NO: Bleeding fuel system 2.5tdi
Old 06-19-2019, 11:20 AM
Tommy Gjendem's Avatar
Default NO: Bleeding fuel system 2.5tdi
Hello. Have an Audi A6 2.5tdi Quattro 2001 mob that has been standing for a week and will not start. Looks like when the car has been left unused for a while then diesel runs back into the tank (not the first time this has happened) Have tried to fill the diesel filter with diesel, shut off the return hoses and put on vacuum to pump diesel up to the diesel pump without any luck. Has also loosened the nuts on the injection nozzles and diesel comes out. But when I tighten them again, it won't start.
Took a diagnosis and got the following errors: 01441 - Low Fuel Level Sensor 01318 - Control Module for Injection Pump 01318 - Control Module for Injection Pump (same error occurred 2 times) 01268 - Quantity Adjuster (N146) Deleted the errors, but 01268 returns when I try to start.
Sorry for bad English,but hope somebody can help me.
Old 06-19-2019, 01:36 PM
update...it started after some startgas,but it running rough,like a old boat. Suggestions?
Old 04-11-2020, 08:39 AM
yourDIYneeds's Avatar
Default tdi fuel system bleed
bleeding air from tdi fuel system is easy , you just have to turn on and off the ignition 7-8 times before starting it it will self bleed itself , but if the air has reached the injectors then you have to take some measures to blead out the air in the system , linking a youtube video for reference , bleeding process is in the end of the video
colton Dunham
06-08-2018 10:00 AM
Wizkhalif
04-17-2013 10:52 AM
brad131a4
03-03-2013 03:49 AM
audi600rr
02-07-2013 03:31 PM
9394Audi90
10-06-2003 06:04 PM
Quick Reply: NO: Bleeding fuel system 2.5tdi
