- So my CPO is about to end. What should i take advantage of?
- so the dealer said that the peeling in my a6 on most of the interior panels...
- This local dealer is making it very difficlut to hang on to my A6 (bmw haters have been warned)
- 4.2 timing belt question
- rims still destroyed... anyone know someone selling some nice 19's?
- I think I should start the "WTF of the week" on here lol, here's this weeks pick...
- 40v-V8.. 4.2 ride height question
- Replacing a brake light bulb in an 04 c5 2.7t
- Heh...
- LOL! I spy with my little eyes...
- Cool iPhone application link inside...
- Any last minute tips for a diy h&r coilover install?
- How important is the mechanical fan (fan clutch)?
- ugh just ate a giant burrito from chipotle.... feel like i'm going to die...
- The Audi Driving Experience was a definite hit!!!
- Friday Poll: Do you already know what your next car will be?
- Exhaust Project Prototype Round 1..
- Suspension noises...think there engine/tranny mounts
- Don't recall if I posted this. Prosport boost gauge install (long w/ BWW) [Edit]
- i just posted a FS ad on a 02+ C5/allroad climate control unit if anyone's interested
- Am I seeing dying oxygen sensor(s)?
- 1999 A6 Quattro upper ball joint
- Look what came in the mail!
- My car needs a bath.....I just got NO time to do it.....I just need 3 more hours in a day
- What are everyones feelings on water/methanol injection kits?
- how can tell if my battery is being drained...
- 5Speed. How much Dynamat did you need for the whole trunk? I think im gonna go ahead and do mine.
- 105,000 mile services-already gleaned info by STFA
- :: ECS Tuning :: Selection of C5 A6 / S6 FK Grilles - Now Available !!!
- Brace yourself for something funny
- Control Arm Sources- going to order
- Anybody have a spare clip that holds the upper rad hose on for the 2.8?
- Press, i dare you to post here ;p
- Transmission Pump Seal...
- check engine light on for b2 s2 faulty
- Do you think there is enough room under our cars to fit these off my piggies?
- 2001 audi a6
- Why isn't anyone helping me:(
- Audible N80 valve ticking + hot day = fuel smell outside car?
- Changing Steering assist with Vag Com
- Possible ECM replacement
- What does everyone use to wash and detail their Cars?
- One of the posts below reminded me of something. How difficult is it to install those cluster rings?
- 2000 Audi A6 2.7T Quattro Transaxle Leaking. What could be causing it to Leak?
- Is this the correct steering wheel for a 2003 2.7T?
- ::Block::
- Pwr Steering Fluid: full to empty 1x / week. Common problems spots?
- Torque Converter troubles...
- so is there a write up to clean the evap drain? did stfa and nothing solid...
- FM modulator quits picking up on 88.x channel randomly?.?.?...
- Switching Motor Oil
- 1. Still looking for Torque Converter. 2. Talked to 3zero3 and got an interesting update
- Finished timing belt job - started it up and there is oil dripping from the bottom (front)of the pan
- trifecta....8^)
- yesterday was the first track event that i didn't drive the big girl
- the holy grail....
- Ahhh - sigh of relief...
- sears has a 1/2" impact wrench on sale this week for 20$ fyi
- FADING SPEEDO DISPLAY ON 98 A6
- 16502 again... help???
- Its gut check time for me... Need Advice
- 2.7T vs. 3.0
- diversity antenna??? WTF, O?
- Very Rough Idle (comes and goes)
- X-Post to awne, our mbworld guys organized a local GTG for make a wish foundation
- Bah! need a new battery soon and have to clean out the evap drain, plus my window lock semi works...
- cant open rear door
- A6 2004 flasher removal
- Much better : )
- Paging Jimmy: YGM : )
- I posted a week or two ago about an annoying rattle from under the car at low speeds. Solved.
- OMG!!!! I can't find where to purchase the tools I am going to need. any suggestions?
- dayco timing belt?????
- Will 19x9.5s fit on lowered 2000 A6 2.7T?
- well, sheeeet. i ignored all the alignment posts i saw about the S6 and it's gone and bit me in the
- Johnny is depressed now. Look what I found under the intake manifold : (
- Paging BD: YGM
- Bentley Manual for an '01 2.7T? Is there an alternative?
- mechanic had my car on a lift, then after my ABS light goes on, he says its due to repeated lifts..t
- Ewwww.. Look what I found when I removed the throttle assembly..
- Quick question.. Which fuse is the one for the fuel pump? (and yes Dave, I STFA.)
- Blah. Just noticed that one of my intake actuator boots has a tear :P
- So, I picked up a new foglight relay to replace the one that fried and I'm thinking...
