- A/C compressor noise
- 1999 A6 2.8 Sealed Transmission
- Audi Club in Phoenix
- ALTERNATOR PULLEY
- Do I really have to pull the front end apart to do an ALTERNATOR?
- New to Audi, New to Forum - Please Give me Your Advice
- 2000 2.7t passenger rear O2 sensor procedure?
- Serpentine Belt Replacement
- word of warning for chipping your car and turbo longevity
- anyone have any rims for snow tires around Seattle?
- How do you remove the coil wires from
- measuring turbine rpm
- Coolant near aux water pump, but replaced it 11k ago...
- Added another German car to the stable
- Power window cable broken
- help with cam/chain allignment
- Cooling system issues
- wont boost past 10 psi, way down on power please help!!
- Wow! Just realized it's 10 years
- Need help in South Jersey!
- 01 A6 4.2, no forward gears but reverse works
- Battery
- Airbag module went bad....radio tools don't work. Alternate way to remove radio?
- A6 4.2L Brakes??????????
- 4.2 issue
- Normal Oil Temps in a 4.2L?
- Loads of Codes and Misfires
- 01 2.7T wheel spacers
- 2010 A6 Water Pump Failure
- Heater Core Hose ID HELP!
- To Audi or not to Audi
- Where to buy the 0650 or latest RNS-E software??
- A6 2.4 V6 Shudder
- ANY performance parts for my little V8????
- heater core hose
- What aftermarket fuel pump to buy??
- A6 4.2 Transmission problems
- might be retiring the ride- coolant boiling
- audi a6 2,8 1998 quattro avant xenon problem..
- Where can I find a k04 housing??
- Simultaneous Coolant Level ad Oil Pressure Light
- Brushed Aluminum Interior Trim
- Strange Issue
- a6 2.4 p1392 problem
- Getting the Stage 3 bug again...
- Trunk lights stay on with lid closed and latched - A6 2.8 2001
- I'm looking at a '01 A6 this weekend, what maintenance should have been done already?
- Can-Bus Adapter..Cant find one???
- First CEL in my 02 3.0 Avant
- I love the new ECS
- Anyone interested in 2000 a6 4.2?
- Poor Highway Mileage
- Boost spike at throttle cut?
- Check Engine light - ongiong problem - S6
- Can I top up existing G12 coolant with long life coolant?
- Belly Pans
- Food for thought can a A6 Become a S6
- where can i get eibach or koni parts cheap?
- Buying k04s, what supporting mods do I need??
- CATALYTIC CONVERTER ALARMING, FULL REPLACEMENT NECESSARY???
- Ski and luggage box
- Revisiting aux coolant pump leaks - 2.7t
- Chicago Help
- 2003 A6 Quattro Torque Converter Stuck Off
- No Heat Brrrrr....
- Where is the Horn Relay located on my 2000 A6 2.7t?
- Ah, new parts!
- Help with CAM plug(s)
- 1997 audi a6 quattro-- Horn!
- first snow pics
- Help...Power folding mirror issue
- Looking for a used A6 Avant 3.0L and wondered about reliability/cost
- Is there any way to disable the Xenon Headlight Range Control through Vag-Com?
- Third row seating for avant
- It's nice to be back in my A6.. After driving a 3 year old Toyota Tacoma for a week..
- RS6 Parts Car at All Star Imports-American Auto
- First time for new shoes on my 3.0 Quattro!!
- What's a good VAG scan tool for Audis?
- Access to Diversity Module on 2003 A6 2.7t
- I cheated on my C5
- New Transmission filter, and pan mounted. Fluid in..
- Little Help?!? ABS sensor replace...
- Fault code scanner not connecting
- Brake Bleeding questions .
- winshield washer not working
- car tuning of randomly
- Parts are here, now all I need is the time to get the job done...
- new shock and spring set up
- 2 Questions: Passenger Mirror and bumper
- Will same year A6's with different MAF's have same ECU?? Please look!!!!!!!
- Looking to drop audi a6 a couple of inches
- what wheel size for a 2001 audi a6
- Remove Rear Deck?
- Gassy smelling exhaust.
- ALLDATAdiy.com Introduces Sponsorship of AudiWorld with a Discount!
- Coolant system issues - help please!
- Problems with ECU/Gearbox on A6 Allroad
- Fuse/Door/Light Issue
- Turn signal wiring issues puzzle
- Who wants a stage 1 GIAC ECU for '01 A6 6 speed!?!?
- Determining ABS system
- Audi A6 Hybrid
- Heads up - M1 0w40 on sale for $3.99 at Advanced
- rs6 18' rims on a a6 2.7T
- LED lights for C5 A6
- Anybody know what color the factory HID's were on an '01 A6 2.7t?
- P2404 code on 2002 A6 2.7t
- Need Advice - Crazy Vibration with throttle applied - CVT
- 2002+ headlight switch into pre-2002
- Dead A6 (P0321-Ign./Distributor Eng.Speed Inp.Circ Range/Performance)
- Oil Pressure Light Randomly Blinking! Please don't go kaboom!
- Lucky break
- auxilary water pump
- how to replace right rear abs speed sensor
- I sold my 2.7t on Saturday so I am off now...
- Trip Computer Does Not Display
- Alternator ID
- audi a6 2002 bumper
- I bought a RNS-E unit, I have a question...
- Taillight short or bad module?
- overheated today
- 2001 A6 check engine light is on ... help
- Any recommendations for drying out A/C system after hard rain?
- Diagnostic Tools
- Transmission issue
- HELP! Difficult Vacuum / Boost Leak - Turbo wastegate actuator hose
- Question about Double-Din System, please help!
