a different chapter here, turn the page.
- my audi a6 door turn from hard to close to open by itself
- Clicking, shaking and hard turning...
- Anyone have a spare cam locking bar?
- Best radar detector?
- A6 2.8 vs A4 2.8
- :: ECS Tuning "Spring Cleaning" Sale!!! ::
- Driveshaft Replacement (slipping, paint can sound, etc)
- Serpentine Belt Gone
- 2003 A6 Quattro 3.0 30 valve: exhaust manifolds removal
- Audis at over 300k
- I'm tired of these vibrations, weird steering wheel habits, etc...
- headlight lens
- Rarity Question!?
- how to make 04 audi a6 2.7t s-line FAST AS POSSIBLE?
- Couple of questions (trans and lights)
- 161.2mph!!!
- Question about buying an 04 audi a6 2.7t s-line
- Audi A6 2.8L ATQ 2000 Power Steering clicking
- Will A6 headlight fit into S6?
- Part # for sunshade clips
- transmission issue
- Anyone have some Hawk Blue ST-40 pads laying around??
- urgent help needed, central locking acting up.vag code
- connecting I pod to 2006 A6 Avant
- Transmission Fluid Change
- C5 A6 a/c problem
- WTB 17x8 et35 Fat Fives
- o2 Sensors, all of em?
- came across these while cleaning the audi....
- door sensor? Dome light not coming on when opening door
- NO CD indicator for Symphony I CDC
- WTB: 01 A6 Driver Door Exterior Molding/Trim LZ5L Ming Blue
- Timing belt pulley replacement
- Laggy 3 to 4th gear shift - Tiptronic
- audi a6 front door very hard to close
- 03 A6 3.0L advice needed
- help identifying crushed line
- Please Help!
- 2000 A6 Avant Quattro Vacuum Reservoir
- Help with rear bumper black plastic trim
- Brake Spring???
- used convinience control module recode...
- Hi, I'm new with a few questions.
- '01 A6 2.7T: Rear/Backseat window controls do not work: childlock stuck on
- C5 A6 Bursting into flames on Fox News
- '01 A6 Headlight Fogs up
- Confusing key issue, 2001 a6 2.7q
- Amsoil ATF
- Recoded ABS module for manual trans, now get "incorrectly coded" fault.
- A6 2.8L V6 Catalytic converter replacement
- '01 A6 2.7T: Help identifying an engine part please.
- :: ECS Tuning :: C5 A6 All Weather Rubber Floor Mats Save 10%!!
- Trying to find speaker upgrade without changing stereo
- i'M New With My Audi S6 2002
- Warning, don't drive your A6 thru floods in freezing temps!
- FTG vs EDU
- Airbag Harness Connector
- coolant temp sensor fault?
- AIR INTAKE 2.7T
- Changing differential oil for 2.8 ATQ - any advice?
- Transmission Fluid Color?
- APTuning's March Madness Timing Belt Special!!
- 2001 4.2 how to align cams on cam tensioner chain?
- CEL could use some guidance on a couple of codes
- Spark Plugs/TB Service
- C5 avant vs C6 avant
- WTB: used passenger xenon lite assembly
- concert plus radio codes
- no sound from Bose spkrs in an 01....
- Hi im New
- Hi im New :D
- Someone stole my fog light grille AGAIN!
- Help ID this Part - AfterRun Coolant Pump?
- Baffles in the valve covers?
- Pre-cats on 2.8?
- New purchase, 2004 A6 2.7T 6spd, got newbie questions!
- Part number look up please :-)
- Anyone running 19's with out lowering?
- pulling my hair out misfire desperate
- 2001 Audi A6: My car was keyed. Paint repair advice would be great
- A6 (C5): loud noise when turning on car...
- 2.8 flex pipe question
- Transmission Slipping?? Help Please!
- FS: 2003 A6 2.7T Factory Recaro Seats and More
- Help Identifying Electronic Attachment
- 2002 allroad needs new clutch - Boston Area
- SAP Part #'s
- Anyone heard from Jonas Collins aka J.col
- those that are Stage 3.......
- ABS and Brake warning lights coming on
- 2.7t stock injectors
- 17819 & 17832 Code help please
- 2002 A6 2.7T - turbo replacement?
- Just purchased a 2003 A6 3.0 Quattro
- G.I.A.C. Spring Specials are alive!
- MAF/CEL/ESP/LIGHT.....HELP !!!!!!!!!!!
- Misfiring! Ready to go Postal
- new VC gaskets seeping
- Purchasing a 2002 S6...50,000 miles
- eletric starter bolts
- How reliable are A6's?
- 00 A6 Avant-sound from undercarriage
- My shop's oil recommendations threw me off
- coolant leak
- Main catalyst bank2: efficiency below threshold
- 2.7t Turbos
- CRUISE CONTROL disconnect ?'s
- Diagnostic Port on Audi A6 2006
- Who's organizing the GB's these days....
- LOWERING MY A6 !!!
- Flashing CEL, Misfire Codes, & Rotten Eggs, Oh my!
- New TB now all cyl misfire!
- Auf Wiedersehen Avant
- TB Replace DIY?
- Transmission Slipping When Turning
- Climate Control replacement question
- Is there a trick to disconnecting headlight washer pump?
- Car Locked Itself-have no key!
- FS 18" OEM RS6 wheels W/tires of my 2008
- Draining coolant from block
- Suspension Replacement or Alignment??
- Dash Cover peeling
- which vag-com
- what is vag-com
- What size wheel spacer
- Catalytic converter
