- Interesting reaction time test
- Poll: Anyone had their alternator go lately? How much did it run to get it fixed?
- im still looking for a tan/beige privacy cover for the Avant...anyone?
- wassup guys
- Anyone know if C5 A6 front seats will work in a B5 Passat?
- A Happy C5 Story
- Comments on 4 wheel alignment report, please...
- Options for iPod Integration?
- zee avant is gone, long live the avant....
- -need driver's side doors, 2001 in Nemo blue...
- I STFA and a couple of guys on the A6/C5 forum have had the same issues with PBR's.
- PSA- Walmart carries Mobil 1 0W-40 : )
- POLL: feeler to see if there is any interest TB kit for 2.7tt from purems, possible group buy
- If the car was not equipped with ESP can you add it later?
- (Friday Poll):if you could have 1 car come back into production,what would it be & what changes?
- Eibach doesn't make dampers for my car anymore!?!?!?!
- Paging 5Speed6......how you feeling today????
- My rear diff is whining! video inside
- A6 4.2 wide wheel pic request...
- Happy Birthday, and R.I.P., Oliver Kenkel aka "Audiablo"
- Pre-Friday Poll: Who here has served in the Military? And if you have, what branch?
- I am about to pull the trigger on spark plugs STFA I am confused...
- To my AW family. Asking for thoughts and prayers.
- Help with fuse?!!!
- My, the years fly by..
- Looking for a pair of used rear springs for A6 4.2 sport suspension
- Crap! Just received the RS6 upper grille and did not realize
- Dog cage for 2003 A6
- ACHTUN!NG | APR Sale - April 14th through May 9th 2008
- Spark Plug Gap. Bently calls for .4 to .6 mm Did a quick measurement and factory is .7 in the NGKs
- My radio keeps burning its fuse in the back, do I need a new headunit?
- All hail the death of good taste at BMW
- 17" OEM price?
- I'm building a stage 3 allroad :)
- HELP!! Water in rear passenger footwell!!!
- STFA already, anyone got any info on inmotion tuning? was interested in their chips...
- audio wire colors
- OT? Sh!t. I lost one of my wheel caps. Now I have to take the rest off, or I'll look
- Removing the stop light from hatch in A6 avant ?
- New rotors needed soon - and I know there are many divergent thoughts about
- Clunk going over bump
- Damn, does anyone contemplate getting a Phaeton?!
- Anyone running FSD Koni/eibach suspension? want to know what the actual drop is over OEM Sport..
- 03 S6 Advice
- Feel a little less depressed about my bumper now. Did 60-90 3rd gear pull in 3.91s.
- a while back i posted about a check engine light after the darintake mod with a cone filter. ...
- Door sometimes wont open..
- Paracaidista2.7T YGM!!!
- ATE Super Blue Brake Fluid DOT 4
- STFA already: who's replaced a headlight/bulb
- Help needed with coolant leak...
- Procedure to replace the emergency flasher switch
- Smoked Headlights 2004 A6
- Anyone have a link to biggest post whores / most viewed threads of 2007 thread?
- Any install headaches or fitment issues with H Sport sways and coilover suspension?
- How many times have you replaced chromatic rear view mirror?
- Servicing questions (80k, 100k, timing belt, etc)
- One of the new gals at work drives a NEW C300 4matic...
- Looking for part help. Replacement Bolt.
- Friday Poll: Is it Friday yet? ..... Why isn't it Friday already :(
- Yesterday was fun...temp gauge up/down/up/down, CEL, and when I got home...
- Is this pretty much the only DIY Write-up for the coolant oil cooler leak?
- Bent wheel perhaps???
- RS6 Plus wheels
- 2.8 vs 3.0 Questions inside
- I knew prices dropped fast but not this fast!!
- RPM guage shows lower than what it actually is??
- Thinking of replacing my A4 with an A6.
- Anyone know the blackout headlight trim part#? Thx.
- Secondary Air System
- RS6 plus
- Now that I am going to have to get some painting done, I guess it's time for door blades........
- Break rotors and pads
- Axle Replacement Cost - "Leaking Boot"
- Anyone in CT doing a TB this summer?
- Someone got me in the parking lot, nailed the front bumper with a trailer hitch. Can it be fixed..
- DIY Replacing Tie Rod End - Just double checking ...
- Anyone use FW1 on their wheels. Was at a gas station today and it took off winter brake dust from
- Thinking of a 2.8 Quattro
- does anyone know which speedi boot (split cv boot) fits the a6 2.7t
- Does running piggie pipes make your car run rich.. more info inside
- Solved my electrical problem
- Well.. I finally removed the screens from my MAF housing..
