2001 A6 4.2L Hands Free Cell Phone
Hey Everyone,
I just bought a 2001 A6, 4.2L and I am looking to use the Hands Free cell phone function. It looks like I do not have the audi cellular phone operating manual, does anyone know where I can get it?
Also, Does anyone or has anyone had good luck hooking up a cell phone to the system and have any good tips or suggestions?
Thanks,
Chris
Thanks,
Chris
i would recommend going for an aftermarket bluetooth kit. See the tech section in audiworld...
...for more details.
Very easy to hook up directly behind your Symphony I head unit.
thanks, but i don't think those solutions would work for me...
I have a connection to the car phone hook up in my arm rest (and I also think in my trunk), is there any equipment out there which will install a bluetooth link to that port?
I looked over the all the bluetooth articles in the tech section but can't seem find one which applies to a 2001 vintage audi. is there a specific article you're thinking of I am overlooking?
Thanks for your help
Chris
Chris
yes...but hooking it up via the trunk/armrest connections will be harder...
...and you won't really be gaining anything.
Plus, your best option is an aftermarket kit ...and I wouldn't recommend trying to use the factory mic for an aftermarket kit. It will sound like crap.
See the tech section of Audiworld.
Drop me an email.
Drop me an email.
AudiWorld Expert
Definitely go aftermarket. I have the Motorola HF850 bluetooth kit for my car...
...it was simple to install, and works great! It only cost about $100 off eBay, and will mute the radio when calls are placed/received, as well as provide the sound via the car's speakers. Mine was the Motorola HF850 kit which only pairs one phone, but for another $100 or so, you can get the iHF1000 which pairs up more than one device.
Here is the control button...
Here is where I mounted the microphone...
Here is the control box mounted under the dash...
Here is the wiring harness I needed to connect the control box speakers and mute wire to the back of the radio. Wire from the speaker of the kit was simply cut and spliced into the (+) and (-) wires for the connector block. It did not matter which speaker wire was spliced to which wire to the radio. Note the Mute wire has a twist connector, but no wire connected yet (this is attached to the Mute wire from the kit's wire harness)...
Part numbers are:
357 035 447B (10-pin connector block)
000 979 133 (wire connectors, you'll need 3 of these)
Here are the connections to be made (wiring)...
You could try to retrofit the Motorola kit's microphone to the OEM location under the dome lamp panel, but I've done that in the past with limited sucess.
Part numbers are:
Re: 2001 A6 4.2L Hands Free Cell Phone
I would go with oem Bluetooth,if you have multifunction steering wheel. You will be able to voice dial, and the phonebook will come up in your Cluster display, which you will be able to scroll through with your MFSW, and answer via the steering wheel controls. It costs more than $100, but function is factory, and is visually unintrusive since all parts are oem. It works great with Syph II radios. If you have a non MFSW, then go with the kit shown, you'll pay 7-8 times that on factory Bluetooth. If your interested email bencover@***.net
Hmmmm....looks like you dumped the aftermarket Moto kit for OEM..
....do you still prefer the aftermarket kit???<ul><li><a href="https://forums.audiworld.com/a6/msgs/697480.phtml">Lots of juicy details - happy reading!!</a></li></ul>
I have a 2001 Audi a6, the 2.7t model, and I have in the armrest a old type of cell phone, that is not active, I have noticed that this cell phone has a RJ45 jack connecting in the armrest itself, what would be really neet is to find an adaptor from RJ45 to Micro-USB, that could fit an Android phone, like the Samsung Galaxy S2 I have presently. Then I could use all the steering features and radio with a new phone. That would be awesome, but I don't see any type of adaptor that would do that. Too bad there are only extensive and complicated conversion kits, a RJ45 adapter would be just plug and play!
If anyone knows about that kind of adapter, please contact me, you would be a genius!
Tony
Tony
skiordie101
12-28-2006 06:19 AM
