- Anyone ever replaced just the blade part of the key before?
- Treo 600 Hands Free Install -> Use Paul W's Instructions?
- I know u guys get a kick out of these ... I do!
- X-Post: Motul Oil 0w-40 GB (5w-30/40 available as well, email me with the request for this)
- would an 01' s8 have a tranny cooler as stock??......anyone?
- what symptoms can you expect from an atf overfill on an ecy tranny??
- Keyless entry and go is great!
- Does anyone have a procedure for installing the Eibach/Bilstein setup..
- just a question
- 03 S8- lost my pass side lower grille
- steering hard to turn on startup
- Best place to get parts for oil cooler / coolant leak fix?
- European A8 questions
- Creaking in the front end
- has anyone bought one of the LED cordless drop lights ? If so, wondering if they are any good
- ECU Upgrade and Cold Air Intake
- Anyone know what the screen resolution of NAV-C is?
- USB KKL driver
- Track Tire question.
- Looking to buy A8L
- Something different in a 5-spoke for your A8L.
- CEL P0422 P0432
- New to VAG-COM. How can I check for airbag light?
- Anyone in ATL have a Phat Noise in their A8/S8 that I could listen to, see how it works ?
- Where to find wheels?
- If anyone in the ATL area is looking for any type Audi let me know soon....
- A8 Transmission Reverse issues
- HELP - Airbag light on - pulled codes
- X-mas came early this year. I got ahold of chrome mirror caps that fits the late model 99 A8.
- NEED A WARRANTY FOR YOUR AUDI? AA AUTO WARRANTY IS YOUR ANSWER
- Squeaking rear brakes. Time for replacement? Recommendations?
- Audi 1999 A8 leaking motor oil
- Tozo.... Where did you find an 02 tranny for KaMaKaZieP?
- FW: Biker cleared after 128mph chase
- re- tranny update from below
- need to replace controls arms (1998)
- 16500 Coolant temp sensor G62 not a plausible signal
- discovered oil leak from right front
- Treo 650
- Anyone have this noise?
- 3mos ago there was barely any CPO RS6 on audiusa.com. Today, there are 14 !
- Any advice on car meets manhole cover? One moves, the other doesn't.
- Any experience with Kuhmo Ecsta ASX in snow? Wheels for sale in Mpls?
- What would happen if an Audi TT, BMW 5series, and a Mazda 3 had a Menage et trois!
- anyone know if it is possible to run xm right to the radio and still have the cd player work?
- has any one ever thought about replacing the engine belly pan with an aluminum one?
- Key fob-infared remote and static transponder
- in need of help
- Transmission Opinions 98 A8Q
- hope this works=If it is of interest here are some listings for A8's in New Zealand
- question off topic a little
- chrome mirror case set on ebay ...
- is this NAV+ on ebay risky to buy?
- Rear Floor Mat Differences? (Anyone have any spares to get rid of?)
- Coolant loss again. Likely suspects?
- Group buy on keyless remote fob for switchblade?
- Anyone have an extra upper grille?
- After 1.5 yrs of ownership, Im going to sell.
- Fixing trunk divider 2 years after it broke...
- Water dripping on my leg after rain!?
- Got pics back from ACNA Sears Event... wife's S8 is further down.. though you would enjoy:^)
- Question, will the Chrysler Crossfire (rear) wheels fit a D2 A8?
- batteries
- Navigation system language change help please
- DSP shut off- what will I notice?
- Is there any Rear BBK or (parts homologation) that I can get for my A8?
- Lumbar and head rests no longer go up and down
- Parking brake stopped working...
- real (d3) s8 test drive
- OEM nav unit (s) for sale
- How can you test for hunting and other tranny issues?
- New S8 test drive..
- Will Bentley wheels fit the D2?
- dunlop wintersport m3 vs. bridgestone blizzak for year-round use
- GTG for PA NJ NY DE MD @ AWE was a blast
- Transmission service/ fill question...
- a8 transmission noise and issues
- "Old" (DIS only) Nav system instructions?