- Why does my car with sport suspension have lots more tire/fender gap than other A6's with
- Control arm help needed ASAP!!
- Side Skirt and Headlight Brow
- Doh, alternator died on the way home today. (w/ questions)
- where to get blank switch/buttons to the left of the hazzard button
- Ready for biking season
- I have searched the classifieds on here, audizine, and audiforums and cannot find anyone....
- PSA: AW License plate frames are in stock again.....
- The time has come
- How old are your tires??
- BWW w/ Poll(e): Compiled some dampener/spring combinations
- *sigh* Still in love *sigh*
- Stoptech stage 2 upgrade and HP-2 install done. link to pics inside
- those S6 vacuum actuated variable cam jobbies
- Does anybody run 5-spoke RS6 reps on a 2.7t with HP2 brakes? What is the offset on the wheels?
- Does anyone have a decent set of 17" wheels that clear HP2s and are for sale/trade?
- Much better pics of my wheels
- PSA: Costco has Mobil 1 on sale $8 off a case
- Looking for something wider dia. Suggestions on where to find used/cheap aftermarket 2.7T exhaust ?
- Cant decide between A4 3.0 or A6 2.7t S-Line
- Sorry More Questions...
- LED Turn Signals - BWW
- Hmm.. N00b question: How should I join my 2.25" cat outlets to THM's 2.5" exhaust?
- What do you recommend for exhaust on the 4.2l ? :)
- I've Been Researching...This might be long
- I had two responses to my caliper bolt question: 120Nm, and 190Nm. Which one is it?
- is the CPO warranty transferable from private party to private party?
- For you with 6 speed MT, and Walnut interior trim...
- Achtuning Spring Cleaning
- Where can I get some good Pho in West L.A.?
- Hmm.. Tip position #1, or tip position #2?
- HELP: 01 2.7T - loud whining noise coming from the big belt on front of engine
- Here's a mock-up of the tips I'm thinking about using for my quad setup..
- Anybody have advice on whether a 4.2 sport swaybar set is worth much? And sport wheels?
- Wheel Help w/ lowered car
- Anyone in Tampa willing to look at a car for me?
- 99 2.8 oil pump
- Anyone want to trade/sell seats? Also need advice on commute.
- WWAWC5A6 Do? I put some LED bulbs in brake/tail, they seem not bright enough
- Engine noise a week after the timing belt replacement...x-post.
- radiator fan part number
- ISATI :P What's the TQ spec for the 21mm caliper-to-upright bolts?
- The POLE on POLE!!!....
- Saturday morning project, new shoes with 12mm spacers
- Gas smell
- crud, it's 65 and sunny today, it's got the summers on, and i'm stuck in a convention
- Ignition coil
- Car just died at idle last night. 16 codes. Any ideas where to look for my electrical gremlin.
- I want your opinions on a exhaust setup I am getting installed today
- Ok, finally got my staggered, wheels, here are some extremely crappy phone pics
- Wow they are really dropping in value !!!!
- Hit 140K today, will be at 142 by tuesday.
- Audi C5 4.2L - Aluminum subframe?!?
- '03 S6 - timing belt etc. completed - 65k miles + Body shop recommendaton...
- weird power loss and shifting........
- Barging in from allroad: my friend - not me - selling his silver 02 S6 dropped his
- 6 Speed 2.7T for sale in my area, NOT MINE
- N00b question: Anyone know the length of my stock wheel bolts? I don't want
- XPost 245/40R17 on 2001 A6 2.7T will these fit?
- Paging S6_Skier: YGM : )
- Feedback please: What spark plugs to get for 4.2 Bosch Platinum or NGK (I STFA)
- ACHTUN!NG | C5 A6 gets our 19" Concept Nuvo...
- Update on electrical problem and water infiltration issues
- temp gauge not working.
- I need some feedbacks on Toyo ProxesT1R's tires. any good?
- Transmission or engine issue?
- off to autobahn country club in joliet, illinois this afternoon for 3 tracks in 3 days
- A Show of hands please!!!!!!
- to followup with vikingdiesel's remark about staggered setups,
- Front End Questions
- 99 C5 2.8 (of course:( ) Avant swaybars. I have read praises but did not see much from the 2.8 crowd
- Question on CAT's
- power steering pressure hose- where is it?
- Friday Poll: Which car "feature" do you use the Most / Least / Never ?
- anyone have a left side motorized mirror?
- My test today of a 2004 Avant RS6 Plus with ABT chip @510BHP
- Looking for an oversized piston - A6 2.7T BEL
- Driver side mirror acting funky
- Stumble at neutral throttle: Fixed by 710Ns
- Need help!!! 2001 Audi A6 2.8Q
- Just got my new (old - 2003) S6...