- Repost Issue - Symphony II....Anyone also have an '04 A6 S-line ...
- Brake Light
- 98 A6 Cruise Vacuum hose diagram
- Repost... Anyone looking for an RS6 Sound Enhanced Exhaust w/ stock trade???
- Do I need to have the ECU "re-coded" or "re-initialized" after installing pre-cat O2 sensors on my..
- Incredible office worker "flip-out" video
- ATTN: Narrow body owners - So I got a chance to come across a good deal on 19 x 8.5 wheels, but...
- Are there any good/low dust brake pads for the FRONT of a 2.7T that are under $100?
- BTW.. Do any of you have a radar detector that you don't need?
- I know this is probably a bad idea, but it might be worth a try.
- MAF to ECU Wiring Testing Help
- brake rotors....DBA 4000 series fit 2000 4.2A6Q?
- After oil overfill (2/3rds quart) car developed leak, but then...
- Say you forgot to put one of the bolts (10mm) back on the waterpump, how bad is that?
- The McBoost.com Waterfest 14 Gallery is DONE!
- Since we're (kinda) on the topic of Tip cars, can someone answer this question for me?
- Anyone looking for an RS6 Sound Enhanced Exhaust?????
- zomg... Driving in D4 FTMFW. Car is so much more aggressive above 40.
- Angel eyes may be for Bimmers, but I think they still look pretty good on Audis (sorry, forum
- squeaky noise from the steering wheel
- Transmission "bump"
- Jet Hot Coating
- So I fired the McModel and hired Kris for the afternoon!
- Custom S6 grill on a prefacelift?....questions
- BostonDriver YGM
- Need to do an ECU swap for testing purposes, anyone in Santa Barbara with an 2000 A6 2.7T, Tip?
- 2.7t Owners Chip Question
- New H2O pump/T-Belt. AC stopped working
- cross post, I need some used 2.7T clutch disks
- IS there a difference between the timing belts of an a4 v6 and an s6 2.7t? LOng
- Calling all people with dead driver displays. Tonight I met the fellow who has successfully and
- Help: Radio just stopped working today....
- living life by the 1/4 mile
- Has anyone purchaased this DVD Manual for repairs?? any thoughts??
- Calling 4.2 folks...am I missing a bolt here??? (engine bay)
- Anyone tried the Blauparts Brakes?? or ECS Stock Brakes for all wheels??
- Quick stupid maintenance questions regarding rear power windows and seat belt holder thingy...lol.
- This just might work, It's going to be close......
- Question on offset for new wheels.
- Any of you other C5's have this sticker?
- Passat 4motion or A6 Avant
- Just a preview of next week's project!
- A.W.E. Tuning 2.7T Downpipes
- Driver Information System Guage
- HELP!!! Anyone have any idea what this control module is for???
- Bummer...deal's off.
- CD changer: just verifying a dealer answer...
- Speedtuning USA chip for 2.8 30v's
- TGIF AM Poll: Nicknames for any and all of your rides....
- Engine misfire at all speeds and burning plastic smell - any helpful hints welcomed
- Boost gauge install (finally)
- Saw this on the B5 S4 forum.. Anyone have $220k laying around? : )
- help needed CD changer wont work....
- Anything I should know before I replace my coolant reservoir?
- You guys were right....
- Calling on Suspension Experts...
- Bought new car, radio says it needs code, code doesn't work, what do I do?
- Bosch part no. for stock APB 2.7t fuel pump?
- Where are folks getting Torque Converters upgraded these days ? Any leads on a spare TC ?
- Got Turkey? They use the A6 as a slide. '87 MC pics also. BWW
- You can't trust 5speed6
- Looking for a local 2.7T manual trans for help with our Downpipes
- Need suggestions for front shocks. Going on a 2.8 and looking for equal to existing stock units.
- Need help keeping headboard light unit in place (pics)
- audikillsbmw: What size cat is needed for the 4.2?My CEL came on today and it may be the CAT...
- Random question: Do 1.8's have the same size fuel regulators as our C5's?
- How many burgundy(maroon) C5 A6's?
- Two of my favorite things...
- Moisture in the TBB?
- heater core signs
- Need help with a lower control arm install
- 2" lift went on tonight.
- OT my ass look at this... rofl...
- Repost | Apple's Front Row integrated in an Audi A6 | Cool! Real car, real Operating System!
- Affordable BOLT ON Rs6 style trunk spoiler for $200 painted!
- F@#$#$#$##$! My car said I had 35 miles left when I put it away last night (light just
- Tyre pressures?
- Instrument cluster removal
- If i get chrome ebay mirrors can i give them the brushed look myself?
