07 A8L 4.2 Source of signal(2) for Leak Detected code generation.
Would like to find out what signals the suspension system controller gets to activate the "Leak Detected" code. Looking through the manual has been difficult.
About a year ago, at about 60k miles, the front went down to the stops and we replaced the compressor with an amazon type, not the dealer type. We could tell the compressor had overheated and remember getting a burning odor before taking it out. The problem was solved...until it wasn't. Now, the same thing happened. We tested the compressor and it was bad (runs OK but no pressure). By now I had installed a new piston ring on the old compressor and it produced about 260 psi, so we re-installed it. This solved the problem...again, for now.
I sprayed soapy water everywhere and can't find a leak. But the compressor rarely runs and only for a minute, maybe once per day? When the problem happened, these are the :evel Control issues found: I'm trying to find out where the signal come from for "01583 - Leak in System Detected". ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2809FB8B3EFDB2C7194-807C 4 Faults Found: 01400 - Suspension Level Control 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 11100010 Fault Priority: 2 Fault Frequency: 104 Reset counter: 45 Mileage: 101475 km Time Indication: 0 Date: 2018.05.04 Time: 20:09:53 01598 - Drive Battery Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 1 Reset counter: 84 Mileage: 102990 km Time Indication: 0 Date: 2018.08.29 Time: 01:54:57 01583 - Leak in System Detected 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 28 Reset counter: 83 Mileage: 0 km Time Indication: 0 01577 - Turn-Off due to Over-Temp 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 4 Fault Frequency: 2 Reset counter: 59 Mileage: 102362 km Time Indication: 0 Date: 2018.06.10 Time: 14:19:08 ------------------------------------------------------------------------------- |
