Simple automation Phone >< BT Audi
Here's a simple example of what I do with the app "MacroDroid" on my cellphone, an app with which you can create...well, as the name it already says...macro's.
I created 4 macro's as seen on screenshot 1. The first macro (under 2) describes what I automatically do when my phone connects to my home/work wifi (5 SSID's) Under 3 you see the opposite: what does the phone do what I disconnect from my home/work wifi (5 SSID's) Under 4 you see what happens when my phone detects the BlueTooth of my car when I push the start button. And finally under 5 you can see the macro that gives you the actions when BT is disconnected. So, what actually happens is the following: When I leave home and go down to the garage in the basement, my wifi is not strong enough downstairs so my phone gets disconnected. Macro 3 then turns on Mobile Data and BlueTooth. When I get into the car and turn on the ignition, the cars BT is then recognized by the phone, so macro 4 performs some actions. The text of the actions is pretty clear I think. Once I get at the office (or back home, depends on what SSID you put in), I shut down the engine, BlueTooth is disconnected and macro 5 does again some actions. When I enter the office, the wifi signal of the office (or home) is recognized again by the phone and macro 2 disconnects the Mobile Data and the BT. It's that simple. I use this program for lots of stuff. Try it out, it's pretty cool... https://cimg4.ibsrv.net/gimg/www.aud...00f5db677c.jpg |
