- Change CVT ATF - do I need new filter and/or gasket?
- Just got car back - Fixed P0491/P0492 - Odd.. more torque, better throttle response.
- Picture Thread - Lets see your A6
- Valve Cover Gasket Kit Opinion
- A6 Brake Job
- Reverse Sensor not on MMI?
- Busted Cruise Control Fix?
- abs-a/c
- Roof rack install... am I doing it right? (pics)
- Couple of Questions CEL Codes
- Just did my tranny drian/refill with filter change!
- brake a/c failure
- Having troubles finding EGT sensors for your A6 2.7t? A solution is available...
- '00 A6 2.7T
- replacing ECM
- how do i advance the timing on my 1999 Audi a6 2.4 v6
- Cabin Air Filter
- Leaking flex-pipe at the catalytic converter:
- lookin to get chipped
- What's a Good Price for an '02 A6 Avant With a TC Code?
- a/c bracket after market???
- Slow Speed Tick/Click?
- Parting out 1999 Audi A6 Avant - NJ
- Is there a Big Brake Kit for 4.2?
- Need Second Opinion!!
- Immobilizer?
- whats with the Squeak!!!
- A6 2.7L Quattro 2004 Brake Job and Brake Fluid Flush
- trying to understand ipod connection
- A6 with R-8 wheels
- new silver face guage face
- New gt kit coming soon
- is there a way to vag-com a MFSW on an ...
- Audi Navigation - Wtf! Pictures
- TIRES - A6 4.2L - 255/40 R 17 v. 245/45 R 17
- TCU Update
- Coolant Temperature Sensor Help
- fuel pump power question
- Please help me???
- 2002 S6 - Lower engine cover question
- How to tie down a kayak on the A6?
- Has anyone ever used this?
- Hello
- Weird Display
- Control Arm's How many and from where
- Upper Control Arms
- My PocketDyno results, anyone wanna help me figure out
- Steady-cruising MAJOR vibration noticed suddenly... no CEL, but...
- does anyone have a 'how to' for removing the door card on a '98 a6?
- brakes/rotors 2001 A6 2.7
- What is this?
- Anyone looking for a super low mileage 2.7T?
- Could my overheating be related to airlocks
- 1998 Audi A6 Door trim
- cel,radio not working, and no comm. with obd scanners
- plastic window / cowl trim above battery
- Tow Bar
- Timing Belt replacement
- Help with electrical issues: The following are all not working:
- 6 speed conversion
- seeking s6 avant
- RS4 or S5
- Brakes
- How to replace the Cub Holder in the rear seat cushion?
- Weird humming noise when driving...
- Are these any good
- New Owner > 2002 Audi A6 Avant Quattro 3.0L
- 2004 A6 2.7T with 77k for $8k
- Help - Advice
- Drivers door stuck shut...help please
- It's been a while and I have searched the forum....
- HELP WITH ERROR CODES!
- What model K04
- will Mazda Wheels fit on Audi A6?
- '00 Avant: Rear license plate panel...
- Has anyone had Avant roof channel rust repaired? ...
- Replacing tail light and head light?
- Question on transmission fluid in 2005 A6
- HELP HELP HELP...no start after engine R&R
- Oil Filter dilemma
- Which Rotors and Pads are the best?
- I want to purchase a 4.2 A6, if you are selling let me know.
- audi wont start
- CEL won't come on....can't pass inspection
- S6 Front Susp /Brake replacement Cost
- Weird exhaust smell
- Help my A6 wont start
- Looking at a high mileage C5 A6 Avant
- Timing Belt
- A6 Quattro , Better rear suspension ?
- A6 Quattro , Rear sway bar dimensions ?
- VAG Code:
- EBC Brakes
- Need help: water in battery compartment area
- Temperature Gauge acting weird
- Replacing the steering rack but I am stuck
- Kind Of Wierd Problem Here. =/
- Control Arm Replacement
- speedo doing alittle dance
- Great Dealer contact: Mckenna Audi in Norwalk CA
- Febi TRE Blowout
- Chipping a 2001 A6 2.7T w/140K Miles>
- coolant leak
- Serious Timing Issues
- valve cover gasket leak
- Starting to get paint bubbles in various spots...
- caplier
- transmission and display problem.
- Auto Dimming mirror issues
- Multitronic transmission-A6
- At what Milage should the Transmission Fluid be changed?
- Need help with VAG codes..
- S-Line Sway Bar
- Big Kudos to Fred Baker Audi
- Rear Brake Pad Chatter Noise...Wrong part?
- wholesale ED boot,Obama Air force fusion,Jordan 2.5,Jordan True flight,J25+AF1,J18+J2
- Looking for info on the C5 starter
- Ash Tray won't close due to coins.
- ABS light
- Audi A6 Parting out...
- Are the turbos on a 2002 interchangeable with 2003 and 2004 model years?
- Anyone have the flat door blade (lower molding) sills in silver?
- Gearbox oil like a milkshake - oil cooler failure!!!!
- Help engine would not start, now white smoke!
- RS4, lightweight flywheel questions. Speedo errors?
- Rough idle, CEL ... code cipher needed.
- Quoted $ 800 from dealer for both engine mount install
- Need some suggestions on ABS brake lights (They are both on dashboard)!
