Telematics Discussion
Sponsored by:
Sponsored by:
1997 Audi A4 Quattro 2.8 no start
Old 04-06-2016, 10:42 AM
Default 1997 Audi A4 Quattro 2.8 no start
Hi everyone!
I bought a 1997 Audi A4 Quattro with a 2.8 v6. The motor was junk so I replaced it with a used one. I've installed a new starter also. However I'm not getting spark and the full pump is not operating. However if I pull the relay cover off and manually operate the fuel pump goes on. I have a parts car so I've swapped ignition switch, ecm, coil packs, engine harness, relays, ignition module. I'm currently stuck. The car cranks but Doesn't start. Any help?? Thanks everyone!!!!
timmrxs is offline
Old 04-06-2016, 10:57 AM
the_duke's Avatar
VCDS codes?
the_duke is offline
Old 04-06-2016, 11:11 AM
Just checked and I have no codes
timmrxs is offline
Old 04-09-2016, 07:14 AM
Still got no start. I have no power at the relay. If I supply power to the small stud at the bottom of the relay panel the pump turns on and I have spark but injectors don't fire. I switched the fuel pump relay with a known good one and still nothing. All grounds are good. I however do no have the front end on or. Would this cause a no start or am I possibly looking at a immobilizer issue?
timmrxs is offline
Tom T
08-03-2010 01:13 PM
pureroundcircle
04-11-2010 09:05 PM
00NogaroS4
02-04-2008 10:32 AM
Sallad
9
05-12-2007 11:29 AM
2.8STEVE
05-04-2003 12:10 AM
Quick Reply: 1997 Audi A4 Quattro 2.8 no start
