- On-board Diagnostic Codes
- Irregular Oil Consumption
- quick power steering fluid question
- TCM location on A6 2.7T
- car engine over heating
- Mirror Switch part #, are they the same swithch?
- Audi 2002 A6 Quattro 3.0L.-- Oxygen sensor
- Motor mounts C5 CVT 2004 42K miles
- See if you can figure this one out...
- Changed to OEM aero wipers.
- 2.8L with large coolant leak
- facelift and none facelift headlights
- Parts rs6 a6 4.2
- MAS Airflow sensor wiring
- Transmission mount failures
- 2002 S6 Inspection
- parts
- 2002 A6 2.7t
- need help i am new to audi
- Floating charcoal canister. Now what?
- A6 4.2 Transmission issue
- Led tail light problem
- very disappointed in BLAUparts
- Somebody's giving away a 4.2 S-Line
- heater noise
- Random misfire on 1-3
- Replace center crank bolt on 4.2 TB/seal job?
- 2001 Audi A6 2.7T
- 04 Audi A6 2.7T Seat Memory
- SAI: on when car is almost to operating temp
- Electric Cooling Fan(s)
- Part # of center arm rest
- catalyc converter issue think ???
- Passenger side mirror wanted 98-99?
- I will post this till i fix it!
- Will these fit my 01 2.7T?
- Vacuum Hose Help
- Anyone removed the center resonator on a 4.2?
- Should it Stay or Should it Go?
- To buy or not to buy....?
- location of ecu
- Will i be able to transform a key fob from ebay to fit my A6?
- Looking for parts for sale
- (semi)Definitive wheel and tire weight info
- custom a6 3 pod pillar gauge update new pics
- alternator replacement part #
- Engine Stall After Cleaning Air Filter
- S4 Recaro Seat Lumbar Support
- ABS & Brake Warning Lights
- 2003 A6 3.0 engine drivers front O2 sensor replacement write up
- PCM error P0606 / should i flash it or buy new?
- Gauge cluster swap problem
- Car Phone Functionality
- Woodgrain Removal
- iPod to A6
- New Owner - Laundry list of fail.
- Are there 2 ECT sensors? Blue one and green one?
- P1338 Camshaft position sensor
- replacing front struts
- Car won't start, starter sounds fine - maybe ignition switch?
- How to remove the stock stereo amplifier? (2003 Audi A6 Symphony)
- Need Help Please Can't figure out Vacuum Line
- A6 1996 water in engine
- Help Audi 2.7t Mods
- Can the transmission cooler be clogged?
- i jsut dont kno! help!
- performance issues
- Need advice on recommended work
- Premature Wearing of Control Arms & Ball Joints
- DIETRICH AUDI A6 98-05 RS6 REAR BUMPER
- HOW MUCH TO DAMAGE VALVES?
- Need some profesional advice
- Audi A8 L 2005 buy / or not?
- s4 seats in a6
- This F@%$ car it dont ever stop
- Paging " THAT Warranty guy" who used to sell warranties on Legacy AW
- Electric mirror switch
- Brake Shopping
- Key FCC ID
- Dashboard Messgae
- Can you get to the boost hoses?
- Aftermarket Xenon Headlights
- TCM question.. Please help
- Suspension Dilemma
- zenon gone - bulbs or ballast?
- Lambda sensor - correct functionality?
- Lots of auto spares and other bits left over
- Glove Box door
- High idle only with AC off
- Stereo Amp Problem - pop in rear speaker, right dead, and battery getting drained
- replacing the bank 2 front O2 sensor
- Condensation in headlight
- HP2 caliper overhaul.
- 01 2.7L Coolant Gauge Not Working Help!!!
- Part No. for remote trunk lid button at driver pillar
- 19" a8 wheels on my 04 c5 2.7 S-line help please
- stage 2 a6 2.7t straight pipe
- stage 2 a6 turbo guage install
- 2.7T on Air Ride
- SKC
- My new rims
- need help to disable or cover yellow passenger air bag light
- Navigation switch in center console
- Center LED Screen?
- vibration during driving and braking
- Bank 2 Cat Below Threshold 2.8Q A6
- Auxiliary Light Wiring - Double Firewall
- Need Help Mechanically on 2001 A6 4.2
- Might buy a A6 185K 2.7T 6 spd
- 2011 3.0 - Sluggish Transmission
- is a 1996 s6 a good buy?
- Most amazing fix I've ever seen!
- A/C problems
- Selling A4 to get A6
- Need advice.
- Audi A6 Service interval Questions.
- Drivers side lock/unlock button does not work!
- Teaser (not work friendly!)
- Greetings Audiworld
- one plug fouled 2.8
- headlamps and washers
- Have xtra O2 sensors and oil filter
- C5 2.7T Wheel, tire and spring setup
- key fob not working after water damage
- Headlight's not adjusting
- Kaflueie Electronic Door locks
- coil pack wiring ? A6
- A6 sensor problems
- Water Leak-NOT Plugged drains, Need Help
- autocheck brake light and washer fluid levels
- DIY License Plate LED Conversion Question
- Rotor size question
- Starter going?
