- Carfax?
- audi a8 p0300 - p0304 random misfires on all of bank 1 and p 1340
- The H&R Catalog, by AWE Tuning.
- 2001 A8L overheating when outside temp is low, when over 75F, seems fine
- 2001 A8L HID headlight...bulb? ballast? other mystery?
- 99" A8 Alternator vent tube
- Motor Mounts ?
- S8 exhaust options
- Auxiliary Cooling Fan Relay Location?? 97 D2
- a8 Vs A6
- '96 42. V8
- Cruise Control Diaphragm Control Rod
- Timing belt job
- Audi S8 in Top Gear Episode
- problem with the TFT Sensor
- Clunking front...leaking subframe bush
- few codes on my a8
- Front bumper release
- Cold start almost stalls then RPM Fluctuates
- 7x17 ET39, will this fit on S8?
- Help 99 audi a8 multiple codes
- VAS-PC v18 & 5054a
- Small jerk when shifting from 3-4 and from 4-3
- Soft brake pedal after new pads installed. Used motive power bleeder, used vag com ab
- Upgrade 97-99 to 00-03 Engine
- Rear brake metal hard lines...has anybody ever replaced these? What's involved?
- Rear bumper alignment
- 2000 m.y. + A8
- Ongoing indicator (turn signal) problem
- Cluster wiring
- Differences in the D2 years?
- Exhaust Pipe Flex/Cat
- AudiOnlineParts.com
- Engine connector / cable Question
- Central Locking vacuum leak traced to trunk lid area
- code 18032 after transmission change??
- D2 A8 question?
- 1999 A8 transmisson problems
- Thinking about picking up a D2 (S8), few questions.
- Noob and A8/A8L questions
- TCM water ingress
- Replacement Cats
- paging teppi /reviving old thread
- charging the AC? Does anyone know how?
- Need Rear Rotors and Pads....1998 Audi A8 4.2 Quattro
- Will Vag-com VCDS-Lite will it clear an airbag code?
- 2001 S8
- 2001 D2 4 pad brake & rotor change - HELP!!!
- Audi A8 Transmission Service
- Adjustable Koni's for the A8/S8 ?
- A8 17 inch rim, used
- Reverse wire location in D2 near dash?
- Show Pride In Your Ride and WIN $100 !!!
- Gullideckel wheels on S8
- Mystery capped off vacuum hose found..
- Need Help with 2001 S8 Door Latch
- extended warranties
- Just test drove 01 S8...Disappointed
- A8 (or S8) D2 in Top Gear!
- 98 audi a8
- Bilstein B6 sport for the S8
- A8 Transmission in limp mode...opinions?
- Waterfest 17 Special at Detailer's Domain - 20% off!
- 98 audi a8
- tcm
- S8 oil change
- FS: D2 A8 Trunk Lid Latch (new in bag) part # 8E5880701
- anyone have a FUN Transmission?
- Dimming OBC and Climate Control
- 2001 S8 shocks?
- Audi A8 Transmission Problems
- 2001 S8
- Need front-passenger window
- '01 S8 Tranny Advice
- July 4th Specials at Detailer's Domain
- A8 Suspension Question
- cam tensioner chain location?
- 2001 A8L, code P0101? Sounds like exhasut leak
- Argh... bought the wrong Diff mounts (there are 3!?)
- Adding AC juice - Freon
- 2000 A8l in need of ballast
- New A8 Owner Needs HELP! Runs Rough
- Downshift shudder
- Minor (I hope) drivetrain issue
- Value of 2001 A8L..
- Fuel Injector, Where to buy?
- Service in West Michigan
- Transmission is possessed
- Father's Day Special at Detailer's Domain
- FUN (2002) instead of a EDG (2000) tranny
- New S8 owner
- After gearbox swap - front end creaking like old boat!
- Some quick pictures of the S8
- adding homelink?
- 1999 Audi A8 issues
- 1998 Audi A8 4.2 quattro - $200
- Cant find the PN for the rear diff mount :(
- 01 S8 - passenger side xenon pointing down
- MAF error and O2 Lambda error codes after MAF sensor replacement
- Water In HAVC after Rain
- mobile phone d2
- Brake noise at start (low speed)
- Considering an s8
- Introducing myself
- Any one program clusters
- Memorial Day Special at Detailer's Domain
- Brake Pads
- S8 front bumper valance
- Is there a way to test a transmission control module?
- G17 and G89 temperature sensors
- Audi A8 - Auto Transmission Issues.
- Replacement Glass for 1998 A8 passanger side mirror
- What is your GAS MPG?
- slow acceleration
- External temperature sensor- A8 D2
- Replacing Tacho/Speedo to Km/h
- Wipers will not deactivate...?
- Leather Seat Covers
- HELP identify Audi S8 (D2) part
- Audi S8 D2 side mirror loose
- Will ECU from D2 S8 work in C5 S6?
- Can someone run a carfax for me, please
- Transmission - play in the final-drive? Anyone else notice that?
- Does anyone need front brake rotors?
- Any Northern New Jersey D2 owners out there?
