About Audi Blue Tooth, Need Help from you guys!
I plan to install a bluetooth module into my 04 A4, but something I have to ask you guys before I do it. I don't have RNS-E, there's Symphony II built in my car, so what should I do so that I can successfuly get it done? what parts do I need to buy except for the bluetooth module? Thanks!
Multi Function Steering Wheel if you want the OEM BT kit.
Without MFSW and without RNS-E there is no way to control the BT interface. Without the RNS-E you should also have the DIS to see whom you are calling or who calls you.
Or you go aftermarket with a Parrot or so, that way you don't need anything else but the Parrot kit.
Since you don't have RNS-E, get aftermarket system like Parrot.
They work fine with Symphony and they have separate screen. If you plan to add RNS-E in the future, you will need Multifunction Steering wheel with buttons to accept your calls.
check this post:<ul><li><a href="http://www.navplus.us/forum/viewtopic.php?t=1362">Audi Bluetooth details</a></li></ul>
Need4TTBoost
NY / NJ / CT Discussion
07-23-2007 08:53 AM