- Replacing electric window switch - help please?
- Central locking question 2001 A6 2.8
- Are EGT codes suppose to throw a CEL?
- Rear axle replacement with larger diameter Front axles?
- Engine tune up time, need some opinions
- recomended independent shop for transmission rebuild
- Oil smell but no clear leak?
- S-Line question...
- Trans mission lines change help!
- Drive shaft bolt strip please help!
- It'sthat time
- '99 Passenger Seat Exchange Questions??
- Bodywork adhesive recommendations
- Audi DOA :( Any help appreciated!
- Headlight washer relay ?
- Weel bearing noise? Differential?
- Odd tramsmission(?) problem
- List of factors which contribute to rough ride ..? [long]
- DIY to replace front drivers O2 sensor
- bose system 6cd problem
- A/C control unit strangeness. LEDs stopped working
- What is a Stage 3 A6 worth?
- 2000 4.2 ART knock sensor location!
- NEED HELP QUICK!!! TRANS P0753!!!
- CD Changer and Phatbox Custom Cable
- Looking at a 2002 S6
- DIY Piggie DPs - Bung relocation VS Oxygen sensor modding
- ac does not blow cold air?
- Thank you Adam!
- A6 4.2 front mudflaps FS
- Shop says I need a new tranny
- getting ready to try to do my front break pads....
- Immobiliser problem. Please help!
- Time to stock up on Microfiber Towels at Detailer's Domain
- How can do i get the head liner out?
- 2,5 TDI 150hp vs 2,5TDI 180hp?
- This should be easy...
- Moon roof What the F! Help please!!!!!!
- What the hell dome light?????? Help!
- Question on ODB codes for Audi A6 2001
- Removing phone cradle from armrest
- cant get radio out please help!
- EGT codes 2001 A6 2.7 MT
- '02 C5 emissions question...
- 01 A6 4.2 P0491 fault
- boost problem
- fuel pump removal, road block
- TIMING BELT MOVING OFF CAMS
- need some help
- Thoughts on S4 2.7T Transmission install in Allroad 2.7T 6MT?
- drive shaft kit or drive shaft support bearing
- 01 A6 2.7t MT clunk while braking
- Deleting auto trans wiring
- 99 A6 2.8 Bad Cat options
- Located water ingress source... get ready
- Intermitent no start....
- Please Help! ICM? CP? Other?
- Hesitation and stumbling between 1400 and 1800 RPM
- Looking at a 1999 A6
- Auxillary coolant pump replacement...
- Hiya..I'm new here!
- Replaced Engine Coolant Sensor and forgot...
- 02 S6 intake manifold for sale..in classifieds
- How to look up the break sensor type for Hawk pads?
- 2002 S6 AC dead and overheating
- In need of wiring diagrams
- Wanted: Owners Manual for 2002 Audi A6
- Calling All A/C Experts....Please
- Single cyl misfire?
- Looking for an authority on Euro RS6 seats
- Camshaft position sensor
- Camshaft position sensor and brake
- Information Center in Gauge Cluster
- Will 2006 TT Wheels fit on a 2003 Audi A6... (more info)
- Anybody wana see my lap of the nurburgring?
- Help identifying "wedge" in 6speed manual trans linkage
- 2002 audi a6 timeing belt change (any one from detroit area??)
- TRICKS for setting properly GAUGES on instrument panel after being removed...
- 00 01 02 Audi S4 OEM Fuel Pump Assembly Sending Unit
- Camshaft adjustment malfunction
- wtb audi sport package 17 inch bbs rims(s)
- #$!@ Pinch Bolt!
- P/S troubleshooting
- Rear brake and rotor replacement
- drive shaft acting a fool Help
- 2004 Audi A6 Quattro 3.0 Automatic Need Advice On Catalytic Converter
- Open or Short to Ground - Terminal 30
- 2008 A6 3.2 Avant brake job
- glove box stuck
- Group buy on JHM weighted Shift knobs going on now... 25% off
- Rear Sunshade, Revisited
- OIL IN SPARK PLUGS. Help please
- 2 Problems on '99 A6 quattro (Pictures & Links Included)
- Chilton DIY Manual?
- Help
- power steering problem
- how to replace steering dampner
- Shift Knob Removed But...
- some weird msg comes in my audi screen
- Front grill piece
- Need Advice help
- Koni FSD's with stock springs? [2003 A6 4.2 Sport]
- Need help with alternator
- 2002 A6 doesn't like my Vag?
- Cheap downpipes for 2.7T?
- where to buy Timing Belt kit ??
- Help with boost leak
- cassette player malfunction?
- rear fog light ?
- 3 Non-Driver Doors Ajar
- Accelerator position sensor
- Replace Catalytic Converters
- ABS issues?
- clear old radio code
- Is this causing my cold start problems? Please help ID broken part