- $990 from indie to replace front shocks with alignment. Ouch! Searched and decided too much for...
- Can i put 215/55/16 on my wheels that have 205/55/16 right now? what would it help.
- Question on ECS' ultimate plus TB kit...
- 2.7T Front Brake Pad Replacement Question
- What would you guys do?
- How difficult is it to remove the impact bar from the front bumper?
- 2002 A6 4.2 Quatro - Problems, looking to buy
- Finally sold the a6 this past weekend...
- whoohoo car is fixed....
- peeking in from the UrS6 forum, anyone know/have opinions on this car?
- Pool: '00 2.8 codes, what's likely the problem(s)?
- Shift linkage rattle? (need opinions on dealer diagnosis... Tnx!)
- help plz car in the shop for 4 week really need help hear
- Money+youth+stupidity=dead
- I just picked up a RS4 exhaust system........this should be fun
- CVT Transmission A6 3.0 - 2003
- Immobilizer class action lawsuit.
- Hard to find parts needed- DS Exterior door handle + engine skirt
- Question about Factory Sport Springs & Shocks for 99A6Q (1BH)
- suggestions for 2.7 bi-turbo,a6 ????
- iPod Integration ... questions
- Porsche statement
- Anyone have a DIY on a SAI delete for a 98 2.8L Quattro?
- Tranny Question
- Torque convertor problems
- Fair asking price for used Stoptechs?
- Waterfest 14 Gallery is live!
- Any leads on aftermarket A6 2.7T exhaust ? Used is ok !
- I have a situation I need some guidance on...(this is kind of long)
- So how many of you received that worthless class action notice???
- Just finished replacing drivers axle. Peice of cake!
- Can someone tell me what the CAT ECU flash upgrade is and how I perform it?
- So how much of a PITA is it to change pre cat O2's? B2 and B1
- Brembo's or Chip?
- To the kid in the Pearl White 2.8L that tried "racing" me on Rt 72 yesterday...
- Having my heads machined... X-Post + another question...
- For those with a Bentley manual: Are there complete diagrams of the SAI system in there?
- So im about to change my timingbelt myself and i want to know if theres anything i should know about
- WaterFest was a blast this year.
- Transmission fluid Change question?
- Softening the Sport Suspension for A6 2.7t
- Installed "New" Symphony II but no sound or volume??
- Poll: Results of gas tank recall?
- Oh, look who's back! Not much to say yet, but maybe Kris does!
- What do you guys think about 18 inch s4 wheels? I know the tires will be about 1300...
- A/C Blower, Blinkers, and headlights
- How do I remove the plastic cover over the wiper wells?
- I need a Catalytic Converter - 2000 A^
- Tail Shaft Leak, Pass Front Axil Shaft Leak, etc
- 5speed6...how did Waterfest go? What awards this year???
- Help Please
- Anyone ever heard of this issue when replacing the hydraulic tensioner?
- Snapped axle...apparently a 4k launch is a bit much, :(
- Left CV joint ticking/clicking while accelerating - should this be fixed RIGHT NOW or can it wait?
- What are they?
- Can anyone tell me the difference between these two part numbers?
- OT- Beautiful exhaust note : )
- Avant guys, I need a measurement please
- Moving to California from Illinois.. Do I have to change the Catalytic Convertor or anything else??
- Paging April, Perfect Alfa for you....Euro Import
- Needed - Avant 3rd Brake Light
- Has anybody successfully realigned front bumper cover themselves?
- The R10 kicked ass again...oh is this OT -
- F hose...where is it?
- Im getting new tires. Pzero Neros? or Pzero Rossos?
- No air flow from console vents to back seat - '03 C5
- 01 4.2 timing belt questions
- serpentine belt tensioner bolt snapped...
- Hmm....can a 2002 2.7t a6 use
- Help!! What does these codes really mean?
- 02 S6 Sirius options?
- How do you remove the lower radiator hose on the 2.8? There doesn't seem to be any access?
- Brake question
- New C5 4.2 Owner checking in
- Coolant temp sensor,,,
- Moving to California.....
- Airco problem
- brake bleeding + vagcom?
- With the exception of the bumper removal, I can use the A4 2.8 bentley t-belt instructions, right?
- Front bumper clips??
- Ok... here we go with the Exhaust-stuff
- Headlight refinishing question. My buddy redid his Passat about 8 months ago and the lights looked
- Ok...I may get flammed but I am asking anyway....
- New (to me) car.......
- Was there another VB attempt this morning? I couldn't access AW for several hours.
- Does anyone know how much the OEM O2 sensors cost pls? (Pre-cat)
- 2003 A6 4.2 engine replacement @ 72,000 miles