- Navigation Sound
- Who drives the white s8 all stock in SE michigan and valeted their car 12/3?
- Winter Kicks
- A Run on Ebay A8s?
- Let's Hear a BIG WoooHooooo for the US Mens Alpine Ski Team!!!!!!!!
- Looking at replacing the A8, but I just can't pull the trigger.
- Many thanks to Gabor and Paul too!!!!!!!!!!
- Does this sound like a deal or lemon?
- Flat-spotted my front tires. Changed all 4 at <9k miles.
- I just change my A8 rotors, PROBLEMS!?
- This guy posted on the D3 forum looking for performance cams
- what oil is the best for the the ABZ engine ??
- Front end creaking after control arm replacement...
- Flush/filter vs. transmission rebuild -- what to look for??
- time to replace timing belt?
- Picture of cracked Wiper transmission
- Tranny code
- Transmission Hunting?!?! What really causes it? I want to test.....
- Uh Oh, I smell something burning, and I'm down on power steering fluid
- trans "thump" - not the usual issue - facelift only (I think)
- Control arm refunds-again
- has anyone fitted an additional cooler for the tranny oil????
- lower driver's side grill
- Parrot 3100CK -- how to push Phonebook?
- Delta to Concert switch: Different pinouts? I checked audipages and search but came up empty-handed
- cold is good
- Guess what I nearly did this morning?
- first experience with A8 on snow
- Has anyone seen this car in Mark Motors in New Haven Ct?
- Sorry, I couldn't wait until winter to post this...
- Engine softcode for Europe?
- Best Practices Re. ATF / 60K service
- No radio after re-code, HELP!
- Help with post of word doc please
- electric cooling fan
- Audi Sat Nav and Haeting
- 2000 A8 newie - two issues
- Part number inquiry
- Is this a good deal?
- ATF change on CML '95 transmission
- 99 transmission question
- Stealer trying to make it right.
- Once again there is hope ...
- The wrong transmission!!!!!
- new S6 revealed -- sort of...
- HP2 calipers when did they start and stop using them on the A8 , TIA
- questions on faded leather
- Wheels frozen onto hubs (When were they last removed?)
- CORNER LIGHT
- Pulled the door locks for light repair
- A8 newbie
- Tranny rebuild odds & timing belt interval
- Single "clunk" while backing up & turning the wheel at the same time?????
- FW: ABS Control Module Problem Solved!
- Extended warranty
- Someone A8 / S8 owner might think this is a deal.
- having a rythmic, thumbing noise from the front wheels... light vibration
- Timing Belt Tensioner on 40v S8
- 2000 A8 brakes 323 x 30
- How Do You...
- Tozo, Paul, and all that is interested... "Blown Engine" update.....
- Eibach Lowering Springs 4 sale $150obo
- S8 with interior fire located
- Reverse light problem
- Clicking noises....
- Transmission Law Suit
- fuel pump assembly
- 2000 A8 - Rear Cig Lighter fuse?
- Anyone need a Blitzsafe adaptor for an MP3 player ?
- 80,000 Major Service - Recommendations? Timing Belt?
- Eh, im sick of looking at my soaking wet power steering hose. Ideas on cheap hose replacements?
- Starting Problem
- What is the value of VAG diagnosis accesories
- Phatnoise questions
- Need reference to competent, honest A8 mechanic in East Bay (Berkeley, Oakland, etc.)
- If I need an engine swap.... How many hours labor?
- Was thinking about an Infiniti FX45, anyone drive a Toureg?
- Directional tire question
- Airbag light is on
- I'm considering buying a certain '02 S8. The oil change history bothers me. What do you think of...
- ECS 2piece rotors not fitting
- S8 Modifications... whats avalible besides exhaust and air filters?
- Instructions for front and rear rotors change to A8?
- On this day I am grateful ...
- Happy Turkey Everyone
- It's good to see that some people have faith in D2 resale values..
- ETKA Parts Codes
- How well do A8's show their age vs. comparable steel cars?