- Ive searched and searched...
- 2001 S8 (D2) in Hong Kong Update
- Transmission problem....help...
- Selling my car 1998-A8 175k miles
- How many 8s can you get in a Lot?
- the "Frankenfridge" needs a new home...
- stuck horn, please help! (mygodwhathaveIdone)
- 4.2 rebuild
- C-NAVI DISK 1 - CALIFORNIA
- Need advice before confronting dealer
- funnel?
- Cant figure this part out....
- Noisy Fuel Line/pump
- Fan squeal
- J2 37D5 Safety Recall-Automatic Transmission Locking Cable
- Related cold problems?
- s8 will crank but won't start
- New to Audi
- Just curious on this S8...
- A8 wiper speed
- Hazard / indicator problem
- 2001 S8 wheels
- D2 S8 miss firing
- 2001 S8 shocks
- I have two left-over tray tables ...any interest?
- Check level / top off transmission fluid
- Seat Cover Compatibility 2000 A8
- (Updated) Parting out a 1999 Audi A8, Everything must go **UPDATED**
- Headlight failure - not bulb, not fuse.
- Serious vibrations on initial braking
- WTB !!! set of 18" Monoblocks (pie plates)
- torque converter fail ?
- I need an A8 quattro trans for a 98 Please
- Leaking Servotronic Module (Through Rotten Cover)
- Disassembing, cleaning & repacking Outer CV Joints >>>
- 2001 Audi S8 (D2) Best Coilover Kit
- D2 vs D3 ???
- 99 A8 Trans Codes 17114 and 17087
- Other 17 inch tire sizes
- trashed bumper?
- breather hose at intake?
- Audi S8 D2 Login (coding)?
- Leaky Valve Cover
- Front bumper removal on 98 A8
- Loss of am/fm signal
- Unable to read German
- Transmission.... grrr
- Deformed oil filter causing whine on cold start
- I just got a 60k transmission from a wrecked A8, that someone tried to reinstall
- A Little Bump Without the Thump. . .
- led light under.3+door handle
- 40V Intake manifold fix for stuck or sluggish flap pivots (no broken parts)...
- Heated Steering Wheel FIX?
- Stalling at low rpm, need advice
- Evaluating/selling my A8
- Hi I have some 2001 S8 used parts left for sale
- Supercharger kits available ???
- Another transmission question LOL
- 01 Timing Belt repair questions (special tools)
- Aftermarket Headunit Resets Itself
- Login code for automatic transmission recoding
- anyone have a set of 18 " 'pie plates' to sell ?
- 2001 S8 Auto Transmission Service
- power problem
- ASR Light stays lit
- Brake Kit (OEM Brembo or, Others)
- Automatic Transmission rebuilders...
- '00 A8 Transmisson issue
- Transmission driving me crazy ! 97 4.2 Q
- Thanks to All for all the input
- 2001 Audi S8 Radiator needed
- S8 Trans rebuild on the West Coast?
- S8 suspension replacement - OEM? Aftermarket?
- Electric Folding Mirror Issue
- Rear Rotor Size
- Parting OUT 1998 A8
- Transmission mounts
- Staggered wheels on an S8 (AWD)
- Just bought a 2001 A8L.........have a coolant leak
- Headlight Fault Code
- Looking to buy 2000-2003 A8L Blue or Burgundy
- Water in the oil pan
- crank seal install - 40v 4.2
- soft ware info needed
- Ok my dumb question, how are the interior vents meant to work
- Headlight Washer Cover
- '01 A8 L...Guys, I'd love for you to take a look and give me your opinions...
- How interchangable are transmissions (ie transplants)?
- key battery
- straighten stock wheels or find replacement
- RPMs fluctuate bobbing between 0 and 1000 (recent battery change??)
- Drivers side camshaft cover - special tools?
- Best tech/shop in the metro Detroit area?
- 4 cylinder misfires in 5 minutes, need some help
- Control Arm Kit for D2 S8
- Why your D2 Fuel Pump fails at around 150K miles...PICS
- Hvac Fan...replace or repair ?
- Does anyone have Ross-tech for sale?
- a8 radio info to instrument cluster,
- New heater fan
- A8 cam tensioner clacking
- 97 a8 STARTS THEN DIES!!!!!
- any one ever had bent axle
- Climate control secret codes trick revisited
- Audi A8 D2 parts for sale..............
- Stutter when going uphill
- 2001 S8
- A8 128kw Automatic gearbox change
- Beat the Winter Blues wtih Detailer's Domain - 20% off.
- D2 performance
- Break pressure switch failure -ABS problem
- I could use a hand.
- Sick of seeing that annoying Service "warning" ?
- Suade headliner
- A8L Problems
- S8 front bumper cover popped off
- TPS Mods?
- 01 S8 - engine "overcooling" and fan clutch question
- VAG - COM Diagnostics
- garage laptop with D2 Bentley installed
- 90 Amp or 120 Amp Alternator
- Annother Overheating Thread.
- Nebbie ?
- WTB set of refinished 'pie plate' wheels