- Wipers, A/C, & turn signals all stop at the same time?
- 01 4.2; loud humming noise from front of engine
- Engine dies and car would not start until I wait around 20 minutes
- Does 2004 S-line have more flared fenders?
- Paging 4Driver4.....
- New member that need some basic info...
- can not access 46-comfort/convienience with Vag-Com
- How do you tell leather from leatherette?
- A long road to recovery :P
- Aftermarket Fuel pump wants more voltage
- Under car now--why grease at driveshaft/diff?
- Extend. Warranty Change/Timing Belt!
- A6/RS6 Rim Question
- Suspension
- BBS CH Reps - Anyone know where to find them?
- Warranty Change, timing belt ??
- Part # for door trim
- 2000 A6 4.2 Air Filter
- Axle Installation
- A6 driver side mirror replacement
- Part Number Request
- Center Cap 4B3601165A
- Jeeze, so now what?
- B8 S4 test mule spotted in MA yesterday!!! (pic inside)...
- Possible failing steering rack?
- LED display corruption in '00 A6
- Clutch pedal
- Cam Position Sensor question
- Cam Pos Sensor question
- Catalytic Converter p0422
- FNR-G60 Brake Retaining Spring for 2003 2.7T
- (P R N D) flashing on dashboard
- Rear Park Assist - How does it work?
- Oil Leak around turbo somewhere
- Anyone with a service manual!
- Newbie rim question.
- Giving a 2001 A6 a refreshed look -
- Rotor Installation 2000 A6 2.7 with 8 pads
- Interested in 2004 S-line 2.7T
- Uh Oh...98k miles and leaky camshaft seals - LONG/ADVICE REQUESTED
- can someone tell me the diff between 2000-01-02 4.2
- P0884
- 02 3.0 cold start misfire lasts 20-30seconds
- ABS and ESP lights come on at the same time
- Timing belt parts ordered...again.
- Are the standard A6's more reliable than the allroad?
- 04 A6 Q 2.7T Broken Headlight Mount Bracket Question
- Transmission acting weird
- anyone know off hand which issues of european car mag talked about a6/s6/rs6?
- Steering fluid coming out of the vent hole
- fixed buzzing noise behind A/C control panel
- Servicing
- Lost top half of key--need help and advice!!
- Coolant Level
- One more fix before I toy with the idea of mods
- Help for a dummy
- Uh oh, what's this on my garage floor?!??
- Anyone have a Aftermarket Warranty on their Audi?
- Would the ICM from a 2.8 work on the 2.7
- Joining the high milage club with my A6.
- High speed fan not working since overheating.
- Hey All!
- Handbrake light flashing and beeping?
- please tell me the SAI relay number and location for 98 a6
- PES S6 G4 Supercharged
- Rear wheel bearings - which size?
- Okay. I did STFA and still need your help
- Wheel bearings
- 2003 2.7T Non-HP2 Brake Caliper Removal...
- 1999 A6 2.8 Part number
- what to do with an A6 Avant
- Do you care enough for your Audi too
- whos 04/2001 and later trannies have failed on 4.2?
- Suspension noise?
- Washed her this morning
- best year for 2.8 to get?
- Audi s6 1995 door panel
- Phantom in the trunk
- High pitched low volume noise above 20 mph
- If you could not find a Bosch or Mann oil filter...
- Need to take off Top Dash...Need Help
- Help! ABS AND BRAKE SIGNAL ON DASHBOARD
- What do you think? DIY blackout Audi S6
- Install cost of PES Supercharger...
- any empty nesters want to trade? my 2000 S4 (stg3) for a C5 S6 avant
- Virbation like hell!
- Couple questions for the experts about an A6
- Need Help Finding yrk2.7t......
- What do I need to set-up or align with vag-com after TCM removal
- Signs of Tranny Problems
- SMOG Time.... but...
- My car is so slow...
- Drove a 3L today and am amazed at the difference from a 2.8
- "please help" 10 things wrong 1 things broke
- A6 Rear View Mirror Assembly
- Trouble Starting When Warm
- Can someone help out and provide the part number for an 01 A6 2.7 Secondary air pump?
- power steering fluid problems
- does anybody have the burnt out foglight syndrome?
- 2002 A6 3L Trans went @ 94k...what do i do?
- Can I make these rims fit: +30 (rear) +42 (front)
- Morning hesitation... Even in 70deg weather...
- Stopped Starting...
- 118,000 mlies and needs $3500 to bring it back to life.
- Installed the RS6 Alcantara Headliner today! (alot of pics)
- Trading in my 02 S4 for an 04 A6, but have a question?
- P0432 Code Help
- Question for PureMS
- DIY timing belt change help needed in MA
- Adjusting Camber or what!?
- 12v switch in trunk.
- Exhaust upgrade
- New/summer wheels are mounted
- TB/Water pump change - timing question
- Kayak roof rack for the A6
- 03 a6 3.0 have bigger flares then 2.8?
- Hello...new to Audi's
- Seat belt buckles not talking to airbag system
- Attempting to replace Driver Side mirror post | Problem w/Window Switch
- CEL code P0118 - Engine coolant temperature circuit, high input
