MMI 2g Bluetooth retrofit - hit a brick wall
I'm going through a retrofit of an oem bluetooth unit. Its all fitted in but I'm getting the 'telephone not connected' message and am not seeing it from my phone when scanning for bt devices.
I've activated it in the Can Gateway module list and changed the settings in Channels 133, 134 etc of Control Module 77 as per instructions on forums. When entering the service menu, there is a new line in the right place (0x0103) but no device name when looking at the MOST list. Clicking on that gives me the software version (0950), part number (....336k) and the date, but no devicename, or hw details. So there must be communication. I thought a software upgrade would fix things but no such luck. Running disc 2 only takes about 4 minutes for the 'programming flash' bit, then it tells me that the update was not ok and it is still running 0950. There are a few messages about unlock no 1 please ( or words to that effect) but they fly past before i can scroll down to read them. I thought running disc 1 could assist as I read somewherethat it can address incompatible sw/fw issues, but I can't select anything to run as everything is up to date. Super confused, so any suggestions would be welcomed. |
Don't know if this is useful in this case but ....
Car: Audi A4 Year: 2009 Engine: CDHB Mileage: 112260 KM --------------------------------------------------------------- 01 Engine Control Module 1 System description: 1.8l R4/4V TF Software number: 8K1907115J Software version: 0001 Hardware number: 8K1907115 Hardware version: H07 ODX name: EV_ECM18TFS8K1907115J ODX version: A01002 Long coding: 0104000C02070020 Trouble codes: No trouble codes found --------------------------------------------------------------- 02 Transmission Control Module System description: 0AW 18TFSIRdW Software number: 8K0927155T Software version: 0007 Hardware number: 0AW927156H Hardware version: H03 Serial number: 0000000312 ODX name: EV_TCMVL381 ODX version: A01015 Long coding: 000001 Trouble codes: No trouble codes found --------------------------------------------------------------- 03 Brakes 1 System description: ESP8 front Software number: 8K0907379AA Software version: 0060 Hardware number: 8K0907379AA Hardware version: H04 Serial number: -------------- Long coding: 050500 Trouble codes: No trouble codes found --------------------------------------------------------------- 04 Steering Angle Sender --------------------------------------------------------------- 05 Kessy System description: BCM2 1.1 Software number: 8K0907064F Software version: 0134 Hardware number: 8K0907064F Hardware version: H70 Long coding: 011100 Subsystems: System description: FBSAUDIB8 IDG Software number: 8T0959754C Software version: 0060 Hardware version: H37 Serial number: 0508000033989021 System description: ELVAUDIB8 Software number: 8K0905852D Software version: 0041 Hardware version: H36 Serial number: 0208000037683010 Trouble codes: No trouble codes found --------------------------------------------------------------- 07 Display Control Unit System description: Interfacebox H43 Software version: 5570 Hardware number: 8T0035730 Serial number: 331LV067504576 Coding: 0000302 Subsystems: System description: E0380 BedienteilH08 Software number: 8T0919609B Software version: 0100 Trouble codes: 03157 - Function restriction due to communication interruption static --------------------------------------------------------------- 08 Air Conditioning System description: KLIMA 1 ZONE Software number: 8T2820043R Software version: 0140 Hardware number: 8T2820043R Hardware version: H06 Serial number: 0131.07.080865 Long coding: 64046000 Trouble codes: No trouble codes found --------------------------------------------------------------- 09 Central Electrics System description: BCM1 1.0 Software number: 8K0907063D Software version: 0253 Hardware number: 8K0907063D Hardware version: H22 Serial number: 00000000201216 Long coding: 260010110030AF010000000300001D0D4F1D43080001010100 0000 Subsystems: System description: WWS 210708 Software number: 8K2955119A Software version: 0070 Hardware version: H05 Serial number: SWFBIE 0000194 Long coding: 00FD11 System description: RLS Software number: 8K0955559 Software version: 0003 Hardware version: H04 Serial number: 10215105 Long coding: 025028 System description: E1 - LDS Software number: 8K0941531G Software version: 0070 Hardware version: H07 Serial number: 00000000000608081624 Trouble codes: No trouble codes found --------------------------------------------------------------- 0E Media Player Position 1 System description: MP3-Changer H44 Software version: 0390 Hardware number: 8T2035110C Serial number: AUZ5ZBH8522718 Trouble codes: No trouble codes found --------------------------------------------------------------- 15 Airbag System description: