running cables from the engine bay to the passenger cabin on B7
Hi guys,
I was wondering if anybody had any tips for the easiest way to run a pair of cables from the engine bay (starting from the grill) to the inside of the passenger cabin on a B7. I assume there is a port which cables pass through the firewall, but I'm not even sure where to start looking. Thanks in advance for any tips.
--SL
--SL
Try the rubber channel which feeds lines through firewall via ECM box
You can then route it down through the rubber damper plug into driverside footwell. You might want to search AZ/AW for boost gauge install on B6/B7 A4 turbos as anyone installing needs to route the vacuum line through the firewall into the cabin.
30V-6
02-16-2009 09:50 AM
Jsmooth65
03-17-2008 07:11 AM
coocoomike
10-20-2002 10:15 AM
Boogak
11-10-2001 10:18 PM