- Photos of the carnage...
- still looking for some parts
- car engine overheats 2
- '99 A6 battery drains in 2-3 days if car not used
- Need some input on a S6 buy
- SAI...wracking my brain! and boost HELP
- Will A6 C5 front seats fit in a B5 A4?
- Coolant Leak
- Modified my transmission's oil pan tonight, with a big rock...
- Can't cry over spilled milk.
- ABS Speed Sensor -eBay Supplier Feedback
- looking to buy a 2004 A6 3.0
- 2.8 30v engine coolant temp sensor
- A6 quattro 1998 won't crank -HELP
- Where to buy A6 C5 RNS-E faceplate??
- Will this in-dash navigation fit in a 2002 A6?
- Replacing Transmission Control Module
- ESP/ABS Lights - Brake "Test" Switch?
- Making Space Around the Throttle
- :: ECS Tuning :: The Holly, Jolly, 2010 ECS Tuning Holiday Sale ~ SAVE UP TO 25%!!
- What to expect on your " new" Audi ( 2.8)
- In the middle of a window guide replacement... Window goes up but stops before top
- :: ECS Tuning :: 6TH ANNUAL HOLIDAY GIVEAWAY
- Diagnosing lock problem
- VAC line diagram anyone? 98 A6 2.8
- Tiptronic 5hp19FLA
- obd 11 communication error
- A6 buyer needs help
- Sad news - I have only just found this and I think a few here...
- Help with relay harness + HID kit = error even with error cancellor
- Heater hose horseshoe spring clip?
- HID-D2S low-beam headlight bulb change
- Car won't boost over 5 psi! Help!
- Air in the master cylinder, ABS
- Volt meter question...
- LCD replacement
- Nervous about long road trip (oil consumption, etc)
- catalytic code
- Dash Faded volts went down (fast)- then died
- P0421 and other MILs
- crank lock pin help for 04 a6 2.t7
- NOX FAILURE AND OCCASIONAL MIS-FIRE
- APTuning November Timing Belt Install Special for Virtually all Audi Models!!!!
- valve noise and oil consumption...two questions
- Anyone besides me looking for a CANGate module for RNS-E? There might be a solution..
- 3M film cleaning question-help
- '02 A6 4.2L w/broken timing belt
- How to jack up rear with front on ramp?
- Please Help!!! ESP/ABS problems
- 2001 Audi A6 2.7T Traction Control light flashing when under Load
- Looking for XM antenna
- Will RNS-E from a new A4 OR A3 fit in A6?
- What is the consensus on the best LED bulbs to buy? Id like to replace all my....
- Confused about single and fouble Din??
- Low idle, stumbling and codes
- Idle, throttle, and driveability issue.
- A6 2.7T AUX Water pump leak and fix
- A6 2.7T Timing Belt Change Blauparts Kit
- tail light question
- A6 2.7T Exhaust Gas Temp Sensor P1453 to P1462
- 2.7T Engine Coolant Temperature sender P1620
- WTB A6 4.2 front grill
- O2 Sensor Internal Resistance Too High Intermittent
- cigarette ligther problem
- Junk yard for new heads?????
- 2000 A6 4.2 TRANNY PROBLEM
- custom a6 pillar gauge
- How do I get to CD7 and CD8 (Symphony I)?
- ECU Import from Germany? Possible?
- New Owner! Pearl White A6 4.2
- Plastic elbow that connects for secondary air pump to the air filter housing
- Squeak in Right Rear at Low Speeds
- Surging
- Code 1555 fixed....but
- New Key Immobilized
- Tie Rod Ends - current thoughts
- Air bag didn't go off
- Carfax/Title question-comments please
- New seats, what to do...
- Trim/Heated seat switch in rear of 2002 A6 problem! Pics!
- Informational screen fading
- I've even got the original window sticker to go with it...
- 97 A6 Quattro follow-up questions
- LED Interior Kit... (Video)
- Crankcase ventilation question (2.8L).
- Broken Drivers Window...Part??
- Advice needed - buying a used 2000 A6
- Front strut replacement made simple .
- Recommended front pads for 00 A6 2.8ATQ
- 01 2.7t MT Oil leak source?
- Air filter housing
- '01 A6 Sudden Tire Wear
- All 6 coils replaced!!
- 99 A6 secondary air pump? rough idle
- A6 Gearbox
- cat converter and bose questions
- '97 A6 Quattro rough idle on startup
- 9 CEL codes.. Please help... Electrical short?
- 4 Brake Lights
- Replacing the torque converter resulted in getting lousy mileage
- flashing key light on dashboard
- I need a new clutch for stage 3+ car... Opinions??
- suggestions for suspension upgrades
- Front caliper leak
- 99 a6 2.8 known for going thru front rotors?
- Where to by OZ Superleggera wheels??? I need one...
- engine management code 16804/p04020
- Abs Peoblems
- Turn Signal Failure 2002 A6 Avant
- Sourcing Colored/Striped Wiring
- Bentley vs Bentley?
- Camshaft Alignment Tool
- New to me A6 4.2 questions
- SHHhhh.....Their is a monster in my trunk
- ABS Control Module - Drive without it
- High idle and B1S1 O2 sensor related?
- Comfort Turn signal in a 2000 4.2L?
- Detailer's Domain: SEMA / PRE BLACK FRIDAY SALE! 20% Plus!
- I NEED A TRANSMISSION MODULE !!!!!!!!!!!!!!!!
- Restart fixes A6 electronics?
- Registering in Arizona live in California
- Had a bad ICM and now low boost
- A tribute to Audi