- part number request
- will a staggered setup mess up my Trans,ABS, awd or anything?
- RS4 reps on a white a6?
- Rolling in style...
- Clutch on it's way out?!
- Is is crazy to trade my 01 a6 avant w/103k for an 02 S6 85k plus 10 to 12k or so?
- Looking for S6_skier...
- So does this look good? Pioneer..
- Control Arm Bushings.
- 3.0 Quatro car trouble!!! Whats going on?
- Today's the day.... Goodbye
- Have any of you bought aluminum plate through an eBay seller?
- I know April already did this but... a feeler post is one where you gauge interest, and worth...
- I just put out a feeler post with no prices or anything and it was deleted? y?
- 2004 A6 S-line 2.7 turbo
- Running at the track...any suggestions?
- S6 cluster in a 2000 A6 possible with no problems?
- Interesting Oddity found : "Audi RS Passat 4motion" with 520bhp (using RS4 and RS6 tech)
- pictures
- Reminder to all our forum users. FS ads of any kind are not allowed in the regular forums unless
- Ok, she's on the block.....
- Finally getting to my electrical problem
- Wiring diagram request.
- The humpday Carlsile report....
- Paging Andrew W: YGM.
- RS6 Grille
- So where can I buy SeaFoam? Do places like Autozone (cringe,) etc. carry it?
- This eBay ad makes Johnny sad : (
- Let's play name the part game.... need the plastic tube that connects to the pass side combi valve
- this is what i'm currently doing, browsing site for pics to look at since i'm bored......
- Nice. Saw two Maserati's and an RS4 today : )
- The Achtuning onesie-twosie wheel clearance sale!
- Opinions welcomed: late model C5 A6 for a new driver?
- pics from the ring....bww
- Johnny, heres the mirror and tail shots, dirty car warning!
- question about instrument display
- 2002 S6 fog light bulb change?
- Hockey Players chime in
- my custom 2.7T exhaust video clip
- center counsel display controls (temp display, A/c on/off, etc) not working when I hit the button
- Intermediate (all seasons on stock 16 wineglass wheels..) are ON. It's officially spring.
- the view from my hotel room at the ring....bww
- Happy Birthday April/Verdegrrl!!
- Anyone got any pics of Supersprint Exhaust fitted ? Round or Oval Tips ?
- Does the dealer stock replacement seat leather? Mine is looking very tired.
- Very little heat coming from the vents???
- So on Sunday Jee came over to the house and he brought this along..
- Weird...traffic information and delays coming up on radio display..
- Question about TB replacement
- Newbie saying Hello and a few questions
- European spec xenon head lights for audi a6 2.7t
- I'm sooo psyched! AoA called and they are replacing my cluster display!!!!
- Woot! Got maintenance history for 20-60K and 60-99K
- Well, its been nothing but gloomy, but I promised some pics so, here they are.
- lugs/wheel q's - urgent, sorta..
- Pics from the NY Auto Show & Audi forum....
- here's a pic of me on the ring, being driven by the ring queen herself
- black sport seats on Portland OR craigslist
- C5 A6 reliability
- interesting radio behaviour observed today
- 2003/3 S6 | Talk me into our out of a purchase.
- I tried to post in the 90/80 forum but to this point no response. Anyone have any feedback on a 1998
- LAST CHANCE to sign up for EPL Custom Tuning in Colorado
- Going to get the Milltek catback exhaust put on today....
- Phantom Car Alarm
- I have a brand new Meyle water pump (still in plastic) for 4.2 - email me if interested.
- Despite the lack of back seat legroom, I'm trading my 4.2 in for the S5!!!
- back in the usa....
- 2000 a6 engine codes P1131, P1411,, P1423?
- Will 321mmx30mm rotors from an S4 with HP2 calipers work for a S6 Avant with same HP2 calipers,
- Anyone had issues with the front running/turn indicator lamps working intermittently?
- Dome light and cluster display door open goin on and off??
- Yes PLEASE!
- Photoshop expert needed, W12 tips on A6, just curious
- Last day for free shipping on Hartmann wheels from Achtuning!
- New Rims
- So what's the cheapest source of OEM parts nowadays?
- clunking noise
- Tail light fluid... where to buy?
- Just picked up an '00 2.7t... saying hi!
- Looking for rear bumper cover for my 2001 a6 avant
- Speaking of IC upgrades, does going to K04s mandate upgraded ICs?
- When I do my IC install do I just need to remove the bumper to get at the IC'S?
- Anyone have a Bose rear psgr side door speaker cover?
- Anyone paint their oem C5 a6 grille to match the S6 charcoal grille???
- Anyone on here have Breyton Wheels? If so, post pics