AirbagVW-AU10 Software number: 8K0959655B Software version: 0410 Hardware number: 8K0959655B Hardware version: H26 Serial number: 0038JD18A1S5 ODX name: EV_AirbaECUVWAUDI010 ODX version: A02007 Long coding: 30373434363030303030554A3052384B3053 Trouble codes: No trouble codes found --------------------------------------------------------------- 16 Steering Column Electronics System description: Lenks.Modul Software number: 8K0953568D Software version: 0013 Hardware number: 8K0953568D Hardware version: H12 Serial number: 90315HG90002C Long coding: 000002 Trouble codes: No trouble codes found --------------------------------------------------------------- 17 Dash Board System description: KOMBIINSTR. Software number: 8K0920930A Software version: 0224 Hardware number: 8K0920930A Hardware version: H16 Serial number: 9DZ547C88 Long coding: 2F0F08000200000C010000 Trouble codes: No trouble codes found --------------------------------------------------------------- 19 Gateway System description: GW-BEM 4CAN-M Software number: 8T0907468K Software version: 0092 Hardware number: 8T0907468K Hardware version: H09 Serial number: 4200E0872584A2 Long coding: 000303 Subsystems: System description: J367-BDM Software number: 8K0915181B Software version: 0150 Hardware version: H04 Serial number: 1803502D260708 Trouble codes: 02077 - Media Player, Position 2 No signal/communication static --------------------------------------------------------------- 37 Navigation System description: MNS ECE H51 Software version: 1060 Hardware number: 4E0910888P Serial number: 364EV087792701 Trouble codes: No trouble codes found --------------------------------------------------------------- 42 Door Electronics Driver Side System description: TSG FA Software number: 8K0959793B Software version: 0170 Hardware number: 8K0959793 Hardware version: H10 Serial number: 0000007538983 Long coding: 011C02205001410001 Trouble codes: No trouble codes found --------------------------------------------------------------- 46 Central Module Comfort System System description: BCM2 1.1 Software number: 8K0907064F Software version: 0134 Hardware number: 8K0907064F Hardware version: H70 Serial number: 0112922700 Long coding: 0100062200390080033001 Trouble codes: No trouble codes found --------------------------------------------------------------- 47 Sound System System description: DSP STD Software number: 8T0035223AG Software version: 0310 Hardware number: 8T0035223G Hardware version: H08 Long coding: 010201 Trouble codes: 00418 - Right front DSP mid-bass speaker Open circuit Intermittent --------------------------------------------------------------- 52 Door Electronics Passenger Side System description: TSG BF Software number: 8K0959792B Software version: 0170 Hardware number: 8K0959792 Hardware version: H10 Serial number: 0000007544795 Long coding: 011C02205C01410001 Trouble codes: 02115 - Lock unit for central locking Implausible signal static --------------------------------------------------------------- 53 Parking Brake System description: EPB Audi B8 Software number: 8K0907801E Software version: 0060 Hardware number: 8K0907801E Hardware version: H05 Serial number: 10000000078764 Trouble codes: No trouble codes found --------------------------------------------------------------- 55 Headlight Regulation System description: Dynamische LWR H01 Software version: 0030 Hardware number: 8K0907357B Coding: 0000004 Trouble codes: No trouble codes found --------------------------------------------------------------- 56 Radio System description: TUNER EU/US/RDW H42 Software version: 0630 Hardware number: 4E0910541T Serial number: 357CV097524950 Coding: 0000001 Trouble codes: No trouble codes found --------------------------------------------------------------- 57 TV Tuner System description: R78 DTV-JP Software version: 0150 Hardware number: 4F0919148A Serial number: 79300600184702 Coding: 0000016 Trouble codes: 03393 - Supply voltage for card reader Open circuit/short circuit to B+ static --------------------------------------------------------------- 62 Door Electronics Rear Left System description: TSG HL Software number: 8K0959795 Software version: 0170 Hardware number: 8K0959795 Hardware version: H06 Serial number: 0000007587846 Long coding: 010C02204001210001 Trouble codes: No trouble codes found --------------------------------------------------------------- 72 Door Electronics Rear Right System description: TSG HR Software number: 8K0959794 Software version: 0170 Hardware number: 8K0959795 Hardware version: H06 Serial number: 0000007560372 Long coding: 010C02204001210001 Trouble codes: 02115 - Lock unit for central locking Implausible signal static --------------------------------------------------------------- 77 Telephone Software version: 0950 Hardware number: 4E0910336K Trouble codes: No trouble codes found |