- Lowering self levelling suspension
- My next car...
- Are there any known recalls for the 1999's A8s???
- 99 A8 transmission hunting started at 98K miles - options?
- Where can I check all recalls for my car?
- Ferrari Killer?
- Send us your pictures, get a free Hartmann Wheels T-shirt
- Put 17" (225/55-17 Michelin X-ice) tire to S8.
- CD player problems
- Webasto Question
- Engine replacement options?
- Anyone Ever Consider A Parts Car "Group" Buy?
- lag in performance - technies please contribute
- Armrest fix
- Found Wiper Transmission- new A8 salvage yard
- Post 1999 A8
- Center Display Mods (tozoM8 I would like your input)
- follow-up on malfunctioning rearview mirror .
- hvac rest mode is confused - stays on
- those dealers...
- Windshield wipers poll: Rain X, I don't like them.
- PSA: Tirerack has EBC Greenstuff pads for the 4 piston calipers for $25 bucks
- Update on whirring sound coming from around the air intake...
- Anyone know anything about this S8 on ebay?
- Transmission
- Transmission question
- Minnesota paint shop
- Relative maintenance costs
- Dealer says I need a new engine!
- looking for a 4 pad 2 pistone left caliper for a8/s4/w8
- Paging KaMaKaZieP -ALUMIN8. How're those fogs coming? :-)
- A pic of the A8 with no audi logos on its side.
- Still having problems
- Tried to buy Wiper Transmission.. hehe
- Whirring motor sound coming from around the HVAC intake....
- Water pump, timing belt incremental cost
- Hey Tozo, guess what time it is! O2 sensor time.any suggestions for removal of a stubborn sensor :)
- engine message on central display
- DOH! Replacing the trunk lights i shorted the light when taking it out.. a dumb design.
- Auto-dimming mirror failure linked to intermittent power window lockout switch lamp perhaps ..
- Hesitation and sputtering
- Coolant flush did not go as planned....
- some new photos
- anyone else thinks the A8/S8's steering is overpowered? can we reduce assist, or
- Ecu relay
- How durable is the display unit in the instrument cluster?
- Florida Audi/Motorsport during vacation?
- What are the differences between regular A8s and S8s?
- Sunroof stay OPEN, HELP!! HELP!!
- Delaware Valley GTG (2nd Philly GTG) Details
- "clicking" in neutral with foot on brake
- Broken 2003 A8 Roof Antenna
- Mobil 1 rebate at Pep Boys ends today save $3/quart limit 6...
- Oil leak
- How to make my Audi wheels shine like in picture??
- Dubai Motorcross GT500 Day 2
- Can self levelling suspension be lowered??
- Wiper Transmission- Fix option vs. replace
- Audi S8 post factory warranty?
- An early message of Thanksgiving: One great year with one great car
- D3 bound.
- Put the car on the lift last night, not bad. Should be less than 10K in damage.
- DSM Tiptronic
- TerminA8r. Question about your Xenons.
- Does anyone know how to line up tube in fuel tank with tube on pump assembly
- Anyone close to Continental Audi of Naperville?
- removing the black plastic piece on the outside inbetween the Drivers Window and the Rear window
- Paul's new brake project?
- Audi S8 2001 90000 Km Service
- A8 clear front corners and smoked lights
- Dubai Motorcross GT500 Day 1
- audi driving schools save a few lives last night (long)
- Ronal wheels, Nokian, Dunlop SNOW tires
- Serpentine belt replacement interval?
- To buy or not to buy - 97 A8
- fuel pump saga continues
- Fall Drive cross post from LRQC
- Thoughts on 1998 Tiptronic?? 97 & 98 transmissions in general??
- R8 is a go...
- Here's a great deal on Ebay? Anyone near Covert MI
- Need input on used A8 purchase
- So..I weighed my car today,1/2 tank of gas, spare in..wanna take a stab at the total?
- AW/A8 link on craigslist fyi
- Wiper Transmission Motor- hard to find?
